[U-Boot] [PATCH] bootm: use BOOTM_STATE_OS_CMDLINE flag for plain bootm
A plain bootm used to call the architecture specific boot function with no flags, but was modified by commit 35fc84fa "Refactor the bootm command to reduce code duplication" to call the architecture specific boot function multiple times with various flags in sequence. The BOOTM_STATE_OS_CMDLINE flag was not used, indeed it seems that at least ARM prepares the command line on BOOTM_STATE_OS_PREP. However on MIPS since commit 59e8cbdb "MIPS: bootm: refactor initialisation of kernel cmdline" the command line is not prepared in response to a BOOTM_STATE_OS_PREP flag, only on BOOTM_STATE_OS_CMDLINE or a call with no flags. The end result is that a combination of those 2 commits leads to MIPS boards booting kernels with no command line arguments.
An extra invocation of the architecture specific boot function with BOOTM_STATE_OS_CMDLINE fixes this.
Signed-off-by: Paul Burton paul.burton@imgtec.com --- common/cmd_bootm.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 1685c14..b8255eb 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -797,8 +797,9 @@ int do_bootm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
return do_bootm_states(cmdtp, flag, argc, argv, BOOTM_STATE_START | BOOTM_STATE_FINDOS | BOOTM_STATE_FINDOTHER | - BOOTM_STATE_LOADOS | BOOTM_STATE_OS_PREP | - BOOTM_STATE_OS_FAKE_GO | BOOTM_STATE_OS_GO, &images, 1); + BOOTM_STATE_LOADOS | BOOTM_STATE_OS_CMDLINE | + BOOTM_STATE_OS_PREP | BOOTM_STATE_OS_FAKE_GO | + BOOTM_STATE_OS_GO, &images, 1); }
int bootm_maybe_autostart(cmd_tbl_t *cmdtp, const char *cmd)
*ping*
(Also CCing MIPS custodian)
Paul
2013/9/6 Paul Burton paul.burton@imgtec.com:
1.8.3.4
you should also add BOOTM_STATE_OS_BD_T. Though it is not used by MIPS, it is also needed if single call of bootm should execute all available bootm sub-commands.
The patch is already assigned to Tom in patchwork, so I hope he'll pick it up for 2013.10.
Daniel Schwierzeck
Paul Burton
