[U-Boot] [PATCH] fixed #if chain and added AVR32 case in cmd_bdinfo.c
From: Reinhard Meyer info@emk-elektronik.de Date: Sun, 6 Jun 2010 19:01:59 +0200 Subject: [PATCH] fixed #if chain and added AVR32 case in cmd_bdinfo.c
AVR32 case was missing in cmd_bdinfo, resulting in compiler warning (bd->bi_baudrate declared unsigned int at AVR32, but printf used %d)
At the same time slightly reordered #if #elif #endif to make ARM one of the cases and not an extra case surrounding all others
Signed-off-by: Reinhard Meyer info@emk-elektronik.de --- common/cmd_bdinfo.c | 44 +++++++++++++++++++++++++++++++++++--------- 1 files changed, 35 insertions(+), 9 deletions(-)
diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index a0f7998..710abdf 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -37,8 +37,9 @@ static void print_eth(int idx);
#ifndef CONFIG_ARM /* PowerPC and other */ static void print_lnum(const char *, u64); +#endif
-#ifdef CONFIG_PPC +#if defined(CONFIG_PPC) static void print_str(const char *, const char *);
int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) @@ -119,7 +120,7 @@ int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 0; }
-#elif defined(CONFIG_NIOS2) /* Nios-II */ +#elif defined(CONFIG_NIOS2)
int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { @@ -145,7 +146,8 @@ int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
return 0; } -#elif defined(CONFIG_MICROBLAZE) /* ! PPC, which leaves Microblaze */ + +#elif defined(CONFIG_MICROBLAZE)
int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { @@ -167,7 +169,8 @@ int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 0; }
-#elif defined(CONFIG_SPARC) /* SPARC */ +#elif defined(CONFIG_SPARC) + int do_bdinfo(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) { bd_t *bd = gd->bd; @@ -199,7 +202,8 @@ int do_bdinfo(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) return 0; }
-#elif defined(CONFIG_M68K) /* M68K */ +#elif defined(CONFIG_M68K) + static void print_str(const char *, const char *);
int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) @@ -249,6 +253,7 @@ int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) }
#elif defined(CONFIG_BLACKFIN) + static void print_str(const char *, const char *);
int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) @@ -277,7 +282,7 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 0; }
-#else /* ! PPC, which leaves MIPS */ +#elif defined(CONFIG_MIPS)
int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { @@ -296,9 +301,28 @@ int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
return 0; } -#endif /* MIPS */
-#else /* ARM */ +#elif defined(CONFIG_AVR32) + +int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + bd_t *bd = gd->bd; + + print_num ("boot_params", (ulong)bd->bi_boot_params); + print_num ("memstart", (ulong)bd->bi_memstart); + print_lnum ("memsize", (u64)bd->bi_memsize); + print_num ("flashstart", (ulong)bd->bi_flashstart); + print_num ("flashsize", (ulong)bd->bi_flashsize); + print_num ("flashoffset", (ulong)bd->bi_flashoffset); + + print_eth(0); + printf ("ip_addr = %pI4\n", &bd->bi_ip_addr); + printf ("baudrate = %lu bps\n", bd->bi_baudrate); + + return 0; +} + +#elif defined(CONFIG_ARM)
int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { @@ -324,7 +348,9 @@ int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 0; }
-#endif /* CONFIG_ARM XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX */ +#else + #error "a case for this architecture does not exist!" +#endif
static void print_num(const char *name, ulong value) {
Am 11.06.2010 09:36, schrieb Reinhard Meyer:
Tested-by: Andreas Bießmann biessmann@corscience.de
Dear Reinhard Meyer,
In message 4C11E777.3060205@emk-elektronik.de you wrote:
This is a multi-part message in MIME format. --------------060008080708060407080307 Content-Type: text/plain; charset=ISO-8859-15 Content-Transfer-Encoding: 7bit
Applied to "next".
Andreas Bießmann
Reinhard Meyer
