[PULL] u-boot-riscv/master
Hi Tom,
The following changes since commit 1311dd37ecf476be041d0452d4ee38619aadd5de:
Merge branch '2021-07-01-update-CI-containers' (2021-07-05 15:29:44 -0400)
git@source.denx.de:u-boot/custodians/u-boot-riscv.git
for you to fetch changes up to 4b4159d0f31ca3e0174ccfdce9a24a1fe3671829:
board: sifive: support spl multi-dtb on unmatched board (2021-07-06 20:24:26 +0800)
CI result shows no issue: https://source.denx.de/u-boot/custodians/u-boot-riscv/-/pipelines/8081
---------------------------------------------------------------- Dimitri John Ledkov (1): riscv: sifive: Set default fdtfile names
Green Wan (1): drivers: clk: sifive: fu740-prci: replace 'pciaux' with 'pcieaux'
Tianrui Wei (2): board: riscv: add openpiton-riscv64 SoC support mmc: openpiton: add piton_mmc driver
Zong Li (6): board: sifive: unmatched: add initial support for a platform ID EEPROM riscv: sifive: fu740: kconfig: Enable support for Opencores I2C controller riscv: sifive: fu740: Support i2c in spl board: sifive: Add an interface to get PCB revision riscv: dts: add dts for unmatched rev1 board: sifive: support spl multi-dtb on unmatched board
arch/riscv/Kconfig | 4 + arch/riscv/cpu/fu740/Kconfig | 3 + arch/riscv/dts/Makefile | 3 +- arch/riscv/dts/fu740-c000-u-boot.dtsi | 4 + .../dts/fu740-hifive-unmatched-a00-ddr-rev1.dtsi | 1489 ++++++++++++++++++++ .../dts/hifive-unmatched-a00-rev1-u-boot.dtsi | 7 + arch/riscv/dts/hifive-unmatched-a00-rev1.dts | 4 + arch/riscv/dts/openpiton-riscv64.dts | 153 ++ arch/riscv/include/asm/arch-fu740/eeprom.h | 15 + board/openpiton/riscv64/Kconfig | 40 + board/openpiton/riscv64/MAINTAINERS | 8 + board/openpiton/riscv64/Makefile | 5 + board/openpiton/riscv64/openpiton-riscv64.c | 33 + board/sifive/unmatched/Kconfig | 1 + board/sifive/unmatched/Makefile | 1 + .../sifive/unmatched/hifive-platform-i2c-eeprom.c | 574 ++++++++ board/sifive/unmatched/spl.c | 28 +- configs/openpiton_riscv64_defconfig | 76 + configs/openpiton_riscv64_spl_defconfig | 87 ++ configs/sifive_unleashed_defconfig | 1 + configs/sifive_unmatched_defconfig | 5 + doc/board/index.rst | 1 + doc/board/openpiton/index.rst | 9 + doc/board/openpiton/riscv64.rst | 376 +++++ drivers/clk/sifive/fu740-prci.c | 6 +- drivers/mmc/Kconfig | 9 + drivers/mmc/Makefile | 1 + drivers/mmc/piton_mmc.c | 161 +++ include/configs/openpiton-riscv64.h | 61 + include/configs/sifive-unleashed.h | 1 + include/configs/sifive-unmatched.h | 7 + 31 files changed, 3167 insertions(+), 6 deletions(-) create mode 100644 arch/riscv/dts/fu740-hifive-unmatched-a00-ddr-rev1.dtsi create mode 100644 arch/riscv/dts/hifive-unmatched-a00-rev1-u-boot.dtsi create mode 100644 arch/riscv/dts/hifive-unmatched-a00-rev1.dts create mode 100644 arch/riscv/dts/openpiton-riscv64.dts create mode 100644 arch/riscv/include/asm/arch-fu740/eeprom.h create mode 100644 board/openpiton/riscv64/Kconfig create mode 100644 board/openpiton/riscv64/MAINTAINERS create mode 100644 board/openpiton/riscv64/Makefile create mode 100644 board/openpiton/riscv64/openpiton-riscv64.c create mode 100644 board/sifive/unmatched/hifive-platform-i2c-eeprom.c create mode 100644 configs/openpiton_riscv64_defconfig create mode 100644 configs/openpiton_riscv64_spl_defconfig create mode 100644 doc/board/openpiton/index.rst create mode 100644 doc/board/openpiton/riscv64.rst create mode 100644 drivers/mmc/piton_mmc.c create mode 100644 include/configs/openpiton-riscv64.h
Best regards, Leo
On Wed, Jul 07, 2021 at 12:02:05AM +0800, Leo Liang wrote:
Hi Tom,
Please note: w+(openpiton_riscv64 openpiton_riscv64_spl) arch/riscv/dts/openpiton-riscv64.dtb: Warning (ranges_format): /soc:ranges: empty "ranges" property but its #address-cells (1) differs from / (2) w+(openpiton_riscv64 openpiton_riscv64_spl) arch/riscv/dts/openpiton-riscv64.dtb: Warning (ranges_format): /soc:ranges: empty "ranges" property but its #size-cells (1) differs from / (2)
need to be fixed in a follow up PR (and the relevant dts files should be added to the board MAINTAINER file too). That said, applied to u-boot/master, thanks!
Hi Tom, Leo,
Apologies for making that mistake, and many many thanks for merging our patches! We’ve already fixed the problem with another patch.
Many thanks, Tianrui
-----Original Message----- From: Tom Rini trini@konsulko.com Date: Wednesday, July 7, 2021 at 3:52 AM To: Leo Liang ycliang@andestech.com Cc: u-boot@lists.denx.de u-boot@lists.denx.de, rick@andestech.com rick@andestech.com, Tianrui Wei tianrui-wei@outlook.com Subject: Re: [PULL] u-boot-riscv/master On Wed, Jul 07, 2021 at 12:02:05AM +0800, Leo Liang wrote:
Hi Tom,
git@source.denx.demailto:git@source.denx.de:u-boot/custodians/u-boot-riscv.git
-- Tom
Leo Liang
Tianrui Wei
