[RFC PATCH 1/2] spl: enable regulator-boot-on and disable regulator-force-boot-off
From: Quentin Schulz quentin.schulz@theobroma-systems.com
This makes sure regulators that need to be turned on or off at boot are turned on or off in the SPL.
This may be required for the SPL to do some operations, such as finding possible loading media for U-Boot proper.
Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com ---
- RFC because only tested on Puma Haikou RK3399
common/spl/spl.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/common/spl/spl.c b/common/spl/spl.c index c8c463f80b..762e9918c7 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -37,6 +37,9 @@ #include <fdt_support.h> #include <bootcount.h> #include <wdt.h> +#if CONFIG_IS_ENABLED(DM_REGULATOR) +#include <power/regulator.h> +#endif
DECLARE_GLOBAL_DATA_PTR;
@@ -766,6 +769,15 @@ void board_init_r(gd_t *dummy1, ulong dummy2) if (CONFIG_IS_ENABLED(GPIO_HOG)) gpio_hog_probe_all();
+ if (CONFIG_IS_ENABLED(DM_REGULATOR)) { + if (regulators_enable_boot_on(false)) + debug("%s: Cannot enable boot on regulator\n", + __func__); + if (regulators_enable_boot_off(false)) + debug("%s: Cannot enable boot off regulator\n", + __func__); + } + #if CONFIG_IS_ENABLED(BOARD_INIT) spl_board_init(); #endif
An earlier commit makes the common SPL code call regulators_enable_boot_on and regulators_enable_boot_off before iterating over possible boot media for U-Boot proper. There is therefore no need to do this in the rk3399-specific code, so let's remove it.
- This patch depends on https://lore.kernel.org/u-boot/20220715150949.952853-1-foss+uboot@0leil.net/ and https://lore.kernel.org/u-boot/20220715150949.952853-2-foss+uboot@0leil.net/
arch/arm/mach-rockchip/rk3399/rk3399.c | 10 ---------- 1 file changed, 10 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index db8a6cb83a..691d69dc59 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -277,15 +277,5 @@ void spl_board_init(void) if (cru->glb_rst_st != 0) rk3399_force_power_on_reset(); } - - if (IS_ENABLED(CONFIG_SPL_DM_REGULATOR)) { - /* - * Turning the eMMC and SPI back on (if disabled via the Qseven - * BIOS_ENABLE) signal is done through a always-on regulator). - */ - if (regulators_enable_boot_on(false)) - debug("%s: Cannot enable boot on regulator\n", - __func__); - } } #endif
El Fri, Jul 15, 2022 at 05:14:26PM +0200, Quentin Schulz deia:
Tested on a Rock-Pi-4B and didn't see any regression. Tested-by: Xavier Drudis Ferran xdrudis@tinet.cat
__func__);
#endif
2.36.1
Hello, and thanks for you work
El Fri, Jul 15, 2022 at 05:14:25PM +0200, Quentin Schulz deia:
Can we remove the #if ? Otherwise I get 2 compilation warnings in tpl, because I miss the dummy regulators_enable_boot_on (and _off) in include/power/regulator.h
When compiling tpl for Rock-pi-4 I have CONFIG_DM_REGULATOR=y, but not CONFIG_TPL_DM_REGULATOR or CONFIG_SPL_DM_REGULATOR.
- if (CONFIG_IS_ENABLED(DM_REGULATOR)) {
__func__);
__func__);
This still introduces a warning for me.
warning: implicit declaration of function 'regulators_enable_boot_off'
So maybe the dummy function must be added to include/power/regulator.h commit 16cc5ad0b439 ("power: regulator: add dummy helper") introduced the dummy regulators_enable_boot_on but missed the regulators_enable_boot_off.
Alternatively one could replace the if with an #if, but I think that'd be against U-Boot policy.
El Mon, Jul 18, 2022 at 10:34:54AM +0200, Xavier Drudis Ferran deia:
Not sure if I was clear. I meant remove the #if and #endif and leave an inconditional #include.
__func__);
__func__);
#endif
2.36.1
Quentin Schulz
