[U-Boot] [PATCH v2 0/7] sunxi: video: Add support for HDMI output on A64/H3/H5
This series implements support for HDMI output. This is done using DM video framework and sharing the HDMI controller code with RK3288.
Patch 1 splits out RK3288 HDMI code in a way that it is appropriate for sharing with Allwinner SoCs.
Patch 2 splits out TCON code which is completely reusable on all Allwinner SoCs.
Patch 3 (new) converts commont TCON code to use DM video compatible timing structure.
Patch 4 adds all necessary clocks which are needed for Display Engine 2, TCON and HDMI.
Patch 5 implement actual DE2 and HDMI driver and patch 6 disables HDMI on all boards which don't have it (default is on).
Patch 7 is included here only for testing HDMI output on A64 due to missing power regulator support (AXP803). Another option is to use ATF which powers on HDMI. Such ATF can be found on Andre Przywara's github.
Code was tested on OrangePi 2 & OrangePi Plus 2E (both H3), OrangePi PC 2 (H5) and Pine64 (A64). It was also tested on RK3288 Tinker board. However, it was only compile tested for A10 and A20 targets.
This series was developed on u-boot-sunxi repository with additional, not yet merged, patch: https://patchwork.ozlabs.org/patch/735617/
Because already merged patches are not yet included in u-boot-sunxi repository, they need to be cherry picked from u-boot-rockchip: a0a2774aebdaa039ce787090c903cf47263f04c9 520c174b3564ae183f0e7c118dc8ce3770ae20b0
Best regards, Jernej Skrabec
Changes in v2: - patch 1 & 2 were removed because they were merged - collect reviewed by and tested by tags - TCON split out patch is splitted in two patches - fixed lcdc_enable() calls in video driver for old SoCs - defconfigs should disable video driver, not enable it - minor constant style fix
Icenowy Zheng (1): [DO NOT MERGE] sunxi: add AXP803 support
Jernej Skrabec (6): rockchip: video: Split out HDMI controller code sunxi: video: Split out TCON code sunxi: video: Convert lcdc to use struct display_timing sunxi: Add clock support for DE2/HDMI/TCON on newer SoCs sunxi: video: Add A64/H3/H5 HDMI driver sunxi: Disable DE2 video driver where not needed
arch/arm/include/asm/arch-rockchip/hdmi_rk3288.h | 456 -------------- arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 54 ++ arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 8 + arch/arm/include/asm/arch-sunxi/display.h | 103 --- arch/arm/include/asm/arch-sunxi/display2.h | 124 ++++ arch/arm/include/asm/arch-sunxi/lcdc.h | 128 ++++ arch/arm/mach-sunxi/Makefile | 3 + arch/arm/mach-sunxi/clock_sun6i.c | 40 +- arch/arm/mach-sunxi/pmic_bus.c | 6 +- arch/arm/mach-sunxi/rsb.c | 2 +- board/sunxi/Kconfig | 10 + board/sunxi/board.c | 31 +- configs/nanopi_neo_air_defconfig | 1 + configs/nanopi_neo_defconfig | 1 + configs/orangepi_zero_defconfig | 1 + drivers/power/Kconfig | 87 ++- drivers/power/Makefile | 1 + drivers/power/axp803.c | 256 ++++++++ drivers/power/axp818.c | 2 +- drivers/video/Makefile | 2 +- drivers/video/dw_hdmi.c | 764 +++++++++++++++++++++++ drivers/video/rockchip/Makefile | 2 +- drivers/video/rockchip/rk_hdmi.c | 757 +--------------------- drivers/video/rockchip/rk_vop.c | 1 - drivers/video/sunxi/Makefile | 9 + drivers/video/sunxi/lcdc.c | 209 +++++++ drivers/video/sunxi/sunxi_de2.c | 258 ++++++++ drivers/video/{ => sunxi}/sunxi_display.c | 220 ++----- drivers/video/sunxi/sunxi_dw_hdmi.c | 389 ++++++++++++ include/axp803.h | 73 +++ include/axp_pmic.h | 3 + include/configs/sun50i.h | 2 + include/configs/sun8i.h | 4 + include/configs/sunxi-common.h | 5 + include/dw_hdmi.h | 486 ++++++++++++++ scripts/config_whitelist.txt | 1 + 36 files changed, 2977 insertions(+), 1522 deletions(-) delete mode 100644 arch/arm/include/asm/arch-rockchip/hdmi_rk3288.h create mode 100644 arch/arm/include/asm/arch-sunxi/display2.h create mode 100644 arch/arm/include/asm/arch-sunxi/lcdc.h create mode 100644 drivers/power/axp803.c create mode 100644 drivers/video/dw_hdmi.c create mode 100644 drivers/video/sunxi/Makefile create mode 100644 drivers/video/sunxi/lcdc.c create mode 100644 drivers/video/sunxi/sunxi_de2.c rename drivers/video/{ => sunxi}/sunxi_display.c (87%) create mode 100644 drivers/video/sunxi/sunxi_dw_hdmi.c create mode 100644 include/axp803.h create mode 100644 include/dw_hdmi.h
Designware HDMI controller and phy are used in other SoCs as well. Split out platform independent code.
DW HDMI has 8 bit registers but they can be represented as 32 bit registers as well. Add support to select access mode.
EDID reading code use reading by blocks which is not supported by other SoCs in general. Make it more general using byte by byte approach, which is also used in Linux driver.
Finally, not all DW HDMI controllers are accompanied with DW HDMI phy. Support custom phys by making controller code independent from phy code.
Signed-off-by: Jernej Skrabec jernej.skrabec@siol.net Tested-by: Nickey Yang nickey.yang@rock-chips.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes in v2: - added tested by tag - added reviewed by tag
arch/arm/include/asm/arch-rockchip/hdmi_rk3288.h | 456 -------------- drivers/video/dw_hdmi.c | 764 +++++++++++++++++++++++ drivers/video/rockchip/Makefile | 2 +- drivers/video/rockchip/rk_hdmi.c | 757 +--------------------- drivers/video/rockchip/rk_vop.c | 1 - include/dw_hdmi.h | 486 ++++++++++++++ 6 files changed, 1275 insertions(+), 1191 deletions(-) delete mode 100644 arch/arm/include/asm/arch-rockchip/hdmi_rk3288.h create mode 100644 drivers/video/dw_hdmi.c create mode 100644 include/dw_hdmi.h
diff --git a/arch/arm/include/asm/arch-rockchip/hdmi_rk3288.h b/arch/arm/include/asm/arch-rockchip/hdmi_rk3288.h deleted file mode 100644 index 0b51d40882..0000000000 --- a/arch/arm/include/asm/arch-rockchip/hdmi_rk3288.h +++ /dev/null @@ -1,456 +0,0 @@ -/* - * Copyright (c) 2015 Google, Inc - * Copyright 2014 Rockchip Inc. - * Copyright (C) 2011 Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef _ASM_ARCH_HDMI_H -#define _ASM_ARCH_HDMI_H - - -#define HDMI_EDID_BLOCK_SIZE 128 - -struct rk3288_hdmi { - u32 reserved0[0x100]; - u32 ih_fc_stat0; - u32 ih_fc_stat1; - u32 ih_fc_stat2; - u32 ih_as_stat0; - u32 ih_phy_stat0; - u32 ih_i2cm_stat0; - u32 ih_cec_stat0; - u32 ih_vp_stat0; - u32 ih_i2cmphy_stat0; - u32 ih_ahbdmaaud_stat0; - u32 reserved1[0x17f-0x109]; - u32 ih_mute_fc_stat0; - u32 ih_mute_fc_stat1; - u32 ih_mute_fc_stat2; - u32 ih_mute_as_stat0; - u32 ih_mute_phy_stat0; - u32 ih_mute_i2cm_stat0; - u32 ih_mute_cec_stat0; - u32 ih_mute_vp_stat0; - u32 ih_mute_i2cmphy_stat0; - u32 ih_mute_ahbdmaaud_stat0; - u32 reserved2[0x1fe - 0x189]; - u32 ih_mute; - u32 tx_invid0; - u32 tx_instuffing; - u32 tx_gydata0; - u32 tx_gydata1; - u32 tx_rcrdata0; - u32 tx_rcrdata1; - u32 tx_bcbdata0; - u32 tx_bcbdata1; - u32 reserved3[0x7ff-0x207]; - u32 vp_status; - u32 vp_pr_cd; - u32 vp_stuff; - u32 vp_remap; - u32 vp_conf; - u32 vp_stat; - u32 vp_int; - u32 vp_mask; - u32 vp_pol; - u32 reserved4[0xfff-0x808]; - u32 fc_invidconf; - u32 fc_inhactv0; - u32 fc_inhactv1; - u32 fc_inhblank0; - u32 fc_inhblank1; - u32 fc_invactv0; - u32 fc_invactv1; - u32 fc_invblank; - u32 fc_hsyncindelay0; - u32 fc_hsyncindelay1; - u32 fc_hsyncinwidth0; - u32 fc_hsyncinwidth1; - u32 fc_vsyncindelay; - u32 fc_vsyncinwidth; - u32 fc_infreq0; - u32 fc_infreq1; - u32 fc_infreq2; - u32 fc_ctrldur; - u32 fc_exctrldur; - u32 fc_exctrlspac; - u32 fc_ch0pream; - u32 fc_ch1pream; - u32 fc_ch2pream; - u32 fc_aviconf3; - u32 fc_gcp; - u32 fc_aviconf0; - u32 fc_aviconf1; - u32 fc_aviconf2; - u32 fc_avivid; - u32 fc_avietb0; - u32 fc_avietb1; - u32 fc_avisbb0; - u32 fc_avisbb1; - u32 fc_avielb0; - u32 fc_avielb1; - u32 fc_avisrb0; - u32 fc_avisrb1; - u32 fc_audiconf0; - u32 fc_audiconf1; - u32 fc_audiconf2; - u32 fc_audiconf3; - u32 fc_vsdieeeid0; - u32 fc_vsdsize; - u32 reserved7[0x2fff-0x102a]; - u32 phy_conf0; - u32 phy_tst0; - u32 phy_tst1; - u32 phy_tst2; - u32 phy_stat0; - u32 phy_int0; - u32 phy_mask0; - u32 phy_pol0; - u32 reserved8[0x301f-0x3007]; - u32 phy_i2cm_slave_addr; - u32 phy_i2cm_address_addr; - u32 phy_i2cm_datao_1_addr; - u32 phy_i2cm_datao_0_addr; - u32 phy_i2cm_datai_1_addr; - u32 phy_i2cm_datai_0_addr; - u32 phy_i2cm_operation_addr; - u32 phy_i2cm_int_addr; - u32 phy_i2cm_ctlint_addr; - u32 phy_i2cm_div_addr; - u32 phy_i2cm_softrstz_addr; - u32 phy_i2cm_ss_scl_hcnt_1_addr; - u32 phy_i2cm_ss_scl_hcnt_0_addr; - u32 phy_i2cm_ss_scl_lcnt_1_addr; - u32 phy_i2cm_ss_scl_lcnt_0_addr; - u32 phy_i2cm_fs_scl_hcnt_1_addr; - u32 phy_i2cm_fs_scl_hcnt_0_addr; - u32 phy_i2cm_fs_scl_lcnt_1_addr; - u32 phy_i2cm_fs_scl_lcnt_0_addr; - u32 reserved9[0x30ff-0x3032]; - u32 aud_conf0; - u32 aud_conf1; - u32 aud_int; - u32 aud_conf2; - u32 aud_int1; - u32 reserved32[0x31ff-0x3104]; - u32 aud_n1; - u32 aud_n2; - u32 aud_n3; - u32 aud_cts1; - u32 aud_cts2; - u32 aud_cts3; - u32 aud_inputclkfs; - u32 reserved12[0x3fff-0x3206]; - u32 mc_sfrdiv; - u32 mc_clkdis; - u32 mc_swrstz; - u32 mc_opctrl; - u32 mc_flowctrl; - u32 mc_phyrstz; - u32 mc_lockonclock; - u32 mc_heacphy_rst; - u32 reserved13[0x40ff-0x4007]; - u32 csc_cfg; - u32 csc_scale; - struct { - u32 msb; - u32 lsb; - } csc_coef[3][4]; - u32 reserved17[0x7dff-0x4119]; - u32 i2cm_slave; - u32 i2c_address; - u32 i2cm_datao; - u32 i2cm_datai; - u32 i2cm_operation; - u32 i2cm_int; - u32 i2cm_ctlint; - u32 i2cm_div; - u32 i2cm_segaddr; - u32 i2cm_softrstz; - u32 i2cm_segptr; - u32 i2cm_ss_scl_hcnt_1_addr; - u32 i2cm_ss_scl_hcnt_0_addr; - u32 i2cm_ss_scl_lcnt_1_addr; - u32 i2cm_ss_scl_lcnt_0_addr; - u32 