[PATCH] imx: imx8: fix build when CONFIG_IMX_BOOTAUX is set
From: Max Krummenacher max.krummenacher@toradex.com
Use correct function name.
Fixes: e8cd1f60d964 ("imx: imx8: bootaux: Add i.MX8 M4 boot support") Signed-off-by: Max Krummenacher max.krummenacher@toradex.com ---
arch/arm/mach-imx/imx8/cpu.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-imx/imx8/cpu.c b/arch/arm/mach-imx/imx8/cpu.c index accba502e492..834aca82bcfd 100644 --- a/arch/arm/mach-imx/imx8/cpu.c +++ b/arch/arm/mach-imx/imx8/cpu.c @@ -258,14 +258,14 @@ int arch_auxiliary_core_up(u32 core_id, ulong boot_private_data) return -EIO; }
- if (!power_domain_lookup_name("audio_sai0", &pd)) { + if (!imx8_power_domain_lookup_name("audio_sai0", &pd)) { if (power_domain_on(&pd)) { printf("Error power on SAI0\n"); return -EIO; } }
- if (!power_domain_lookup_name("audio_ocram", &pd)) { + if (!imx8_power_domain_lookup_name("audio_ocram", &pd)) { if (power_domain_on(&pd)) { printf("Error power on HIFI RAM\n"); return -EIO;
Subject: [PATCH] imx: imx8: fix build when CONFIG_IMX_BOOTAUX is set
diff --git a/arch/arm/mach-imx/imx8/cpu.c b/arch/arm/mach- imx/imx8/cpu.c index accba502e492..834aca82bcfd 100644 --- a/arch/arm/mach-imx/imx8/cpu.c +++ b/arch/arm/mach-imx/imx8/cpu.c @@ -258,14 +258,14 @@ int arch_auxiliary_core_up(u32 core_id, ulong boot_private_data) return -EIO; }
&pd)) {
I think need to find a proper fix to this. This API is legacy API.
Thanks Peng
&pd)) {
The current code does call a function which does not exist. Thus the compile fails if enabling CONFIG_IMX_BOOTAUX for a i.MX 8X and likely always did. I think that would merrit fixing it now rather than waiting until the more modern API is ported into U-Boot and the code using it changed to the new API.
Alternatively I could remove the handling of the HiFi auxiliary core from arch_auxiliary_core_up() and returning EINVAL if someone tried to set that core up.
Regards Max
Thanks Peng
Hi Max,
Agreed, applied it.
Peng, feel free to submit additional patches to address this issue.
Fabio Estevam
Max Krummenacher
Peng Fan
