[U-Boot] [U-Boot, RFC] ext4fs: le32_to_cpu() used on a 16-bit field
Hi All,
U-Boot 2013.07-rc3 [ELDK 5.2.1 / ELDK 5.3]
Now I've started to use the new ext4 code. I need the "ext4write" command. Though there seems to be several problems with the ext2/ext4 code.
I am testing on an ml507 (PPC440, Big Endian). There are some cases where the a field is 16-bit but le32_to_cpu() is used. Some checks (ie eh_magic) fails to match even if I use a correctly ext4 formatted MMC/SD card.
Does these seem right? Or am I mistaken?
----- diff --git a/fs/ext4/ext4_common.c b/fs/ext4/ext4_common.c index 58880b4..22d4377 100644 --- a/fs/ext4/ext4_common.c +++ b/fs/ext4/ext4_common.c @@ -1429,7 +1429,7 @@ static struct ext4_extent_header *ext4fs_get_extent_block while (1) { index = (struct ext4_extent_idx *)(ext_block + 1);
- if (le32_to_cpu(ext_block->eh_magic) != EXT4_EXT_MAGIC) + if (le16_to_cpu(ext_block->eh_magic) != EXT4_EXT_MAGIC) return 0;
if (ext_block->eh_depth == 0) @@ -1437,14 +1437,14 @@ static struct ext4_extent_header *ext4fs_get_extent_block i = -1; do { i++; - if (i >= le32_to_cpu(ext_block->eh_entries)) + if (i >= le16_to_cpu(ext_block->eh_entries)) break; } while (fileblock > le32_to_cpu(index[i].ei_block));
if (--i < 0) return 0;
- block = le32_to_cpu(index[i].ei_leaf_hi); + block = le16_to_cpu(index[i].ei_leaf_hi); block = (block << 32) + le32_to_cpu(index[i].ei_leaf_lo);
if (ext4fs_devread(block << log2_blksz, 0, fs->blksz, buf)) @@ -1543,17 +1543,17 @@ long int read_allocated_block(struct ext2_inode *inode, int fileblock)
do { i++; - if (i >= le32_to_cpu(ext_block->eh_entries)) + if (i >= le16_to_cpu(ext_block->eh_entries)) break; } while (fileblock >= le32_to_cpu(extent[i].ee_block)); if (--i >= 0) { fileblock -= le32_to_cpu(extent[i].ee_block); - if (fileblock >= le32_to_cpu(extent[i].ee_len)) { + if (fileblock >= le16_to_cpu(extent[i].ee_len)) { free(buf); return 0; }
- start = le32_to_cpu(extent[i].ee_start_hi); + start = le16_to_cpu(extent[i].ee_start_hi); start = (start << 32) + le32_to_cpu(extent[i].ee_start_lo); free(buf); -----
(Sorry, I can't CC anyone directly as I'm using the gmane "post" interface)
All the best, Rommel
Hi Rommel,
Hi All,
The ext4 code at u-boot (especially ext4write) needs special attention.
It is on top of my list to refactor and clean up this code base (especially the ext4write command).
I would need to double check it (since I'm using only ext4load at my target board currently).
EXT4_EXT_MAGIC)
^^^^^ We had some problems with unaligned access to 16 bit values recently (when those start at 0x2). It was observed on our ARM Exynos4 based target.
break; } while (fileblock > le32_to_cpu(index[i].ei_block)); if (--i < 0) return 0;
block = (block << 32) +block = le16_to_cpu(index[i].ei_leaf_hi);
le32_to_cpu(index[i].ei_leaf_lo); if (ext4fs_devread(block << log2_blksz, 0, fs->blksz, buf)) @@ -1543,17 +1543,17 @@ long int read_allocated_block(struct ext2_inode *inode, int fileblock)
do { i++;
} while (fileblock >=if (i >= le16_to_cpu(ext_block->eh_entries)) break;
if (fileblock >=
if (fileblock >=
You can also CC ext4 u-boot's implementation authors.
On Tue, 16 Jul 2013 08:14:35 +0000 (UTC) Rommel Custodio sessyargc+uboot@gmail.com wrote,
Hi Rommel,
Hi All,
What kind of mailer program have you used to sent this e-mail? I receive following errors:
fatal: corrupt patch at line 111
I cannot apply this patch with either git am -3 or git apply.
Were you using git send-email?
+Tom
On Fri, Jul 19, 2013 at 1:03 AM, Lukasz Majewski l.majewski@samsung.comwrote:
Hi Rommel,
Hi All,
It seems like we should try to fix this before the release?
Hi all,
On 21.07.2013 06:32, Simon Glass wrote:
+Tom
Hi Rommel,
Hi All,
+1
I can confirm that reading ext4 extended header on BE machine (avr32) is broken. I'm currently on it to get it working by using Rommel's patch.
Regards
Andreas Bießmann
Hi!
This fixed ext4 on powerpc-based board. Thanks!
Tested-by: Pavel Machek pavel@denx.de
participants (5)
Andreas Bießmann
Lukasz Majewski
Pavel Machek
Rommel Custodio