i2cm_fs_scl_hcnt_1_addr; - u32 i2cm_fs_scl_hcnt_0_addr; - u32 i2cm_fs_scl_lcnt_1_addr; - u32 i2cm_fs_scl_lcnt_0_addr; - u32 reserved18[0x7e1f-0x7e12]; - u32 i2cm_buf0; -}; -check_member(rk3288_hdmi, i2cm_buf0, 0x1f880); - -enum { - /* HDMI PHY registers define */ - PHY_OPMODE_PLLCFG = 0x06, - PHY_CKCALCTRL = 0x05, - PHY_CKSYMTXCTRL = 0x09, - PHY_VLEVCTRL = 0x0e, - PHY_PLLCURRCTRL = 0x10, - PHY_PLLPHBYCTRL = 0x13, - PHY_PLLGMPCTRL = 0x15, - PHY_PLLCLKBISTPHASE = 0x17, - PHY_TXTERM = 0x19, - - /* ih_phy_stat0 field values */ - HDMI_IH_PHY_STAT0_HPD = 0x1, - - /* ih_mute field values */ - HDMI_IH_MUTE_MUTE_WAKEUP_INTERRUPT = 0x2, - HDMI_IH_MUTE_MUTE_ALL_INTERRUPT = 0x1, - - /* tx_invid0 field values */ - HDMI_TX_INVID0_INTERNAL_DE_GENERATOR_DISABLE = 0x00, - HDMI_TX_INVID0_VIDEO_MAPPING_MASK = 0x1f, - HDMI_TX_INVID0_VIDEO_MAPPING_OFFSET = 0, - - /* tx_instuffing field values */ - HDMI_TX_INSTUFFING_BDBDATA_STUFFING_ENABLE = 0x4, - HDMI_TX_INSTUFFING_RCRDATA_STUFFING_ENABLE = 0x2, - HDMI_TX_INSTUFFING_GYDATA_STUFFING_ENABLE = 0x1, - - /* vp_pr_cd field values */ - HDMI_VP_PR_CD_COLOR_DEPTH_MASK = 0xf0, - HDMI_VP_PR_CD_COLOR_DEPTH_OFFSET = 4, - HDMI_VP_PR_CD_DESIRED_PR_FACTOR_MASK = 0x0f, - HDMI_VP_PR_CD_DESIRED_PR_FACTOR_OFFSET = 0, - - /* vp_stuff field values */ - HDMI_VP_STUFF_IDEFAULT_PHASE_MASK = 0x20, - HDMI_VP_STUFF_IDEFAULT_PHASE_OFFSET = 5, - HDMI_VP_STUFF_YCC422_STUFFING_MASK = 0x4, - HDMI_VP_STUFF_YCC422_STUFFING_STUFFING_MODE = 0x4, - HDMI_VP_STUFF_PP_STUFFING_MASK = 0x2, - HDMI_VP_STUFF_PP_STUFFING_STUFFING_MODE = 0x2, - HDMI_VP_STUFF_PR_STUFFING_MASK = 0x1, - HDMI_VP_STUFF_PR_STUFFING_STUFFING_MODE = 0x1, - - /* vp_conf field values */ - HDMI_VP_CONF_BYPASS_EN_MASK = 0x40, - HDMI_VP_CONF_BYPASS_EN_ENABLE = 0x40, - HDMI_VP_CONF_PP_EN_ENMASK = 0x20, - HDMI_VP_CONF_PP_EN_DISABLE = 0x00, - HDMI_VP_CONF_PR_EN_MASK = 0x10, - HDMI_VP_CONF_PR_EN_DISABLE = 0x00, - HDMI_VP_CONF_YCC422_EN_MASK = 0x8, - HDMI_VP_CONF_YCC422_EN_DISABLE = 0x0, - HDMI_VP_CONF_BYPASS_SELECT_MASK = 0x4, - HDMI_VP_CONF_BYPASS_SELECT_VID_PACKETIZER = 0x4, - HDMI_VP_CONF_OUTPUT_SELECTOR_MASK = 0x3, - HDMI_VP_CONF_OUTPUT_SELECTOR_BYPASS = 0x3, - - /* vp_remap field values */ - HDMI_VP_REMAP_YCC422_16BIT = 0x0, - - /* fc_invidconf field values */ - HDMI_FC_INVIDCONF_HDCP_KEEPOUT_MASK = 0x80, - HDMI_FC_INVIDCONF_HDCP_KEEPOUT_ACTIVE = 0x80, - HDMI_FC_INVIDCONF_HDCP_KEEPOUT_INACTIVE = 0x00, - HDMI_FC_INVIDCONF_VSYNC_IN_POLARITY_MASK = 0x40, - HDMI_FC_INVIDCONF_VSYNC_IN_POLARITY_ACTIVE_HIGH = 0x40, - HDMI_FC_INVIDCONF_VSYNC_IN_POLARITY_ACTIVE_LOW = 0x00, - HDMI_FC_INVIDCONF_HSYNC_IN_POLARITY_MASK = 0x20, - HDMI_FC_INVIDCONF_HSYNC_IN_POLARITY_ACTIVE_HIGH = 0x20, - HDMI_FC_INVIDCONF_HSYNC_IN_POLARITY_ACTIVE_LOW = 0x00, - HDMI_FC_INVIDCONF_DE_IN_POLARITY_MASK = 0x10, - HDMI_FC_INVIDCONF_DE_IN_POLARITY_ACTIVE_HIGH = 0x10, - HDMI_FC_INVIDCONF_DE_IN_POLARITY_ACTIVE_LOW = 0x00, - HDMI_FC_INVIDCONF_DVI_MODEZ_MASK = 0x8, - HDMI_FC_INVIDCONF_DVI_MODEZ_HDMI_MODE = 0x8, - HDMI_FC_INVIDCONF_DVI_MODEZ_DVI_MODE = 0x0, - HDMI_FC_INVIDCONF_R_V_BLANK_IN_OSC_MASK = 0x2, - HDMI_FC_INVIDCONF_R_V_BLANK_IN_OSC_ACTIVE_HIGH = 0x2, - HDMI_FC_INVIDCONF_R_V_BLANK_IN_OSC_ACTIVE_LOW = 0x0, - HDMI_FC_INVIDCONF_IN_I_P_MASK = 0x1, - HDMI_FC_INVIDCONF_IN_I_P_INTERLACED = 0x1, - HDMI_FC_INVIDCONF_IN_I_P_PROGRESSIVE = 0x0, - - - /* fc_aviconf0-fc_aviconf3 field values */ - HDMI_FC_AVICONF0_PIX_FMT_MASK = 0x03, - HDMI_FC_AVICONF0_PIX_FMT_RGB = 0x00, - HDMI_FC_AVICONF0_PIX_FMT_YCBCR422 = 0x01, - HDMI_FC_AVICONF0_PIX_FMT_YCBCR444 = 0x02, - HDMI_FC_AVICONF0_ACTIVE_FMT_MASK = 0x40, - HDMI_FC_AVICONF0_ACTIVE_FMT_INFO_PRESENT = 0x40, - HDMI_FC_AVICONF0_ACTIVE_FMT_NO_INFO = 0x00, - HDMI_FC_AVICONF0_BAR_DATA_MASK = 0x0c, - HDMI_FC_AVICONF0_BAR_DATA_NO_DATA = 0x00, - HDMI_FC_AVICONF0_BAR_DATA_VERT_BAR = 0x04, - HDMI_FC_AVICONF0_BAR_DATA_HORIZ_BAR = 0x08, - HDMI_FC_AVICONF0_BAR_DATA_VERT_HORIZ_BAR = 0x0c, - HDMI_FC_AVICONF0_SCAN_INFO_MASK = 0x30, - HDMI_FC_AVICONF0_SCAN_INFO_OVERSCAN = 0x10, - HDMI_FC_AVICONF0_SCAN_INFO_UNDERSCAN = 0x20, - HDMI_FC_AVICONF0_SCAN_INFO_NODATA = 0x00, - - HDMI_FC_AVICONF1_ACTIVE_ASPECT_RATIO_MASK = 0x0f, - HDMI_FC_AVICONF1_ACTIVE_ASPECT_RATIO_USE_CODED = 0x08, - HDMI_FC_AVICONF1_ACTIVE_ASPECT_RATIO_4_3 = 0x09, - HDMI_FC_AVICONF1_ACTIVE_ASPECT_RATIO_16_9 = 0x0a, - HDMI_FC_AVICONF1_ACTIVE_ASPECT_RATIO_14_9 = 0x0b, - HDMI_FC_AVICONF1_CODED_ASPECT_RATIO_MASK = 0x30, - HDMI_FC_AVICONF1_CODED_ASPECT_RATIO_NO_DATA = 0x00, - HDMI_FC_AVICONF1_CODED_ASPECT_RATIO_4_3 = 0x10, - HDMI_FC_AVICONF1_CODED_ASPECT_RATIO_16_9 = 0x20, - HDMI_FC_AVICONF1_COLORIMETRY_MASK = 0xc0, - HDMI_FC_AVICONF1_COLORIMETRY_NO_DATA = 0x00, - HDMI_FC_AVICONF1_COLORIMETRY_SMPTE = 0x40, - HDMI_FC_AVICONF1_COLORIMETRY_ITUR = 0x80, - HDMI_FC_AVICONF1_COLORIMETRY_EXTENDED_INFO = 0xc0, - - HDMI_FC_AVICONF2_SCALING_MASK = 0x03, - HDMI_FC_AVICONF2_SCALING_NONE = 0x00, - HDMI_FC_AVICONF2_SCALING_HORIZ = 0x01, - HDMI_FC_AVICONF2_SCALING_VERT = 0x02, - HDMI_FC_AVICONF2_SCALING_HORIZ_vert = 0x03, - HDMI_FC_AVICONF2_RGB_QUANT_MASK = 0x0c, - HDMI_FC_AVICONF2_RGB_QUANT_DEFAULT = 0x00, - HDMI_FC_AVICONF2_RGB_QUANT_LIMITED_RANGE = 0x04, - HDMI_FC_AVICONF2_RGB_QUANT_FULL_RANGE = 0x08, - HDMI_FC_AVICONF2_EXT_COLORIMETRY_MASK = 0x70, - HDMI_FC_AVICONF2_EXT_COLORIMETRY_XVYCC601 = 0x00, - HDMI_FC_AVICONF2_EXT_COLORIMETRY_XVYCC709 = 0x10, - HDMI_FC_AVICONF2_EXT_COLORIMETRY_SYCC601 = 0x20, - HDMI_FC_AVICONF2_EXT_COLORIMETRY_ADOBE_YCC601 = 0x30, - HDMI_FC_AVICONF2_EXT_COLORIMETRY_ADOBE_RGB = 0x40, - HDMI_FC_AVICONF2_IT_CONTENT_MASK = 0x80, - HDMI_FC_AVICONF2_IT_CONTENT_NO_DATA = 0x00, - HDMI_FC_AVICONF2_IT_CONTENT_VALID = 0x80, - - HDMI_FC_AVICONF3_IT_CONTENT_TYPE_MASK = 0x03, - HDMI_FC_AVICONF3_IT_CONTENT_TYPE_GRAPHICS = 0x00, - HDMI_FC_AVICONF3_IT_CONTENT_TYPE_PHOTO = 0x01, - HDMI_FC_AVICONF3_IT_CONTENT_TYPE_CINEMA = 0x02, - HDMI_FC_AVICONF3_IT_CONTENT_TYPE_GAME = 0x03, - HDMI_FC_AVICONF3_QUANT_RANGE_MASK = 0x0c, - HDMI_FC_AVICONF3_QUANT_RANGE_LIMITED = 0x00, - HDMI_FC_AVICONF3_QUANT_RANGE_FULL = 0x04, - - /* fc_gcp field values*/ - HDMI_FC_GCP_SET_AVMUTE = 0x02, - HDMI_FC_GCP_CLEAR_AVMUTE = 0x01, - - /* phy_conf0 field values */ - HDMI_PHY_CONF0_PDZ_MASK = 0x80, - HDMI_PHY_CONF0_PDZ_OFFSET = 7, - HDMI_PHY_CONF0_ENTMDS_MASK = 0x40, - HDMI_PHY_CONF0_ENTMDS_OFFSET = 6, - HDMI_PHY_CONF0_SPARECTRL_MASK = 0x20, - HDMI_PHY_CONF0_SPARECTRL_OFFSET = 5, - HDMI_PHY_CONF0_GEN2_PDDQ_MASK = 0x10, - HDMI_PHY_CONF0_GEN2_PDDQ_OFFSET = 4, - HDMI_PHY_CONF0_GEN2_TXPWRON_MASK = 0x8, - HDMI_PHY_CONF0_GEN2_TXPWRON_OFFSET = 3, - HDMI_PHY_CONF0_SELDATAENPOL_MASK = 0x2, - HDMI_PHY_CONF0_SELDATAENPOL_OFFSET = 1, - HDMI_PHY_CONF0_SELDIPIF_MASK = 0x1, - HDMI_PHY_CONF0_SELDIPIF_OFFSET = 0, - - /* phy_tst0 field values */ - HDMI_PHY_TST0_TSTCLR_MASK = 0x20, - HDMI_PHY_TST0_TSTCLR_OFFSET = 5, - - /* phy_stat0 field values */ - HDMI_PHY_HPD = 0x02, - HDMI_PHY_TX_PHY_LOCK = 0x01, - - /* phy_i2cm_slave_addr field values */ - HDMI_PHY_I2CM_SLAVE_ADDR_PHY_GEN2 = 0x69, - - /* phy_i2cm_operation_addr field values */ - HDMI_PHY_I2CM_OPERATION_ADDR_WRITE = 0x10, - - /* hdmi_phy_i2cm_int_addr */ - HDMI_PHY_I2CM_INT_ADDR_DONE_POL = 0x08, - - /* hdmi_phy_i2cm_ctlint_addr */ - HDMI_PHY_I2CM_CTLINT_ADDR_NAC_POL = 0x80, - HDMI_PHY_I2CM_CTLINT_ADDR_ARBITRATION_POL = 0x08, - - /* aud_conf0 field values */ - HDMI_AUD_CONF0_SW_AUDIO_FIFO_RST = 0x80, - HDMI_AUD_CONF0_I2S_SELECT = 0x20, - HDMI_AUD_CONF0_I2S_IN_EN_0 = 0x01, - HDMI_AUD_CONF0_I2S_IN_EN_1 = 0x02, - HDMI_AUD_CONF0_I2S_IN_EN_2 = 0x04, - HDMI_AUD_CONF0_I2S_IN_EN_3 = 0x08, - - /* aud_conf0 field values */ - HDMI_AUD_CONF1_I2S_MODE_STANDARD_MODE = 0x0, - HDMI_AUD_CONF1_I2S_WIDTH_16BIT = 0x10, - - /* aud_n3 field values */ - HDMI_AUD_N3_NCTS_ATOMIC_WRITE = 0x80, - HDMI_AUD_N3_AUDN19_16_MASK = 0x0f, - - /* aud_cts3 field values */ - HDMI_AUD_CTS3_N_SHIFT_OFFSET = 5, - HDMI_AUD_CTS3_N_SHIFT_MASK = 0xe0, - HDMI_AUD_CTS3_N_SHIFT_1 = 0, - HDMI_AUD_CTS3_N_SHIFT_16 = 0x20, - HDMI_AUD_CTS3_N_SHIFT_32 = 0x40, - HDMI_AUD_CTS3_N_SHIFT_64 = 0x60, - HDMI_AUD_CTS3_N_SHIFT_128 = 0x80, - HDMI_AUD_CTS3_N_SHIFT_256 = 0xa0, - HDMI_AUD_CTS3_CTS_MANUAL = 0x10, - HDMI_AUD_CTS3_AUDCTS19_16_MASK = 0x0f, - - /* aud_inputclkfs filed values */ - HDMI_AUD_INPUTCLKFS_128 = 0x0, - - /* mc_clkdis field values */ - HDMI_MC_CLKDIS_AUDCLK_DISABLE = 0x8, - HDMI_MC_CLKDIS_TMDSCLK_DISABLE = 0x2, - HDMI_MC_CLKDIS_PIXELCLK_DISABLE = 0x1, - - /* mc_swrstz field values */ - HDMI_MC_SWRSTZ_II2SSWRST_REQ = 0x08, - HDMI_MC_SWRSTZ_TMDSSWRST_REQ = 0x02, - - /* mc_flowctrl field values */ - HDMI_MC_FLOWCTRL_FEED_THROUGH_OFF_CSC_IN_PATH = 0x1, - HDMI_MC_FLOWCTRL_FEED_THROUGH_OFF_CSC_BYPASS = 0x0, - - /* mc_phyrstz field values */ - HDMI_MC_PHYRSTZ_ASSERT = 0x0, - HDMI_MC_PHYRSTZ_DEASSERT = 0x1, - - /* mc_heacphy_rst field values */ - HDMI_MC_HEACPHY_RST_ASSERT = 0x1, - - /* csc_cfg field values */ - HDMI_CSC_CFG_INTMODE_DISABLE = 0x00, - - /* csc_scale field values */ - HDMI_CSC_SCALE_CSC_COLORDE_PTH_MASK = 0xf0, - HDMI_CSC_SCALE_CSC_COLORDE_PTH_24BPP = 0x00, - HDMI_CSC_SCALE_CSC_COLORDE_PTH_30BPP = 0x50, - HDMI_CSC_SCALE_CSC_COLORDE_PTH_36BPP = 0x60, - HDMI_CSC_SCALE_CSC_COLORDE_PTH_48BPP = 0x70, - HDMI_CSC_SCALE_CSCSCALE_MASK = 0x03, - - /* i2cm filed values */ - HDMI_I2CM_SLAVE_DDC_ADDR = 0x50, - HDMI_I2CM_SEGADDR_DDC = 0x30, - HDMI_I2CM_OPT_RD8_EXT = 0x8, - HDMI_I2CM_OPT_RD8 = 0x4, - HDMI_I2CM_DIV_FAST_STD_MODE = 0x8, - HDMI_I2CM_DIV_FAST_MODE = 0x8, - HDMI_I2CM_DIV_STD_MODE = 0x0, - HDMI_I2CM_SOFTRSTZ = 0x1, -}; - -/* -struct display_timing; -struct rk3288_grf; - -int rk_hdmi_init(struct rk3288_grf *grf, u32 vop_id); -int rk_hdmi_enable(const struct display_timing *edid); -int rk_hdmi_get_edid(struct rk3288_grf *grf, struct display_timing *edid); -*/ - -#endif diff --git a/drivers/video/dw_hdmi.c b/drivers/video/dw_hdmi.c new file mode 100644 index 0000000000..8a53109823 --- /dev/null +++ b/drivers/video/dw_hdmi.c @@ -0,0 +1,764 @@ +/* + * Copyright (c) 2015 Google, Inc + * Copyright 2014 Rockchip Inc. + * Copyright 2017 Jernej Skrabec jernej.skrabec@siol.