[U-Boot] [PATCH v3 0/2] Generic firmware loader
This patchset contains generic firmware loader which is very close to Linux firmware loader but for U-Boot framework. Generic firmware loader can be used load whatever into target location, and then consumer driver would use it to program whatever, ie. the FPGA. This version mainly resolved comments from Lothar Waßmann in [v2].
This series is working on top of u-boot.git - http://git.denx.de/u-boot.git .
[v2]: https://www.mail-archive.com/u-boot@lists.denx.de/msg271979.html
v2 -> v3 changes: ----------------- - Fixed the bugs in generic firmware loader driver.
Patchset history ---------------- [v1]: https://www.mail-archive.com/u-boot@lists.denx.de/msg271905.html
Tien Fong Chee (2): spl: Remove static declaration on spl_mmc_find_device function common: Generic firmware loader for file system
common/Makefile | 1 + common/fs_loader.c | 305 +++++++++++++++++++++++++++++++++++++++++++++++++++ common/spl/spl_mmc.c | 2 +- include/fs_loader.h | 33 ++++++ include/spl.h | 2 + 5 files changed, 342 insertions(+), 1 deletion(-) create mode 100644 common/fs_loader.c create mode 100644 include/fs_loader.h
This patch removes the static declation on spl_mmc_find_device_function so this function is accessible by the caller from other file. This patch is required for later patch.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- common/spl/spl_mmc.c | 2 +- include/spl.h | 2 ++ 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index b57e0b0..183d05a 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -114,7 +114,7 @@ static int spl_mmc_get_device_index(u32 boot_device) return -ENODEV; }
-static int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device) +int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device) { #if CONFIG_IS_ENABLED(DM_MMC) struct udevice *dev; diff --git a/include/spl.h b/include/spl.h index 308ce7b..912983a 100644 --- a/include/spl.h +++ b/include/spl.h @@ -10,6 +10,7 @@ /* Platform-specific defines */ #include <linux/compiler.h> #include <asm/spl.h> +#include <mmc.h>
/* Value in r0 indicates we booted from U-Boot */ #define UBOOT_NOT_LOADED_FROM_SPL 0x13578642 @@ -72,6 +73,7 @@ void preloader_console_init(void); u32 spl_boot_device(void); u32 spl_boot_mode(const u32 boot_device); void spl_set_bd(void); +int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device);
/** * spl_set_header_raw_uboot() - Set up a standard SPL image structure
This is file system generic loader which can be used to load the file image from the storage into target such as memory. The consumer driver would then use this loader to program whatever, ie. the FPGA device.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- common/Makefile | 1 + common/fs_loader.c | 305 ++++++++++++++++++++++++++++++++++++++++++++++++++++ include/fs_loader.h | 33 ++++++ 3 files changed, 339 insertions(+) create mode 100644 common/fs_loader.c create mode 100644 include/fs_loader.h
diff --git a/common/Makefile b/common/Makefile index cec506f..2934221 100644 --- a/common/Makefile +++ b/common/Makefile @@ -130,3 +130,4 @@ obj-$(CONFIG_CMD_DFU) += dfu.o obj-y += command.o obj-y += s_record.o obj-y += xyzModem.o +obj-y += fs_loader.o diff --git a/common/fs_loader.c b/common/fs_loader.c new file mode 100644 index 0000000..59214d6 --- /dev/null +++ b/common/fs_loader.c @@ -0,0 +1,305 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <errno.h> +#include <fs.h> +#include <fs_loader.h> +#include <nand.h> +#include <sata.h> +#include <spi.h> +#include <spi_flash.h> +#include <spl.h> +#include <linux/string.h> +#include <usb.h> + +static struct device_location default_locations[] = { + { + .name = "mmc", + .devpart = "0:1", + }, + { + .name = "usb", + .devpart = "0:1", + }, + { + .name = "sata", + .devpart = "0:1", + }, +}; + +/* USB build is not supported yet in SPL */ +#ifndef CONFIG_SPL_BUILD +#ifdef CONFIG_USB_STORAGE +static int init_usb(void) +{ + int err; + + err = usb_init(); + if (err) + return err; + +#ifndef CONFIG_DM_USB + err = usb_stor_scan(1) < 0 ? -ENODEV : 0; +#endif + + return err; +} +#else +static int init_usb(void) +{ + printf("Error: Cannot load flash