[PATCH v2 1/4] misc: make CONFIG_IRQ selectable for all platforms
UCLASS_IRQ driver is not Intel specific. Make CONFIG_IRQ selectable for all platforms.
Signed-off-by: Wasim Khan wasim.khan@nxp.com Tested-by: Vladimir Oltean vladimir.oltean@nxp.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes in v2: - Corrected typo in commit description
drivers/misc/Kconfig | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 29432ae7eb..5eab1ed9c6 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -211,10 +211,9 @@ config FSL_SEC_MON like software violations or hardware security violations.
config IRQ - bool "Intel Interrupt controller" - depends on X86 || SANDBOX + bool "Interrupt controller" help - This enables support for Intel interrupt controllers, including ITSS. + This enables support for interrupt controllers, including ITSS. Some devices have extra features, such as Apollo Lake. The device has its own uclass since there are several operations involved.
GIC_V3_ITS uses UCLASS_IRQ driver. Update Kconfig to select IRQ when GIC_V3_ITS is enabled.
Signed-off-by: Wasim Khan wasim.khan@nxp.com Reviewed-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes in v2: - no change
arch/arm/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index fbe90875ae..f8b4d422d9 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -67,6 +67,7 @@ config GIC_V3_ITS bool "ARM GICV3 ITS" select REGMAP select SYSCON + select IRQ help ARM GICV3 Interrupt translation service (ITS). Basic support for programming locality specific peripheral
Needs this patch to actually work properly, so that should be accepted as well: https://patchwork.ozlabs.org/project/uboot/patch/20210305070235.13547-1-Zhiq...
Changes in v2:
- no change
- select IRQ help ARM GICV3 Interrupt translation service (ITS). Basic support for programming locality specific peripheral
-- 2.25.1
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Wasim Khan Sent: Monday, March 8, 2021 9:18 PM To: sjg@chromium.org; bmeng.cn@gmail.com; mario.six@gdsys.cc; bharat.gooty@broadcom.com; rayagonda.kokatanur@broadcom.com; t- kristo@ti.com; Varun Sethi V.Sethi@nxp.com Cc: u-boot@lists.denx.de; Wasim Khan wasim.khan@nxp.com; Z.q. Hou zhiqiang.hou@nxp.com Subject: [PATCH v2 2/4] arch: arm: update Kconfig to select IRQ when GIC_V3_ITS is enabled
Changes in v2:
- no change
-- 2.25.1
Reviewed-by: Priyanka Jain priyanka.jain@nxp.com
Tom,
Kindly help to merge this patch. This is required to fix boot issue on many of NXP fsl-qoriq platforms like lx2160ardb.
Thanks Priyanka
Signed-off-by: Wasim Khan wasim.khan@nxp.com Reviewed-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Vladimir Oltean vladimir.oltean@nxp.com
use 'select' to enable IRQ as it does not have architecture specific dependency.
arch/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/Kconfig b/arch/Kconfig index 3aa99e08fc..362b220948 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -167,6 +167,7 @@ config X86 select TIMER select USE_PRIVATE_LIBGCC select X86_TSC_TIMER + select IRQ imply HAS_ROM if X86_RESET_VECTOR imply BLK imply CMD_DM @@ -197,7 +198,6 @@ config X86 imply USB_HOST_ETHER imply PCH imply RTC_MC146818 - imply IRQ imply ACPIGEN if !QEMU imply SYSINFO if GENERATE_SMBIOS_TABLE imply SYSINFO_SMBIOS if GENERATE_SMBIOS_TABLE
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Wasim Khan Sent: Monday, March 8, 2021 9:18 PM To: sjg@chromium.org; bmeng.cn@gmail.com; mario.six@gdsys.cc; bharat.gooty@broadcom.com; rayagonda.kokatanur@broadcom.com; t- kristo@ti.com; Varun Sethi V.Sethi@nxp.com Cc: u-boot@lists.denx.de; Wasim Khan wasim.khan@nxp.com; Z.q. Hou zhiqiang.hou@nxp.com Subject: [PATCH v2 3/4] arch: Kconfig: enable IRQ using select for x86 architecture
Changes in v2:
- no change
- select IRQ imply HAS_ROM if X86_RESET_VECTOR imply BLK imply CMD_DM
-- 2.25.1
Tom,
Thanks Priyanka
Enable IRQ using select for sandbox architecture.