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fdtdec.h> +#include <asm/io.h> +#include "dw_hdmi.h" + +struct tmds_n_cts { + u32 tmds; + u32 cts; + u32 n; +}; + +static const struct tmds_n_cts n_cts_table[] = { + { + .tmds = 25175000, .n = 6144, .cts = 25175, + }, { + .tmds = 25200000, .n = 6144, .cts = 25200, + }, { + .tmds = 27000000, .n = 6144, .cts = 27000, + }, { + .tmds = 27027000, .n = 6144, .cts = 27027, + }, { + .tmds = 40000000, .n = 6144, .cts = 40000, + }, { + .tmds = 54000000, .n = 6144, .cts = 54000, + }, { + .tmds = 54054000, .n = 6144, .cts = 54054, + }, { + .tmds = 65000000, .n = 6144, .cts = 65000, + }, { + .tmds = 74176000, .n = 11648, .cts = 140625, + }, { + .tmds = 74250000, .n = 6144, .cts = 74250, + }, { + .tmds = 83500000, .n = 6144, .cts = 83500, + }, { + .tmds = 106500000, .n = 6144, .cts = 106500, + }, { + .tmds = 108000000, .n = 6144, .cts = 108000, + }, { + .tmds = 148352000, .n = 5824, .cts = 140625, + }, { + .tmds = 148500000, .n = 6144, .cts = 148500, + }, { + .tmds = 297000000, .n = 5120, .cts = 247500, + } +}; + +static void hdmi_write(struct dw_hdmi *hdmi, u8 val, int offset) +{ + switch (hdmi->reg_io_width) { + case 1: + writeb(val, hdmi->ioaddr + offset); + break; + case 4: + writel(val, hdmi->ioaddr + (offset << 2)); + break; + default: + debug("reg_io_width has unsupported width!\n"); + break; + } +} + +static u8 hdmi_read(struct dw_hdmi *hdmi, int offset) +{ + switch (hdmi->reg_io_width) { + case 1: + return readb(hdmi->ioaddr + offset); + case 4: + return readl(hdmi->ioaddr + (offset << 2)); + default: + debug("reg_io_width has unsupported width!\n"); + break; + } + + return 0; +} + +static void hdmi_mod(struct dw_hdmi *hdmi, unsigned reg, u8 mask, u8 data) +{ + u8 val = hdmi_read(hdmi, reg) & ~mask; + + val |= data & mask; + hdmi_write(hdmi, val, reg); +} + +static void hdmi_set_clock_regenerator(struct dw_hdmi *hdmi, u32 n, u32 cts) +{ + uint cts3; + uint n3; + + /* first set ncts_atomic_write (if present) */ + n3 = HDMI_AUD_N3_NCTS_ATOMIC_WRITE; + hdmi_write(hdmi, n3, HDMI_AUD_N3); + + /* set cts_manual (if present) */ + cts3 = HDMI_AUD_CTS3_CTS_MANUAL; + + cts3 |= HDMI_AUD_CTS3_N_SHIFT_1 << HDMI_AUD_CTS3_N_SHIFT_OFFSET; + cts3 |= (cts >> 16) & HDMI_AUD_CTS3_AUDCTS19_16_MASK; + + /* write cts values; cts3 must be written first */ + hdmi_write(hdmi, cts3, HDMI_AUD_CTS3); + hdmi_write(hdmi, (cts >> 8) & 0xff, HDMI_AUD_CTS2); + hdmi_write(hdmi, cts & 0xff, HDMI_AUD_CTS1); + + /* write n values; n1 must be written last */ + n3 |= (n >> 16) & HDMI_AUD_N3_AUDN19_16_MASK; + hdmi_write(hdmi, n3, HDMI_AUD_N3); + hdmi_write(hdmi, (n >> 8) & 0xff, HDMI_AUD_N2); + hdmi_write(hdmi, n & 0xff, HDMI_AUD_N3); + + hdmi_write(hdmi, HDMI_AUD_INPUTCLKFS_128, HDMI_AUD_INPUTCLKFS); +} + +static int hdmi_lookup_n_cts(u32 pixel_clk) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(n_cts_table); i++) + if (pixel_clk <= n_cts_table[i].tmds) + break; + + if (i >= ARRAY_SIZE(n_cts_table)) + return -1; + + return i; +} + +static void hdmi_audio_set_samplerate(struct dw_hdmi *hdmi, u32 pixel_clk) +{ + u32 clk_n, clk_cts; + int index; + + index = hdmi_lookup_n_cts(pixel_clk); + if (index == -1) { + debug("audio not supported for pixel clk %d\n", pixel_clk); + return; + } + + clk_n = n_cts_table[index].n; + clk_cts = n_cts_table[index].cts; + hdmi_set_clock_regenerator(hdmi, clk_n, clk_cts); +} + +/* + * this submodule is responsible for the video data synchronization. + * for example, for rgb 4:4:4 input, the data map is defined as + * pin{47~40} <==> r[7:0] + * pin{31~24} <==> g[7:0] + * pin{15~8} <==> b[7:0] + */ +static void hdmi_video_sample(struct dw_hdmi *hdmi) +{ + u32 color_format = 0x01; + uint val; + + val = HDMI_TX_INVID0_INTERNAL_DE_GENERATOR_DISABLE | + ((color_format << HDMI_TX_INVID0_VIDEO_MAPPING_OFFSET) & + HDMI_TX_INVID0_VIDEO_MAPPING_MASK); + + hdmi_write(hdmi, val, HDMI_TX_INVID0); + + /* enable tx stuffing: when de is inactive, fix the output data to 0 */ + val = HDMI_TX_INSTUFFING_BDBDATA_STUFFING_ENABLE | + HDMI_TX_INSTUFFING_RCRDATA_STUFFING_ENABLE | + HDMI_TX_INSTUFFING_GYDATA_STUFFING_ENABLE; + hdmi_write(hdmi, val, HDMI_TX_INSTUFFING); + hdmi_write(hdmi, 0x0, HDMI_TX_GYDATA0); + hdmi_write(hdmi, 0x0, HDMI_TX_GYDATA1); + hdmi_write(hdmi, 0x0, HDMI_TX_RCRDATA0); + hdmi_write(hdmi, 0x0, HDMI_TX_RCRDATA1); + hdmi_write(hdmi, 0x0, HDMI_TX_BCBDATA0); + hdmi_write(hdmi, 0x0, HDMI_TX_BCBDATA1); +} + +static void hdmi_video_packetize(struct dw_hdmi *hdmi) +{ + u32 output_select = HDMI_VP_CONF_OUTPUT_SELECTOR_BYPASS; + u32 remap_size = HDMI_VP_REMAP_YCC422_16BIT; + u32 color_depth = 0; + uint val, vp_conf; + + /* set the packetizer registers */ + val = ((color_depth << HDMI_VP_PR_CD_COLOR_DEPTH_OFFSET) & + HDMI_VP_PR_CD_COLOR_DEPTH_MASK) | + ((0 << HDMI_VP_PR_CD_DESIRED_PR_FACTOR_OFFSET) & + HDMI_VP_PR_CD_DESIRED_PR_FACTOR_MASK); + hdmi_write(hdmi, val, HDMI_VP_PR_CD); + + hdmi_mod(hdmi, HDMI_VP_STUFF, HDMI_VP_STUFF_PR_STUFFING_MASK, + HDMI_VP_STUFF_PR_STUFFING_STUFFING_MODE); + + /* data from pixel repeater block */ + vp_conf = HDMI_VP_CONF_PR_EN_DISABLE | + HDMI_VP_CONF_BYPASS_SELECT_VID_PACKETIZER; + + hdmi_mod(hdmi, HDMI_VP_CONF, HDMI_VP_CONF_PR_EN_MASK | + HDMI_VP_CONF_BYPASS_SELECT_MASK, vp_conf); + + hdmi_mod(hdmi, HDMI_VP_STUFF, HDMI_VP_STUFF_IDEFAULT_PHASE_MASK, + 1 << HDMI_VP_STUFF_IDEFAULT_PHASE_OFFSET); + + hdmi_write(hdmi, remap_size, HDMI_VP_REMAP); + + vp_conf = HDMI_VP_CONF_BYPASS_EN_ENABLE | + HDMI_VP_CONF_PP_EN_DISABLE | + HDMI_VP_CONF_YCC422_EN_DISABLE; + + hdmi_mod(hdmi, HDMI_VP_CONF, HDMI_VP_CONF_BYPASS_EN_MASK | + HDMI_VP_CONF_PP_EN_ENMASK | HDMI_VP_CONF_YCC422_EN_MASK, + vp_conf); + + hdmi_mod(hdmi, HDMI_VP_STUFF, HDMI_VP_STUFF_PP_STUFFING_MASK | + HDMI_VP_STUFF_YCC422_STUFFING_MASK, + HDMI_VP_STUFF_PP_STUFFING_STUFFING_MODE | + HDMI_VP_STUFF_YCC422_STUFFING_STUFFING_MODE); + + hdmi_mod(hdmi, HDMI_VP_CONF, HDMI_VP_CONF_OUTPUT_SELECTOR_MASK, + output_select); +} + +static inline void hdmi_phy_test_clear(struct dw_hdmi *hdmi, uint bit) +{ + hdmi_mod(hdmi, HDMI_PHY_TST0, HDMI_PHY_TST0_TSTCLR_MASK, + bit << HDMI_PHY_TST0_TSTCLR_OFFSET); +} + +static int hdmi_phy_wait_i2c_done(struct dw_hdmi *hdmi, u32 msec) +{ + ulong start; + u32 val; + + start = get_timer(0); + do { + val = hdmi_read(hdmi, HDMI_IH_I2CMPHY_STAT0); + if (val & 0x3) { + hdmi_write(hdmi, val, HDMI_IH_I2CMPHY_STAT0); + return 0; + } + + udelay(100); + } while (get_timer(start) < msec); + + return 1; +} + +static void hdmi_phy_i2c_write(struct dw_hdmi *hdmi, uint data, uint addr) +{ + hdmi_write(hdmi, 0xff, HDMI_IH_I2CMPHY_STAT0); + hdmi_write(hdmi, addr, HDMI_PHY_I2CM_ADDRESS_ADDR); + hdmi_write(hdmi, (u8)(data >> 8), HDMI_PHY_I2CM_DATAO_1_ADDR); + hdmi_write(hdmi, (u8)(data >> 0), HDMI_PHY_I2CM_DATAO_0_ADDR); + hdmi_write(hdmi, HDMI_PHY_I2CM_OPERATION_ADDR_WRITE, + HDMI_PHY_I2CM_OPERATION_ADDR); + + hdmi_phy_wait_i2c_done(hdmi, 1000); +} + +static void hdmi_phy_enable_power(struct dw_hdmi *hdmi, uint enable) +{ + hdmi_mod(hdmi, HDMI_PHY_CONF0, HDMI_PHY_CONF0_PDZ_MASK, + enable << HDMI_PHY_CONF0_PDZ_OFFSET); +} + +static void hdmi_phy_enable_tmds(struct dw_hdmi *hdmi, uint enable) +{ + hdmi_mod(hdmi, HDMI_PHY_CONF0, HDMI_PHY_CONF0_ENTMDS_MASK, + enable << HDMI_PHY_CONF0_ENTMDS_OFFSET); +} + +static void hdmi_phy_enable_spare(struct dw_hdmi *hdmi, uint enable) +{ + hdmi_mod(hdmi, HDMI_PHY_CONF0, HDMI_PHY_CONF0_SPARECTRL_MASK, + enable << HDMI_PHY_CONF0_SPARECTRL_OFFSET); +} + +static void hdmi_phy_gen2_pddq(struct dw_hdmi *hdmi, uint enable) +{ + hdmi_mod(hdmi, HDMI_PHY_CONF0, HDMI_PHY_CONF0_GEN2_PDDQ_MASK, + enable << HDMI_PHY_CONF0_GEN2_PDDQ_OFFSET); +} + +static void hdmi_phy_gen2_txpwron(struct dw_hdmi *hdmi, uint enable) +{ + hdmi_mod(hdmi, HDMI_PHY_CONF0, + HDMI_PHY_CONF0_GEN2_TXPWRON_MASK, + enable << HDMI_PHY_CONF0_GEN2_TXPWRON_OFFSET); +} + +static void hdmi_phy_sel_data_en_pol(struct dw_hdmi *hdmi, uint enable) +{ + hdmi_mod(hdmi, HDMI_PHY_CONF0, + HDMI_PHY_CONF0_SELDATAENPOL_MASK, + enable << HDMI_PHY_CONF0_SELDATAENPOL_OFFSET); +} + +static void hdmi_phy_sel_interface_control(struct dw_hdmi *hdmi, + uint enable) +{ + hdmi_mod(hdmi, HDMI_PHY_CONF0, HDMI_PHY_CONF0_SELDIPIF_MASK, + enable << HDMI_PHY_CONF0_SELDIPIF_OFFSET); +} + +static int hdmi_phy_configure(struct dw_hdmi *hdmi, u32 mpixelclock) +{ + ulong start; + uint i, val; + + if (!hdmi->mpll_cfg || !hdmi->phy_cfg) + return -1; + + /* gen2 tx power off */ + hdmi_phy_gen2_txpwron(hdmi, 0); + + /* gen2 pddq */ + hdmi_phy_gen2_pddq(hdmi, 1); + + /* phy reset */ + hdmi_write(hdmi, HDMI_MC_PHYRSTZ_DEASSERT, HDMI_MC_PHYRSTZ); + hdmi_write(hdmi, HDMI_MC_PHYRSTZ_ASSERT, HDMI_MC_PHYRSTZ); + hdmi_write(hdmi, HDMI_MC_HEACPHY_RST_ASSERT, HDMI_MC_HEACPHY_RST); + + hdmi_phy_test_clear(hdmi, 1); + hdmi_write(hdmi, HDMI_PHY_I2CM_SLAVE_ADDR_PHY_GEN2, + HDMI_PHY_I2CM_SLAVE_ADDR); + hdmi_phy_test_clear(hdmi, 0); + + /* pll/mpll cfg - always match on final entry */ + for (i = 0; hdmi->mpll_cfg[i].mpixelclock != (~0ul); i++) + if (mpixelclock <= hdmi->mpll_cfg[i].mpixelclock) + break; + + hdmi_phy_i2c_write(hdmi, hdmi->mpll_cfg[i].cpce, PHY_OPMODE_PLLCFG); + hdmi_phy_i2c_write(hdmi, hdmi->mpll_cfg[i].gmp, PHY_PLLGMPCTRL); + hdmi_phy_i2c_write(hdmi, hdmi->mpll_cfg[i].curr, PHY_PLLCURRCTRL); + + hdmi_phy_i2c_write(hdmi, 0x0000, PHY_PLLPHBYCTRL); + hdmi_phy_i2c_write(hdmi, 0x0006, PHY_PLLCLKBISTPHASE); + + for (i = 0; hdmi->phy_cfg[i].mpixelclock != (~0ul); i++) + if (mpixelclock <= hdmi->phy_cfg[i].mpixelclock) + break; + + /* + * resistance term 133ohm cfg + * preemp cgf 0.00 + * tx/ck lvl 10 + */ + hdmi_phy_i2c_write(hdmi, hdmi->phy_cfg[i].term, PHY_TXTERM); + hdmi_phy_i2c_write(hdmi, hdmi->phy_cfg[i].sym_ctr, PHY_CKSYMTXCTRL); + hdmi_phy_i2c_write(hdmi, hdmi->phy_cfg[i].vlev_ctr, PHY_VLEVCTRL); + + /* remove clk term */ + hdmi_phy_i2c_write(hdmi, 0x8000, PHY_CKCALCTRL); + + hdmi_phy_enable_power(hdmi, 1); + + /* toggle tmds enable */ + hdmi_phy_enable_tmds(hdmi, 0); + hdmi_phy_enable_tmds(hdmi, 1); + + /* gen2 tx power on */ + hdmi_phy_gen2_txpwron(hdmi, 1); + hdmi_phy_gen2_pddq(hdmi, 0); + + hdmi_phy_enable_spare(hdmi, 1); + + /* wait for phy pll lock */ + start = get_timer(0); + do { + val = hdmi_read(hdmi, HDMI_PHY_STAT0); + if (!