[PATCH] arm: K3: j721e: Fix boot parameter table index memory address
The boot parameter table index memory address for J721E was configured to an incorrect value which prevented the use of this definition to determine which boot parameter table is active which is needed to be able to distinguish between primary and backup boot modes. Fix this issue by updating the value to the correct one also in alignment with the J721E Technical Reference Manual (TRM).
Signed-off-by: Andreas Dannenberg dannenberg@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/mach-k3/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index 2e111bbf27..8f4272286c 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -50,7 +50,7 @@ config SYS_K3_MCU_SCRATCHPAD_SIZE config SYS_K3_BOOT_PARAM_TABLE_INDEX hex default 0x41c7fbfc if SOC_K3_AM6 - default 0x41cffc00 if SOC_K3_J721E + default 0x41cffbfc if SOC_K3_J721E help Address at which ROM stores the value which determines if SPL is booted up by primary boot media or secondary boot media.
Merged into u-boot-ti.
Thanks and regards, Lokesh
Lokesh Vutla
