Hi Peng,
Just noticed that mx6ulevk is not booting with latest U-boot:
U-Boot SPL 2016.01-rc1-00078-g736d174 (Nov 19 2015 - 13:45:19) Trying to boot from MMC spl: mmc block read error SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ###
I haven't had a chance to investigate/debug this yet.
Could you please take a look?
Regards,
Fabio Estevam
On Thu, Nov 19, 2015 at 1:58 PM, Fabio Estevam festevam@gmail.com wrote:
Hi Peng,
Looks like I cannot boot using my SanDisk micro SD card. I changed the SD card and now it boots.
Regards,
Fabio Estevam
Hi Fabio,
Hi Peng,
I can confirm you this weirdness. It depends on the SD Card, I have seen the same on a iMX6 Dual. It does not boot with industrial card (Pretec, 1Gb), no problems with "HC" cards of any size (Toshiba, Sandisk, Hama,..).
Regards, Stefano
Hi Stefano,
On Thu, Nov 19, 2015 at 3:09 PM, Stefano Babic sbabic@denx.de wrote:
Hi Fabio,
Hi Peng,
It is interesting that I do not see the problem if I don't use SPL.
For example: on a mx6qsabresd I can boot the SanDisk card without issues if I boot the mx6qbsabresd_deconfig target (u-boot.imx binary).
However, if I try booting the mx6sabresd_spl_defconfig (SPL + u-boot.img) the boot fails with the same error as I noticed on the mx6ul board.
So it seems this is is SPL MMC related problem.
Thanks,
Fabio Estevam
On Thu, Nov 19, 2015 at 03:15:31PM -0200, Fabio Estevam wrote:
Hi Stefano,
Hi Fabio,
Hi Peng,
Or the header stuff on the .imx file making things be set that aren't in the SPL case? Can you for example use the bad SD card to read from in U-Boot if you boot off a good card?
Hi Fabio,
Confirmed, I see the same. It looks like that the BootROM can, but SPL no. I supposed an isseu with the frequency, and I set it in SPL to 25Mhz, but it does not help.
Right, I see the same.
Bet regards, Stefano
Hi Peng,
Sorry for this late reply. I missed you mail. I tried in my side with one sandisk 2GB macro sd card and one sandisk SDHC I 8GB card.
Both boots fine. What card are you using? Also which revision board, RevA B or C?
Regards, Peng.
Regards,
Fabio Estevam
Hi Peng,
The card I have here that fails to boot is a SanDisk microSD HC I 8GB.
My mx6ulevk is revB. What about yours?
Thanks
Hi Fabio, On Mon, Nov 30, 2015 at 12:54:37PM -0200, Fabio Estevam wrote:
Hi Peng,
My is revA. I just tried on revB board using one Sandisk 8GB micro SDHC I card, it boots ok.
" U-Boot SPL 2016.01-rc1-00190-g90447ef (Dec 01 2015 - 09:29:18) Trying to boot from MMC
U-Boot 2016.01-rc1-00190-g90447ef (Dec 01 2015 - 09:29:18 +0800) ........ "
Regards, Peng.
Thanks
In my case even mx6qsabresd fails to boot when I use the Sandisk 8GB micro SDHC I card and SPL image.
The non-SPL image (u-boot.imx) boots fine though. I haven't had a chance to investigate this yet.
Regards,
Fabio Estevam
Fabio Estevam
Peng Fan
Stefano Babic
