[U-Boot-Users] [[PATCH] Resubmit] QE UEC: Extend number of supported UECs to 4
Description: This patch extends the number of supported UECs to 4. Note that the problem of QE thread resources exhaustion is resolved by setting the correct number of QE threads according to Ethernet type (GBE or FE).
Signed-off-by: David Saada david.saada@ecitele.com
diff -purN drivers/qe/uec.c.orig drivers/qe/uec.c
--- drivers/qe/uec.c.orig 2008-01-14 11:48:28.000000000 +0200 +++ drivers/qe/uec.c 2008-01-14 19:03:55.248775000 +0200 @@ -40,8 +40,13 @@ static uec_info_t eth1_uec_info = { .tx_clock = CFG_UEC1_TX_CLK, .eth_type = CFG_UEC1_ETH_TYPE, }, +#if (CFG_UEC1_ETH_TYPE == FAST_ETH) + .num_threads_tx = UEC_NUM_OF_THREADS_1, + .num_threads_rx = UEC_NUM_OF_THREADS_1, +#else .num_threads_tx = UEC_NUM_OF_THREADS_4, .num_threads_rx = UEC_NUM_OF_THREADS_4, +#endif .riscTx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, .riscRx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, .tx_bd_ring_len = 16, @@ -58,8 +63,13 @@ static uec_info_t eth2_uec_info = { .tx_clock = CFG_UEC2_TX_CLK, .eth_type = CFG_UEC2_ETH_TYPE, }, +#if (CFG_UEC2_ETH_TYPE == FAST_ETH) + .num_threads_tx = UEC_NUM_OF_THREADS_1, + .num_threads_rx = UEC_NUM_OF_THREADS_1, +#else .num_threads_tx = UEC_NUM_OF_THREADS_4, .num_threads_rx = UEC_NUM_OF_THREADS_4, +#endif .riscTx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, .riscRx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, .tx_bd_ring_len = 16, @@ -68,7 +78,6 @@ static uec_info_t eth2_uec_info = { .enet_interface = CFG_UEC2_INTERFACE_MODE, }; #endif - #ifdef CONFIG_UEC_ETH3 static uec_info_t eth3_uec_info = { .uf_info = { @@ -77,8 +86,13 @@ static uec_info_t eth3_uec_info = { .tx_clock = CFG_UEC3_TX_CLK, .eth_type = CFG_UEC3_ETH_TYPE, }, +#if (CFG_UEC3_ETH_TYPE == FAST_ETH) + .num_threads_tx = UEC_NUM_OF_THREADS_1, + .num_threads_rx = UEC_NUM_OF_THREADS_1, +#else .num_threads_tx = UEC_NUM_OF_THREADS_4, .num_threads_rx = UEC_NUM_OF_THREADS_4, +#endif .riscTx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, .riscRx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, .tx_bd_ring_len = 16, @@ -87,6 +101,29 @@ static uec_info_t eth3_uec_info = { .enet_interface = CFG_UEC3_INTERFACE_MODE, }; #endif +#ifdef CONFIG_UEC_ETH4 +static uec_info_t eth4_uec_info = { + .uf_info = { + .ucc_num = CFG_UEC4_UCC_NUM, + .rx_clock = CFG_UEC4_RX_CLK, + .tx_clock = CFG_UEC4_TX_CLK, + .eth_type = CFG_UEC4_ETH_TYPE, + }, +#if (CFG_UEC4_ETH_TYPE == FAST_ETH) + .num_threads_tx = UEC_NUM_OF_THREADS_1, + .num_threads_rx = UEC_NUM_OF_THREADS_1, +#else + .num_threads_tx = UEC_NUM_OF_THREADS_4, + .num_threads_rx = UEC_NUM_OF_THREADS_4, +#endif + .riscTx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, + .riscRx = QE_RISC_ALLOCATION_RISC1_AND_RISC2, + .tx_bd_ring_len = 16, + .rx_bd_ring_len = 16, + .phy_address = CFG_UEC4_PHY_ADDR, + .enet_interface = CFG_UEC4_INTERFACE_MODE, +}; +#endif
static int uec_mac_enable(uec_private_t *uec, comm_dir_e mode) { @@ -1262,6 +1299,10 @@ int uec_initialize(int index) #ifdef CONFIG_UEC_ETH3 uec_info = ð3_uec_info; #endif + } else if (index == 3) { +#ifdef CONFIG_UEC_ETH4 + uec_info = ð4_uec_info; +#endif } else { printf("%s: index is illegal.\n", __FUNCTION__); return -EINVAL;
diff -purN net/eth.c.orig net/eth.c
--- net/eth.c.orig 2008-01-14 11:48:28.000000000 +0200 +++ net/eth.c 2008-01-14 18:59:56.708822000 +0200 @@ -217,6 +217,9 @@ int eth_initialize(bd_t *bis) #if defined(CONFIG_UEC_ETH3) uec_initialize(2); #endif +#if defined(CONFIG_UEC_ETH4) + uec_initialize(3); +#endif
#if defined(FEC_ENET) || defined(CONFIG_ETHER_ON_FCC) fec_initialize(bis);
On Mon, 2008-01-14 at 19:24 +0200, David Saada wrote:
Description:
David, You may delete the 'Description' in commit log
The patch have whitespace, please clean up.
Thanks, Dave
Applying 'Resubmit] QE UEC: Extend number of supported UECs to 4'
Adds trailing whitespace. .dotest/patch:7:#if (CFG_UEC1_ETH_TYPE == FAST_ETH) Adds trailing whitespace. .dotest/patch:21:#if (CFG_UEC2_ETH_TYPE == FAST_ETH) Adds trailing whitespace. .dotest/patch:43:#if (CFG_UEC3_ETH_TYPE == FAST_ETH) Adds trailing whitespace. .dotest/patch:65:#if (CFG_UEC4_ETH_TYPE == FAST_ETH) fatal: corrupt patch at line 107 Patch failed at 0001.
Dave Liu
David Saada
