[U-Boot] [PATCH 1/2][v2] powerpc/t2080qds: fixup dtb for 10g-kr
XFI ports on t2080qds can work with fiber cable and direct attach cable(copper). We use hwconfig to define cable type for XFI, and fixup dtb based on the cable type.
For copper cable, set below env in hwconfig:
fsl_10gkr_copper:<10g_mac_name>
the <10g_mac_name> can be fm1_10g1, fm1_10g2, fm1_10g3, fm1_10g4. fm1_10g1 stands for FM1-MAC9, fm1_10g2 stands for FM1-MAC10, fm1_10g3 stands for FM1-MAC1, fm1_10g4 stands for FM1-MAC2. The four <10g_mac_name>s do not have to be coexist in hwconfig. For XFI ports, if a given 10G port will use the copper cable for 10GBASE-KR, set the <10g_mac_name> of the port in hwconfig, otherwise, fiber cable will be assumed to be used for the port.
For ex. if four XFI ports will both use copper cable, the hwconfig should contain:
fsl_10gkr_copper:fm1_10g1,fm1_10g2,fm1_10g3,fm1_10g4
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- changes for V2: add XFI description in t208xqds README. board/freescale/t208xqds/README | 23 ++++++++- board/freescale/t208xqds/eth_t208xqds.c | 86 +++++++++++++++++++++++++++++---- 2 files changed, 98 insertions(+), 11 deletions(-)
diff --git a/board/freescale/t208xqds/README b/board/freescale/t208xqds/README index e05a10f..e3eb5ba 100755 --- a/board/freescale/t208xqds/README +++ b/board/freescale/t208xqds/README @@ -85,10 +85,29 @@ System Logic: - QIXIS-II FPGA system controll Debug Features: - Support Legacy, COP/JTAG, Aurora, Event and EVT - +XFI: + - XFI is supported on T2080QDS through Lane A/B/C/D on Serdes 1 routed to + a on-board SFP+ cages, which to house optical module (fiber cable) or + direct attach cable(copper), the copper cable is used to emulate + 10GBASE-KR scenario. + So, for XFI usage, there are two scenarios, one will use fiber cable, + another will use copper cable. An hwconfig env "fsl_10gkr_copper" is + introduced to indicate a XFI port will use copper cable, and U-boot + will fixup the dtb accordingly. + It's used as: fsl_10gkr_copper:<10g_mac_name> + The <10g_mac_name> can be fm1_10g1, fm1_10g2, fm1_10g3, fm1_10g4, they + do not have to be coexist in hwconfig. If a MAC is listed in the env + "fsl_10gkr_copper", it will use copper cable, otherwise, fiber cable + will be used by default. + for ex. set "fsl_10gkr_copper:fm1_10g1,fm1_10g2,fm1_10g3,fm1_10g4" in + hwconfig, then both four XFI ports will use copper cable. + set "fsl_10gkr_copper:fm1_10g1,fm1_10g2" in hwconfig, then first two + XFI ports will use copper cable, the other two XFI ports will use fiber + cable.
System Memory map ------------------ +---------------- + Start Address End Address Description Size 0xF_FFDF_0000 0xF_FFDF_0FFF IFC - CPLD 4KB 0xF_FF80_0000 0xF_FF80_FFFF IFC - NAND Flash 64KB diff --git a/board/freescale/t208xqds/eth_t208xqds.c b/board/freescale/t208xqds/eth_t208xqds.c index 5879198..8675dbb 100644 --- a/board/freescale/t208xqds/eth_t208xqds.c +++ b/board/freescale/t208xqds/eth_t208xqds.c @@ -23,6 +23,7 @@ #include <phy.h> #include <asm/fsl_dtsec.h> #include <asm/fsl_serdes.h> +#include <hwconfig.h> #include "../common/qixis.h" #include "../common/fman.h" #include "t208xqds_qixis.h" @@ -187,7 +188,12 @@ void board_ft_fman_fixup_port(void *fdt, char *compat, phys_addr_t addr, { int phy; char alias[20]; + char lane_mode[2][20] = {"1000BASE-KX", "10GBASE-KR"}; + char buf[32] = "serdes-1,"; struct fixed_link f_link; + int media_type = 0; + int off; + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); u32 srds_s1 = in_be32(&gur->rcwsr[4]) & FSL_CORENET2_RCWSR4_SRDS1_PRTCL; @@ -265,15 +271,77 @@ void board_ft_fman_fixup_port(void *fdt, char *compat, phys_addr_t addr, case 0x6c: case 0x6d: case 0x71: - f_link.phy_id = port; - f_link.duplex = 1; - f_link.link_speed = 10000; - f_link.pause = 0; - f_link.asym_pause = 0; - /* no PHY for XFI */ - fdt_delprop(fdt, offset, "phy-handle"); - fdt_setprop(fdt, offset, "fixed-link", &f_link, - sizeof(f_link)); + /* + * if the 10G is XFI, check hwconfig to see what is the + * media type, there are two types, fiber or copper, + * fix the dtb accordingly. + */ + switch (port) { + case FM1_10GEC1: + if (hwconfig_sub("fsl_10gkr_copper", "fm1_10g1")) { + /* it's MAC9 */ + media_type = 1; + fdt_set_phy_handle(fdt, compat, addr, + "phy_xfi9"); + fdt_status_okay_by_alias(fdt, "xfi_pcs_mdio9"); + sprintf(buf, "%s%s%s", buf, "lane-a,", + (char *)lane_mode[1]); + } + break; + case FM1_10GEC2: + if (hwconfig_sub("fsl_10gkr_copper", "fm1_10g2")) { + /* it's MAC10 */ + media_type = 1; + fdt_set_phy_handle(fdt, compat, addr, + "phy_xfi10"); + fdt_status_okay_by_alias(fdt, "xfi_pcs_mdio10"); + sprintf(buf, "%s%s%s", buf, "lane-b,", + (char *)lane_mode[1]); + } + break; + case FM1_10GEC3: + if (hwconfig_sub("fsl_10gkr_copper", "fm1_10g3")) { + /* it's MAC1 */ + media_type = 1; + fdt_set_phy_handle(fdt, compat, addr, + "phy_xfi1"); + fdt_status_okay_by_alias(fdt, "xfi_pcs_mdio1"); + sprintf(buf, "%s%s%s", buf, "lane-c,", + (char *)lane_mode[1]); + } + break; + case FM1_10GEC4: + if (hwconfig_sub("fsl_10gkr_copper", "fm1_10g4")) { + /* it's MAC2 */ + media_type = 1; + fdt_set_phy_handle(fdt, compat, addr, + "phy_xfi2"); + fdt_status_okay_by_alias(fdt, "xfi_pcs_mdio2"); + sprintf(buf, "%s%s%s", buf, "lane-d,", + (char *)lane_mode[1]); + } + break; + default: + return; + } + + if (!media_type) { + /* fixed-link is used for XFI fiber cable */ + f_link.phy_id = port; + f_link.duplex = 1; + f_link.link_speed = 10000; + f_link.pause = 0; + f_link.asym_pause = 0; + fdt_delprop(fdt, offset, "phy-handle"); + fdt_setprop(fdt, offset, "fixed-link", &f_link, + sizeof(f_link)); + } else { + /* set property for copper cable */ + off = fdt_node_offset_by_compat_reg(fdt, + "fsl,fman-memac-mdio", addr + 0x1000); + fdt_setprop_string(fdt, off, + "lane-instance", buf); + } break; default: break;
Applied to u-boot-mpc85xx master. Awaiting upstream. Thanks.
York
Shaohui Xie
York Sun
