Hi Tom,
please pull a minor bugfix for MIPS64 Octeon and the removal of qemu_mips boards.
Gitlab: https://source.denx.de/u-boot/custodians/u-boot-mips/-/pipelines/7625
Azure: https://dev.azure.com/danielschwierzeck/u-boot/_build/results?buildId=24&...
The following changes since commit e1bf0336a58cfe873a34c36ff53e5e3806f2d263:
Prepare v2021.07-rc3 (2021-05-24 20:53:13 -0400)
https://source.denx.de/u-boot/custodians/u-boot-mips.git/ tags/mips-pull-2021-05-25
for you to fetch changes up to 835b4fdf3bf5ec778e1fb7610f00707754454974:
doc: update and fix Qemu MIPS documentation (2021-05-25 15:35:06 +0200)
---------------------------------------------------------------- - MIPS: octeon: fix CFI flash setup - MIPS: remove qemu_mips boards
---------------------------------------------------------------- Daniel Schwierzeck (2): MIPS: remove deprecated qemu_mips board doc: update and fix Qemu MIPS documentation
Stefan Roese (1): mips: octeon: octeon_ebb7304_defconfig: Fix CFI flash setup
.azure-pipelines.yml | 12 -- .gitlab-ci.yml | 24 ---- arch/mips/Kconfig | 11 -- board/qemu-mips/Kconfig | 26 ---- board/qemu-mips/MAINTAINERS | 14 -- board/qemu-mips/Makefile | 7 - board/qemu-mips/lowlevel_init.S | 40 ------ board/qemu-mips/qemu-mips.c | 85 ------------ configs/octeon_ebb7304_defconfig | 5 +- configs/qemu_mips64_defconfig | 29 ---- configs/qemu_mips64el_defconfig | 30 ----- configs/qemu_mips_defconfig | 27 ---- configs/qemu_mipsel_defconfig | 28 ---- doc/board/emulation/qemu-mips.rst | 273 +++++++++++--------------------------- include/configs/qemu-mips.h | 89 ------------- include/configs/qemu-mips64.h | 89 ------------- scripts/config_whitelist.txt | 1 - 17 files changed, 81 insertions(+), 709 deletions(-) delete mode 100644 board/qemu-mips/Kconfig delete mode 100644 board/qemu-mips/MAINTAINERS delete mode 100644 board/qemu-mips/Makefile delete mode 100644 board/qemu-mips/lowlevel_init.S delete mode 100644 board/qemu-mips/qemu-mips.c delete mode 100644 configs/qemu_mips64_defconfig delete mode 100644 configs/qemu_mips64el_defconfig delete mode 100644 configs/qemu_mips_defconfig delete mode 100644 configs/qemu_mipsel_defconfig delete mode 100644 include/configs/qemu-mips.h delete mode 100644 include/configs/qemu-mips64.h
With the last user of this driver removed, remove the driver.
Signed-off-by: Tom Rini trini@konsulko.com --- doc/README.ne2000 | 27 -- drivers/net/8390.h | 124 ------ drivers/net/Makefile | 1 - drivers/net/ne2000.c | 260 ------------- drivers/net/ne2000.h | 94 ----- drivers/net/ne2000_base.c | 792 -------------------------------------- drivers/net/ne2000_base.h | 305 --------------- 7 files changed, 1603 deletions(-) delete mode 100644 doc/README.ne2000 delete mode 100644 drivers/net/8390.h delete mode 100644 drivers/net/ne2000.c delete mode 100644 drivers/net/ne2000.h delete mode 100644 drivers/net/ne2000_base.c delete mode 100644 drivers/net/ne2000_base.h
diff --git a/doc/README.ne2000 b/doc/README.ne2000 deleted file mode 100644 index 0f6a2e04ff1c..000000000000 --- a/doc/README.ne2000 +++ /dev/null @@ -1,27 +0,0 @@ -This driver supports NE2000 compatible cards (those based on DP8390, -DP83902 and similar). It can be used with PCMCIA/CF cards provided -that the CCR is correctly initialized. - -The code is based on sources from the Linux kernel (pcnet_cs.c, -8390.h) and eCOS(if_dp83902a.c, if_dp83902a.h). Both of these 2 -wonderful world are GPL, so this is, of course, GPL. - -I developed and tested this driver on a custom PXA255 based system and -with a billionton CF network card connected to the PCMCIA interface of -the micro (have a look at README.PXA_CF for the support of this port). - -The options you have to specify in the config file are (with the -value for my board as an example): - -#define CONFIG_DRIVER_NE2000 - -- Enables the driver - -#define CONFIG_DRIVER_NE2000_BASE (0x20000000+0x300) - -- Address where the board is mapped - - -Enjoy! - -Christian Pellegrin chri@ascensit.com diff --git a/drivers/net/8390.h b/drivers/net/8390.h deleted file mode 100644 index f087217ed00a..000000000000 --- a/drivers/net/8390.h +++ /dev/null @@ -1,124 +0,0 @@ -/* - -Ported to U-Boot by Christian Pellegrin chri@ascensit.com - -Based on sources from the Linux kernel (pcnet_cs.c, 8390.h) and -eCOS(if_dp83902a.c, if_dp83902a.h). Both of these 2 wonderful world -are GPL, so this is, of course, GPL. - -*/ - -/* Generic NS8390 register definitions. */ -/* This file is part of Donald Becker's 8390 drivers, and is distributed - under the same license. Auto-loading of 8390.o only in v2.2 - Paul G. - Some of these names and comments originated from the Crynwr - packet drivers, which are distributed under the GPL. */ - -#ifndef _8390_h -#define _8390_h - -/* Some generic ethernet register configurations. */ -#define E8390_TX_IRQ_MASK 0xa /* For register EN0_ISR */ -#define E8390_RX_IRQ_MASK 0x5 -#define E8390_RXCONFIG 0x4 /* EN0_RXCR: broadcasts, no multicast,errors */ -#define E8390_RXOFF 0x20 /* EN0_RXCR: Accept no packets */ -#define E8390_TXCONFIG 0x00 /* EN0_TXCR: Normal transmit mode */ -#define E8390_TXOFF 0x02 /* EN0_TXCR: Transmitter off */ - -/* Register accessed at EN_CMD, the 8390 base addr. */ -#define E8390_STOP 0x01 /* Stop and reset the chip */ -#define E8390_START 0x02 /* Start the chip, clear reset */ -#define E8390_TRANS 0x04 /* Transmit a frame */ -#define E8390_RREAD 0x08 /* Remote read */ -#define E8390_RWRITE 0x10 /* Remote write */ -#define E8390_NODMA 0x20 /* Remote DMA */ -#define E8390_PAGE0 0x00 /* Select page chip registers */ -#define E8390_PAGE1 0x40 /* using the two high-order bits */ -#define E8390_PAGE2 0x80 /* Page 3 is invalid. */ - -/* - * Only generate indirect loads given a machine that needs them. - * - removed AMIGA_PCMCIA from this list, handled as ISA io now - */ - -#define n2k_inb(port) (*((volatile unsigned char *)(port+CONFIG_DRIVER_NE2000_BASE))) -#define n2k_outb(val,port) (*((volatile unsigned char *)(port+CONFIG_DRIVER_NE2000_BASE)) = val) - -#define EI_SHIFT(x) (x) - -#define E8390_CMD EI_SHIFT(0x00) /* The command register (for all pages) */ -/* Page 0 register offsets. */ -#define EN0_CLDALO EI_SHIFT(0x01) /* Low byte of current local dma addr RD */ -#define EN0_STARTPG EI_SHIFT(0x01) /* Starting page of ring bfr WR */ -#define EN0_CLDAHI EI_SHIFT(0x02) /* High byte of current local dma addr RD */ -#define EN0_STOPPG EI_SHIFT(0x02) /* Ending page +1 of ring bfr WR */ -#define EN0_BOUNDARY EI_SHIFT(0x03) /* Boundary page of ring bfr RD WR */ -#define EN0_TSR EI_SHIFT(0x04) /* Transmit status reg RD */ -#define EN0_TPSR EI_SHIFT(0x04) /* Transmit starting page WR */ -#define EN0_NCR EI_SHIFT(0x05) /* Number of collision reg RD */ -#define EN0_TCNTLO EI_SHIFT(0x05) /* Low byte of tx byte count WR */ -#define EN0_FIFO EI_SHIFT(0x06) /* FIFO RD */ -#define EN0_TCNTHI EI_SHIFT(0x06) /* High byte of tx byte count WR */ -#define EN0_ISR EI_SHIFT(0x07) /* Interrupt status reg RD WR */ -#define EN0_CRDALO EI_SHIFT(0x08) /* low byte of current remote dma address RD */ -#define EN0_RSARLO EI_SHIFT(0x08) /* Remote start address