[U-Boot] [PATCH 3/3] nds32: board: Support ftsdc010 DM.
Support Andestech ftsdc010 SD/MMC device tree flow on AG101P/AE3XX platforms.
Signed-off-by: rick rick@andestech.com --- board/AndesTech/adp-ae3xx/adp-ae3xx.c | 4 +--- board/AndesTech/adp-ag101p/adp-ag101p.c | 7 +------ configs/adp-ae3xx_defconfig | 5 +++++ configs/adp-ag101p_defconfig | 5 +++++ include/configs/adp-ae3xx.h | 1 - include/configs/adp-ag101p.h | 1 - 6 files changed, 12 insertions(+), 11 deletions(-)
diff --git a/board/AndesTech/adp-ae3xx/adp-ae3xx.c b/board/AndesTech/adp-ae3xx/adp-ae3xx.c index 98ed4d9..3903427 100644 --- a/board/AndesTech/adp-ae3xx/adp-ae3xx.c +++ b/board/AndesTech/adp-ae3xx/adp-ae3xx.c @@ -77,10 +77,8 @@ ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info)
int board_mmc_init(bd_t *bis) { -#ifndef CONFIG_DM_MMC -#ifdef CONFIG_FTSDC010 +#if defined(CONFIG_FTSDC010) && !defined(CONFIG_DM_MMC) ftsdc010_mmc_init(0); #endif -#endif return 0; } diff --git a/board/AndesTech/adp-ag101p/adp-ag101p.c b/board/AndesTech/adp-ag101p/adp-ag101p.c index a462941..826ba14 100644 --- a/board/AndesTech/adp-ag101p/adp-ag101p.c +++ b/board/AndesTech/adp-ag101p/adp-ag101p.c @@ -20,7 +20,6 @@ DECLARE_GLOBAL_DATA_PTR; /* * Miscellaneous platform dependent initializations */ - int board_init(void) { /* @@ -30,7 +29,6 @@ int board_init(void) printf("Board: %s\n" , CONFIG_SYS_BOARD); gd->bd->bi_arch_number = MACH_TYPE_ADPAG101P; gd->bd->bi_boot_params = PHYS_SDRAM_0 + 0x400; - return 0; }
@@ -39,11 +37,8 @@ int dram_init(void) unsigned long sdram_base = PHYS_SDRAM_0; unsigned long expected_size = PHYS_SDRAM_0_SIZE + PHYS_SDRAM_1_SIZE; unsigned long actual_size; - actual_size = get_ram_size((void *)sdram_base, expected_size); - gd->ram_size = actual_size; - if (expected_size != actual_size) { printf("Warning: Only %lu of %lu MiB SDRAM is working\n", actual_size >> 20, expected_size >> 20); @@ -83,7 +78,7 @@ ulong board_flash_get_legacy(ulong base, int banknum, flash_info_t *info)
int board_mmc_init(bd_t *bis) { -#ifdef CONFIG_FTSDC010 +#if defined(CONFIG_FTSDC010) && !defined(CONFIG_DM_MMC) ftsdc010_mmc_init(0); #endif return 0; diff --git a/configs/adp-ae3xx_defconfig b/configs/adp-ae3xx_defconfig index cbef412..d12f307 100644 --- a/configs/adp-ae3xx_defconfig +++ b/configs/adp-ae3xx_defconfig @@ -18,6 +18,11 @@ CONFIG_BAUDRATE=38400 CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_BLK=y +CONFIG_DM_MMC=y +CONFIG_DM_MMC_OPS=y +CONFIG_MMC_NDS32=y +CONFIG_FTSDC010=y CONFIG_MTD=y CONFIG_CFI_FLASH=y CONFIG_DM_ETH=y diff --git a/configs/adp-ag101p_defconfig b/configs/adp-ag101p_defconfig index 22b1182..85e2225 100644 --- a/configs/adp-ag101p_defconfig +++ b/configs/adp-ag101p_defconfig @@ -18,6 +18,11 @@ CONFIG_BAUDRATE=38400 CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y +CONFIG_BLK=y +CONFIG_DM_MMC=y +CONFIG_DM_MMC_OPS=y +CONFIG_MMC_NDS32=y +CONFIG_FTSDC010=y CONFIG_DM_ETH=y CONFIG_FTMAC100=y CONFIG_DM_SERIAL=y diff --git a/include/configs/adp-ae3xx.h b/include/configs/adp-ae3xx.h index 6bfc08e..011b2a8 100644 --- a/include/configs/adp-ae3xx.h +++ b/include/configs/adp-ae3xx.h @@ -92,7 +92,6 @@ /* * SD (MMC) controller */ -#define CONFIG_FTSDC010 #define CONFIG_FTSDC010_NUMBER 1 #define CONFIG_FTSDC010_SDIO
diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index 4cef64e..71a557b 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -98,7 +98,6 @@ /* * SD (MMC) controller */ -#define CONFIG_FTSDC010 #define CONFIG_FTSDC010_NUMBER 1 #define CONFIG_FTSDC010_SDIO
What's difference?
- Miscellaneous platform dependent initializations
This is not relevant to "support ftsdc010 DM".
return 0; }
Ditto.
Don't need to enable CONFIG_DM_MMC_OPS and CONFIG_BLK. when DM_MMC is enabled, they are enabled by default.
- SD (MMC) controller
Andes
Jaehoon Chung