image: no USB support\n"); + return -ENOSYS; +} +#endif +#endif + +#ifdef CONFIG_SATA +static int init_storage_sata(void) +{ + return sata_probe(0); +} +#else +static int init_storage_sata(void) +{ + printf("Error: Cannot load image: no SATA support\n"); + return -ENOSYS; +} +#endif + +#ifdef CONFIG_CMD_UBIFS +static int mount_ubifs(struct device_location *location) +{ + int ret; + char cmd[32]; + + sprintf(cmd, "ubi part %s", location->mtdpart); + + ret = run_command(cmd, 0); + if (ret) + return ret; + + sprintf(cmd, "ubifsmount %s", location->ubivol); + + ret = run_command(cmd, 0); + + return ret; +} + +static int umount_ubifs(void) +{ + return run_command("ubifsumount", 0); +} +#else +static int mount_ubifs(struct device_location *location) +{ + printf("Error: Cannot load image: no UBIFS support\n"); + return -ENOSYS; +} +#endif + +#if defined(CONFIG_SPL_MMC_SUPPORT) && defined(CONFIG_SPL_BUILD) +static int init_mmc(void) +{ + /* Just for the case MMC is not yet initialized */ + struct mmc *mmc = NULL; + int err; + + spl_mmc_find_device(&mmc, spl_boot_device()); + + err = mmc_init(mmc); + if (err) { + printf("spl: mmc init failed with error: %d\n", err); + return err; + } + + return err; +} +#else +static int init_mmc(void) +{ + /* Expect somewhere already initialize MMC */ + return 0; +} +#endif + +static int select_fs_dev(struct device_location *location) +{ + int ret; + + if (!strcmp("mmc", location->name)) { + ret = fs_set_blk_dev("mmc", location->devpart, FS_TYPE_ANY); + } else if (!strcmp("usb", location->name)) { + ret = fs_set_blk_dev("usb", location->devpart, FS_TYPE_ANY); + } else if (!strcmp("sata", location->name)) { + ret = fs_set_blk_dev("sata", location->devpart, FS_TYPE_ANY); + } else if (!strcmp("ubi", location->name)) { + if (location->ubivol != NULL) + ret = fs_set_blk_dev("ubi", NULL, FS_TYPE_UBIFS); + else + ret = -ENODEV; + } else { + printf("Error: unsupported location storage.\n"); + return -ENODEV; + } + + if (ret) + printf("Error: could not access storage.\n"); + + return ret; +} + +static int init_storage_device(struct device_location *location) +{ + int ret; + + if (!strcmp("mmc", location->name)) { + ret = init_mmc(); + } else if (!strcmp("sata", location->name)) { + ret = init_storage_sata(); + } else if (location->ubivol != NULL) { + ret = mount_ubifs(location); +#ifndef CONFIG_SPL_BUILD + /* USB build is not supported yet in SPL */ + } else if (!strcmp("usb", location->name)) { + ret = init_usb(); +#endif + } else { + printf("Error: no supported storage device is available.\n"); + ret = -ENODEV; + } + + return ret; +} + +static void set_storage_devpart(char *name, char *devpart) +{ + size_t i; + + for (i = 0; i < ARRAY_SIZE(default_locations); i++) { + if (!strcmp(default_locations[i].name, name)) + default_locations[i].devpart = devpart; + } +} + +/* + * Prepare firmware struct; + * return -ve if fail. + */ +static int _request_firmware_prepare(struct firmware **firmware_p, + const char *name, void *dbuf, + size_t size, u32 offset) +{ + struct firmware *firmware = NULL; + struct firmware_priv *fw_priv = NULL; + + *firmware_p = NULL; + + if (!name || name[0] == '\0') + return -EINVAL; + + *firmware_p = firmware = calloc(1, sizeof(*firmware)); + + if (!firmware) { + printf("%s: calloc(struct firmware) failed\n", __func__); + return -ENOMEM; + } + + fw_priv = calloc(1, sizeof(*fw_priv)); + + if (!fw_priv) { + printf("%s: calloc(struct fw_priv) failed\n", __func__); + return -ENOMEM; + } + + fw_priv->name = name; + fw_priv->offset = offset; + firmware->data = dbuf; + firmware->size = size; + firmware->priv = fw_priv; + + return 0; +} + +/* + * fw_get_filesystem_firmware - load firmware into an allocated buffer + * @firmware_p: pointer to firmware image + * @location: An array of supported firmware location + * + * @return: size of total read + * -ve when error + */ +static int fw_get_filesystem_firmware(struct device_location *location, + struct firmware *firmware_p) +{ + struct firmware_priv *fw_priv = NULL; + loff_t actread; + char *dev_part; + int ret; + + dev_part = env_get("FW_DEV_PART"); + if (dev_part) + set_storage_devpart(location->name, dev_part); + + ret = init_storage_device(location); + if (ret) + goto out; + + select_fs_dev(location); + if (ret) + goto out; + + fw_priv = (struct firmware_priv *)firmware_p->priv; + + ret = fs_read(fw_priv->name, (ulong)firmware_p->data, fw_priv->offset, + firmware_p->size, &actread); + + if (ret || (actread != firmware_p->size)) { + printf("Error: %d Failed to read %s from flash %lld != %d.