reg 0 */ -#define EN0_CRDAHI EI_SHIFT(0x09) /* high byte, current remote dma address RD */ -#define EN0_RSARHI EI_SHIFT(0x09) /* Remote start address reg 1 */ -#define EN0_RCNTLO EI_SHIFT(0x0a) /* Remote byte count reg WR */ -#define EN0_RCNTHI EI_SHIFT(0x0b) /* Remote byte count reg WR */ -#define EN0_RSR EI_SHIFT(0x0c) /* rx status reg RD */ -#define EN0_RXCR EI_SHIFT(0x0c) /* RX configuration reg WR */ -#define EN0_TXCR EI_SHIFT(0x0d) /* TX configuration reg WR */ -#define EN0_COUNTER0 EI_SHIFT(0x0d) /* Rcv alignment error counter RD */ -#define EN0_DCFG EI_SHIFT(0x0e) /* Data configuration reg WR */ -#define EN0_COUNTER1 EI_SHIFT(0x0e) /* Rcv CRC error counter RD */ -#define EN0_IMR EI_SHIFT(0x0f) /* Interrupt mask reg WR */ -#define EN0_COUNTER2 EI_SHIFT(0x0f) /* Rcv missed frame error counter RD */ - -/* Bits in EN0_ISR - Interrupt status register */ -#define ENISR_RX 0x01 /* Receiver, no error */ -#define ENISR_TX 0x02 /* Transmitter, no error */ -#define ENISR_RX_ERR 0x04 /* Receiver, with error */ -#define ENISR_TX_ERR 0x08 /* Transmitter, with error */ -#define ENISR_OVER 0x10 /* Receiver overwrote the ring */ -#define ENISR_COUNTERS 0x20 /* Counters need emptying */ -#define ENISR_RDC 0x40 /* remote dma complete */ -#define ENISR_RESET 0x80 /* Reset completed */ -#define ENISR_ALL 0x3f /* Interrupts we will enable */ - -/* Bits in EN0_DCFG - Data config register */ -#define ENDCFG_WTS 0x01 /* word transfer mode selection */ -#define ENDCFG_BOS 0x02 /* byte order selection */ -#define ENDCFG_AUTO_INIT 0x10 /* Auto-init to remove packets from ring */ -#define ENDCFG_FIFO 0x40 /* 8 bytes */ - -/* Page 1 register offsets. */ -#define EN1_PHYS EI_SHIFT(0x01) /* This board's physical enet addr RD WR */ -#define EN1_PHYS_SHIFT(i) EI_SHIFT(i+1) /* Get and set mac address */ -#define EN1_CURPAG EI_SHIFT(0x07) /* Current memory page RD WR */ -#define EN1_MULT EI_SHIFT(0x08) /* Multicast filter mask array (8 bytes) RD WR */ -#define EN1_MULT_SHIFT(i) EI_SHIFT(8+i) /* Get and set multicast filter */ - -/* Bits in received packet status byte and EN0_RSR*/ -#define ENRSR_RXOK 0x01 /* Received a good packet */ -#define ENRSR_CRC 0x02 /* CRC error */ -#define ENRSR_FAE 0x04 /* frame alignment error */ -#define ENRSR_FO 0x08 /* FIFO overrun */ -#define ENRSR_MPA 0x10 /* missed pkt */ -#define ENRSR_PHY 0x20 /* physical/multicast address */ -#define ENRSR_DIS 0x40 /* receiver disable. set in monitor mode */ -#define ENRSR_DEF 0x80 /* deferring */ - -/* Transmitted packet status, EN0_TSR. */ -#define ENTSR_PTX 0x01 /* Packet transmitted without error */ -#define ENTSR_ND 0x02 /* The transmit wasn't deferred. */ -#define ENTSR_COL 0x04 /* The transmit collided at least once. */ -#define ENTSR_ABT 0x08 /* The transmit collided 16 times, and was deferred. */ -#define ENTSR_CRS 0x10 /* The carrier sense was lost. */ -#define ENTSR_FU 0x20 /* A "FIFO underrun" occurred during transmit. */ -#define ENTSR_CDH 0x40 /* The collision detect "heartbeat" signal was lost. */ -#define ENTSR_OWC 0x80 /* There was an out-of-window collision. */ - -#define NIC_RECEIVE_MONITOR_MODE 0x20 - -#endif /* _8390_h */ diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 2ce89f7e3c61..a44a7d3f56aa 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -56,7 +56,6 @@ obj-$(CONFIG_MVMDIO) += mvmdio.o obj-$(CONFIG_MVNETA) += mvneta.o obj-$(CONFIG_MVPP2) += mvpp2.o obj-$(CONFIG_NATSEMI) += natsemi.o -obj-$(CONFIG_DRIVER_NE2000) += ne2000.o ne2000_base.o obj-$(CONFIG_NETCONSOLE) += netconsole.o obj-$(CONFIG_NS8382X) += ns8382x.o obj-$(CONFIG_PCH_GBE) += pch_gbe.o diff --git a/drivers/net/ne2000.c b/drivers/net/ne2000.c deleted file mode 100644 index 28a99bb8c48e..000000000000 --- a/drivers/net/ne2000.c +++ /dev/null @@ -1,260 +0,0 @@ -/* -Ported to U-Boot by Christian Pellegrin chri@ascensit.com - -Based on sources from the Linux kernel (pcnet_cs.c, 8390.h) and -eCOS(if_dp83902a.c, if_dp83902a.h). Both of these 2 wonderful world -are GPL, so this is, of course, GPL. - -========================================================================== - -dev/if_dp83902a.c - -Ethernet device driver for NS DP83902a ethernet controller - -========================================================================== -####ECOSGPLCOPYRIGHTBEGIN#### -------------------------------------------- -This file is part of eCos, the Embedded Configurable Operating System. -Copyright (C) 1998, 1999, 2000, 2001, 2002 Red Hat, Inc. - -eCos is free software; you can redistribute it and/or modify it under -the terms of the GNU General Public License as published by the Free -Software Foundation; either version 2 or (at your option) any later version. - -eCos is distributed in the hope that it will be useful, but WITHOUT ANY -WARRANTY; without even the implied warranty of MERCHANTABILITY or -FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License -for more details. - -You should have received a copy of the GNU General Public License along -with eCos; if not, write to the Free Software Foundation, Inc., -59 Temple Place, Suite 330, Boston, MA 02111-1307 USA. - -As a special exception, if other files instantiate templates or use macros -or inline functions from this file, or you compile this file and link it -with other works to produce a work based on this file, this file does not -by itself cause the resulting work to be covered by the GNU General Public -License. However the source code for this file must still be made available -in accordance with section (3) of the GNU General Public License. - -This exception does not invalidate any other reasons why a work based on -this file might be covered by the GNU General Public License. - -Alternative licenses for eCos may be arranged by contacting Red Hat, Inc. -at http://sources.redhat.com/ecos/ecos-license/ -------------------------------------------- -####ECOSGPLCOPYRIGHTEND#### -####BSDCOPYRIGHTBEGIN#### - -------------------------------------------- - -Portions of this software may have been derived from OpenBSD or other sources, -and are covered by the appropriate copyright disclaimers included herein. - -------------------------------------------- - -####BSDCOPYRIGHTEND#### -========================================================================== -#####DESCRIPTIONBEGIN#### - -Author(s): gthomas -Contributors: gthomas, jskov, rsandifo -Date: 2001-06-13 -Purpose: -Description: - -FIXME: Will fail if pinged with large packets (1520 bytes) -Add promisc config -Add SNMP - -####DESCRIPTIONEND#### - -========================================================================== -*/ - -#include <common.h> -#include <command.h> -#include <linux/delay.h> - -/* NE2000 base header file */ -#include "ne2000_base.h" - -/* find prom (taken from pc_net_cs.c from Linux) */ - -#include "8390.h" -/* -typedef struct hw_info_t { - u_int offset; - u_char a0, a1, a2; - u_int flags; -} hw_info_t; -*/ -#define DELAY_OUTPUT 0x01 -#define HAS_MISC_REG 0x02 -#define USE_BIG_BUF 0x04 -#define HAS_IBM_MISC 0x08 -#define IS_DL10019 0x10 -#define IS_DL10022 0x20 -#define HAS_MII 0x40 -#define