(val & HDMI_PHY_TX_PHY_LOCK)) + return 0; + + udelay(100); + } while (get_timer(start) < 5); + + return -1; +} + +static void hdmi_av_composer(struct dw_hdmi *hdmi, + const struct display_timing *edid) +{ + bool mdataenablepolarity = true; + uint inv_val; + uint hbl; + uint vbl; + + hbl = edid->hback_porch.typ + edid->hfront_porch.typ + + edid->hsync_len.typ; + vbl = edid->vback_porch.typ + edid->vfront_porch.typ + + edid->vsync_len.typ; + + /* set up hdmi_fc_invidconf */ + inv_val = HDMI_FC_INVIDCONF_HDCP_KEEPOUT_INACTIVE; + + inv_val |= (edid->flags & DISPLAY_FLAGS_HSYNC_HIGH ? + HDMI_FC_INVIDCONF_VSYNC_IN_POLARITY_ACTIVE_HIGH : + HDMI_FC_INVIDCONF_VSYNC_IN_POLARITY_ACTIVE_LOW); + + inv_val |= (edid->flags & DISPLAY_FLAGS_VSYNC_HIGH ? + HDMI_FC_INVIDCONF_HSYNC_IN_POLARITY_ACTIVE_HIGH : + HDMI_FC_INVIDCONF_HSYNC_IN_POLARITY_ACTIVE_LOW); + + inv_val |= (mdataenablepolarity ? + HDMI_FC_INVIDCONF_DE_IN_POLARITY_ACTIVE_HIGH : + HDMI_FC_INVIDCONF_DE_IN_POLARITY_ACTIVE_LOW); + + /* + * TODO(sjg@chromium.org>: Need to check for HDMI / DVI + * inv_val |= (edid->hdmi_monitor_detected ? + * HDMI_FC_INVIDCONF_DVI_MODEZ_HDMI_MODE : + * HDMI_FC_INVIDCONF_DVI_MODEZ_DVI_MODE); + */ + inv_val |= HDMI_FC_INVIDCONF_DVI_MODEZ_HDMI_MODE; + + inv_val |= HDMI_FC_INVIDCONF_R_V_BLANK_IN_OSC_ACTIVE_LOW; + + inv_val |= HDMI_FC_INVIDCONF_IN_I_P_PROGRESSIVE; + + hdmi_write(hdmi, inv_val, HDMI_FC_INVIDCONF); + + /* set up horizontal active pixel width */ + hdmi_write(hdmi, edid->hactive.typ >> 8, HDMI_FC_INHACTV1); + hdmi_write(hdmi, edid->hactive.typ, HDMI_FC_INHACTV0); + + /* set up vertical active lines */ + hdmi_write(hdmi, edid->vactive.typ >> 8, HDMI_FC_INVACTV1); + hdmi_write(hdmi, edid->vactive.typ, HDMI_FC_INVACTV0); + + /* set up horizontal blanking pixel region width */ + hdmi_write(hdmi, hbl >> 8, HDMI_FC_INHBLANK1); + hdmi_write(hdmi, hbl, HDMI_FC_INHBLANK0); + + /* set up vertical blanking pixel region width */ + hdmi_write(hdmi, vbl, HDMI_FC_INVBLANK); + + /* set up hsync active edge delay width (in pixel clks) */ + hdmi_write(hdmi, edid->hfront_porch.typ >> 8, HDMI_FC_HSYNCINDELAY1); + hdmi_write(hdmi, edid->hfront_porch.typ, HDMI_FC_HSYNCINDELAY0); + + /* set up vsync active edge delay (in lines) */ + hdmi_write(hdmi, edid->vfront_porch.typ, HDMI_FC_VSYNCINDELAY); + + /* set up hsync active pulse width (in pixel clks) */ + hdmi_write(hdmi, edid->hsync_len.typ >> 8, HDMI_FC_HSYNCINWIDTH1); + hdmi_write(hdmi, edid->hsync_len.typ, HDMI_FC_HSYNCINWIDTH0); + + /* set up vsync active edge delay (in lines) */ + hdmi_write(hdmi, edid->vsync_len.typ, HDMI_FC_VSYNCINWIDTH); +} + +/* hdmi initialization step b.4 */ +static void hdmi_enable_video_path(struct dw_hdmi *hdmi) +{ + uint clkdis; + + /* control period minimum duration */ + hdmi_write(hdmi, 12, HDMI_FC_CTRLDUR); + hdmi_write(hdmi, 32, HDMI_FC_EXCTRLDUR); + hdmi_write(hdmi, 1, HDMI_FC_EXCTRLSPAC); + + /* set to fill tmds data channels */ + hdmi_write(hdmi, 0x0b, HDMI_FC_CH0PREAM); + hdmi_write(hdmi, 0x16, HDMI_FC_CH1PREAM); + hdmi_write(hdmi, 0x21, HDMI_FC_CH2PREAM); + + hdmi_write(hdmi, HDMI_MC_FLOWCTRL_FEED_THROUGH_OFF_CSC_BYPASS, + HDMI_MC_FLOWCTRL); + + /* enable pixel clock and tmds data path */ + clkdis = 0x7f; + clkdis &= ~HDMI_MC_CLKDIS_PIXELCLK_DISABLE; + hdmi_write(hdmi, clkdis, HDMI_MC_CLKDIS); + + clkdis &= ~HDMI_MC_CLKDIS_TMDSCLK_DISABLE; + hdmi_write(hdmi, clkdis, HDMI_MC_CLKDIS); + + clkdis &= ~HDMI_MC_CLKDIS_AUDCLK_DISABLE; + hdmi_write(hdmi, clkdis, HDMI_MC_CLKDIS); +} + +/* workaround to clear the overflow condition */ +static void hdmi_clear_overflow(struct dw_hdmi *hdmi) +{ + uint val, count; + + /* tmds software reset */ + hdmi_write(hdmi, (u8)~HDMI_MC_SWRSTZ_TMDSSWRST_REQ, HDMI_MC_SWRSTZ); + + val = hdmi_read(hdmi, HDMI_FC_INVIDCONF); + + for (count = 0; count < 4; count++) + hdmi_write(hdmi, val, HDMI_FC_INVIDCONF); +} + +static void hdmi_audio_set_format(struct dw_hdmi *hdmi) +{ + hdmi_write(hdmi, HDMI_AUD_CONF0_I2S_SELECT | HDMI_AUD_CONF0_I2S_IN_EN_0, + HDMI_AUD_CONF0); + + + hdmi_write(hdmi, HDMI_AUD_CONF1_I2S_MODE_STANDARD_MODE | + HDMI_AUD_CONF1_I2S_WIDTH_16BIT, HDMI_AUD_CONF1); + + hdmi_write(hdmi, 0x00, HDMI_AUD_CONF2); +} + +static void hdmi_audio_fifo_reset(struct dw_hdmi *hdmi) +{ + hdmi_write(hdmi, (u8)~HDMI_MC_SWRSTZ_II2SSWRST_REQ, HDMI_MC_SWRSTZ); + hdmi_write(hdmi, HDMI_AUD_CONF0_SW_AUDIO_FIFO_RST, HDMI_AUD_CONF0); + + hdmi_write(hdmi, 0x00, HDMI_AUD_INT); + hdmi_write(hdmi, 0x00, HDMI_AUD_INT1); +} + +static int hdmi_get_plug_in_status(struct dw_hdmi *hdmi) +{ + uint val = hdmi_read(hdmi, HDMI_PHY_STAT0) & HDMI_PHY_HPD; + + return !!val; +} + +static int hdmi_ddc_wait_i2c_done(struct dw_hdmi *hdmi, int msec) +{ + u32 val; + ulong start; + + start = get_timer(0); + do { + val = hdmi_read(hdmi, HDMI_IH_I2CM_STAT0); + if (val & 0x2) { + hdmi_write(hdmi, val, HDMI_IH_I2CM_STAT0); + return 0; + } + + udelay(100); + } while (get_timer(start) < msec); + + return 1; +} + +static void hdmi_ddc_reset(struct dw_hdmi *hdmi) +{ + hdmi_mod(hdmi, HDMI_I2CM_SOFTRSTZ, HDMI_I2CM_SOFTRSTZ_MASK, 0); +} + +static int hdmi_read_edid(struct dw_hdmi *hdmi, int block, u8 *buff) +{ + int shift = (block % 2) * 0x80; + int edid_read_err = 0; + u32 trytime = 5; + u32 n; + + /* set ddc i2c clk which devided from ddc_clk to 100khz */ + hdmi_write(hdmi, hdmi->i2c_clk_high, HDMI_I2CM_SS_SCL_HCNT_0_ADDR); + hdmi_write(hdmi, hdmi->i2c_clk_low, HDMI_I2CM_SS_SCL_LCNT_0_ADDR); + hdmi_mod(hdmi, HDMI_I2CM_DIV, HDMI_I2CM_DIV_FAST_STD_MODE, + HDMI_I2CM_DIV_STD_MODE); + + hdmi_write(hdmi, HDMI_I2CM_SLAVE_DDC_ADDR, HDMI_I2CM_SLAVE); + hdmi_write(hdmi, HDMI_I2CM_SEGADDR_DDC, HDMI_I2CM_SEGADDR); + hdmi_write(hdmi, block >> 1, HDMI_I2CM_SEGPTR); + + while (trytime--) { + edid_read_err = 0; + + for (n = 0; n < HDMI_EDID_BLOCK_SIZE; n++) { + hdmi_write(hdmi, shift + n, HDMI_I2CM_ADDRESS); + + if (block == 0) + hdmi_write(hdmi, HDMI_I2CM_OP_RD8, + HDMI_I2CM_OPERATION); + else + hdmi_write(hdmi, HDMI_I2CM_OP_RD8_EXT, + HDMI_I2CM_OPERATION); + + if (hdmi_ddc_wait_i2c_done(hdmi, 10)) { + hdmi_ddc_reset(hdmi); + edid_read_err = 1; + break; + } + + buff[n] = hdmi_read(hdmi, HDMI_I2CM_DATAI); + } + + if (!edid_read_err) + break; + } + + return edid_read_err; +} + +static const u8 pre_buf[] = { + 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, + 0x04, 0x69, 0xfa, 0x23, 0xc8, 0x28, 0x01, 0x00, + 0x10, 0x17, 0x01, 0x03, 0x80, 0x33, 0x1d, 0x78, + 0x2a, 0xd9, 0x45, 0xa2, 0x55, 0x4d, 0xa0, 0x27, + 0x12, 0x50, 0x54, 0xb7, 0xef, 0x00, 0x71, 0x4f, + 0x81, 0x40, 0x81, 0x80, 0x95, 0x00, 0xb3, 0x00, + 0xd1, 0xc0, 0x81, 0xc0, 0x81, 0x00, 0x02, 0x3a, + 0x80, 0x18, 0x71, 0x38, 0x2d, 0x40, 0x58, 0x2c, + 0x45, 0x00, 0xfd, 0x1e, 0x11, 0x00, 0x00, 0x1e, + 0x00, 0x00, 0x00, 0xff, 0x00, 0x44, 0x34, 0x4c, + 0x4d, 0x54, 0x46, 0x30, 0x37, 0x35, 0x39, 0x37, + 0x36, 0x0a, 0x00, 0x00, 0x00, 0xfd, 0x00, 0x32, + 0x4b, 0x18, 0x53, 0x11, 0x00, 0x0a, 0x20, 0x20, + 0x20, 0x20, 0x20, 0x20, 0x00, 0x00, 0x00, 0xfc, + 0x00, 0x41, 0x53, 0x55, 0x53, 0x20, 0x56, 0x53, + 0x32, 0x33, 0x38, 0x0a, 0x20, 0x20, 0x01, 0xb0, + 0x02, 0x03, 0x22, 0x71, 0x4f, 0x01, 0x02, 0x03, + 0x11, 0x12, 0x13, 0x04, 0x14, 0x05, 0x0e, 0x0f, + 0x1d, 0x1e, 0x1f, 0x10, 0x23, 0x09, 0x17, 0x07, + 0x83, 0x01, 0x00, 0x00, 0x65, 0x03, 0x0c, 0x00, + 0x10, 0x00, 0x8c, 0x0a, 0xd0, 0x8a, 0x20, 0xe0, + 0x2d, 0x10, 0x10, 0x3e, 0x96, 0x00, 0xfd, 0x1e, + 0x11, 0x00, 0x00, 0x18, 0x01, 0x1d, 0x00, 0x72, + 0x51, 0xd0, 0x1e, 0x20, 0x6e, 0x28, 0x55, 0x00, + 0xfd, 0x1e, 0x11, 0x00, 0x00, 0x1e, 0x01, 0x1d, + 0x00, 0xbc, 0x52, 0xd0, 0x1e, 0x20, 0xb8, 0x28, + 0x55, 0x40, 0xfd, 0x1e, 0x11, 0x00, 0x00, 0x1e, + 0x8c, 0x0a, 0xd0, 0x90, 0x20, 0x40, 0x31, 0x20, + 0x0c, 0x40, 0x55, 0x00, 0xfd, 0x1e, 0x11, 0x00, + 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe9, +}; + +int dw_hdmi_phy_cfg(struct dw_hdmi *hdmi, uint mpixelclock) +{ + int i, ret; + + /* hdmi phy spec says to do the phy initialization sequence twice */ + for (i = 0; i < 2; i++) { + hdmi_phy_sel_data_en_pol(hdmi, 1); + hdmi_phy_sel_interface_control(hdmi, 0); + hdmi_phy_enable_tmds(hdmi, 0); + hdmi_phy_enable_power(hdmi, 0); + + ret = hdmi_phy_configure(hdmi, mpixelclock); + if (ret) { + debug("hdmi phy config failure %d\n", ret); + return ret; + } + } + + return 0; +} + +int dw_hdmi_phy_wait_for_hpd(struct dw_hdmi *hdmi) +{ + ulong start; + + start = get_timer(0); + do { + if (hdmi_get_plug_in_status(hdmi)) + return 0; + udelay(100); + } while (get_timer(start) < 300); + + return -1; +} + +void dw_hdmi_phy_init(struct dw_hdmi *hdmi) +{ + /* enable phy i2cm done irq */ + hdmi_write(hdmi, HDMI_PHY_I2CM_INT_ADDR_DONE_POL, + HDMI_PHY_I2CM_INT_ADDR); + + /* enable phy i2cm nack & arbitration error irq */ + hdmi_write(hdmi, HDMI_PHY_I2CM_CTLINT_ADDR_NAC_POL | + HDMI_PHY_I2CM_CTLINT_ADDR_ARBITRATION_POL, + HDMI_PHY_I2CM_CTLINT_ADDR); + + /* enable cable hot plug irq */ + hdmi_write(hdmi, (u8)~HDMI_PHY_HPD, HDMI_PHY_MASK0); + + /* clear hotplug interrupts */ + hdmi_write(hdmi, HDMI_IH_PHY_STAT0_HPD, HDMI_IH_PHY_STAT0); +} + +int dw_hdmi_read_edid(struct dw_hdmi *hdmi, u8 *buf, int buf_size) +{ + u32 edid_size = HDMI_EDID_BLOCK_SIZE; + int ret; + + if (0) { + edid_size = sizeof(pre_buf); + memcpy(buf, pre_buf, edid_size); + } else { + ret = hdmi_read_edid(hdmi, 0, buf); + if (ret) { + debug("failed to read edid.