[U-Boot] [PATCH] ARM: disable HAVE_PRIVATE_LIBGCC for ARM64
We have not supported the private library for ARM 64bit. Prohibit ARM64 boards from enabling it until we make things ready.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Albert,
I think this patch is safe and possible for upcoming v2015.07 release. Please consider applying it.
arch/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/Kconfig b/arch/Kconfig index 96db5c5..afa1d6c 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -18,7 +18,7 @@ config ARC
config ARM bool "ARM architecture" - select HAVE_PRIVATE_LIBGCC + select HAVE_PRIVATE_LIBGCC if !ARM64 select HAVE_GENERIC_BOARD select SUPPORT_OF_CONTROL
Hello Masahiro,
On Fri, 3 Jul 2015 16:13:09 +0900, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Albert,
Seeing as this does not affect any aarch64 target, it is indeed safe, and it prevents selecting an option which is useless. Besides, we can always revisit this if and when some aarch64 target needs a private libgcc.
So:
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Masahiro Yamada