USE_SHMEM 0x80 /* autodetected */ - -#define AM79C9XX_HOME_PHY 0x00006B90 /* HomePNA PHY */ -#define AM79C9XX_ETH_PHY 0x00006B70 /* 10baseT PHY */ -#define MII_PHYID_REV_MASK 0xfffffff0 -#define MII_PHYID_REG1 0x02 -#define MII_PHYID_REG2 0x03 - -static hw_info_t hw_info[] = { - { /* Accton EN2212 */ 0x0ff0, 0x00, 0x00, 0xe8, DELAY_OUTPUT }, - { /* Allied Telesis LA-PCM */ 0x0ff0, 0x00, 0x00, 0xf4, 0 }, - { /* APEX MultiCard */ 0x03f4, 0x00, 0x20, 0xe5, 0 }, - { /* ASANTE FriendlyNet */ 0x4910, 0x00, 0x00, 0x94, - DELAY_OUTPUT | HAS_IBM_MISC }, - { /* Danpex EN-6200P2 */ 0x0110, 0x00, 0x40, 0xc7, 0 }, - { /* DataTrek NetCard */ 0x0ff0, 0x00, 0x20, 0xe8, 0 }, - { /* Dayna CommuniCard E */ 0x0110, 0x00, 0x80, 0x19, 0 }, - { /* D-Link DE-650 */ 0x0040, 0x00, 0x80, 0xc8, 0 }, - { /* EP-210 Ethernet */ 0x0110, 0x00, 0x40, 0x33, 0 }, - { /* EP4000 Ethernet */ 0x01c0, 0x00, 0x00, 0xb4, 0 }, - { /* Epson EEN10B */ 0x0ff0, 0x00, 0x00, 0x48, - HAS_MISC_REG | HAS_IBM_MISC }, - { /* ELECOM Laneed LD-CDWA */ 0xb8, 0x08, 0x00, 0x42, 0 }, - { /* Hypertec Ethernet */ 0x01c0, 0x00, 0x40, 0x4c, 0 }, - { /* IBM CCAE */ 0x0ff0, 0x08, 0x00, 0x5a, - HAS_MISC_REG | HAS_IBM_MISC }, - { /* IBM CCAE */ 0x0ff0, 0x00, 0x04, 0xac, - HAS_MISC_REG | HAS_IBM_MISC }, - { /* IBM CCAE */ 0x0ff0, 0x00, 0x06, 0x29, - HAS_MISC_REG | HAS_IBM_MISC }, - { /* IBM FME */ 0x0374, 0x08, 0x00, 0x5a, - HAS_MISC_REG | HAS_IBM_MISC }, - { /* IBM FME */ 0x0374, 0x00, 0x04, 0xac, - HAS_MISC_REG | HAS_IBM_MISC }, - { /* Kansai KLA-PCM/T */ 0x0ff0, 0x00, 0x60, 0x87, - HAS_MISC_REG | HAS_IBM_MISC }, - { /* NSC DP83903 */ 0x0374, 0x08, 0x00, 0x17, - HAS_MISC_REG | HAS_IBM_MISC }, - { /* NSC DP83903 */ 0x0374, 0x00, 0xc0, 0xa8, - HAS_MISC_REG | HAS_IBM_MISC }, - { /* NSC DP83903 */ 0x0374, 0x00, 0xa0, 0xb0, - HAS_MISC_REG | HAS_IBM_MISC }, - { /* NSC DP83903 */ 0x0198, 0x00, 0x20, 0xe0, - HAS_MISC_REG | HAS_IBM_MISC }, - { /* I-O DATA PCLA/T */ 0x0ff0, 0x00, 0xa0, 0xb0, 0 }, - { /* Katron PE-520 */ 0x0110, 0x00, 0x40, 0xf6, 0 }, - { /* Kingston KNE-PCM/x */ 0x0ff0, 0x00, 0xc0, 0xf0, - HAS_MISC_REG | HAS_IBM_MISC }, - { /* Kingston KNE-PCM/x */ 0x0ff0, 0xe2, 0x0c, 0x0f, - HAS_MISC_REG | HAS_IBM_MISC }, - { /* Kingston KNE-PC2 */ 0x0180, 0x00, 0xc0, 0xf0, 0 }, - { /* Maxtech PCN2000 */ 0x5000, 0x00, 0x00, 0xe8, 0 }, - { /* NDC Instant-Link */ 0x003a, 0x00, 0x80, 0xc6, 0 }, - { /* NE2000 Compatible */ 0x0ff0, 0x00, 0xa0, 0x0c, 0 }, - { /* Network General Sniffer */ 0x0ff0, 0x00, 0x00, 0x65, - HAS_MISC_REG | HAS_IBM_MISC }, - { /* Panasonic VEL211 */ 0x0ff0, 0x00, 0x80, 0x45, - HAS_MISC_REG | HAS_IBM_MISC }, - { /* PreMax PE-200 */ 0x07f0, 0x00, 0x20, 0xe0, 0 }, - { /* RPTI EP400 */ 0x0110, 0x00, 0x40, 0x95, 0 }, - { /* SCM Ethernet */ 0x0ff0, 0x00, 0x20, 0xcb, 0 }, - { /* Socket EA */ 0x4000, 0x00, 0xc0, 0x1b, - DELAY_OUTPUT | HAS_MISC_REG | USE_BIG_BUF }, - { /* Socket LP-E CF+ */ 0x01c0, 0x00, 0xc0, 0x1b, 0 }, - { /* SuperSocket RE450T */ 0x0110, 0x00, 0xe0, 0x98, 0 }, - { /* Volktek NPL-402CT */ 0x0060, 0x00, 0x40, 0x05, 0 }, - { /* NEC PC-9801N-J12 */ 0x0ff0, 0x00, 0x00, 0x4c, 0 }, - { /* PCMCIA Technology OEM */ 0x01c8, 0x00, 0xa0, 0x0c, 0 }, - { /* Qemu */ 0x0, 0x52, 0x54, 0x00, 0 }, - { /* RTL8019AS */ 0x0, 0x0, 0x18, 0x5f, 0 } -}; - -#define NR_INFO (sizeof(hw_info)/sizeof(hw_info_t)) - -#define PCNET_CMD 0x00 -#define PCNET_DATAPORT 0x10 /* NatSemi-defined port window offset. */ -#define PCNET_RESET 0x1f /* Issue a read to reset, a write to clear. */ -#define PCNET_MISC 0x18 /* For IBM CCAE and Socket EA cards */ - -static void pcnet_reset_8390(u8* addr) -{ - int i, r; - - n2k_outb(E8390_NODMA + E8390_PAGE0+E8390_STOP, E8390_CMD); - PRINTK("cmd (at %lx) is %x\n", addr + E8390_CMD, n2k_inb(E8390_CMD)); - n2k_outb(E8390_NODMA+E8390_PAGE1+E8390_STOP, E8390_CMD); - PRINTK("cmd (at %lx) is %x\n", addr + E8390_CMD, n2k_inb(E8390_CMD)); - n2k_outb(E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD); - PRINTK("cmd (at %lx) is %x\n", addr + E8390_CMD, n2k_inb(E8390_CMD)); - n2k_outb(E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD); - - n2k_outb(n2k_inb(PCNET_RESET), PCNET_RESET); - - for (i = 0; i < 100; i++) { - if ((r = (n2k_inb(EN0_ISR) & ENISR_RESET)) != 0) - break; - PRINTK("got %x in reset\n", r); - udelay(100); - } - n2k_outb(ENISR_RESET, EN0_ISR); /* Ack intr. */ - - if (i == 100) - printf("pcnet_reset_8390() did not complete.\n"); -} /* pcnet_reset_8390 */ - -int get_prom(u8* mac_addr, u8* base_addr) -{ - u8 prom[32]; - int i, j; - struct { - u_char value, offset; - } program_seq[] = { - {E8390_NODMA+E8390_PAGE0+E8390_STOP, E8390_CMD}, /* Select page 0*/ - {0x48, EN0_DCFG}, /* Set byte-wide (0x48) access. */ - {0x00, EN0_RCNTLO}, /* Clear the count regs. */ - {0x00, EN0_RCNTHI}, - {0x00, EN0_IMR}, /* Mask completion irq. */ - {0xFF, EN0_ISR}, - {E8390_RXOFF, EN0_RXCR}, /* 0x20 Set to monitor */ - {E8390_TXOFF, EN0_TXCR}, /* 0x02 and loopback mode. */ - {32, EN0_RCNTLO}, - {0x00, EN0_RCNTHI}, - {0x00, EN0_RSARLO}, /* DMA starting at 0x0000. */ - {0x00, EN0_RSARHI}, - {E8390_RREAD+E8390_START, E8390_CMD}, - }; - - PRINTK ("trying to get MAC via prom reading\n"); - - pcnet_reset_8390 (base_addr); - - mdelay (10); - - for (i = 0; i < ARRAY_SIZE(program_seq); i++) - n2k_outb (program_seq[i].value, program_seq[i].offset); - - PRINTK ("PROM:"); - for (i = 0; i < 32; i++) { - prom[i] = n2k_inb (PCNET_DATAPORT); - PRINTK (" %02x", prom[i]); - } - PRINTK ("\n"); - for (i = 0; i < NR_INFO; i++) { - if ((prom[0] == hw_info[i].a0) && - (prom[2] == hw_info[i].a1) && - (prom[4] == hw_info[i].a2)) { - PRINTK ("matched board %d\n", i); - break; - } - } - if ((i < NR_INFO) || ((prom[28] == 0x57) && (prom[30] == 0x57))) { - PRINTK ("on exit i is %d/%ld\n", i, NR_INFO); - PRINTK ("MAC address is "); - for (j = 0; j < 6; j++) { - mac_addr[j] = prom[j << 1]; - PRINTK ("%02x:", mac_addr[i]); - } - PRINTK ("\n"); - return (i < NR_INFO) ? i : 0; - } - return 0; -} diff --git a/drivers/net/ne2000.h b/drivers/net/ne2000.h deleted file mode 100644 index 2cde6be4377d..000000000000 --- a/drivers/net/ne2000.h +++ /dev/null @@ -1,94 +0,0 @@ -/* -Ported to U-Boot by Christian Pellegrin chri@ascensit.com - -Based on sources from the Linux kernel (pcnet_cs.c, 8390.h) and -eCOS(if_dp83902a.c, if_dp83902a.h). Both of these 2 wonderful world -are GPL, so this is, of course, GPL. - -========================================================================== - - dev/dp83902a.h - - National Semiconductor DP83902a ethernet chip - -========================================================================== -####ECOSGPLCOPYRIGHTBEGIN#### - ------------------------------------------- - This file is part of eCos, the Embedded Configurable Operating System. - Copyright (C) 1998, 1999, 2000, 2001, 2002 Red Hat, Inc. - - eCos is free software; you can redistribute it and/or modify it under - the terms of the GNU General Public License as published by the Free - Software Foundation; either version 2 or (at your option) any later version. - - eCos is distributed in the hope that it will be useful, but WITHOUT ANY - WARRANTY; without even the