\n"); + return -1; + } + + if (buf[0x7e] != 0) { + hdmi_read_edid(hdmi, 1, buf + HDMI_EDID_BLOCK_SIZE); + edid_size += HDMI_EDID_BLOCK_SIZE; + } + } + + return edid_size; +} + +int dw_hdmi_enable(struct dw_hdmi *hdmi, const struct display_timing *edid) +{ + int ret; + + debug("hdmi, mode info : clock %d hdis %d vdis %d\n", + edid->pixelclock.typ, edid->hactive.typ, edid->vactive.typ); + + hdmi_av_composer(hdmi, edid); + + ret = hdmi->phy_set(hdmi, edid->pixelclock.typ); + if (ret) + return ret; + + hdmi_enable_video_path(hdmi); + + hdmi_audio_fifo_reset(hdmi); + hdmi_audio_set_format(hdmi); + hdmi_audio_set_samplerate(hdmi, edid->pixelclock.typ); + + hdmi_video_packetize(hdmi); + hdmi_video_sample(hdmi); + + hdmi_clear_overflow(hdmi); + + return 0; +} + +void dw_hdmi_init(struct dw_hdmi *hdmi) +{ + uint ih_mute; + + /* + * boot up defaults are: + * hdmi_ih_mute = 0x03 (disabled) + * hdmi_ih_mute_* = 0x00 (enabled) + * + * disable top level interrupt bits in hdmi block + */ + ih_mute = /*hdmi_read(hdmi, HDMI_IH_MUTE) |*/ + HDMI_IH_MUTE_MUTE_WAKEUP_INTERRUPT | + HDMI_IH_MUTE_MUTE_ALL_INTERRUPT; + + hdmi_write(hdmi, ih_mute, HDMI_IH_MUTE); + + /* enable i2c master done irq */ + hdmi_write(hdmi, ~0x04, HDMI_I2CM_INT); + + /* enable i2c client nack % arbitration error irq */ + hdmi_write(hdmi, ~0x44, HDMI_I2CM_CTLINT); +} diff --git a/drivers/video/rockchip/Makefile b/drivers/video/rockchip/Makefile index 7962f8611e..755350b934 100644 --- a/drivers/video/rockchip/Makefile +++ b/drivers/video/rockchip/Makefile @@ -5,4 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += rk_edp.o rk_hdmi.o rk_vop.o rk_lvds.o +obj-y += rk_edp.o rk_hdmi.o rk_vop.o rk_lvds.o ../dw_hdmi.o diff --git a/drivers/video/rockchip/rk_hdmi.c b/drivers/video/rockchip/rk_hdmi.c index c8608db23c..db07588302 100644 --- a/drivers/video/rockchip/rk_hdmi.c +++ b/drivers/video/rockchip/rk_hdmi.c @@ -9,6 +9,7 @@ #include <clk.h> #include <display.h> #include <dm.h> +#include <dw_hdmi.h> #include <edid.h> #include <regmap.h> #include <syscon.h> @@ -16,73 +17,13 @@ #include <asm/io.h> #include <asm/arch/clock.h> #include <asm/arch/grf_rk3288.h> -#include <asm/arch/hdmi_rk3288.h> #include <power/regulator.h>
-struct tmds_n_cts { - u32 tmds; - u32 cts; - u32 n; -}; - struct rk_hdmi_priv { - struct rk3288_hdmi *regs; + struct dw_hdmi hdmi; struct rk3288_grf *grf; };
-static const struct tmds_n_cts n_cts_table[] = { - { - .tmds = 25175000, .n = 6144, .cts = 25175, - }, { - .tmds = 25200000, .n = 6144, .cts = 25200, - }, { - .tmds = 27000000, .n = 6144, .cts = 27000, - }, { - .tmds = 27027000, .n = 6144, .cts = 27027, - }, { - .tmds = 40000000, .n = 6144, .cts = 40000, - }, { - .tmds = 54000000, .n = 6144, .cts = 54000, - }, { - .tmds = 54054000, .n = 6144, .cts = 54054, - }, { - .tmds = 65000000, .n = 6144, .cts = 65000, - }, { - .tmds = 74176000, .n = 11648, .cts = 140625, - }, { - .tmds = 74250000, .n = 6144, .cts = 74250, - }, { - .tmds = 83500000, .n = 6144, .cts = 83500, - }, { - .tmds = 106500000, .n = 6144, .cts = 106500, - }, { - .tmds = 108000000, .n = 6144, .cts = 108000, - }, { - .tmds = 148352000, .n = 5824, .cts = 140625, - }, { - .tmds = 148500000, .n = 6144, .cts = 148500, - }, { - .tmds = 297000000, .n = 5120, .cts = 247500, - } -}; - -struct hdmi_mpll_config { - u64 mpixelclock; - /* Mode of Operation and PLL Dividers Control Register */ - u32 cpce; - /* PLL Gmp Control Register */ - u32 gmp; - /* PLL Current COntrol Register */ - u32 curr; -}; - -struct hdmi_phy_config { - u64 mpixelclock; - u32 sym_ctr; /* clock symbol and transmitter control */ - u32 term; /* transmission termination value */ - u32 vlev_ctr; /* voltage level control */ -}; - static const struct hdmi_phy_config rockchip_phy_config[] = { { .mpixelclock = 74250000, @@ -124,693 +65,41 @@ static const struct hdmi_mpll_config rockchip_mpll_cfg[] = { } };
-static void hdmi_set_clock_regenerator(struct rk3288_hdmi *regs, u32 n, u32 cts) -{ - uint cts3; - uint n3; - - /* first set ncts_atomic_write (if present) */ - n3 = HDMI_AUD_N3_NCTS_ATOMIC_WRITE; - writel(n3, ®s->aud_n3); - - /* set cts_manual (if present) */ - cts3 = HDMI_AUD_CTS3_CTS_MANUAL; - - cts3 |= HDMI_AUD_CTS3_N_SHIFT_1 << HDMI_AUD_CTS3_N_SHIFT_OFFSET; - cts3 |= (cts >> 16) & HDMI_AUD_CTS3_AUDCTS19_16_MASK; - - /* write cts values; cts3 must be written first */ - writel(cts3, ®s->aud_cts3); - writel((cts >> 8) & 0xff, ®s->aud_cts2); - writel(cts & 0xff, ®s->aud_cts1); - - /* write n values; n1 must be written last */ - n3 |= (n >> 16) & HDMI_AUD_N3_AUDN19_16_MASK; - writel(n3, ®s->aud_n3); - writel((n >> 8) & 0xff, ®s->aud_n2); - writel(n & 0xff, ®s->aud_n1); - - writel(HDMI_AUD_INPUTCLKFS_128, ®s->aud_inputclkfs); -} - -static int hdmi_lookup_n_cts(u32 pixel_clk) -{ - int i; - - for (i = 0; i < ARRAY_SIZE(n_cts_table); i++) - if (pixel_clk <= n_cts_table[i].tmds) - break; - - if (i >= ARRAY_SIZE(n_cts_table)) - return -1; - - return i; -} - -static void hdmi_audio_set_samplerate(struct rk3288_hdmi *regs, u32 pixel_clk) -{ - u32 clk_n, clk_cts; - int index; - - index = hdmi_lookup_n_cts(pixel_clk); - if (index == -1) { - debug("audio not supported for pixel clk %d\n", pixel_clk); - return; - } - - clk_n = n_cts_table[index].n; - clk_cts = n_cts_table[index].cts; - hdmi_set_clock_regenerator(regs, clk_n, clk_cts); -} - -/* - * this submodule is responsible for the video data synchronization. - * for example, for rgb 4:4:4 input, the data map is defined as - * pin{47~40} <==> r[7:0] - * pin{31~24} <==> g[7:0] - * pin{15~8} <==> b[7:0] - */ -static void hdmi_video_sample(struct rk3288_hdmi *regs) -{ - u32 color_format = 0x01; - uint val; - - val = HDMI_TX_INVID0_INTERNAL_DE_GENERATOR_DISABLE | - ((color_format << HDMI_TX_INVID0_VIDEO_MAPPING_OFFSET) & - HDMI_TX_INVID0_VIDEO_MAPPING_MASK); - - writel(val, ®s->tx_invid0); - - /* enable tx stuffing: when de is inactive, fix the output data to 0 */ - val = HDMI_TX_INSTUFFING_BDBDATA_STUFFING_ENABLE | - HDMI_TX_INSTUFFING_RCRDATA_STUFFING_ENABLE | - HDMI_TX_INSTUFFING_GYDATA_STUFFING_ENABLE; - writel(val, ®s->tx_instuffing); - writel(0x0, ®s->tx_gydata0); - writel(0x0, ®s->tx_gydata1); - writel(0x0, ®s->tx_rcrdata0); - writel(0x0, ®s->tx_rcrdata1); - writel(0x0, ®s->tx_bcbdata0); - writel(0x0, ®s->tx_bcbdata1); -} - -static void hdmi_video_packetize(struct rk3288_hdmi *regs) -{ - u32 output_select = HDMI_VP_CONF_OUTPUT_SELECTOR_BYPASS; - u32 remap_size = HDMI_VP_REMAP_YCC422_16BIT; - u32 color_depth = 0; - uint val, vp_conf; - - /* set the packetizer registers */ - val = ((color_depth << HDMI_VP_PR_CD_COLOR_DEPTH_OFFSET) & - HDMI_VP_PR_CD_COLOR_DEPTH_MASK) | - ((0 << HDMI_VP_PR_CD_DESIRED_PR_FACTOR_OFFSET) & - HDMI_VP_PR_CD_DESIRED_PR_FACTOR_MASK); - writel(val, ®s->vp_pr_cd); - - clrsetbits_le32(®s->vp_stuff, HDMI_VP_STUFF_PR_STUFFING_MASK, - HDMI_VP_STUFF_PR_STUFFING_STUFFING_MODE); - - /* data from pixel repeater block */ - vp_conf = HDMI_VP_CONF_PR_EN_DISABLE | - HDMI_VP_CONF_BYPASS_SELECT_VID_PACKETIZER; - - clrsetbits_le32(®s->vp_conf, HDMI_VP_CONF_PR_EN_MASK | - HDMI_VP_CONF_BYPASS_SELECT_MASK, vp_conf); - - clrsetbits_le32(®s->vp_stuff, HDMI_VP_STUFF_IDEFAULT_PHASE_MASK, - 1 << HDMI_VP_STUFF_IDEFAULT_PHASE_OFFSET); - - writel(remap_size, ®s->vp_remap); - - vp_conf = HDMI_VP_CONF_BYPASS_EN_ENABLE | - HDMI_VP_CONF_PP_EN_DISABLE | - HDMI_VP_CONF_YCC422_EN_DISABLE; - - clrsetbits_le32(®s->vp_conf, HDMI_VP_CONF_BYPASS_EN_MASK | - HDMI_VP_CONF_PP_EN_ENMASK | HDMI_VP_CONF_YCC422_EN_MASK, - vp_conf); - - clrsetbits_le32(®s->vp_stuff, HDMI_VP_STUFF_PP_STUFFING_MASK | - HDMI_VP_STUFF_YCC422_STUFFING_MASK, - HDMI_VP_STUFF_PP_STUFFING_STUFFING_MODE | - HDMI_VP_STUFF_YCC422_STUFFING_STUFFING_MODE); - - clrsetbits_le32(®s->vp_conf, HDMI_VP_CONF_OUTPUT_SELECTOR_MASK, - output_select); -} - -static inline void hdmi_phy_test_clear(struct rk3288_hdmi *regs, uint bit) -{ - clrsetbits_le32(®s->phy_tst0, HDMI_PHY_TST0_TSTCLR_MASK, - bit << HDMI_PHY_TST0_TSTCLR_OFFSET); -} - -static int hdmi_phy_wait_i2c_done(struct rk3288_hdmi *regs, u32 msec) -{ - ulong start; - u32 val; - - start = get_timer(0); - do { - val = readl(®s->ih_i2cmphy_stat0); - if (val & 0x3) { - writel(val, ®s->ih_i2cmphy_stat0); - return 0; - } - - udelay(100); - } while (get_timer(start) < msec); - - return 1; -} - -static void hdmi_phy_i2c_write(struct rk3288_hdmi *regs, uint data, uint addr) -{ - writel(0xff, ®s->ih_i2cmphy_stat0); - writel(addr, ®s->phy_i2cm_address_addr); - writel((u8)(data >> 8), ®s->phy_i2cm_datao_1_addr); - writel((u8)(data >> 