[U-Boot-Users] MPC832xEMDS: ttyS0 output stops mid boot
Sorry about the cross posting, but I'm not sure which list I should send to....
I'm trying to boot an up-to-date kernel on my MPC8323E-MDS-PB board, but I the console output stops early on during the kernel boot.
I'm running the latest u-boot (git://www.denx.de/git/u-boot-mpc83xx.git) with its default environment. The kernel is built from Paulus' powerpc.git, after checking out tag 2.6.21-rc5. The dtb is build from arch/powerpc/boot/dts/mpc832x_mds.dts with the latest compiler (git://www.jdl.com/software/dtc.git).
Has anyone else been here before...? If so I'd appreciate any help you can offer.
TIA,
Alex
-------------------my ttyS0 output------------------ => => printenv bootcmd=setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off console=$consoledev,$baudrate $othbootargs;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr - $fdtaddr ramboot=setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr nfsboot=setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off console=$consoledev,$baudrate $othbootargs;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr - $fdtaddr bootdelay=6 baudrate=115200 loads_echo=1 ethaddr=00:04:9f:ef:03:01 eth1addr=00:04:9f:ef:03:02 loadaddr=200000 netdev=eth0 consoledev=ttyS0 ramdiskaddr=1000000 ramdiskfile=ramfs.83xx fdtaddr=400000 fdtfile=mpc832xemds.dtb stdin=serial stdout=serial stderr=serial ethact=FSL UEC0
Environment size: 979/8188 bytes => setenv ramdiskfile uRamdisk => setenv fdtfile mpc832x_mds.dtb => setenv bootfile uImage => setenv serverip 10.0.0.107 => setenv ipaddr 10.0.6.65 => run ramboot Using FSL UEC0 device TFTP from server 10.0.0.107; our IP address is 10.0.6.65 Filename 'uRamdisk'. Load address: 0x1000000 Loading: ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ################################################################# ########################################################### done Bytes transferred = 3296770 (324e02 hex) Using FSL UEC0 device TFTP from server 10.0.0.107; our IP address is 10.0.6.65 Filename 'uImage'. Load address: 0x200000 Loading: ################################################################# ################################################################# ################################################################# ########################################## done Bytes transferred = 1212615 (1280c7 hex) Using FSL UEC0 device TFTP from server 10.0.0.107; our IP address is 10.0.6.65 Filename 'mpc832x_mds.dtb'. Load address: 0x400000 Loading: ### done Bytes transferred = 12288 (3000 hex) ## Booting image at 00200000 ... Image Name: Linux-2.6.21-rc5 Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 1212551 Bytes = 1.2 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK ## Loading RAMDisk Image at 01000000 ... Image Name: uboot ext2 ramdisk rootfs Image Type: PowerPC Linux RAMDisk Image (gzip compressed) Data Size: 3296706 Bytes = 3.1 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Booting using flat device tree at 0x400000 Loading Ramdisk to 07c87000, end 07fabdc2 ... OK Using MPC832x MDS machine description Linux version 2.6.21-rc5 (ajz@zambia) (gcc version 3.4.3) #2 Thu May 3 16:42:54 BST 2007 Found initrd at 0xc7c87000:0xc7fabdc2 setup_arch: bootmem mpc832x_sys_setup_arch() Found MPC83xx PCI host bridge at 0x00000000e0008500. Firmware bus number: 0->0 arch: exit Zone PFN ranges: DMA 0 -> 32768 Normal 32768 -> 32768 early_node_map[1] active PFN ranges 0: 0 -> 32768 Built 1 zonelists. Total pages: 32512 Kernel command line: root=/dev/ram rw console=ttyS0,115200 IPIC (128 IRQ sources) at fddf3700 QEIC (64 IRQ sources) at fddf2080 PID hash table entries: 512 (order: 9, 2048 bytes)
For the record, I've just merged powerpc.git from kernel.org and it has started working now! Clearly this means it was a kernel issue rather than a bootloader issue.
Regards,
Alex
TIA,
Alex
Regards,
Alex
TIA,
Alex
Regards,
Alex
TIA,
Alex
Alex Zeffertt