implied warranty of MERCHANTABILITY or - FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License - for more details. - - You should have received a copy of the GNU General Public License along - with eCos; if not, write to the Free Software Foundation, Inc., - 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA. - - As a special exception, if other files instantiate templates or use macros - or inline functions from this file, or you compile this file and link it - with other works to produce a work based on this file, this file does not - by itself cause the resulting work to be covered by the GNU General Public - License. However the source code for this file must still be made available - in accordance with section (3) of the GNU General Public License. - - This exception does not invalidate any other reasons why a work based on - this file might be covered by the GNU General Public License. - - Alternative licenses for eCos may be arranged by contacting Red Hat, Inc. - at http://sources.redhat.com/ecos/ecos-license/ - ------------------------------------------- -####ECOSGPLCOPYRIGHTEND#### -####BSDCOPYRIGHTBEGIN#### - - ------------------------------------------- - - Portions of this software may have been derived from OpenBSD or other sources, - and are covered by the appropriate copyright disclaimers included herein. - - ------------------------------------------- - -####BSDCOPYRIGHTEND#### -========================================================================== -#####DESCRIPTIONBEGIN#### - - Author(s): gthomas - Contributors: gthomas, jskov - Date: 2001-06-13 - Purpose: - Description: - -####DESCRIPTIONEND#### - -========================================================================== -*/ - -/* - * NE2000 support header file. - * Created by Nobuhiro Iwamatsu iwamatsu@nigauri.org - */ - -#ifndef __DRIVERS_NE2000_H__ -#define __DRIVERS_NE2000_H__ - -/* Enable NE2000 basic init function */ -#define NE2000_BASIC_INIT - -#define DP_DATA 0x10 -#define START_PG 0x50 /* First page of TX buffer */ -#define START_PG2 0x48 -#define STOP_PG 0x80 /* Last page +1 of RX ring */ - -#define RX_START 0x50 -#define RX_END 0x80 - -#define DP_IN(_b_, _o_, _d_) (_d_) = *( (vu_char *) ((_b_)+(_o_))) -#define DP_OUT(_b_, _o_, _d_) *( (vu_char *) ((_b_)+(_o_))) = (_d_) -#define DP_IN_DATA(_b_, _d_) (_d_) = *( (vu_char *) ((_b_))) -#define DP_OUT_DATA(_b_, _d_) *( (vu_char *) ((_b_))) = (_d_) -#endif /* __DRIVERS_NE2000_H__ */ diff --git a/drivers/net/ne2000_base.c b/drivers/net/ne2000_base.c deleted file mode 100644 index f6673f5e4c65..000000000000 --- a/drivers/net/ne2000_base.c +++ /dev/null @@ -1,792 +0,0 @@ -/* -Ported to U-Boot by Christian Pellegrin chri@ascensit.com - -Based on sources from the Linux kernel (pcnet_cs.c, 8390.h) and -eCOS(if_dp83902a.c, if_dp83902a.h). Both of these 2 wonderful world -are GPL, so this is, of course, GPL. - -========================================================================== - -dev/if_dp83902a.c - -Ethernet device driver for NS DP83902a ethernet controller - -========================================================================== -####ECOSGPLCOPYRIGHTBEGIN#### -------------------------------------------- -This file is part of eCos, the Embedded Configurable Operating System. -Copyright (C) 1998, 1999, 2000, 2001, 2002 Red Hat, Inc. - -eCos is free software; you can redistribute it and/or modify it under -the terms of the GNU General Public License as published by the Free -Software Foundation; either version 2 or (at your option) any later version. - -eCos is distributed in the hope that it will be useful, but WITHOUT ANY -WARRANTY; without even the implied warranty of MERCHANTABILITY or -FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License -for more details. - -You should have received a copy of the GNU General Public License along -with eCos; if not, write to the Free Software Foundation, Inc., -59 Temple Place, Suite 330, Boston, MA 02111-1307 USA. - -As a special exception, if other files instantiate templates or use macros -or inline functions from this file, or you compile this file and link it -with other works to produce a work based on this file, this file does not -by itself cause the resulting work to be covered by the GNU General Public -License. However the source code for this file must still be made available -in accordance with section (3) of the GNU General Public License. - -This exception does not invalidate any other reasons why a work based on -this file might be covered by the GNU General Public License. - -Alternative licenses for eCos may be arranged by contacting Red Hat, Inc. -at http://sources.redhat.com/ecos/ecos-license/ -------------------------------------------- -####ECOSGPLCOPYRIGHTEND#### -####BSDCOPYRIGHTBEGIN#### - -------------------------------------------- - -Portions of this software may have been derived from OpenBSD or other sources, -and are covered by the appropriate copyright disclaimers included herein. - -------------------------------------------- - -####BSDCOPYRIGHTEND#### -========================================================================== -#####DESCRIPTIONBEGIN#### - -Author(s): gthomas -Contributors: gthomas, jskov, rsandifo -Date: 2001-06-13 -Purpose: -Description: - -FIXME: Will fail if pinged with large packets (1520 bytes) -Add promisc config -Add SNMP - -####DESCRIPTIONEND#### - -========================================================================== -*/ - -#include <common.h> -#include <command.h> -#include <env.h> -#include <log.h> -#include <net.h> -#include <malloc.h> -#include <linux/compiler.h> - -/* forward definition of function used for the uboot interface */ -void uboot_push_packet_len(int len); -void uboot_push_tx_done(int key, int val); - -/* NE2000 base header file */ -#include "ne2000_base.h" - -#if defined(CONFIG_DRIVER_AX88796L) -/* AX88796L support */ -#include "ax88796.h" -#else -/* Basic NE2000 chip support */ -#include "ne2000.h" -#endif - -static dp83902a_priv_data_t nic; /* just one instance of the card supported */ - -/** - * This function reads the MAC address from the serial EEPROM, - * used if PROM read fails. Does nothing for ax88796 chips (sh boards) - */ -static bool -dp83902a_init(unsigned char *enetaddr) -{ - dp83902a_priv_data_t *dp = &nic; - u8* base; -#if defined(NE2000_BASIC_INIT) - int i; -#endif - - DEBUG_FUNCTION(); - - base = dp->base; - if (!base) - return false; /* No device found */ - - DEBUG_LINE(); - -#if defined(NE2000_BASIC_INIT) - /* AX88796L doesn't need */ - /* Prepare ESA */ - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE1); /* Select page 1 */ - /* Use the address from the serial EEPROM */ - for (i = 0; i < 6; i++) - DP_IN(base, DP_P1_PAR0+i, dp->esa[i]); - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE0); /* Select page 0 */ - - printf("NE2000 - %s ESA: %02x:%02x:%02x:%02x:%02x:%02x\n", - "eeprom", - dp->esa[0], - dp->esa[1], - dp->esa[2], - dp->esa[3], - dp->esa[4], - dp->esa[5] ); - - memcpy(enetaddr, dp->esa, 6); /* Use MAC from serial EEPROM */ -#endif /* NE2000_BASIC_INIT */ - return true; -} - -static void -dp83902a_stop(void) -{ - dp83902a_priv_data_t *dp = &nic; - u8 *base = dp->base; - - DEBUG_FUNCTION(); - - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_STOP); /* Brutal */ - DP_OUT(base, DP_ISR, 0xFF); /* Clear any pending interrupts */ - DP_OUT(base, DP_IMR, 0x00); /* Disable all interrupts */ - - dp->running = false; -} - -/* - * This function is called to "start up" the interface. It may be called - * multiple times, even when the hardware is already running. It will be - * called whenever something "hardware oriented" changes and should leave - * the hardware ready to send/receive packets. - */ -static void -dp83902a_start(u8 * enaddr) -{ - dp83902a_priv_data_t *dp = &nic; - u8 *base = dp->base; - int i; - - debug("The MAC is %pM\n", enaddr); - - DEBUG_FUNCTION(); - - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_STOP); /* Brutal */ - DP_OUT(base, DP_DCR, DP_DCR_INIT); - DP_OUT(base, DP_RBCH, 0); /* Remote byte count */ - DP_OUT(base, DP_RBCL, 0); - DP_OUT(base, DP_RCR, DP_RCR_MON); /* Accept no packets */ - DP_OUT(base, DP_TCR, DP_TCR_LOCAL); /* Transmitter [virtually] off */ - DP_OUT(base, DP_TPSR, dp->tx_buf1); /* Transmitter start page */ - dp->tx1 = dp->tx2 = 0; - dp->tx_next = dp->tx_buf1; - dp->tx_started = false; - dp->running = true; - DP_OUT(base, DP_PSTART, dp->rx_buf_start); /* Receive ring start page */ - DP_OUT(base, DP_BNDRY, dp->rx_buf_end - 1); /* Receive ring boundary */ - DP_OUT(base, DP_PSTOP, dp->rx_buf_end); /* Receive ring end page */ - dp->rx_next = dp->rx_buf_start - 1; - dp->running = true; - DP_OUT(base, DP_ISR, 0xFF); /* Clear any pending interrupts */ - DP_OUT(base, DP_IMR, DP_IMR_All); /* Enable all interrupts */ - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE1 | DP_CR_STOP); /* Select page 1 */ - DP_OUT(base, DP_P1_CURP, dp->rx_buf_start); /* Current page - next free page for Rx */ - dp->running = true; - for (i = 0; i < ETHER_ADDR_LEN; i++) { - /* FIXME */ - /*((vu_short*)( base + ((DP_P1_PAR0 + i) * 2) + - * 0x1400)) = enaddr[i];*/ - DP_OUT(base, DP_P1_PAR0+i, enaddr[i]); - } - /* Enable and start device */ - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); - DP_OUT(base, DP_TCR, DP_TCR_NORMAL); /* Normal transmit operations */ - DP_OUT(base, DP_RCR, DP_RCR_AB); /* Accept broadcast, no errors, no multicast */ - dp->running = true; -} - -/* - * This routine is called to start the transmitter. It is split out from the - * data handling routine so it may be called either when data becomes first - * available or when an Tx interrupt occurs - */ - -static void -dp83902a_start_xmit(int start_page, int len) -{ - dp83902a_priv_data_t *dp = (dp83902a_priv_data_t *) &nic; - u8 *base = dp->base; - - DEBUG_FUNCTION(); - -#if DEBUG & 1 - printf("Tx pkt %d len %d\n", start_page, len); - if (dp->tx_started) - printf("TX already started?!?\n"); -#endif - - DP_OUT(base, DP_ISR, (DP_ISR_TxP | DP_ISR_TxE)); - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); - DP_OUT(base, DP_TBCL, len & 0xFF); - DP_OUT(base, DP_TBCH, len >> 8); - DP_OUT(base, DP_TPSR, start_page); - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_TXPKT | DP_CR_START); - - dp->tx_started = true; -} - -/* - * This routine is called to send data to the hardware. It is known a-priori - * that there is free buffer space (dp->tx_next). - */ -static void -dp83902a_send(u8 *data, int total_len, u32 key) -{ - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; - u8 *base = dp->base; - int len, start_page, pkt_len, i, isr; -#if DEBUG & 4 - int dx; -#endif - - DEBUG_FUNCTION(); - - len = pkt_len = total_len; - if (pkt_len < IEEE_8023_MIN_FRAME) - pkt_len = IEEE_8023_MIN_FRAME; - - start_page = dp->tx_next; - if (dp->tx_next == dp->tx_buf1) { - dp->tx1 = start_page; - dp->tx1_len = pkt_len; - dp->tx1_key = key; - dp->tx_next = dp->tx_buf2; - } else { - dp->tx2 = start_page; - dp->tx2_len = pkt_len; - dp->tx2_key = key; - dp->tx_next = dp->tx_buf1; - } - -#if DEBUG & 5 - printf("TX prep page %d len %d\n", start_page, pkt_len); -#endif - - DP_OUT(base, DP_ISR, DP_ISR_RDC); /* Clear end of DMA */ - { - /* - * Dummy read. The manual sez something slightly different, - * but the code is extended a bit to do what Hitachi's monitor - * does (i.e., also read data). - */ - - __maybe_unused u16 tmp; - int len = 1; - - DP_OUT(base, DP_RSAL, 0x100 - len); - DP_OUT(base, DP_RSAH, (start_page - 1) & 0xff); - DP_OUT(base, DP_RBCL, len); - DP_OUT(base, DP_RBCH, 0); - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_RDMA | DP_CR_START); - DP_IN_DATA(dp->data, tmp); - } - -#ifdef CYGHWR_NS_DP83902A_PLF_BROKEN_TX_DMA - /* - * Stall for a bit before continuing to work around random data - * corruption problems on some platforms. - */ - CYGACC_CALL_IF_DELAY_US(1); -#endif - - /* Send data to device buffer(s) */ - DP_OUT(base, DP_RSAL, 0); - DP_OUT(base, DP_RSAH, start_page); - DP_OUT(base, DP_RBCL, pkt_len & 0xFF); - DP_OUT(base, DP_RBCH, pkt_len >> 8); - DP_OUT(base, DP_CR, DP_CR_WDMA | DP_CR_START); - - /* Put data into buffer */ -#if DEBUG & 4 - printf(" sg buf %08lx len %08x\n ", (u32)data, len); - dx = 0; -#endif - while (len > 0) { -#if DEBUG & 4 - printf(" %02x", *data); - if (0 == (++dx % 16)) printf("\n "); -#endif - - DP_OUT_DATA(dp->data, *data++); - len--; - } -#if DEBUG & 4 - printf("\n"); -#endif - if (total_len < pkt_len) { -#if DEBUG & 4 - printf(" + %d bytes of padding\n", pkt_len - total_len); -#endif - /* Padding to 802.3 length was required */ - for (i = total_len; i < pkt_len;) { - i++; - DP_OUT_DATA(dp->data, 0); - } - } - -#ifdef CYGHWR_NS_DP83902A_PLF_BROKEN_TX_DMA - /* - * After last data write, delay for a bit before accessing the - * device again, or we may get random data corruption in the last - * datum (on some platforms). - */ - CYGACC_CALL_IF_DELAY_US(1); -#endif - - /* Wait for DMA to complete */ - do { - DP_IN(base, DP_ISR, isr); - } while ((isr & DP_ISR_RDC) == 0); - - /* Then disable DMA */ - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); - - /* Start transmit if not already going */ - if (!dp->tx_started) { - if (start_page == dp->tx1) { - dp->tx_int = 1; /* Expecting interrupt from BUF1 */ - } else { - dp->tx_int = 2; /* Expecting interrupt from BUF2 */ - } - dp83902a_start_xmit(start_page, pkt_len); - } -} - -/* - * This function is called when a packet has been received. It's job is - * to prepare to unload the packet from the hardware. Once the length of - * the packet is known, the upper layer of the driver can be told. When - * the upper layer is ready to unload the packet, the internal function - * 'dp83902a_recv' will be called to actually fetch it from the hardware. - */ -static void -dp83902a_RxEvent(void) -{ - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; - u8 *base = dp->base; - __maybe_unused u8 rsr; - u8 rcv_hdr[4]; - int i, len, pkt, cur; - - DEBUG_FUNCTION(); - - DP_IN(base, DP_RSR, rsr); - while (true) { - /* Read incoming packet header */ - DP_OUT(base, DP_CR, DP_CR_PAGE1 | DP_CR_NODMA | DP_CR_START); - DP_IN(base, DP_P1_CURP, cur); - DP_OUT(base, DP_P1_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); - DP_IN(base, DP_BNDRY, pkt); - - pkt += 1; - if (pkt == dp->rx_buf_end) - pkt = dp->rx_buf_start; - - if (pkt == cur) { - break; - } - DP_OUT(base, DP_RBCL, sizeof(rcv_hdr)); - DP_OUT(base, DP_RBCH, 0); - DP_OUT(base, DP_RSAL, 0); - DP_OUT(base, DP_RSAH, pkt); - if (dp->rx_next == pkt) { - if (cur == dp->rx_buf_start) - DP_OUT(base, DP_BNDRY, dp->rx_buf_end - 1); - else - DP_OUT(base, DP_BNDRY, cur - 1); /* Update pointer */ - return; - } - dp->rx_next = pkt; - DP_OUT(base, DP_ISR, DP_ISR_RDC); /* Clear end of DMA */ - DP_OUT(base, DP_CR, DP_CR_RDMA | DP_CR_START); -#ifdef CYGHWR_NS_DP83902A_PLF_BROKEN_RX_DMA - CYGACC_CALL_IF_DELAY_US(10); -#endif - - /* read header (get data size)*/ - for (i = 0; i < sizeof(rcv_hdr);) { - DP_IN_DATA(dp->data, rcv_hdr[i++]); - } - -#if DEBUG & 5 - printf("rx hdr %02x %02x %02x %02x\n", - rcv_hdr[0], rcv_hdr[1], rcv_hdr[2], rcv_hdr[3]); -#endif - len = ((rcv_hdr[3] << 8) | rcv_hdr[2]) - sizeof(rcv_hdr); - - /* data read */ - uboot_push_packet_len(len); - - if (rcv_hdr[1] == dp->rx_buf_start) - DP_OUT(base, DP_BNDRY, dp->rx_buf_end - 1); - else - DP_OUT(base, DP_BNDRY, rcv_hdr[1] - 1); /* Update pointer */ - } -} - -/* - * This function is called as a result of the "eth_drv_recv()" call above. - * It's job is to actually fetch data for a packet from the hardware once - * memory buffers have been allocated for the packet. Note that the buffers - * may come in pieces, using a scatter-gather list. This allows for more - * efficient processing in the upper layers of the stack. - */ -static void -dp83902a_recv(u8 *data, int len) -{ - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; - u8 *base = dp->base; - int i, mlen; - u8 saved_char = 0; - bool saved; -#if DEBUG & 4 - int dx; -#endif - - DEBUG_FUNCTION(); - -#if DEBUG & 5 - printf("Rx packet %d length %d\n", dp->rx_next, len); -#endif - - /* Read incoming packet data */ - DP_OUT(base, DP_CR, DP_CR_PAGE0 | DP_CR_NODMA | DP_CR_START); - DP_OUT(base, DP_RBCL, len & 0xFF); - DP_OUT(base, DP_RBCH, len >> 8); - DP_OUT(base, DP_RSAL, 4); /* Past header */ - DP_OUT(base, DP_RSAH, dp->rx_next); - DP_OUT(base, DP_ISR, DP_ISR_RDC); /* Clear end of DMA */ - DP_OUT(base, DP_CR, DP_CR_RDMA | DP_CR_START); -#ifdef CYGHWR_NS_DP83902A_PLF_BROKEN_RX_DMA - CYGACC_CALL_IF_DELAY_US(10); -#endif - - saved = false; - for (i = 0; i < 1; i++) { - if (data) { - mlen = len; -#if DEBUG & 4 - printf(" sg buf %08lx len %08x \n", (u32) data, mlen); - dx = 0; -#endif - while (0 < mlen) { - /* Saved byte from previous loop? */ - if (saved) { - *data++ = saved_char; - mlen--; - saved = false; - continue; - } - - { - u8 tmp; - DP_IN_DATA(dp->data, tmp); -#if DEBUG & 4 - printf(" %02x", tmp); - if (0 == (++dx % 16)) printf("\n "); -#endif - *data++ = tmp; - mlen--; - } - } -#if DEBUG & 4 - printf("\n"); -#endif - } - } -} - -static void -dp83902a_TxEvent(void) -{ - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; - u8 *base = dp->base; - __maybe_unused u8 tsr; - u32 key; - - DEBUG_FUNCTION(); - - DP_IN(base, DP_TSR, tsr); - if (dp->tx_int == 1) { - key = dp->tx1_key; - dp->tx1 = 0; - } else { - key = dp->tx2_key; - dp->tx2 = 0; - } - /* Start next packet if one is ready */ - dp->tx_started = false; - if (dp->tx1) { - dp83902a_start_xmit(dp->tx1, dp->tx1_len); - dp->tx_int = 1; - } else if (dp->tx2) { - dp83902a_start_xmit(dp->tx2, dp->tx2_len); - dp->tx_int = 2; - } else { - dp->tx_int = 0; - } - /* Tell higher level we sent this packet */ - uboot_push_tx_done(key, 0); -} - -/* - * Read the tally counters to clear them. Called in response to a CNT - * interrupt. - */ -static void -dp83902a_ClearCounters(void) -{ - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; - u8 *base = dp->base; - __maybe_unused u8 cnt1, cnt2, cnt3; - - DP_IN(base, DP_FER, cnt1); - DP_IN(base, DP_CER, cnt2); - DP_IN(base, DP_MISSED, cnt3); - DP_OUT(base, DP_ISR, DP_ISR_CNT); -} - -/* - * Deal with an overflow condition. This code follows the procedure set - * out in section 7.0 of the datasheet. - */ -static void -dp83902a_Overflow(void) -{ - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *)&nic; - u8 *base = dp->base; - u8 isr; - - /* Issue a stop command and wait 1.6ms for it to complete. */ - DP_OUT(base, DP_CR, DP_CR_STOP | DP_CR_NODMA); - CYGACC_CALL_IF_DELAY_US(1600); - - /* Clear the remote byte counter registers. */ - DP_OUT(base, DP_RBCL, 0); - DP_OUT(base, DP_RBCH, 0); - - /* Enter loopback mode while we clear the buffer. */ - DP_OUT(base, DP_TCR, DP_TCR_LOCAL); - DP_OUT(base, DP_CR, DP_CR_START | DP_CR_NODMA); - - /* - * Read in as many packets as we can and acknowledge any and receive - * interrupts. Since the buffer has overflowed, a receive event of - * some kind will have occurred. - */ - dp83902a_RxEvent(); - DP_OUT(base, DP_ISR, DP_ISR_RxP|DP_ISR_RxE); - - /* Clear the overflow condition and leave loopback mode. */ - DP_OUT(base, DP_ISR, DP_ISR_OFLW); - DP_OUT(base, DP_TCR, DP_TCR_NORMAL); - - /* - * If a transmit command was issued, but no transmit event has occurred, - * restart it here. - */ - DP_IN(base, DP_ISR, isr); - if (dp->tx_started && !(isr & (DP_ISR_TxP|DP_ISR_TxE))) { - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_TXPKT | DP_CR_START); - } -} - -static void -dp83902a_poll(void) -{ - struct dp83902a_priv_data *dp = (struct dp83902a_priv_data *) &nic; - u8 *base = dp->base; - u8 isr; - - DP_OUT(base, DP_CR, DP_CR_NODMA | DP_CR_PAGE0 | DP_CR_START); - DP_IN(base, DP_ISR, isr); - while (0 != isr) { - /* - * The CNT interrupt triggers when the MSB of one of the error - * counters is set. We don't much care about these counters, but - * we should read their values to reset them. - */ - if (isr & DP_ISR_CNT) { - dp83902a_ClearCounters(); - } - /* - * Check for overflow. It's a special case, since there's a - * particular procedure that must be followed to get back into - * a running state.a - */ - if (isr & DP_ISR_OFLW) { - dp83902a_Overflow(); - } else { - /* - * Other kinds of interrupts can be acknowledged simply by - * clearing the relevant bits of the ISR. Do that now, then - * handle the interrupts we care about. - */ - DP_OUT(base, DP_ISR, isr); /* Clear set bits */ - if (!dp->running) break; /* Is this necessary? */ - /* - * Check for tx_started on TX event since these may happen - * spuriously it seems. - */ - if (isr & (DP_ISR_TxP|DP_ISR_TxE) && dp->tx_started) { - dp83902a_TxEvent(); - } - if (isr & (DP_ISR_RxP|DP_ISR_RxE)) { - dp83902a_RxEvent(); - } - } - DP_IN(base, DP_ISR, isr); - } -} - - -/* U-Boot specific routines */ -static u8 *pbuf = NULL; - -static int pkey = -1; -static int initialized = 0; - -void uboot_push_packet_len(int len) { - PRINTK("pushed len = %d\n", len); - if (len >= 2000) { - printf("NE2000: packet too big\n"); - return; - } - dp83902a_recv(&pbuf[0], len); - - /*Just pass it to the upper layer*/ - net_process_received_packet(&pbuf[0], len); -} - -void uboot_push_tx_done(int key, int val) { - PRINTK("pushed key = %d\n", key); - pkey = key; -} - -/** - * Setup the driver and init MAC address