0), ®s->phy_i2cm_datao_0_addr); - writel(HDMI_PHY_I2CM_OPERATION_ADDR_WRITE, - ®s->phy_i2cm_operation_addr); - - hdmi_phy_wait_i2c_done(regs, 1000); -} - -static void hdmi_phy_enable_power(struct rk3288_hdmi *regs, uint enable) -{ - clrsetbits_le32(®s->phy_conf0, HDMI_PHY_CONF0_PDZ_MASK, - enable << HDMI_PHY_CONF0_PDZ_OFFSET); -} - -static void hdmi_phy_enable_tmds(struct rk3288_hdmi *regs, uint enable) -{ - clrsetbits_le32(®s->phy_conf0, HDMI_PHY_CONF0_ENTMDS_MASK, - enable << HDMI_PHY_CONF0_ENTMDS_OFFSET); -} - -static void hdmi_phy_enable_spare(struct rk3288_hdmi *regs, uint enable) -{ - clrsetbits_le32(®s->phy_conf0, HDMI_PHY_CONF0_SPARECTRL_MASK, - enable << HDMI_PHY_CONF0_SPARECTRL_OFFSET); -} - -static void hdmi_phy_gen2_pddq(struct rk3288_hdmi *regs, uint enable) -{ - clrsetbits_le32(®s->phy_conf0, HDMI_PHY_CONF0_GEN2_PDDQ_MASK, - enable << HDMI_PHY_CONF0_GEN2_PDDQ_OFFSET); -} - -static void hdmi_phy_gen2_txpwron(struct rk3288_hdmi *regs, uint enable) -{ - clrsetbits_le32(®s->phy_conf0, - HDMI_PHY_CONF0_GEN2_TXPWRON_MASK, - enable << HDMI_PHY_CONF0_GEN2_TXPWRON_OFFSET); -} - -static void hdmi_phy_sel_data_en_pol(struct rk3288_hdmi *regs, uint enable) -{ - clrsetbits_le32(®s->phy_conf0, - HDMI_PHY_CONF0_SELDATAENPOL_MASK, - enable << HDMI_PHY_CONF0_SELDATAENPOL_OFFSET); -} - -static void hdmi_phy_sel_interface_control(struct rk3288_hdmi *regs, - uint enable) -{ - clrsetbits_le32(®s->phy_conf0, HDMI_PHY_CONF0_SELDIPIF_MASK, - enable << HDMI_PHY_CONF0_SELDIPIF_OFFSET); -} - -static int hdmi_phy_configure(struct rk3288_hdmi *regs, u32 mpixelclock) -{ - ulong start; - uint i, val; - - writel(HDMI_MC_FLOWCTRL_FEED_THROUGH_OFF_CSC_BYPASS, - ®s->mc_flowctrl); - - /* gen2 tx power off */ - hdmi_phy_gen2_txpwron(regs, 0); - - /* gen2 pddq */ - hdmi_phy_gen2_pddq(regs, 1); - - /* phy reset */ - writel(HDMI_MC_PHYRSTZ_DEASSERT, ®s->mc_phyrstz); - writel(HDMI_MC_PHYRSTZ_ASSERT, ®s->mc_phyrstz); - writel(HDMI_MC_HEACPHY_RST_ASSERT, ®s->mc_heacphy_rst); - - hdmi_phy_test_clear(regs, 1); - writel(HDMI_PHY_I2CM_SLAVE_ADDR_PHY_GEN2, ®s->phy_i2cm_slave_addr); - hdmi_phy_test_clear(regs, 0); - - /* pll/mpll cfg - always match on final entry */ - for (i = 0; rockchip_mpll_cfg[i].mpixelclock != (~0ul); i++) - if (mpixelclock <= rockchip_mpll_cfg[i].mpixelclock) - break; - - hdmi_phy_i2c_write(regs, rockchip_mpll_cfg[i].cpce, PHY_OPMODE_PLLCFG); - hdmi_phy_i2c_write(regs, rockchip_mpll_cfg[i].gmp, PHY_PLLGMPCTRL); - hdmi_phy_i2c_write(regs, rockchip_mpll_cfg[i].curr, PHY_PLLCURRCTRL); - - hdmi_phy_i2c_write(regs, 0x0000, PHY_PLLPHBYCTRL); - hdmi_phy_i2c_write(regs, 0x0006, PHY_PLLCLKBISTPHASE); - - for (i = 0; rockchip_phy_config[i].mpixelclock != (~0ul); i++) - if (mpixelclock <= rockchip_phy_config[i].mpixelclock) - break; - - /* - * resistance term 133ohm cfg - * preemp cgf 0.00 - * tx/ck lvl 10 - */ - hdmi_phy_i2c_write(regs, rockchip_phy_config[i].term, PHY_TXTERM); - hdmi_phy_i2c_write(regs, rockchip_phy_config[i].sym_ctr, - PHY_CKSYMTXCTRL); - hdmi_phy_i2c_write(regs, rockchip_phy_config[i].vlev_ctr, PHY_VLEVCTRL); - - /* remove clk term */ - hdmi_phy_i2c_write(regs, 0x8000, PHY_CKCALCTRL); - - hdmi_phy_enable_power(regs, 1); - - /* toggle tmds enable */ - hdmi_phy_enable_tmds(regs, 0); - hdmi_phy_enable_tmds(regs, 1); - - /* gen2 tx power on */ - hdmi_phy_gen2_txpwron(regs, 1); - hdmi_phy_gen2_pddq(regs, 0); - - hdmi_phy_enable_spare(regs, 1); - - /* wait for phy pll lock */ - start = get_timer(0); - do { - val = readl(®s->phy_stat0); - if (!(val & HDMI_PHY_TX_PHY_LOCK)) - return 0; - - udelay(100); - } while (get_timer(start) < 5); - - return -1; -} - -static int hdmi_phy_init(struct rk3288_hdmi *regs, uint mpixelclock) -{ - int i, ret; - - /* hdmi phy spec says to do the phy initialization sequence twice */ - for (i = 0; i < 2; i++) { - hdmi_phy_sel_data_en_pol(regs, 1); - hdmi_phy_sel_interface_control(regs, 0); - hdmi_phy_enable_tmds(regs, 0); - hdmi_phy_enable_power(regs, 0); - - ret = hdmi_phy_configure(regs, mpixelclock); - if (ret) { - debug("hdmi phy config failure %d\n", ret); - return ret; - } - } - - return 0; -} - -static void hdmi_av_composer(struct rk3288_hdmi *regs, - const struct display_timing *edid) -{ - bool mdataenablepolarity = true; - uint inv_val; - uint hbl; - uint vbl; - - hbl = edid->hback_porch.typ + edid->hfront_porch.typ + - edid->hsync_len.typ; - vbl = edid->vback_porch.typ + edid->vfront_porch.typ + - edid->vsync_len.typ; - - /* set up hdmi_fc_invidconf */ - inv_val = HDMI_FC_INVIDCONF_HDCP_KEEPOUT_INACTIVE; - - inv_val |= (edid->flags & DISPLAY_FLAGS_HSYNC_HIGH ? - HDMI_FC_INVIDCONF_VSYNC_IN_POLARITY_ACTIVE_HIGH : - HDMI_FC_INVIDCONF_VSYNC_IN_POLARITY_ACTIVE_LOW); - - inv_val |= (edid->flags & DISPLAY_FLAGS_VSYNC_HIGH ? - HDMI_FC_INVIDCONF_HSYNC_IN_POLARITY_ACTIVE_HIGH : - HDMI_FC_INVIDCONF_HSYNC_IN_POLARITY_ACTIVE_LOW); - - inv_val |= (mdataenablepolarity ? - HDMI_FC_INVIDCONF_DE_IN_POLARITY_ACTIVE_HIGH : - HDMI_FC_INVIDCONF_DE_IN_POLARITY_ACTIVE_LOW); - - /* - * TODO(sjg@chromium.org>: Need to check for HDMI / DVI - * inv_val |= (edid->hdmi_monitor_detected ? - * HDMI_FC_INVIDCONF_DVI_MODEZ_HDMI_MODE : - * HDMI_FC_INVIDCONF_DVI_MODEZ_DVI_MODE); - */ - inv_val |= HDMI_FC_INVIDCONF_DVI_MODEZ_HDMI_MODE; - - inv_val |= HDMI_FC_INVIDCONF_R_V_BLANK_IN_OSC_ACTIVE_LOW; - - inv_val |= HDMI_FC_INVIDCONF_IN_I_P_PROGRESSIVE; - - writel(inv_val, ®s->fc_invidconf); - - /* set up horizontal active pixel width */ - writel(edid->hactive.typ >> 8, ®s->fc_inhactv1); - writel(edid->hactive.typ, ®s->fc_inhactv0); - - /* set up vertical active lines */ - writel(edid->vactive.typ >> 8, ®s->fc_invactv1); - writel(edid->vactive.typ, ®s->fc_invactv0); - - /* set up horizontal blanking pixel region width */ - writel(hbl >> 8, ®s->fc_inhblank1); - writel(hbl, ®s->fc_inhblank0); - - /* set up vertical blanking pixel region width */ - writel(vbl, ®s->fc_invblank); - - /* set up hsync active edge delay width (in pixel clks) */ - writel(edid->hfront_porch.typ >> 8, ®s->fc_hsyncindelay1); - writel(edid->hfront_porch.typ, ®s->fc_hsyncindelay0); - - /* set up vsync active edge delay (in lines) */ - writel(edid->vfront_porch.typ, ®s->fc_vsyncindelay); - - /* set up hsync active pulse width (in pixel clks) */ - writel(edid->hsync_len.typ >> 8, ®s->fc_hsyncinwidth1); - writel(edid->hsync_len.typ, ®s->fc_hsyncinwidth0); - - /* set up vsync active edge delay (in lines) */ - writel(edid->vsync_len.typ, ®s->fc_vsyncinwidth); -} - -/* hdmi initialization step b.4 */ -static void hdmi_enable_video_path(struct rk3288_hdmi *regs) -{ - uint clkdis; - - /* control period minimum duration */ - writel(12, ®s->fc_ctrldur); - writel(32, ®s->fc_exctrldur); - writel(1, ®s->fc_exctrlspac); - - /* set to fill tmds data channels */ - writel(0x0b, ®s->fc_ch0pream); - writel(0x16, ®s->fc_ch1pream); - writel(0x21, ®s->fc_ch2pream); - - /* enable pixel clock and tmds data path */ - clkdis = 0x7f; - clkdis &= ~HDMI_MC_CLKDIS_PIXELCLK_DISABLE; - writel(clkdis, ®s->mc_clkdis); - - clkdis &= ~HDMI_MC_CLKDIS_TMDSCLK_DISABLE; - writel(clkdis, ®s->mc_clkdis); - - clkdis &= ~HDMI_MC_CLKDIS_AUDCLK_DISABLE; - writel(clkdis, ®s->mc_clkdis); -} - -/* workaround to clear the overflow condition */ -static void hdmi_clear_overflow(struct rk3288_hdmi *regs) -{ - uint val, count; - - /* tmds software reset */ - writel((u8)~HDMI_MC_SWRSTZ_TMDSSWRST_REQ, ®s->mc_swrstz); - - val = readl(®s->fc_invidconf); - - for (count = 0; count < 4; count++) - writel(val, ®s->fc_invidconf); -} - -static void hdmi_audio_set_format(struct rk3288_hdmi *regs) -{ - writel(HDMI_AUD_CONF0_I2S_SELECT | HDMI_AUD_CONF0_I2S_IN_EN_0, - ®s->aud_conf0); - - - writel(HDMI_AUD_CONF1_I2S_MODE_STANDARD_MODE | - HDMI_AUD_CONF1_I2S_WIDTH_16BIT, ®s->aud_conf1); - - writel(0x00, ®s->aud_conf2); -} - -static void hdmi_audio_fifo_reset(struct rk3288_hdmi *regs) -{ - writel((u8)~HDMI_MC_SWRSTZ_II2SSWRST_REQ, ®s->mc_swrstz); - writel(HDMI_AUD_CONF0_SW_AUDIO_FIFO_RST, ®s->aud_conf0); - - writel(0x00, ®s->aud_int); - writel(0x00, ®s->aud_int1); -} - -static void hdmi_init_interrupt(struct rk3288_hdmi *regs) -{ - uint ih_mute; - - /* - * boot up defaults are: - * hdmi_ih_mute = 0x03 (disabled) - * hdmi_ih_mute_* = 0x00 (enabled) - * - * disable top level interrupt bits in hdmi block - */ - ih_mute = readl(®s->ih_mute) | - HDMI_IH_MUTE_MUTE_WAKEUP_INTERRUPT | - HDMI_IH_MUTE_MUTE_ALL_INTERRUPT; - - writel(ih_mute, ®s->ih_mute); - - /* enable i2c master done irq */ - writel(~0x04, ®s->i2cm_int); - - /* enable i2c client nack % arbitration error irq */ - writel(~0x44, ®s->i2cm_ctlint); - - /* enable phy i2cm done irq */ - writel(HDMI_PHY_I2CM_INT_ADDR_DONE_POL, ®s->phy_i2cm_int_addr); - - /* enable phy i2cm nack & arbitration error irq */ - writel(HDMI_PHY_I2CM_CTLINT_ADDR_NAC_POL | - HDMI_PHY_I2CM_CTLINT_ADDR_ARBITRATION_POL, - ®s->phy_i2cm_ctlint_addr); - - /* enable cable hot plug irq */ - writel((u8)~HDMI_PHY_HPD, ®s->phy_mask0); - - /* clear hotplug interrupts */ - writel(HDMI_IH_PHY_STAT0_HPD, ®s->ih_phy_stat0); -} - -static int hdmi_get_plug_in_status(struct rk3288_hdmi *regs) -{ - uint val = readl(®s->phy_stat0) & HDMI_PHY_HPD; - - return !!val; -} - -static int hdmi_wait_for_hpd(struct rk3288_hdmi *regs) -{ - ulong start; - - start = get_timer(0); - do { - if (hdmi_get_plug_in_status(regs)) - return 0; - udelay(100); - } while (get_timer(start) < 300); - - return -1; -} - -static int hdmi_ddc_wait_i2c_done(struct rk3288_hdmi *regs, int msec) -{ - u32 val; - ulong start; - - start = get_timer(0); - do { - val = readl(®s->ih_i2cm_stat0); - if (val & 