\n", + ret, fw_priv->name, actread, firmware_p->size); + return -EPERM; + } else { + ret = actread; + } + +out: +#ifdef CONFIG_CMD_UBIFS + if (location->ubivol != NULL) + umount_ubifs(); +#endif + + return ret; +} + +/* + * request_firmware_into_buf - load firmware into a previously allocated buffer + * @firmware_p: pointer to firmware image + * @name: name of firmware file + * @buf: address of buffer to load firmware into + * @size: size of buffer + * @offset: offset of a file for start reading + * + * This firmware is loaded directly into the buffer pointed to by @buf and + * the @firmware_p data member is pointed at @buf. + * + * @return: size of total read + * -ve when error + */ +int request_firmware_into_buf(struct firmware **firmware_p, + const char *name, + struct device_location *location, + void *buf, size_t size, u32 offset) +{ + int ret; + + ret = _request_firmware_prepare(firmware_p, name, buf, size, offset); + if (ret < 0) /* error */ + return ret; + + ret = fw_get_filesystem_firmware(location, *firmware_p); + + return ret; +} diff --git a/include/fs_loader.h b/include/fs_loader.h new file mode 100644 index 0000000..35a6b5b --- /dev/null +++ b/include/fs_loader.h @@ -0,0 +1,33 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ +#ifndef _FS_LOADER_H_ +#define _FS_LOADER_H_ + +#include <linux/types.h> + +struct firmware_priv { + const char *name; /* Filename */ + u32 offset; /* Offset of reading a file */ +}; + +struct firmware { + size_t size; /* Size of a file */ + const u8 *data; /* Buffer for file */ + void *priv; /* Firmware loader private fields */ +}; + +struct device_location { + char *name; /* Such as mmc, usb,and sata. */ + char *devpart; /* Use the load command dev:part conventions */ + char *mtdpart; /* MTD partition for ubi part */ + char *ubivol; /* UBI volume-name for ubifsmount */ +}; + +int request_firmware_into_buf(struct firmware **firmware_p, + const char *name, + struct device_location *location, + void *buf, size_t size, u32 offset); +#endif
- Copyright (C) 2017 Intel Corporation <www.intel.com>
- SPDX-License-Identifier: GPL-2.0
- const char *name; /* Filename */
- u32 offset; /* Offset of reading a file */
This is private to the firmware loader and should be declared locally in the source file. That's the whole point of being 'private'. You could have different firmware loaders with different requirements for their private data, thus there is no use in defining this globally.
+struct firmware {
- size_t size; /* Size of a file */
- const u8 *data; /* Buffer for file */
- void *priv; /* Firmware loader private fields */
Lothar Waßmann
Okay, i will move this declaration to source file. Any comments to the source file?
+struct firmware {
fields */ +};
Lothar Waßmann
Dear Tien,
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of tien.fong.chee@intel.com Sent: Tuesday, December 12, 2017 5:26 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Tien Fong Chee tien.fong.chee@intel.com; Ching Liang See chin.liang.see@intel.com; Tien Fong skywindctf@gmail.com; Westergteen Dalon dalon.westergreen@intel.com Subject: [U-Boot] [PATCH v3 2/2] common: Generic firmware loader for file system
A README about how to use this feature in u-boot will be very helpful.
--pk
Hi Tien,
Dear Tien,
+1
--pk _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
On Rab, 2017-12-13 at 11:55 +0100, Lukasz Majewski wrote:
Hi Tien,
Dear Tien,
+1
Okay, i will send out the initial draft documents separately for discussion.
Lukasz Majewski
v2 -> v3 changes:
Patchset history
I thought we discussed resending patchsets multiple times a day already, didn't we ?
tml
v2 -> v3 changes:
Patchset history
tml
Sorry, i will kepp it slow down.
participants (6)
Chee, Tien Fong
Lothar Waßmann
Lukasz Majewski
Prabhakar Kushwaha