according to doc/README.enetaddr - * Called by ne2k_register() before registering the driver @eth layer - * - * @param struct ethdevice of this instance of the driver for dev->enetaddr - * @return 0 on success, -1 on error (causing caller to print error msg) - */ -static int ne2k_setup_driver(struct eth_device *dev) -{ - PRINTK("### ne2k_setup_driver\n"); - - if (!pbuf) { - pbuf = malloc(2000); - if (!pbuf) { - printf("Cannot allocate rx buffer\n"); - return -1; - } - } - - nic.base = (u8 *) CONFIG_DRIVER_NE2000_BASE; - - nic.data = nic.base + DP_DATA; - nic.tx_buf1 = START_PG; - nic.tx_buf2 = START_PG2; - nic.rx_buf_start = RX_START; - nic.rx_buf_end = RX_END; - - /* - * According to doc/README.enetaddr, drivers shall give priority - * to the MAC address value in the environment, so we do not read - * it from the prom or eeprom if it is specified in the environment. - */ - if (!eth_env_get_enetaddr("ethaddr", dev->enetaddr)) { - /* If the MAC address is not in the environment, get it: */ - if (!get_prom(dev->enetaddr, nic.base)) /* get MAC from prom */ - dp83902a_init(dev->enetaddr); /* fallback: seeprom */ - /* And write it into the environment otherwise eth_write_hwaddr - * returns -1 due to eth_env_get_enetaddr_by_index() failing, - * and this causes "Warning: failed to set MAC address", and - * cmd_bdinfo has no ethaddr value which it can show: */ - eth_env_set_enetaddr("ethaddr", dev->enetaddr); - } - return 0; -} - -static int ne2k_init(struct eth_device *dev, struct bd_info *bd) -{ - dp83902a_start(dev->enetaddr); - initialized = 1; - return 0; -} - -static void ne2k_halt(struct eth_device *dev) -{ - debug("### ne2k_halt\n"); - if(initialized) - dp83902a_stop(); - initialized = 0; -} - -static int ne2k_recv(struct eth_device *dev) -{ - dp83902a_poll(); - return 1; -} - -static int ne2k_send(struct eth_device *dev, void *packet, int length) -{ - int tmo; - - debug("### ne2k_send\n"); - - pkey = -1; - - dp83902a_send((u8 *) packet, length, 666); - tmo = get_timer (0) + TOUT * CONFIG_SYS_HZ; - while(1) { - dp83902a_poll(); - if (pkey != -1) { - PRINTK("Packet sucesfully sent\n"); - return 0; - } - if (get_timer (0) >= tmo) { - printf("transmission error (timoeut)\n"); - return 0; - } - - } - return 0; -} - -/** - * Setup the driver for use and register it with the eth layer - * @return 0 on success, -1 on error (causing caller to print error msg) - */ -int ne2k_register(void) -{ - struct eth_device *dev; - - dev = calloc(sizeof(*dev), 1); - if (dev == NULL) - return -1; - - if (ne2k_setup_driver(dev)) - return -1; - - dev->init = ne2k_init; - dev->halt = ne2k_halt; - dev->send = ne2k_send; - dev->recv = ne2k_recv; - - strcpy(dev->name, "NE2000"); - - return eth_register(dev); -} diff --git a/drivers/net/ne2000_base.h b/drivers/net/ne2000_base.h deleted file mode 100644 index 2493608a5a64..000000000000 --- a/drivers/net/ne2000_base.h +++ /dev/null @@ -1,305 +0,0 @@ -/* -Ported to U-Boot by Christian Pellegrin chri@ascensit.com - -Based on sources from the Linux kernel (pcnet_cs.c, 8390.h) and -eCOS(if_dp83902a.c, if_dp83902a.h). Both of these 2 wonderful world -are GPL, so this is, of course, GPL. - - -========================================================================== - - dev/dp83902a.h - - National Semiconductor DP83902a ethernet chip - -========================================================================== -####ECOSGPLCOPYRIGHTBEGIN#### - ------------------------------------------- - This file is part of eCos, the Embedded Configurable Operating System. - Copyright (C) 1998, 1999, 2000, 2001, 2002 Red Hat, Inc. - - eCos is free software; you can redistribute it and/or modify it under - the terms of the GNU General Public License as published by the Free - Software Foundation; either version 2 or (at your option) any later version. - - eCos is distributed in the hope that it will be useful, but WITHOUT ANY - WARRANTY; without even the implied warranty of MERCHANTABILITY or - FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License - for more details. - - You should have received a copy of the GNU General Public License along - with eCos; if not, write to the Free Software Foundation, Inc., - 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA. - - As a special exception, if other files instantiate templates or use macros - or inline functions from this file, or you compile this file and link it - with other works to produce a work based on this file, this file does not - by itself cause the resulting work to be covered by the GNU General Public - License. However the source code for this file must still be made available - in accordance with section (3) of the GNU General Public License. - - This exception does not invalidate any other reasons why a work based on - this file might be covered by the GNU General Public License. - - Alternative licenses for eCos may be arranged by contacting Red Hat, Inc. - at http://sources.redhat.com/ecos/ecos-license/ - ------------------------------------------- -####ECOSGPLCOPYRIGHTEND#### -####BSDCOPYRIGHTBEGIN#### - - ------------------------------------------- - - Portions of this software may have been derived from OpenBSD or other sources, - and are covered by the appropriate copyright disclaimers included herein. - - ------------------------------------------- - -####BSDCOPYRIGHTEND#### -========================================================================== -#####DESCRIPTIONBEGIN#### - - Author(s): gthomas - Contributors: gthomas, jskov - Date: 2001-06-13 - Purpose: - Description: - -####DESCRIPTIONEND#### - -========================================================================== - -*/ - -/* - ------------------------------------------------------------------------ - Macros for accessing DP registers - These can be overridden by the platform header -*/ - -#ifndef __NE2000_BASE_H__ -#define __NE2000_BASE_H__ - -/* - * Debugging details - * - * Set to perms of: - * 0 disables all debug output - * 1 for process debug output - * 2 for added data IO output: get_reg, put_reg - * 4 for packet allocation/free output - * 8 for only startup status, so we can tell we're installed OK - */ -#if 0 -#define DEBUG 0xf -#else -#define DEBUG 0 -#endif - -#if DEBUG & 1 -#define DEBUG_FUNCTION() do { printf("%s\n", __FUNCTION__); } while (0) -#define DEBUG_LINE() do { printf("%d\n", __LINE__); } while (0) -#define PRINTK(args...) printf(args) -#else -#define DEBUG_FUNCTION() do {} while(0) -#define DEBUG_LINE() do {} while(0) -#define PRINTK(args...) -#endif - -/* timeout for tx/rx in s */ -#include <linux/delay.h> -#define TOUT 5 -/* Ether MAC address size */ -#define ETHER_ADDR_LEN 6 - - -#define CYGHWR_NS_DP83902A_PLF_BROKEN_TX_DMA 1 -#define CYGACC_CALL_IF_DELAY_US(X) udelay(X) - -/* H/W infomation struct */ -typedef struct hw_info_t { - u32 offset; - u8 a0, a1, a2; - u32 flags; -} hw_info_t; - -typedef struct dp83902a_priv_data { - u8* base; - u8* data; - u8* reset; - int tx_next; /* First free Tx page */ - int tx_int; /* Expecting interrupt from this buffer */ - int rx_next; /* First free Rx