0x2) { - writel(val, ®s->ih_i2cm_stat0); - return 0; - } - - udelay(100); - } while (get_timer(start) < msec); - - return 1; -} - -static void hdmi_ddc_reset(struct rk3288_hdmi *regs) -{ - clrbits_le32(®s->i2cm_softrstz, HDMI_I2CM_SOFTRSTZ); -} - -static int hdmi_read_edid(struct rk3288_hdmi *regs, int block, u8 *buff) -{ - int shift = (block % 2) * 0x80; - int edid_read_err = 0; - u32 trytime = 5; - u32 n, j, val; - - /* set ddc i2c clk which devided from ddc_clk to 100khz */ - writel(0x7a, ®s->i2cm_ss_scl_hcnt_0_addr); - writel(0x8d, ®s->i2cm_ss_scl_lcnt_0_addr); - - /* - * TODO(sjg@chromium.org): The above values don't work - these ones - * work better, but generate lots of errors in the data. - */ - writel(0x0d, ®s->i2cm_ss_scl_hcnt_0_addr); - writel(0x0d, ®s->i2cm_ss_scl_lcnt_0_addr); - clrsetbits_le32(®s->i2cm_div, HDMI_I2CM_DIV_FAST_STD_MODE, - HDMI_I2CM_DIV_STD_MODE); - - writel(HDMI_I2CM_SLAVE_DDC_ADDR, ®s->i2cm_slave); - writel(HDMI_I2CM_SEGADDR_DDC, ®s->i2cm_segaddr); - writel(block >> 1, ®s->i2cm_segptr); - - while (trytime--) { - edid_read_err = 0; - - for (n = 0; n < HDMI_EDID_BLOCK_SIZE / 8; n++) { - writel(shift + 8 * n, ®s->i2c_address); - - if (block == 0) - clrsetbits_le32(®s->i2cm_operation, - HDMI_I2CM_OPT_RD8, - HDMI_I2CM_OPT_RD8); - else - clrsetbits_le32(®s->i2cm_operation, - HDMI_I2CM_OPT_RD8_EXT, - HDMI_I2CM_OPT_RD8_EXT); - - if (hdmi_ddc_wait_i2c_done(regs, 10)) { - hdmi_ddc_reset(regs); - edid_read_err = 1; - break; - } - - for (j = 0; j < 8; j++) { - val = readl(®s->i2cm_buf0 + j); - buff[8 * n + j] = val; - } - } - - if (!edid_read_err) - break; - } - - return edid_read_err; -} - -static const u8 pre_buf[] = { - 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x00, - 0x04, 0x69, 0xfa, 0x23, 0xc8, 0x28, 0x01, 0x00, - 0x10, 0x17, 0x01, 0x03, 0x80, 0x33, 0x1d, 0x78, - 0x2a, 0xd9, 0x45, 0xa2, 0x55, 0x4d, 0xa0, 0x27, - 0x12, 0x50, 0x54, 0xb7, 0xef, 0x00, 0x71, 0x4f, - 0x81, 0x40, 0x81, 0x80, 0x95, 0x00, 0xb3, 0x00, - 0xd1, 0xc0, 0x81, 0xc0, 0x81, 0x00, 0x02, 0x3a, - 0x80, 0x18, 0x71, 0x38, 0x2d, 0x40, 0x58, 0x2c, - 0x45, 0x00, 0xfd, 0x1e, 0x11, 0x00, 0x00, 0x1e, - 0x00, 0x00, 0x00, 0xff, 0x00, 0x44, 0x34, 0x4c, - 0x4d, 0x54, 0x46, 0x30, 0x37, 0x35, 0x39, 0x37, - 0x36, 0x0a, 0x00, 0x00, 0x00, 0xfd, 0x00, 0x32, - 0x4b, 0x18, 0x53, 0x11, 0x00, 0x0a, 0x20, 0x20, - 0x20, 0x20, 0x20, 0x20, 0x00, 0x00, 0x00, 0xfc, - 0x00, 0x41, 0x53, 0x55, 0x53, 0x20, 0x56, 0x53, - 0x32, 0x33, 0x38, 0x0a, 0x20, 0x20, 0x01, 0xb0, - 0x02, 0x03, 0x22, 0x71, 0x4f, 0x01, 0x02, 0x03, - 0x11, 0x12, 0x13, 0x04, 0x14, 0x05, 0x0e, 0x0f, - 0x1d, 0x1e, 0x1f, 0x10, 0x23, 0x09, 0x17, 0x07, - 0x83, 0x01, 0x00, 0x00, 0x65, 0x03, 0x0c, 0x00, - 0x10, 0x00, 0x8c, 0x0a, 0xd0, 0x8a, 0x20, 0xe0, - 0x2d, 0x10, 0x10, 0x3e, 0x96, 0x00, 0xfd, 0x1e, - 0x11, 0x00, 0x00, 0x18, 0x01, 0x1d, 0x00, 0x72, - 0x51, 0xd0, 0x1e, 0x20, 0x6e, 0x28, 0x55, 0x00, - 0xfd, 0x1e, 0x11, 0x00, 0x00, 0x1e, 0x01, 0x1d, - 0x00, 0xbc, 0x52, 0xd0, 0x1e, 0x20, 0xb8, 0x28, - 0x55, 0x40, 0xfd, 0x1e, 0x11, 0x00, 0x00, 0x1e, - 0x8c, 0x0a, 0xd0, 0x90, 0x20, 0x40, 0x31, 0x20, - 0x0c, 0x40, 0x55, 0x00, 0xfd, 0x1e, 0x11, 0x00, - 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, - 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xe9, -}; - static int rk_hdmi_read_edid(struct udevice *dev, u8 *buf, int buf_size) { struct rk_hdmi_priv *priv = dev_get_priv(dev); - u32 edid_size = HDMI_EDID_BLOCK_SIZE; - int ret; - - if (0) { - edid_size = sizeof(pre_buf); - memcpy(buf, pre_buf, edid_size); - } else { - ret = hdmi_read_edid(priv->regs, 0, buf); - if (ret) { - debug("failed to read edid.\n"); - return -1; - }
- if (buf[0x7e] != 0) { - hdmi_read_edid(priv->regs, 1, - buf + HDMI_EDID_BLOCK_SIZE); - edid_size += HDMI_EDID_BLOCK_SIZE; - } - } - - return edid_size; + return dw_hdmi_read_edid(&priv->hdmi, buf, buf_size); }
static int rk_hdmi_enable(struct udevice *dev, int panel_bpp, const struct display_timing *edid) { struct rk_hdmi_priv *priv = dev_get_priv(dev); - struct rk3288_hdmi *regs = priv->regs; - int ret; - - debug("hdmi, mode info : clock %d hdis %d vdis %d\n", - edid->pixelclock.typ, edid->hactive.typ, edid->vactive.typ);
- hdmi_av_composer(regs, edid); - - ret = hdmi_phy_init(regs, edid->pixelclock.typ); - if (ret) - return ret; - - hdmi_enable_video_path(regs); - - hdmi_audio_fifo_reset(regs); - hdmi_audio_set_format(regs); - hdmi_audio_set_samplerate(regs, edid->pixelclock.typ); - - hdmi_video_packetize(regs); - hdmi_video_sample(regs); - - hdmi_clear_overflow(regs); - - return 0; + return dw_hdmi_enable(&priv->hdmi, edid); }
static int rk_hdmi_ofdata_to_platdata(struct udevice *dev) { struct rk_hdmi_priv *priv = dev_get_priv(dev); + struct dw_hdmi *hdmi = &priv->hdmi; + + hdmi->ioaddr = (ulong)dev_get_addr(dev); + hdmi->mpll_cfg = rockchip_mpll_cfg; + hdmi->phy_cfg = rockchip_phy_config; + hdmi->i2c_clk_high = 0x7a; + hdmi->i2c_clk_low = 0x8d; + + /* + * TODO(sjg@chromium.org): The above values don't work - these ones + * work better, but generate lots of errors in the data. + */ + hdmi->i2c_clk_high = 0x0d; + hdmi->i2c_clk_low = 0x0d; + hdmi->reg_io_width = 4; + hdmi->phy_set = dw_hdmi_phy_cfg;
- priv->regs = (struct rk3288_hdmi *)dev_get_addr(dev); priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF);
return 0; @@ -820,6 +109,7 @@ static int rk_hdmi_probe(struct udevice *dev) { struct display_plat *uc_plat = dev_get_uclass_platdata(dev); struct rk_hdmi_priv *priv = dev_get_priv(dev); + struct dw_hdmi *hdmi = &priv->hdmi; struct udevice *reg; struct clk clk; int ret; @@ -863,13 +153,14 @@ static int rk_hdmi_probe(struct udevice *dev) rk_clrsetreg(&priv->grf->soc_con6, 1 << 4, (vop_id == 1) ? (1 << 4) : 0);
- ret = hdmi_wait_for_hpd(priv->regs); + ret = dw_hdmi_phy_wait_for_hpd(hdmi); if (ret < 0) { debug("hdmi can not get hpd signal\n"); return -1; }
- hdmi_init_interrupt(priv->regs); + dw_hdmi_init(hdmi); + dw_hdmi_phy_init(hdmi);
return 0; } diff --git a/drivers/video/rockchip/rk_vop.c b/drivers/video/rockchip/rk_vop.c index aeecb5815b..bc02f800dc 100644 --- a/drivers/video/rockchip/rk_vop.c +++ b/drivers/video/rockchip/rk_vop.c @@ -20,7 +20,6 @@ #include <asm/arch/cru_rk3288.h> #include <asm/arch/grf_rk3288.h> #include <asm/arch/edp_rk3288.h> -#include <asm/arch/hdmi_rk3288.h> #include <asm/arch/vop_rk3288.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h> diff --git a/include/dw_hdmi.h b/include/dw_hdmi.h new file mode 100644 index 0000000000..902abd4d44 --- /dev/null +++ b/include/dw_hdmi.h @@ -0,0 +1,486 @@ +/* + * Copyright (c) 2015 Google, Inc + * Copyright 2014 Rockchip Inc. + * Copyright (C) 2011 Freescale Semiconductor, Inc. + * (C) Copyright 2017 Jernej Skrabec jernej.skrabec@siol.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _DW_HDMI_H +#define _DW_HDMI_H + +#include <edid.h> + +#define HDMI_EDID_BLOCK_SIZE 128 + +/* Identification Registers */ +#define HDMI_DESIGN_ID 0x0000 +#define HDMI_REVISION_ID 0x0001 +#define HDMI_PRODUCT_ID0 0x0002 +#define HDMI_PRODUCT_ID1 0x0003 +#define HDMI_CONFIG0_ID 0x0004 +#define HDMI_CONFIG1_ID 0x0005 +#define HDMI_CONFIG2_ID 0x0006 +#define HDMI_CONFIG3_ID 0x0007 + +/* Interrupt Registers */ +#define HDMI_IH_FC_STAT0 0x0100 +#define HDMI_IH_FC_STAT1 0x0101 +#define HDMI_IH_FC_STAT2 0x0102 +#define HDMI_IH_AS_STAT0 0x0103 +#define HDMI_IH_PHY_STAT0 0x0104 +#define HDMI_IH_I2CM_STAT0 0x0105 +#define HDMI_IH_CEC_STAT0 0x0106 +#define HDMI_IH_VP_STAT0 0x0107 +#define HDMI_IH_I2CMPHY_STAT0 0x0108 +#define HDMI_IH_AHBDMAAUD_STAT0 0x0109 + +#define HDMI_IH_MUTE_FC_STAT0 0x0180 +#define HDMI_IH_MUTE_FC_STAT1 0x0181 +#define HDMI_IH_MUTE_FC_STAT2 0x0182 +#define HDMI_IH_MUTE_AS_STAT0 0x0183 +#define HDMI_IH_MUTE_PHY_STAT0 0x0184 +#define HDMI_IH_MUTE_I2CM_STAT0 0x0185 +#define HDMI_IH_MUTE_CEC_STAT0 0x0186 +#define HDMI_IH_MUTE_VP_STAT0 0x0187 +#define HDMI_IH_MUTE_I2CMPHY_STAT0 0x0188 +#define HDMI_IH_MUTE_AHBDMAAUD_STAT0 0x0189 +#define HDMI_IH_MUTE 0x01FF + +/* Video Sample Registers */ +#define HDMI_TX_INVID0 0x0200 +#define HDMI_TX_INSTUFFING 0x0201 +#define HDMI_TX_GYDATA0 0x0202 +#define HDMI_TX_GYDATA1 0x0203 +#define HDMI_TX_RCRDATA0 0x0204 +#define HDMI_TX_RCRDATA1 0x0205 +#define HDMI_TX_BCBDATA0 0x0206 +#define HDMI_TX_BCBDATA1 0x0207 + +/* Video Packetizer Registers */ +#define HDMI_VP_STATUS 0x0800 +#define HDMI_VP_PR_CD 0x0801 +#define HDMI_VP_STUFF 0x0802 +#define HDMI_VP_REMAP 0x0803 +#define HDMI_VP_CONF 0x0804 +#define HDMI_VP_STAT 0x0805 +#define HDMI_VP_INT 0x0806 +#define HDMI_VP_MASK 0x0807 +#define HDMI_VP_POL 0x0808 + +/* Frame Composer Registers */ +#define HDMI_FC_INVIDCONF 0x1000 +#define HDMI_FC_INHACTV0 0x1001 +#define HDMI_FC_INHACTV1 0x1002 +#define HDMI_FC_INHBLANK0 0x1003 +#define HDMI_FC_INHBLANK1 0x1004 +#define HDMI_FC_INVACTV0 0x1005 +#define HDMI_FC_INVACTV1 0x1006 +#define HDMI_FC_INVBLANK 0x1007 +#define HDMI_FC_HSYNCINDELAY0 0x1008 +#define HDMI_FC_HSYNCINDELAY1 0x1009 +#define HDMI_FC_HSYNCINWIDTH0 0x100A +#define HDMI_FC_HSYNCINWIDTH1 0x100B +#define HDMI_FC_VSYNCINDELAY 0x100C +#define HDMI_FC_VSYNCINWIDTH 0x100D +#define HDMI_FC_INFREQ0 0x100E +#define HDMI_FC_INFREQ1 0x100F +#define HDMI_FC_INFREQ2 0x1010 +#define HDMI_FC_CTRLDUR 0x1011 +#define HDMI_FC_EXCTRLDUR 0x1012 +#define HDMI_FC_EXCTRLSPAC 0x1013 +#define HDMI_FC_CH0PREAM 0x1014 +#define HDMI_FC_CH1PREAM 0x1015 +#define HDMI_FC_CH2PREAM 0x1016 +#define HDMI_FC_AVICONF3 0x1017 +#define HDMI_FC_GCP 0x1018 +#define HDMI_FC_AVICONF0 0x1019 +#define HDMI_FC_AVICONF1 0x101A +#define HDMI_FC_AVICONF2 0x101B +#define HDMI_FC_AVIVID 