[U-Boot-Users] [PATCH]ppc_4xx:netstal/common define routines used by all boards
Added some routines used by all Netstal boards nm_show_print and common_misc_init_r and the very specific code to handle our SW installation procedure (set_params_for_sw_install).
Signed-off-by: Niklaus Giger niklaus.giger@netstal.com --- board/netstal/common/nm_bsp.c | 131 ++++++++++++++++++++++++++++++++++++----- 1 files changed, 116 insertions(+), 15 deletions(-)
diff --git a/board/netstal/common/nm_bsp.c b/board/netstal/common/nm_bsp.c index a9de45e..2c1d483 100644 --- a/board/netstal/common/nm_bsp.c +++ b/board/netstal/common/nm_bsp.c @@ -20,22 +20,123 @@
#include <common.h> #include <command.h> +#include <net.h>
-#ifdef CONFIG_CMD_BSP -/* - * Command nm_bsp: Netstal Maschinen BSP specific command - */ -int nm_bsp(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +DECLARE_GLOBAL_DATA_PTR; + +#define DEFAULT_ETH_ADDR "ethaddr" + +extern void hcu_led_set(u32 value); +extern u32 get_serial_number(void); +extern u32 hcu_get_slot(void); + +enum { + /* HW_GENERATION_HCU1 is no longer supported */ + HW_GENERATION_HCU2 = 0x10, + HW_GENERATION_HCU3 = 0x10, + HW_GENERATION_HCU4 = 0x20, + HW_GENERATION_HCU5 = 0x30, + HW_GENERATION_MCU = 0x08, + HW_GENERATION_MCU20 = 0x0a, + HW_GENERATION_MCU25 = 0x09, +}; + + +void nm_show_print(int generation, int index, int hw_capabilities) +{ + int j; + /* reset ANSI terminal color mode */ + printf ("\x1B""[0m""Netstal Maschinen AG: "); + if (generation == HW_GENERATION_HCU3) + printf("HCU3: index %d", index); + else if (generation == HW_GENERATION_HCU4) + printf("HCU4: index %d", index); + else if (generation == HW_GENERATION_HCU5) + printf("HCU5: index %d", index); + else if (generation == HW_GENERATION_MCU25) + printf("MCU25: index %d", index); + printf(" HW 0x%x\n", hw_capabilities); + for (j = 0;j < 6; j++) { + hcu_led_set(1 << j); + udelay(200 * 1000); + } +} + +void set_params_for_sw_install(int install_requested, char *board_name ) { - printf("%s: flag %d, argc %d, argv[0] %s\n", __FUNCTION__, - flag, argc, argv[0]); - printf("Netstal Maschinen BSP specific command. None at the moment.\n"); - return 0; + if (install_requested) { + char string[128]; + printf("\n\n%s SW-Installation: %d patching boot parameters\n", + board_name, install_requested); + setenv("bootdelay", "0"); + setenv("loadaddr", "0x01000000"); + setenv("serverip", "172.25.1.1"); + setenv("bootcmd", "run install"); + sprintf(string, "tftp ${loadaddr} admin/sw_on_hd; " + "tftp ${loadaddr} installer/%s_sw_inst; " + "run boot_sw_inst", board_name); + setenv("install", string); + sprintf(string, "setenv bootargs emac(0,0)c:%s/%s_sw_inst " + "e=${ipaddr} h=${serverip} f=0x1000; bootvx ${loadaddr}\0", + board_name, board_name); + setenv("boot_sw_inst", string); + } +} + +void common_misc_init_r(void) +{ + char *s = getenv(DEFAULT_ETH_ADDR); + char *e; + int i; + u32 serial = get_serial_number(); + + for (i = 0; i < 6; ++i) { + gd->bd->bi_enetaddr[i] = s ? simple_strtoul(s, &e, 16) : 0; + if (s) + s = (*e) ? e + 1 : e; + } + + if (gd->bd->bi_enetaddr[3] == 0 && + gd->bd->bi_enetaddr[4] == 0 && + gd->bd->bi_enetaddr[5] == 0) { + char ethaddr[22]; + + /* Must be in sync with CONFIG_ETHADDR */ + gd->bd->bi_enetaddr[0] = 0x00; + gd->bd->bi_enetaddr[1] = 0x60; + gd->bd->bi_enetaddr[2] = 0x13; + gd->bd->bi_enetaddr[3] = (serial >> 16) & 0xff; + gd->bd->bi_enetaddr[4] = (serial >> 8) & 0xff; + gd->bd->bi_enetaddr[5] = hcu_get_slot(); + sprintf(ethaddr, "%02X:%02X:%02X:%02X:%02X:%02X\0", + gd->bd->bi_enetaddr[0], gd->bd->bi_enetaddr[1], + gd->bd->bi_enetaddr[2], gd->bd->bi_enetaddr[3], + gd->bd->bi_enetaddr[4], gd->bd->bi_enetaddr[5]) ; + printf("%s: Setting eth %s serial 0x%x\n", __FUNCTION__, + ethaddr, serial); + setenv(DEFAULT_ETH_ADDR, ethaddr); + } + + /* IP-Adress update */ + { + IPaddr_t ipaddr; + char *ipstring; + + ipstring = getenv("ipaddr"); + if (ipstring == 0) + ipaddr = string_to_ip("172.25.1.99"); + else + ipaddr = string_to_ip(ipstring); + if ((ipaddr & 0xff) != (32 + hcu_get_slot())) { + char tmp[22]; + + ipaddr = (ipaddr & 0xffffff00) + 32 + hcu_get_slot(); + ip_to_string (ipaddr, tmp); + printf("%s: enforce %s\n", __FUNCTION__, tmp); + setenv("ipaddr", tmp); + saveenv(); + } + } + }
-U_BOOT_CMD( - nm_bsp, 1, 1, nm_bsp, - "nm_bsp - Netstal Maschinen BSP specific command. \n", - "Help for Netstal Maschinen BSP specific command.\n" - ); -#endif
- Command nm_bsp: Netstal Maschinen BSP specific command
+enum {
- /* HW_GENERATION_HCU1 is no longer supported */
- HW_GENERATION_HCU2 = 0x10,
- HW_GENERATION_HCU3 = 0x10,
- HW_GENERATION_HCU4 = 0x20,
- HW_GENERATION_HCU5 = 0x30,
- HW_GENERATION_MCU = 0x08,
- HW_GENERATION_MCU20 = 0x0a,
- HW_GENERATION_MCU25 = 0x09,
- int j;
Empty line after var declaration.
- /* reset ANSI terminal color mode */
- printf ("\x1B""[0m""Netstal Maschinen AG: ");
Either use space after the function (here "print") all the time in this file or never (which is what I prefer).
- if (generation == HW_GENERATION_HCU3)
- else if (generation == HW_GENERATION_HCU4)
- else if (generation == HW_GENERATION_HCU5)
- else if (generation == HW_GENERATION_MCU25)
- printf(" HW 0x%x\n", hw_capabilities);
- for (j = 0;j < 6; j++) {
udelay(200 * 1000);
- if (install_requested) {
char string[128];
Newline.
- char *s = getenv(DEFAULT_ETH_ADDR);
- char *e;
- int i;
- u32 serial = get_serial_number();
- for (i = 0; i < 6; ++i) {
if (s)
- if (gd->bd->bi_enetaddr[3] == 0 &&
char ethaddr[22];
ethaddr, serial);
- /* IP-Adress update */
Why do you need this "{" here? Doesn't really make sense to me.
Please fix and resubmit.
Thanks.
Best regards, Stefan
+enum {
- int j;
else ??? You probably want to do this in a loop over an array of structs matching "generation" IDs with names - will become more readable and less error prone. And eventually smaller code, too.
IPaddr_t ipaddr;
char *ipstring;
Please don't do this. Declare the vaiable at entry into this funtion.
Niklaus Giger
Stefan Roese
