[PATCH] bootcounter: add DM support for memory based bootcounter
add DM/DTS support for the memory based bootcounter in drivers/bootcount/bootcount.c.
Let the old implementation in, so boards which have not yet convert to DM/DTS do not break.
Signed-off-by: Heiko Schocher hs@denx.de --- Travis build:
https://travis-ci.org/hsdenx/u-boot-test/builds/652839618
doc/device-tree-bindings/misc/bootcounter.txt | 21 +++++ drivers/bootcount/Kconfig | 5 ++ drivers/bootcount/Makefile | 1 + drivers/bootcount/bootcount.c | 86 +++++++++++++++++++ 4 files changed, 113 insertions(+) create mode 100644 doc/device-tree-bindings/misc/bootcounter.txt
diff --git a/doc/device-tree-bindings/misc/bootcounter.txt b/doc/device-tree-bindings/misc/bootcounter.txt new file mode 100644 index 0000000000..f4a4a731b9 --- /dev/null +++ b/doc/device-tree-bindings/misc/bootcounter.txt @@ -0,0 +1,21 @@ +U-Boot bootcounter Devicetree Binding +===================================== + +The device tree node describes the U-Boot bootcounter +memory based device binding. + +Required properties : + +- compatible : "uboot,bootcount"; +- singleword : set this, if you have only one word space + for storing the bootcounter. + +Example +------- + +MPC83xx based board: + +bootcount@0x13ff8 { + compatible = "uboot,bootcount"; + reg = <0x13ff8 0x08>; +}; diff --git a/drivers/bootcount/Kconfig b/drivers/bootcount/Kconfig index 0e506c9ea2..88203607a8 100644 --- a/drivers/bootcount/Kconfig +++ b/drivers/bootcount/Kconfig @@ -106,6 +106,11 @@ config DM_BOOTCOUNT_I2C_EEPROM pointing to the underlying i2c eeprom device) and an optional 'offset' property are supported.
+config BOOTCOUNT_MEM + bool "memory based bootcounter" + help + Memory based bootcount, compatible = "uboot,bootcount"; + endmenu
endif diff --git a/drivers/bootcount/Makefile b/drivers/bootcount/Makefile index 73ccfb5a08..059d40d16b 100644 --- a/drivers/bootcount/Makefile +++ b/drivers/bootcount/Makefile @@ -1,6 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+
obj-$(CONFIG_BOOTCOUNT_GENERIC) += bootcount.o +obj-$(CONFIG_BOOTCOUNT_MEM) += bootcount.o obj-$(CONFIG_BOOTCOUNT_AT91) += bootcount_at91.o obj-$(CONFIG_BOOTCOUNT_AM33XX) += bootcount_davinci.o obj-$(CONFIG_BOOTCOUNT_RAM) += bootcount_ram.o diff --git a/drivers/bootcount/bootcount.c b/drivers/bootcount/bootcount.c index 7a6d03dcca..53bd416cf6 100644 --- a/drivers/bootcount/bootcount.c +++ b/drivers/bootcount/bootcount.c @@ -8,6 +8,7 @@ #include <cpu_func.h> #include <linux/compiler.h>
+#if !defined(CONFIG_DM_BOOTCOUNT) /* Now implement the generic default functions */ __weak void bootcount_store(ulong a) { @@ -49,3 +50,88 @@ __weak ulong bootcount_load(void) return raw_bootcount_load(reg); #endif /* defined(CONFIG_SYS_BOOTCOUNT_SINGLEWORD) */ } +#else +#include <dm.h> + +struct bootcount_mem_priv { + phys_addr_t base; + u8 singleword; +}; + +static int bootcount_mem_get(struct udevice *dev, u32 *a) +{ + struct bootcount_mem_priv *priv = dev_get_priv(dev); + void *reg = (void *)priv->base; + u32 magic = CONFIG_SYS_BOOTCOUNT_MAGIC; + + if (priv->singleword) { + u32 tmp = raw_bootcount_load(reg); + + if ((tmp & 0xffff0000) != (magic & 0xffff0000)) + return -ENODEV; + + *a = (tmp & 0x0000ffff); + } else { + if (raw_bootcount_load(reg + 4) != magic) + return -ENODEV; + + *a = raw_bootcount_load(reg); + } + + return 0; +}; + +static int bootcount_mem_set(struct udevice *dev, const u32 a) +{ + struct bootcount_mem_priv *priv = dev_get_priv(dev); + void *reg = (void *)priv->base; + u32 magic = CONFIG_SYS_BOOTCOUNT_MAGIC; + uintptr_t flush_start = rounddown(priv->base, + CONFIG_SYS_CACHELINE_SIZE); + uintptr_t flush_end; + + if (priv->singleword) { + raw_bootcount_store(reg, (magic & 0xffff0000) | a); + flush_end = roundup(priv->base + 4, + CONFIG_SYS_CACHELINE_SIZE); + } else { + raw_bootcount_store(reg, a); + raw_bootcount_store(reg + 4, magic); + flush_end = roundup(priv->base + 8, + CONFIG_SYS_CACHELINE_SIZE); + } + flush_dcache_range(flush_start, flush_end); + + return 0; +}; + +static const struct bootcount_ops bootcount_mem_ops = { + .get = bootcount_mem_get, + .set = bootcount_mem_set, +}; + +static int bootcount_mem_probe(struct udevice *dev) +{ + struct bootcount_mem_priv *priv = dev_get_priv(dev); + + priv->base = (phys_addr_t)devfdt_get_addr(dev); + priv->singleword = dev_read_u32_default(dev, "singleword", 0); + + return 0; +} + +static const struct udevice_id bootcount_mem_ids[] = { + { .compatible = "uboot,bootcount" }, + { .compatible = "u-boot,bootcount" }, + { } +}; + +U_BOOT_DRIVER(bootcount_mem) = { + .name = "bootcount-mem", + .id = UCLASS_BOOTCOUNT, + .priv_auto_alloc_size = sizeof(struct bootcount_mem_priv), + .probe = bootcount_mem_probe, + .of_match = bootcount_mem_ids, + .ops = &bootcount_mem_ops, +}; +#endif
Hi Heiko,
Travis build:
I think we use u-boot in other bindings
- for storing the bootcounter.
single-word
I think this is a boolean property, right?
What is a word? Is it 32 bits? Also, what does it actually mean/do?
+Example +-------
help
endmenu
Comment for struct
phys_addr_t base;
u8 singleword;
bool?
return -ENODEV;
} else {
return -ENODEV;
} else {
dev_read_addr()
dev_read_bool() ?
Can we just have the second one?
2.24.1
Hello Simon,
Am 21.02.2020 um 01:50 schrieb Simon Glass:
Hi Heiko,
Travis build:
Yes. I just porting some mpc83xx boards to DM/DTS and they use "uboot,bootcounter" ... but I think, it should be possible to change this in the respectiv DTS files.
single-word
Yep
Yes.
If enabled bootcounter driver does use one word (32 bit) only.
See CONFIG_SYS_BOOTCOUNT_SINGLEWORD in current version of mainline driver.
+Example +-------
help
endmenu
endif
Comment for struct
Of course, I add one, sorry for this.
phys_addr_t base;
u8 singleword;
bool?
Yes, I change this to bool.
return -ENODEV;
} else {
return -ENODEV;
} else {
dev_read_addr()
Ok, I check it with dev_read_addr()
dev_read_bool() ?
Yep.
I ask, if we can change the DTS files they use.
2.24.1
Thanks for the review.
bye, Heiko
Heiko Schocher