page */ - int tx1, tx2; /* Page numbers for Tx buffers */ - u32 tx1_key, tx2_key; /* Used to ack when packet sent */ - int tx1_len, tx2_len; - bool tx_started, running, hardwired_esa; - u8 esa[6]; - void* plf_priv; - - /* Buffer allocation */ - int tx_buf1, tx_buf2; - int rx_buf_start, rx_buf_end; -} dp83902a_priv_data_t; - -/* ------------------------------------------------------------------------ */ -/* Register offsets */ - -#define DP_CR 0x00 -#define DP_CLDA0 0x01 -#define DP_PSTART 0x01 /* write */ -#define DP_CLDA1 0x02 -#define DP_PSTOP 0x02 /* write */ -#define DP_BNDRY 0x03 -#define DP_TSR 0x04 -#define DP_TPSR 0x04 /* write */ -#define DP_NCR 0x05 -#define DP_TBCL 0x05 /* write */ -#define DP_FIFO 0x06 -#define DP_TBCH 0x06 /* write */ -#define DP_ISR 0x07 -#define DP_CRDA0 0x08 -#define DP_RSAL 0x08 /* write */ -#define DP_CRDA1 0x09 -#define DP_RSAH 0x09 /* write */ -#define DP_RBCL 0x0a /* write */ -#define DP_RBCH 0x0b /* write */ -#define DP_RSR 0x0c -#define DP_RCR 0x0c /* write */ -#define DP_FER 0x0d -#define DP_TCR 0x0d /* write */ -#define DP_CER 0x0e -#define DP_DCR 0x0e /* write */ -#define DP_MISSED 0x0f -#define DP_IMR 0x0f /* write */ -#define DP_DATAPORT 0x10 /* "eprom" data port */ - -#define DP_P1_CR 0x00 -#define DP_P1_PAR0 0x01 -#define DP_P1_PAR1 0x02 -#define DP_P1_PAR2 0x03 -#define DP_P1_PAR3 0x04 -#define DP_P1_PAR4 0x05 -#define DP_P1_PAR5 0x06 -#define DP_P1_CURP 0x07 -#define DP_P1_MAR0 0x08 -#define DP_P1_MAR1 0x09 -#define DP_P1_MAR2 0x0a -#define DP_P1_MAR3 0x0b -#define DP_P1_MAR4 0x0c -#define DP_P1_MAR5 0x0d -#define DP_P1_MAR6 0x0e -#define DP_P1_MAR7 0x0f - -#define DP_P2_CR 0x00 -#define DP_P2_PSTART 0x01 -#define DP_P2_CLDA0 0x01 /* write */ -#define DP_P2_PSTOP 0x02 -#define DP_P2_CLDA1 0x02 /* write */ -#define DP_P2_RNPP 0x03 -#define DP_P2_TPSR 0x04 -#define DP_P2_LNPP 0x05 -#define DP_P2_ACH 0x06 -#define DP_P2_ACL 0x07 -#define DP_P2_RCR 0x0c -#define DP_P2_TCR 0x0d -#define DP_P2_DCR 0x0e -#define DP_P2_IMR 0x0f - -/* Command register - common to all pages */ - -#define DP_CR_STOP 0x01 /* Stop: software reset */ -#define DP_CR_START 0x02 /* Start: initialize device */ -#define DP_CR_TXPKT 0x04 /* Transmit packet */ -#define DP_CR_RDMA 0x08 /* Read DMA (recv data from device) */ -#define DP_CR_WDMA 0x10 /* Write DMA (send data to device) */ -#define DP_CR_SEND 0x18 /* Send packet */ -#define DP_CR_NODMA 0x20 /* Remote (or no) DMA */ -#define DP_CR_PAGE0 0x00 /* Page select */ -#define DP_CR_PAGE1 0x40 -#define DP_CR_PAGE2 0x80 -#define DP_CR_PAGEMSK 0x3F /* Used to mask out page bits */ - -/* Data configuration register */ - -#define DP_DCR_WTS 0x01 /* 1=16 bit word transfers */ -#define DP_DCR_BOS 0x02 /* 1=Little Endian */ -#define DP_DCR_LAS 0x04 /* 1=Single 32 bit DMA mode */ -#define DP_DCR_LS 0x08 /* 1=normal mode, 0=loopback */ -#define DP_DCR_ARM 0x10 /* 0=no send command (program I/O) */ -#define DP_DCR_FIFO_1 0x00 /* FIFO threshold */ -#define DP_DCR_FIFO_2 0x20 -#define DP_DCR_FIFO_4 0x40 -#define DP_DCR_FIFO_6 0x60 - -#define DP_DCR_INIT (DP_DCR_LS|DP_DCR_FIFO_4) - -/* Interrupt status register */ - -#define DP_ISR_RxP 0x01 /* Packet received */ -#define DP_ISR_TxP 0x02 /* Packet transmitted */ -#define DP_ISR_RxE 0x04 /* Receive error */ -#define DP_ISR_TxE 0x08 /* Transmit error */ -#define DP_ISR_OFLW 0x10 /* Receive overflow */ -#define DP_ISR_CNT 0x20 /* Tally counters need emptying */ -#define DP_ISR_RDC 0x40 /* Remote DMA complete */ -#define DP_ISR_RESET 0x80 /* Device has reset (shutdown, error) */ - -/* Interrupt mask register */ - -#define DP_IMR_RxP 0x01 /* Packet received */ -#define DP_IMR_TxP 0x02 /* Packet transmitted */ -#define DP_IMR_RxE 0x04 /* Receive error */ -#define DP_IMR_TxE 0x08 /* Transmit error */ -#define DP_IMR_OFLW 0x10 /* Receive overflow */ -#define DP_IMR_CNT 0x20 /* Tall counters need emptying */ -#define DP_IMR_RDC 0x40 /* Remote DMA complete */ - -#define DP_IMR_All 0x3F /* Everything but remote DMA */ - -/* Receiver control register */ - -#define DP_RCR_SEP 0x01 /* Save bad(error) packets */ -#define DP_RCR_AR 0x02 /* Accept runt packets */ -#define DP_RCR_AB 0x04 /* Accept broadcast packets */ -#define DP_RCR_AM 0x08 /* Accept multicast packets */ -#define DP_RCR_PROM 0x10 /* Promiscuous mode */ -#define DP_RCR_MON 0x20 /* Monitor mode - 1=accept no packets */ - -/* Receiver status register */ - -#define DP_RSR_RxP 0x01 /* Packet received */ -#define DP_RSR_CRC 0x02 /* CRC error */ -#define DP_RSR_FRAME 0x04 /* Framing error */ -#define DP_RSR_FO 0x08 /* FIFO overrun */ -#define DP_RSR_MISS 0x10 /* Missed packet */ -#define DP_RSR_PHY 0x20 /* 0=pad match, 1=mad match */ -#define DP_RSR_DIS 0x40 /* Receiver disabled */ -#define DP_RSR_DFR 0x80 /* Receiver processing deferred */ - -/* Transmitter control register */ - -#define DP_TCR_NOCRC 0x01 /* 1=inhibit CRC */ -#define DP_TCR_NORMAL 0x00 /* Normal transmitter operation */ -#define DP_TCR_LOCAL 0x02 /* Internal NIC loopback */ -#define DP_TCR_INLOOP 0x04 /* Full internal loopback */ -#define DP_TCR_OUTLOOP 0x08 /* External loopback */ -#define DP_TCR_ATD 0x10 /* Auto transmit disable */ -#define DP_TCR_OFFSET 0x20 /* Collision offset adjust */ - -/* Transmit status register */ - -#define DP_TSR_TxP 0x01 /* Packet transmitted */ -#define DP_TSR_COL 0x04 /* Collision (at least one) */ -#define DP_TSR_ABT 0x08 /* Aborted because of too many collisions */ -#define DP_TSR_CRS 0x10 /* Lost carrier */ -#define DP_TSR_FU 0x20 /* FIFO underrun */ -#define DP_TSR_CDH 0x40 /* Collision Detect Heartbeat */ -#define DP_TSR_OWC 0x80 /* Collision outside normal window */ - -#define IEEE_8023_MAX_FRAME 1518 /* Largest possible ethernet frame */ -#define IEEE_8023_MIN_FRAME 64 /* Smallest possible ethernet frame */ - -/* Functions */ -int get_prom(u8* mac_addr, u8* base_addr); - -#endif /* __NE2000_BASE_H__ */
Am Dienstag, den 25.05.2021, 11:54 -0400 schrieb Tom Rini:
doc/README.ne2000 | 27 -- drivers/net/8390.h | 124 ------ drivers/net/Makefile | 1 - drivers/net/ne2000.c | 260 ------------- drivers/net/ne2000.h | 94 ----- drivers/net/ne2000_base.c | 792 ------------------------------------ -- drivers/net/ne2000_base.h | 305 --------------- 7 files changed, 1603 deletions(-) delete mode 100644 doc/README.ne2000 delete mode 100644 drivers/net/8390.h delete mode 100644 drivers/net/ne2000.c delete mode 100644 drivers/net/ne2000.h delete mode 100644 drivers/net/ne2000_base.c delete mode 100644 drivers/net/ne2000_base.h
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
There are still some references in config_whitelist.txt:
$ git grep -in ne2000 -- scripts/config_whitelist.txt scripts/config_whitelist.txt:303:CONFIG_DRIVER_NE2000 scripts/config_whitelist.txt:304:CONFIG_DRIVER_NE2000_BASE
Thanks. I often rebuild the whitelist and resync defconfigs, and don't post that. One of those is also testing now (I caught the driver since I rebuilt the whitelist, saw CONFIG_DRIVER_NE2000_BASE go away and wondered what else could go).
On Tue, May 25, 2021 at 04:59:55PM +0200, Daniel Schwierzeck wrote:
Hi Tom,
Daniel Schwierzeck
