[U-Boot] [PATCH v1 0/3] arm, at91: taurus board updates
This series enables THUMB mode in SPL for the taurus board. On this hw are 16k only for SPL code, so THUMB mode is needed, because we need to detect the nor flash on the spi bus. This is needed because we want to erase sector 0 of the spi nor flash if the recovery button is pressed in SPL.
Heiko Schocher (3): arm, arm926ejs: make thumb mode compileable arm, at91: enable thumb mode for taurus board in SPL taurus, spl: erase also spi flash if recovery button is pressed
arch/arm/cpu/arm926ejs/cpu.c | 2 ++ arch/arm/lib/cache.c | 2 ++ board/siemens/taurus/taurus.c | 24 +++++++++++++++--------- include/configs/taurus.h | 23 ++++++++++++++++++++++- 4 files changed, 41 insertions(+), 10 deletions(-)
in thumb mode compiler says for example for arch/arm/lib/cache-cp15.c when enabling CONFIG_SYS_THUMB_BUILD:
{standard input}: Assembler messages: {standard input}:373: Error: selected processor does not support Thumb mode `mrc p15,0,r4,c1,c0,0' {standard input}:416: Error: selected processor does not support Thumb mode `mcr p15,0,r3,c2,c0,0'
so, if caches are disabled, do not use this command on arm926ejs. used on at91 in SPL, to reduce size of SPL.
Signed-off-by: Heiko Schocher hs@denx.de
arch/arm/cpu/arm926ejs/cpu.c | 2 ++ arch/arm/lib/cache.c | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/arch/arm/cpu/arm926ejs/cpu.c b/arch/arm/cpu/arm926ejs/cpu.c index e37e87b..a90ce30 100644 --- a/arch/arm/cpu/arm926ejs/cpu.c +++ b/arch/arm/cpu/arm926ejs/cpu.c @@ -45,7 +45,9 @@ int cleanup_before_linux (void) /* flush I/D-cache */ static void cache_flush (void) { +#if !(defined(CONFIG_SYS_ICACHE_OFF) && defined(CONFIG_SYS_DCACHE_OFF)) unsigned long i = 0;
asm ("mcr p15, 0, %0, c7, c7, 0": :"r" (i)); +#endif } diff --git a/arch/arm/lib/cache.c b/arch/arm/lib/cache.c index 4e597a4..b016558 100644 --- a/arch/arm/lib/cache.c +++ b/arch/arm/lib/cache.c @@ -24,10 +24,12 @@ __weak void flush_cache(unsigned long start, unsigned long size) #endif /* CONFIG_ARM1136 */
#ifdef CONFIG_ARM926EJS +#if !(defined(CONFIG_SYS_ICACHE_OFF) && defined(CONFIG_SYS_DCACHE_OFF)) /* test and clean, page 2-23 of arm926ejs manual */ asm("0: mrc p15, 0, r15, c7, c10, 3\n\t" "bne 0b\n" : : : "memory"); /* disable write buffer as well (page 2-22) */ asm("mcr p15, 0, %0, c7, c10, 4" : : "r" (0)); +#endif #endif /* CONFIG_ARM926EJS */ return; }
Dear Heiko Schocher,
Heiko Schocher hs@denx.de writes:
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Signed-off-by: Heiko Schocher hs@denx.de ---
include/configs/taurus.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/configs/taurus.h b/include/configs/taurus.h index 20194ae..06725cd 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -26,6 +26,11 @@
#define CONFIG_SYS_GENERIC_BOARD
+#if defined(CONFIG_SPL_BUILD) +#define CONFIG_SYS_THUMB_BUILD +#define CONFIG_SYS_ICACHE_OFF +#define CONFIG_SYS_DCACHE_OFF +#endif /* * Warning: changing CONFIG_SYS_TEXT_BASE requires * adapting the initial boot program.
if in SPL mode recovery button is pressed, erase also spi flash from offset 0 to CONFIG_SYS_NAND_U_BOOT_SIZE on the taurus board.
board/siemens/taurus/taurus.c | 24 +++++++++++++++--------- include/configs/taurus.h | 18 +++++++++++++++++- 2 files changed, 32 insertions(+), 10 deletions(-)
diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index b8ff478..013dac2 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -68,6 +68,7 @@ static void taurus_nand_hw_init(void) #if defined(CONFIG_SPL_BUILD) #include <spl.h> #include <nand.h> +#include <spi_flash.h>
void matrix_init(void) { @@ -81,23 +82,28 @@ void matrix_init(void) void at91_spl_board_init(void) { taurus_nand_hw_init(); + at91_spi0_hw_init(TAURUS_SPI_MASK);
/* Configure recovery button PINs */ at91_set_gpio_input(AT91_PIN_PA31, 1);
/* check if button is pressed */ if (at91_get_gpio_value(AT91_PIN_PA31) == 0) { - u32 boot_device; + struct spi_flash *flash;
debug("Recovery button pressed\n"); - boot_device = spl_boot_device(); - switch (boot_device) { -#ifdef CONFIG_SPL_NAND_SUPPORT - case BOOT_DEVICE_NAND: - nand_init(); - spl_nand_erase_one(0, 0); - break; -#endif + nand_init(); + spl_nand_erase_one(0, 0); + flash = spi_flash_probe(CONFIG_SF_DEFAULT_BUS, + 0, + CONFIG_SF_DEFAULT_SPEED, + SPI_MODE_3); + if (!flash) { + puts("no flash\n"); + } else { + puts("erase spi flash sector 0\n"); + spi_flash_erase(flash, 0, + CONFIG_SYS_NAND_U_BOOT_SIZE); } } } diff --git a/include/configs/taurus.h b/include/configs/taurus.h index 06725cd..65468ad 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -142,6 +142,19 @@ #define TAURUS_SPI_MASK (1 << 4) #define TAURUS_SPI_CS_PIN AT91_PIN_PA3
+#if defined(CONFIG_SPL_BUILD) +/* SPL related */ +#undef CONFIG_SPL_OS_BOOT /* Not supported by existing map */ +#define CONFIG_SPL_SPI_SUPPORT +#define CONFIG_SPL_SPI_FLASH_SUPPORT +#define CONFIG_SPL_SPI_LOAD +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 + +#define CONFIG_SF_DEFAULT_BUS 0 +#define CONFIG_SF_DEFAULT_SPEED 10000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#endif + /* load address */ #define CONFIG_SYS_LOAD_ADDR 0x22000000
@@ -176,8 +189,11 @@ /* Defines for SPL */ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_TEXT_BASE 0x0 -#define CONFIG_SPL_MAX_SIZE (11 * 1024) +#define CONFIG_SPL_MAX_SIZE (14 * 1024) #define CONFIG_SPL_STACK (16 * 1024) +#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_TEXT_BASE - \ + CONFIG_SYS_MALLOC_LEN) +#define CONFIG_SYS_SPL_MALLOC_SIZE CONFIG_SYS_MALLOC_LEN
#define CONFIG_SPL_BSS_START_ADDR CONFIG_SPL_MAX_SIZE #define CONFIG_SPL_BSS_MAX_SIZE (3 * 1024)
Andreas Bießmann
Heiko Schocher