Signed-off-by: Wasim Khan wasim.khan@nxp.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes in v2: - no change
arch/Kconfig | 1 + configs/sandbox64_defconfig | 1 - configs/sandbox_defconfig | 1 - configs/sandbox_flattree_defconfig | 1 - configs/sandbox_spl_defconfig | 1 - 5 files changed, 1 insertion(+), 4 deletions(-)
diff --git a/arch/Kconfig b/arch/Kconfig index 362b220948..336a5a68ef 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -109,6 +109,7 @@ config SANDBOX select SPI select SUPPORT_OF_CONTROL select SYSRESET_CMD_POWEROFF + select IRQ imply BITREVERSE select BLOBLIST imply CMD_DM diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 5fbbfd7236..534f58f868 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -133,7 +133,6 @@ CONFIG_CROS_EC_I2C=y CONFIG_CROS_EC_LPC=y CONFIG_CROS_EC_SANDBOX=y CONFIG_CROS_EC_SPI=y -CONFIG_IRQ=y CONFIG_P2SB=y CONFIG_PWRSEQ=y CONFIG_SPL_PWRSEQ=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index f1ec701a9f..56f83695e0 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -160,7 +160,6 @@ CONFIG_CROS_EC_I2C=y CONFIG_CROS_EC_LPC=y CONFIG_CROS_EC_SANDBOX=y CONFIG_CROS_EC_SPI=y -CONFIG_IRQ=y CONFIG_P2SB=y CONFIG_PWRSEQ=y CONFIG_SPL_PWRSEQ=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index edca7f1808..8098d652dc 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -114,7 +114,6 @@ CONFIG_CROS_EC_I2C=y CONFIG_CROS_EC_LPC=y CONFIG_CROS_EC_SANDBOX=y CONFIG_CROS_EC_SPI=y -CONFIG_IRQ=y CONFIG_P2SB=y CONFIG_PWRSEQ=y CONFIG_SPL_PWRSEQ=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 479f0226e3..0afb0bec34 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -134,7 +134,6 @@ CONFIG_CROS_EC_I2C=y CONFIG_CROS_EC_LPC=y CONFIG_CROS_EC_SANDBOX=y CONFIG_CROS_EC_SPI=y -CONFIG_IRQ=y CONFIG_P2SB=y CONFIG_PWRSEQ=y CONFIG_SPL_PWRSEQ=y
Hi Wasim,
Changes in v2:
- no change
You can see the status of your series here:
http://patchwork.ozlabs.org/project/uboot/list/?series=232773
It is assigned to Tom Rini.
Hi Tom,
-----Original Message----- From: Simon Glass sjg@chromium.org Sent: Tuesday, March 30, 2021 10:27 PM To: Wasim Khan (OSS) wasim.khan@oss.nxp.com Cc: Bin Meng bmeng.cn@gmail.com; Mario Six mario.six@gdsys.cc; Bharat Gooty bharat.gooty@broadcom.com; Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com; Tero Kristo t-kristo@ti.com; Varun Sethi V.Sethi@nxp.com; U-Boot Mailing List u-boot@lists.denx.de; Wasim Khan wasim.khan@nxp.com Subject: Re: [PATCH v2 4/4] sandbox: enable IRQ using select for sandbox architecture
Hi Wasim,
Changes in v2:
- no change
https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fpatchwor k.ozlabs.org%2Fproject%2Fuboot%2Flist%2F%3Fseries%3D232773&data=0 4%7C01%7Cwasim.khan%40nxp.com%7Cbabc6763976e4d9c257808d8f39cd77b %7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C637527202242089410 %7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJB TiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=cmOzxfmhlIdP6A0G1P%2 BAXg%2FhPVky02%2BeUEMxd5y1bHs%3D&reserved=0
https://patchwork.ozlabs.org/project/uboot/list/?series=232773 this series is tested, reviewed. It can be merged after https://patchwork.ozlabs.org/project/uboot/patch/20210305070235.13547-1-Zhiq...
Kindly do the needful
Regards, Wasim
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Wasim Khan (OSS) Sent: Friday, April 16, 2021 1:52 PM To: Tom Rini trini@konsulko.com; Simon Glass sjg@chromium.org Cc: u-boot@lists.denx.de Subject: RE: [PATCH v2 4/4] sandbox: enable IRQ using select for sandbox architecture
Hi Tom,
Hi Wasim,
Changes in v2:
- no change
https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fpatch wor
k.ozlabs.org%2Fproject%2Fuboot%2Flist%2F%3Fseries%3D232773&data =0
0
LCJB
TiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=cmOzxfmhlIdP6A0G1P% 2
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatch work.ozlabs.org%2Fproject%2Fuboot%2Flist%2F%3Fseries%3D232773&d ata=04%7C01%7Cpriyanka.jain%40nxp.com%7C7a5eea075a364cc3863d08d900 b0b077%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C6375415811448 67361%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2lu MzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=ZBoZ4dxhQBW cFuR3E5zE0fQVb55e%2BxbWWxnFgyo411s%3D&reserved=0 this series is tested, reviewed. It can be merged after https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatch work.ozlabs.org%2Fproject%2Fuboot%2Fpatch%2F20210305070235.13547-1- Zhiqiang.Hou%40nxp.com%2F&data=04%7C01%7Cpriyanka.jain%40nxp.c om%7C7a5eea075a364cc3863d08d900b0b077%7C686ea1d3bc2b4c6fa92cd99c5 c301635%7C0%7C0%7C637541581144867361%7CUnknown%7CTWFpbGZsb3d8 eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D %7C1000&sdata=%2FidlO6hAGlxGD1cO2fA5cQORDIorCY%2FPq%2FQkZQ 4pEm0%3D&reserved=0
Regards, Wasim
Tom,
Thanks Priyanka
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Wasim Khan Sent: Monday, March 8, 2021 9:18 PM To: sjg@chromium.org; bmeng.cn@gmail.com; mario.six@gdsys.cc; bharat.gooty@broadcom.com; rayagonda.kokatanur@broadcom.com; t- kristo@ti.com; Varun Sethi V.Sethi@nxp.com Cc: u-boot@lists.denx.de; Wasim Khan wasim.khan@nxp.com; Vladimir Oltean vladimir.oltean@nxp.com Subject: [PATCH v2 1/4] misc: make CONFIG_IRQ selectable for all platforms
Changes in v2:
config IRQ
- bool "Interrupt controller" help
Some devices have extra features, such as Apollo Lake. The device has its own uclass since there are several operations involved.This enables support for interrupt controllers, including ITSS.
-- 2.25.1
Tom,
Thanks Priyanka
participants (6)
Priyanka Jain
Vladimir Oltean
Wasim Khan
Wasim Khan (OSS)
