[U-Boot] [PATCH] armv8: ls1088a: Update MC boot sequence
This patch follows the work of previous commits: 5707dfb02e drivers: net: fsl-mc: Fixup MAC addresses in DPC 33a8991a87 drivers: net: fsl-mc: Link MC boot to PHY_RESET_R 1161dbcc0a drivers: net: fsl-mc: Include MAC addr fixup to DPL
Add support for LS1088 platforms, to make sure u-boot env MAC addresses are properly set in DPC / DPL.
Signed-off-by: Bogdan Purcareata bogdan.purcareata@nxp.com --- board/freescale/ls1088a/eth_ls1088aqds.c | 14 ++++++++------ board/freescale/ls1088a/eth_ls1088ardb.c | 13 ++++++++----- include/configs/ls1088a_common.h | 6 ++++++ 3 files changed, 22 insertions(+), 11 deletions(-)
diff --git a/board/freescale/ls1088a/eth_ls1088aqds.c b/board/freescale/ls1088a/eth_ls1088aqds.c index c19f59a..de70aee 100644 --- a/board/freescale/ls1088a/eth_ls1088aqds.c +++ b/board/freescale/ls1088a/eth_ls1088aqds.c @@ -14,14 +14,13 @@ #include <fm_eth.h> #include <i2c.h> #include <miiphy.h> +#include <fsl-mc/fsl_mc.h> #include <fsl-mc/ldpaa_wriop.h>
#include "../common/qixis.h"
#include "ls1088a_qixis.h"
-#define MC_BOOT_ENV_VAR "mcinitcmd" - #ifdef CONFIG_FSL_MC_ENET
#define SFP_TX 0 @@ -612,7 +611,6 @@ static void ls1088a_handle_phy_interface_rgmii(int dpmac_id) int board_eth_init(bd_t *bis) { int error = 0, i; - char *mc_boot_env_var; #ifdef CONFIG_FSL_MC_ENET struct memac_mdio_info *memac_mdio0_info; char *env_hwconfig = env_get("hwconfig"); @@ -655,9 +653,6 @@ int board_eth_init(bd_t *bis) } }
- mc_boot_env_var = env_get(MC_BOOT_ENV_VAR); - if (mc_boot_env_var) - run_command_list(mc_boot_env_var, -1, 0); error = cpu_eth_init(bis);
if (hwconfig_f("xqsgmii", env_hwconfig)) { @@ -681,3 +676,10 @@ int board_eth_init(bd_t *bis) error = pci_eth_init(bis); return error; } + +#if defined(CONFIG_RESET_PHY_R) +void reset_phy(void) +{ + mc_env_boot(); +} +#endif /* CONFIG_RESET_PHY_R */ diff --git a/board/freescale/ls1088a/eth_ls1088ardb.c b/board/freescale/ls1088a/eth_ls1088ardb.c index 853d815..97accc9 100644 --- a/board/freescale/ls1088a/eth_ls1088ardb.c +++ b/board/freescale/ls1088a/eth_ls1088ardb.c @@ -15,15 +15,14 @@ #include <asm/io.h> #include <exports.h> #include <asm/arch/fsl_serdes.h> +#include <fsl-mc/fsl_mc.h> #include <fsl-mc/ldpaa_wriop.h>
DECLARE_GLOBAL_DATA_PTR;
-#define MC_BOOT_ENV_VAR "mcinitcmd" int board_eth_init(bd_t *bis) { #if defined(CONFIG_FSL_MC_ENET) - char *mc_boot_env_var; int i, interface; struct memac_mdio_info mdio_info; struct mii_dev *dev; @@ -92,11 +91,15 @@ int board_eth_init(bd_t *bis) dev = miiphy_get_dev_by_name(DEFAULT_WRIOP_MDIO2_NAME); wriop_set_mdio(WRIOP1_DPMAC2, dev);
- mc_boot_env_var = env_get(MC_BOOT_ENV_VAR); - if (mc_boot_env_var) - run_command_list(mc_boot_env_var, -1, 0); cpu_eth_init(bis); #endif /* CONFIG_FMAN_ENET */
return pci_eth_init(bis); } + +#if defined(CONFIG_RESET_PHY_R) +void reset_phy(void) +{ + mc_env_boot(); +} +#endif /* CONFIG_RESET_PHY_R */ diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index 84e9b14..fa058f7 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -122,6 +122,12 @@ unsigned long long get_qixis_addr(void); #define CONFIG_SYS_LS_MC_DRAM_DPL_OFFSET 0x00F20000 #define CONFIG_SYS_LS_MC_AIOP_IMG_MAX_LENGTH 0x200000 #define CONFIG_SYS_LS_MC_DRAM_AIOP_IMG_OFFSET 0x07000000 + +/* Define phy_reset function to boot the MC based on mcinitcmd. + * This happens late enough to properly fixup u-boot env MAC addresses. + */ +#define CONFIG_RESET_PHY_R + /* * Carve out a DDR region which will not be used by u-boot/Linux *
These are not commit message. They belong to under the --- line under your signature.
This message doesn't match the change. You are removing mc_boot_env_var from qds and rdb files and replace it with a common function call to reset phy. You are not actually adding support for LS1088 platforms. Please revise your commit message.
York
Hello York,
-----Original Message----- From: York Sun Sent: Wednesday, October 04, 2017 8:22 PM To: Bogdan Purcareata bogdan.purcareata@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Ashish Kumar ashish.kumar@nxp.com; u- boot@lists.denx.de Subject: Re: [PATCH] armv8: ls1088a: Update MC boot sequence
I mentioned the patches to provide the overall context of the refactoring work.
I agree I was ambiguous there - I was referring to the support mentioned in the above patches.
I will send a v2 to incorporate your suggestions.
Thank you! Bogdan P.
Bogdan Purcareata
York Sun
