[U-Boot] env_mmc: Fix crashing bug encountered after enabling ARM relocation
The crash was occuring in env_relocate because it was being called prior to mmc_initialize. This patch moves the MMC initialization earlier in the init process.
This patch also cleans up the env_relocate_spec code in env_mmc.c
Developed jointly with Stefano Babic
Signed-off-by: Steve Sakoman steve.sakoman@linaro.org ---
diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index 5f2dfd0..0e2f129 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -779,6 +779,11 @@ void board_init_r (gd_t *id, ulong dest_addr) onenand_init(); #endif
+#ifdef CONFIG_GENERIC_MMC + puts ("MMC: "); + mmc_initialize (bd); +#endif + #ifdef CONFIG_HAS_DATAFLASH AT91F_DataflashInit(); dataflash_print_info(); @@ -854,11 +859,6 @@ extern void davinci_eth_set_mac_addr (const u_int8_t *addr); board_late_init (); #endif
-#ifdef CONFIG_GENERIC_MMC - puts ("MMC: "); - mmc_initialize (gd->bd); -#endif - #ifdef CONFIG_BITBANGMII bb_miiphy_init(); #endif diff --git a/common/env_mmc.c b/common/env_mmc.c index cc288d4..d443ff5 100644 --- a/common/env_mmc.c +++ b/common/env_mmc.c @@ -129,18 +129,21 @@ inline int read_env(struct mmc *mmc, unsigned long size, void env_relocate_spec(void) { #if !defined(ENV_IS_EMBEDDED) + char buf[CONFIG_ENV_SIZE]; + struct mmc *mmc = find_mmc_device(CONFIG_SYS_MMC_ENV_DEV);
- if (init_mmc_for_env(mmc)) + if (init_mmc_for_env(mmc)) { + use_default(); return; + }
- if (read_env(mmc, CONFIG_ENV_SIZE, CONFIG_ENV_OFFSET, env_ptr)) - return use_default(); - - if (crc32(0, env_ptr->data, ENV_SIZE) != env_ptr->crc) - return use_default(); + if (read_env(mmc, CONFIG_ENV_SIZE, CONFIG_ENV_OFFSET, buf)) { + use_default(); + return; + }
- gd->env_valid = 1; + env_import(buf, 1); #endif }
Fine; but is a Signed-off-by or Tested-by/Acked-by required from Stefano then?
Also this patch touch ARM and MMC code so can't add to u-boot-ti unless Wolfgang is ok.
puts ("MMC: ");
- puts ("MMC: ");
-#endif
- struct mmc *mmc = find_mmc_device(CONFIG_SYS_MMC_ENV_DEV);
- if (init_mmc_for_env(mmc)) {
return;use_default();
- if (read_env(mmc, CONFIG_ENV_SIZE, CONFIG_ENV_OFFSET, buf)) {
use_default();
return;
- env_import(buf, 1);
#endif }
Am 09.10.2010 23:49, schrieb Paulraj, Sandeep:
Steve can add my acked-by, as I discussed with him how to fix the issue.
Acked-by: Stefano Babic sbabic@denx.de
Agree. The patch touches both ARM code and common code, and Wolfgang is maintainer for both of them.
Stefano
Hello.
Signed-off-by: Steve Sakomansteve.sakoman@linaro.org
puts ("MMC: ");
This would cause checkpatch.pl to complain -- no spaces allowed before (.
WBR, Sergei
On Sun, Oct 10, 2010 at 4:46 AM, Sergei Shtylyov sshtylyov@mvista.com wrote:
Hello.
- puts ("MMC: ");
- mmc_initialize (bd);
I will resubmit a V2 with that change as well as Stefano's Signed-off-by
Steve
Hello.
puts ("MMC: ");
You've posted V2 with Stefano's ACK... and this line unchanged. :-)
Steve
WBR, Sergei
On Sun, Oct 10, 2010 at 7:52 AM, Sergei Shtylyov sshtylyov@mvista.com wrote:
Hello.
- puts ("MMC: ");
+#ifdef CONFIG_GENERIC_MMC + puts("MMC: "); + mmc_initialize (bd); +#endif +
It looks changed to me!
Steve
puts ("MMC: ");
puts("MMC: ");
Indeed, I have ovelooked that first line under #ifdef was changed. But not the second. ;-)
Steve
WBR, Sergei
puts ("MMC: ");
puts("MMC: ");
Sigh. You are correct!
I hate these older files that were done when "space before paren" was the rule. You have to be really careful when cutting and pasting, and even then you end up with a source file that is totally inconsistent in spacing unless you go and fix the entire file!
I will submit a v3.
Steve
participants (5)
Paulraj, Sandeep
Sergei Shtylyov
stefano babic
Steve Sakoman
Steve Sakoman
