[U-Boot] please pull u-boot-samsung master
Dear Albert ARIBAUD,
The following changes since commit 5f50310588e87f2ff501992564d1b05df71419f4:
davinci, c6x: Always use C version of reset code (2012-08-25 13:40:03 +0200)
git://git.denx.de/u-boot-samsung master
for you to fetch changes up to 76f60ac2246d433c6995041d1aaf9f5d4e59b941:
arm:cache:trats: Enable PL310 L2 Cache Controller at TRATS Samsung board (2012-08-27 12:25:09 +0900)
---------------------------------------------------------------- Donghwa Lee (9): video: support exynos fimd driver for various exynos series EXYNOS5: support exynos5 lcd clock control EXYNOS5: support display system register control EXYNOS5: support display port phy control function EXYNOS5: add display port base address video: support exynos display port drivers video: add dp_enabled variable in vidinfo structure video: exynos fb driver supports display port feature video: support exynos pwm backlight driver
Jaehoon Chung (1): ARM: EXYNOS: fixed compiler warning message
Rajeshwari Shinde (10): ARCH: SPL: Add parametric board initializer SMDK5250: SPL: Define parametric board initializer SMDK5250: Add smdk5250-uboot-spl.lds EXYNOS5: CLOCK: define additional clock registers for Exynos5250 Rev 1.0 EXYNOS5: CLOCK: Add clock support for Exynos5250 Rev 1.0 Exynos5: DDR3: Add DDR3 memory setup for Exynos5250 Rev 1.0 EXYNOS5: CLOCK: Modify MPLL clock out for Exynos5250 Rev 1.0 EXYNOS5: CLOCK: Add BPLL support EXYNOS5 : Modify pinnumx settings as per Exynos5250 Rev 1.0 Zhong Hongbo (1): arm/s5pxx: Fix get_timer_masked to get the time.
Łukasz Majewski (3): arm:trats: loaduimage environment variable defied for TRATS target arm:exynos: Enable data cache at exynos based processors. arm:cache:trats: Enable PL310 L2 Cache Controller at TRATS Samsung board
arch/arm/cpu/armv7/exynos/clock.c | 139 ++- arch/arm/cpu/armv7/exynos/pinmux.c | 22 +- arch/arm/cpu/armv7/exynos/power.c | 21 + arch/arm/cpu/armv7/exynos/soc.c | 8 + arch/arm/cpu/armv7/exynos/system.c | 18 + arch/arm/cpu/armv7/s5p-common/pwm.c | 2 +- arch/arm/cpu/armv7/s5p-common/timer.c | 20 +- arch/arm/include/asm/arch-exynos/clk.h | 1 + arch/arm/include/asm/arch-exynos/clock.h | 237 ++-- arch/arm/include/asm/arch-exynos/cpu.h | 3 + arch/arm/include/asm/arch-exynos/dmc.h | 65 ++ arch/arm/include/asm/arch-exynos/dp.h | 751 +++++++++++++ arch/arm/include/asm/arch-exynos/dp_info.h | 214 ++++ arch/arm/include/asm/arch-exynos/fb.h | 27 +- arch/arm/include/asm/arch-exynos/gpio.h | 7 +- arch/arm/include/asm/arch-exynos/power.h | 5 + arch/arm/include/asm/arch-exynos/pwm_backlight.h | 34 + arch/arm/include/asm/arch-exynos/spl.h | 97 ++ board/samsung/smdk5250/Makefile | 3 +- board/samsung/smdk5250/clock_init.c | 714 +++++++++--- board/samsung/smdk5250/clock_init.h | 149 +++ board/samsung/smdk5250/dmc_common.c | 199 ++++ board/samsung/smdk5250/dmc_init.c | 462 -------- board/samsung/smdk5250/dmc_init_ddr3.c | 228 ++++ board/samsung/smdk5250/setup.h | 763 +++++++------ board/samsung/smdk5250/smdk5250-uboot-spl.lds | 66 ++ board/samsung/smdk5250/smdk5250.c | 6 +- board/samsung/smdk5250/smdk5250_spl.c | 68 ++ drivers/video/Makefile | 2 + drivers/video/exynos_dp.c | 925 ++++++++++++++++ drivers/video/exynos_dp_lowlevel.c | 1291 ++++++++++++++++++++++ drivers/video/exynos_dp_lowlevel.h | 80 ++ drivers/video/exynos_fb.c | 5 +- drivers/video/exynos_fimd.c | 91 +- drivers/video/exynos_pwm_bl.c | 57 + include/configs/smdk5250.h | 7 +- include/configs/trats.h | 7 +- include/lcd.h | 1 + 38 files changed, 5730 insertions(+), 1065 deletions(-) create mode 100644 arch/arm/include/asm/arch-exynos/dp.h create mode 100644 arch/arm/include/asm/arch-exynos/dp_info.h create mode 100644 arch/arm/include/asm/arch-exynos/pwm_backlight.h create mode 100644 arch/arm/include/asm/arch-exynos/spl.h create mode 100644 board/samsung/smdk5250/clock_init.h create mode 100644 board/samsung/smdk5250/dmc_common.c delete mode 100644 board/samsung/smdk5250/dmc_init.c create mode 100644 board/samsung/smdk5250/dmc_init_ddr3.c create mode 100644 board/samsung/smdk5250/smdk5250-uboot-spl.lds create mode 100644 board/samsung/smdk5250/smdk5250_spl.c create mode 100644 drivers/video/exynos_dp.c create mode 100644 drivers/video/exynos_dp_lowlevel.c create mode 100644 drivers/video/exynos_dp_lowlevel.h create mode 100644 drivers/video/exynos_pwm_bl.c
Hi Minkyu,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Minkyu Kang