0x101C +#define HDMI_FC_AVIETB0 0x101D +#define HDMI_FC_AVIETB1 0x101E +#define HDMI_FC_AVISBB0 0x101F +#define HDMI_FC_AVISBB1 0x1020 +#define HDMI_FC_AVIELB0 0x1021 +#define HDMI_FC_AVIELB1 0x1022 +#define HDMI_FC_AVISRB0 0x1023 +#define HDMI_FC_AVISRB1 0x1024 +#define HDMI_FC_AUDICONF0 0x1025 +#define HDMI_FC_AUDICONF1 0x1026 +#define HDMI_FC_AUDICONF2 0x1027 +#define HDMI_FC_AUDICONF3 0x1028 +#define HDMI_FC_VSDIEEEID0 0x1029 +#define HDMI_FC_VSDSIZE 0x102A + +/* HDMI Source PHY Registers */ +#define HDMI_PHY_CONF0 0x3000 +#define HDMI_PHY_TST0 0x3001 +#define HDMI_PHY_TST1 0x3002 +#define HDMI_PHY_TST2 0x3003 +#define HDMI_PHY_STAT0 0x3004 +#define HDMI_PHY_INT0 0x3005 +#define HDMI_PHY_MASK0 0x3006 +#define HDMI_PHY_POL0 0x3007 + +/* HDMI Master PHY Registers */ +#define HDMI_PHY_I2CM_SLAVE_ADDR 0x3020 +#define HDMI_PHY_I2CM_ADDRESS_ADDR 0x3021 +#define HDMI_PHY_I2CM_DATAO_1_ADDR 0x3022 +#define HDMI_PHY_I2CM_DATAO_0_ADDR 0x3023 +#define HDMI_PHY_I2CM_DATAI_1_ADDR 0x3024 +#define HDMI_PHY_I2CM_DATAI_0_ADDR 0x3025 +#define HDMI_PHY_I2CM_OPERATION_ADDR 0x3026 +#define HDMI_PHY_I2CM_INT_ADDR 0x3027 +#define HDMI_PHY_I2CM_CTLINT_ADDR 0x3028 +#define HDMI_PHY_I2CM_DIV_ADDR 0x3029 +#define HDMI_PHY_I2CM_SOFTRSTZ_ADDR 0x302a +#define HDMI_PHY_I2CM_SS_SCL_HCNT_1_ADDR 0x302b +#define HDMI_PHY_I2CM_SS_SCL_HCNT_0_ADDR 0x302c +#define HDMI_PHY_I2CM_SS_SCL_LCNT_1_ADDR 0x302d +#define HDMI_PHY_I2CM_SS_SCL_LCNT_0_ADDR 0x302e +#define HDMI_PHY_I2CM_FS_SCL_HCNT_1_ADDR 0x302f +#define HDMI_PHY_I2CM_FS_SCL_HCNT_0_ADDR 0x3030 +#define HDMI_PHY_I2CM_FS_SCL_LCNT_1_ADDR 0x3031 +#define HDMI_PHY_I2CM_FS_SCL_LCNT_0_ADDR 0x3032 + +/* Audio Sampler Registers */ +#define HDMI_AUD_CONF0 0x3100 +#define HDMI_AUD_CONF1 0x3101 +#define HDMI_AUD_INT 0x3102 +#define HDMI_AUD_CONF2 0x3103 +#define HDMI_AUD_INT1 0x3104 +#define HDMI_AUD_N1 0x3200 +#define HDMI_AUD_N2 0x3201 +#define HDMI_AUD_N3 0x3202 +#define HDMI_AUD_CTS1 0x3203 +#define HDMI_AUD_CTS2 0x3204 +#define HDMI_AUD_CTS3 0x3205 +#define HDMI_AUD_INPUTCLKFS 0x3206 +#define HDMI_AUD_SPDIFINT 0x3302 +#define HDMI_AUD_CONF0_HBR 0x3400 +#define HDMI_AUD_HBR_STATUS 0x3401 +#define HDMI_AUD_HBR_INT 0x3402 +#define HDMI_AUD_HBR_POL 0x3403 +#define HDMI_AUD_HBR_MASK 0x3404 + +/* Main Controller Registers */ +#define HDMI_MC_SFRDIV 0x4000 +#define HDMI_MC_CLKDIS 0x4001 +#define HDMI_MC_SWRSTZ 0x4002 +#define HDMI_MC_OPCTRL 0x4003 +#define HDMI_MC_FLOWCTRL 0x4004 +#define HDMI_MC_PHYRSTZ 0x4005 +#define HDMI_MC_LOCKONCLOCK 0x4006 +#define HDMI_MC_HEACPHY_RST 0x4007 + +/* I2C Master Registers (E-DDC) */ +#define HDMI_I2CM_SLAVE 0x7E00 +#define HDMI_I2CM_ADDRESS 0x7E01 +#define HDMI_I2CM_DATAO 0x7E02 +#define HDMI_I2CM_DATAI 0x7E03 +#define HDMI_I2CM_OPERATION 0x7E04 +#define HDMI_I2CM_INT 0x7E05 +#define HDMI_I2CM_CTLINT 0x7E06 +#define HDMI_I2CM_DIV 0x7E07 +#define HDMI_I2CM_SEGADDR 0x7E08 +#define HDMI_I2CM_SOFTRSTZ 0x7E09 +#define HDMI_I2CM_SEGPTR 0x7E0A +#define HDMI_I2CM_SS_SCL_HCNT_1_ADDR 0x7E0B +#define HDMI_I2CM_SS_SCL_HCNT_0_ADDR 0x7E0C +#define HDMI_I2CM_SS_SCL_LCNT_1_ADDR 0x7E0D +#define HDMI_I2CM_SS_SCL_LCNT_0_ADDR 0x7E0E +#define HDMI_I2CM_FS_SCL_HCNT_1_ADDR 0x7E0F +#define HDMI_I2CM_FS_SCL_HCNT_0_ADDR 0x7E10 +#define HDMI_I2CM_FS_SCL_LCNT_1_ADDR 0x7E11 +#define HDMI_I2CM_FS_SCL_LCNT_0_ADDR 0x7E12 +#define HDMI_I2CM_BUF0 0x7E20 + +enum { + /* HDMI PHY registers define */ + PHY_OPMODE_PLLCFG = 0x06, + PHY_CKCALCTRL = 0x05, + PHY_CKSYMTXCTRL = 0x09, + PHY_VLEVCTRL = 0x0e, + PHY_PLLCURRCTRL = 0x10, + PHY_PLLPHBYCTRL = 0x13, + PHY_PLLGMPCTRL = 0x15, + PHY_PLLCLKBISTPHASE = 0x17, + PHY_TXTERM = 0x19, + + /* ih_phy_stat0 field values */ + HDMI_IH_PHY_STAT0_HPD = 0x1, + + /* ih_mute field values */ + HDMI_IH_MUTE_MUTE_WAKEUP_INTERRUPT = 0x2, + HDMI_IH_MUTE_MUTE_ALL_INTERRUPT = 0x1, + + /* tx_invid0 field values */ + HDMI_TX_INVID0_INTERNAL_DE_GENERATOR_DISABLE = 0x00, + HDMI_TX_INVID0_VIDEO_MAPPING_MASK = 0x1f, + HDMI_TX_INVID0_VIDEO_MAPPING_OFFSET = 0, + + /* tx_instuffing field values */ + HDMI_TX_INSTUFFING_BDBDATA_STUFFING_ENABLE = 0x4, + HDMI_TX_INSTUFFING_RCRDATA_STUFFING_ENABLE = 0x2, + HDMI_TX_INSTUFFING_GYDATA_STUFFING_ENABLE = 0x1, + + /* vp_pr_cd field values */ + HDMI_VP_PR_CD_COLOR_DEPTH_MASK = 0xf0, + HDMI_VP_PR_CD_COLOR_DEPTH_OFFSET = 4, + HDMI_VP_PR_CD_DESIRED_PR_FACTOR_MASK = 0x0f, + HDMI_VP_PR_CD_DESIRED_PR_FACTOR_OFFSET = 0, + + /* vp_stuff field values */ + HDMI_VP_STUFF_IDEFAULT_PHASE_MASK = 0x20, + HDMI_VP_STUFF_IDEFAULT_PHASE_OFFSET = 5, + HDMI_VP_STUFF_YCC422_STUFFING_MASK = 0x4, + HDMI_VP_STUFF_YCC422_STUFFING_STUFFING_MODE = 0x4, + HDMI_VP_STUFF_PP_STUFFING_MASK = 0x2, + HDMI_VP_STUFF_PP_STUFFING_STUFFING_MODE = 0x2, + HDMI_VP_STUFF_PR_STUFFING_MASK = 0x1, + HDMI_VP_STUFF_PR_STUFFING_STUFFING_MODE = 0x1, + + /* vp_conf field values */ + HDMI_VP_CONF_BYPASS_EN_MASK = 0x40, + HDMI_VP_CONF_BYPASS_EN_ENABLE = 0x40, + HDMI_VP_CONF_PP_EN_ENMASK = 0x20, + HDMI_VP_CONF_PP_EN_DISABLE = 0x00, + HDMI_VP_CONF_PR_EN_MASK = 0x10, + HDMI_VP_CONF_PR_EN_DISABLE = 0x00, + HDMI_VP_CONF_YCC422_EN_MASK = 0x8, + HDMI_VP_CONF_YCC422_EN_DISABLE = 0x0, + HDMI_VP_CONF_BYPASS_SELECT_MASK = 0x4, + HDMI_VP_CONF_BYPASS_SELECT_VID_PACKETIZER = 0x4, + HDMI_VP_CONF_OUTPUT_SELECTOR_MASK = 0x3, + HDMI_VP_CONF_OUTPUT_SELECTOR_BYPASS = 0x3, + + /* vp_remap field values */ + HDMI_VP_REMAP_YCC422_16BIT = 0x0, + + /* fc_invidconf field values */ + HDMI_FC_INVIDCONF_HDCP_KEEPOUT_MASK = 0x80, + HDMI_FC_INVIDCONF_HDCP_KEEPOUT_ACTIVE = 0x80, + HDMI_FC_INVIDCONF_HDCP_KEEPOUT_INACTIVE = 0x00, + HDMI_FC_INVIDCONF_VSYNC_IN_POLARITY_MASK = 0x40, + HDMI_FC_INVIDCONF_VSYNC_IN_POLARITY_ACTIVE_HIGH = 0x40, + HDMI_FC_INVIDCONF_VSYNC_IN_POLARITY_ACTIVE_LOW = 0x00, + HDMI_FC_INVIDCONF_HSYNC_IN_POLARITY_MASK = 0x20, + HDMI_FC_INVIDCONF_HSYNC_IN_POLARITY_ACTIVE_HIGH = 0x20, + HDMI_FC_INVIDCONF_HSYNC_IN_POLARITY_ACTIVE_LOW = 0x00, + HDMI_FC_INVIDCONF_DE_IN_POLARITY_MASK = 0x10, + HDMI_FC_INVIDCONF_DE_IN_POLARITY_ACTIVE_HIGH = 0x10, + HDMI_FC_INVIDCONF_DE_IN_POLARITY_ACTIVE_LOW = 0x00, + HDMI_FC_INVIDCONF_DVI_MODEZ_MASK = 0x8, + HDMI_FC_INVIDCONF_DVI_MODEZ_HDMI_MODE = 0x8, + HDMI_FC_INVIDCONF_DVI_MODEZ_DVI_MODE = 0x0, + HDMI_FC_INVIDCONF_R_V_BLANK_IN_OSC_MASK = 0x2, + HDMI_FC_INVIDCONF_R_V_BLANK_IN_OSC_ACTIVE_HIGH = 0x2, + HDMI_FC_INVIDCONF_R_V_BLANK_IN_OSC_ACTIVE_LOW = 0x0, + HDMI_FC_INVIDCONF_IN_I_P_MASK = 0x1, + HDMI_FC_INVIDCONF_IN_I_P_INTERLACED = 0x1, + HDMI_FC_INVIDCONF_IN_I_P_PROGRESSIVE = 0x0, + + + /* fc_aviconf0-fc_aviconf3 field values */ + HDMI_FC_AVICONF0_PIX_FMT_MASK = 0x03, + HDMI_FC_AVICONF0_PIX_FMT_RGB = 0x00, + HDMI_FC_AVICONF0_PIX_FMT_YCBCR422 = 0x01, + HDMI_FC_AVICONF0_PIX_FMT_YCBCR444 = 0x02, + HDMI_FC_AVICONF0_ACTIVE_FMT_MASK = 0x40, + HDMI_FC_AVICONF0_ACTIVE_FMT_INFO_PRESENT = 0x40, + HDMI_FC_AVICONF0_ACTIVE_FMT_NO_INFO = 0x00, + HDMI_FC_AVICONF0_BAR_DATA_MASK = 0x0c, + HDMI_FC_AVICONF0_BAR_DATA_NO_DATA = 0x00, + HDMI_FC_AVICONF0_BAR_DATA_VERT_BAR = 0x04, + HDMI_FC_AVICONF0_BAR_DATA_HORIZ_BAR = 0x08, + HDMI_FC_AVICONF0_BAR_DATA_VERT_HORIZ_BAR = 0x0c, + HDMI_FC_AVICONF0_SCAN_INFO_MASK = 0x30, + HDMI_FC_AVICONF0_SCAN_INFO_OVERSCAN = 0x10, + HDMI_FC_AVICONF0_SCAN_INFO_UNDERSCAN = 0x20, + HDMI_FC_AVICONF0_SCAN_INFO_NODATA = 0x00, + + HDMI_FC_AVICONF1_ACTIVE_ASPECT_RATIO_MASK = 0x0f, + HDMI_FC_AVICONF1_ACTIVE_ASPECT_RATIO_USE_CODED = 0x08, + HDMI_FC_AVICONF1_ACTIVE_ASPECT_RATIO_4_3 = 0x09, + HDMI_FC_AVICONF1_ACTIVE_ASPECT_RATIO_16_9 = 0x0a, + HDMI_FC_AVICONF1_ACTIVE_ASPECT_RATIO_14_9 = 0x0b, + HDMI_FC_AVICONF1_CODED_ASPECT_RATIO_MASK = 0x30, + HDMI_FC_AVICONF1_CODED_ASPECT_RATIO_NO_DATA = 0x00, + HDMI_FC_AVICONF1_CODED_ASPECT_RATIO_4_3 = 0x10, + HDMI_FC_AVICONF1_CODED_ASPECT_RATIO_16_9 = 0x20, + HDMI_FC_AVICONF1_COLORIMETRY_MASK = 0xc0, + HDMI_FC_AVICONF1_COLORIMETRY_NO_DATA = 0x00, + HDMI_FC_AVICONF1_COLORIMETRY_SMPTE = 0x40, + HDMI_FC_AVICONF1_COLORIMETRY_ITUR = 0x80, + HDMI_FC_AVICONF1_COLORIMETRY_EXTENDED_INFO = 0xc0, + + HDMI_FC_AVICONF2_SCALING_MASK = 0x03, + HDMI_FC_AVICONF2_SCALING_NONE = 0x00, + HDMI_FC_AVICONF2_SCALING_HORIZ = 0x01, + HDMI_FC_AVICONF2_SCALING_VERT = 0x02, + HDMI_FC_AVICONF2_SCALING_HORIZ_vert = 0x03, + HDMI_FC_AVICONF2_RGB_QUANT_MASK = 0x0c, + HDMI_FC_AVICONF2_RGB_QUANT_DEFAULT = 0x00, + HDMI_FC_AVICONF2_RGB_QUANT_LIMITED_RANGE = 0x04, + HDMI_FC_AVICONF2_RGB_QUANT_FULL_RANGE = 0x08, + HDMI_FC_AVICONF2_EXT_COLORIMETRY_MASK = 0x70, + HDMI_FC_AVICONF2_EXT_COLORIMETRY_XVYCC601 = 0x00, + HDMI_FC_AVICONF2_EXT_COLORIMETRY_XVYCC709 = 0x10, + HDMI_FC_AVICONF2_EXT_COLORIMETRY_SYCC601 = 0x20, + HDMI_FC_AVICONF2_EXT_COLORIMETRY_ADOBE_YCC601 = 0x30, + HDMI_FC_AVICONF2_EXT_COLORIMETRY_ADOBE_RGB = 0x40, + HDMI_FC_AVICONF2_IT_CONTENT_MASK = 0x80, + HDMI_FC_AVICONF2_IT_CONTENT_NO_DATA = 0x00, + HDMI_FC_AVICONF2_IT_CONTENT_VALID = 0x80, + + HDMI_FC_AVICONF3_IT_CONTENT_TYPE_MASK = 0x03, + HDMI_FC_AVICONF3_IT_CONTENT_TYPE_GRAPHICS = 0x00, + HDMI_FC_AVICONF3_IT_CONTENT_TYPE_PHOTO = 0x01, + HDMI_FC_AVICONF3_IT_CONTENT_TYPE_CINEMA = 0x02, + HDMI_FC_AVICONF3_IT_CONTENT_TYPE_GAME = 0x03, + HDMI_FC_AVICONF3_QUANT_RANGE_MASK = 0x0c, + HDMI_FC_AVICONF3_QUANT_RANGE_LIMITED = 0x00, + HDMI_FC_AVICONF3_QUANT_RANGE_FULL = 0x04, + + /* fc_gcp field values*/ + HDMI_FC_GCP_SET_AVMUTE = 0x02, + HDMI_FC_GCP_CLEAR_AVMUTE = 0x01, + + /* phy_conf0 field values */ + HDMI_PHY_CONF0_PDZ_MASK = 0x80, + HDMI_PHY_CONF0_PDZ_OFFSET = 7, + HDMI_PHY_CONF0_ENTMDS_MASK = 0x40, + HDMI_PHY_CONF0_ENTMDS_OFFSET = 6, + HDMI_PHY_CONF0_SPARECTRL_MASK = 0x20, + HDMI_PHY_CONF0_SPARECTRL_OFFSET = 5, + HDMI_PHY_CONF0_GEN2_PDDQ_MASK = 0x10, + HDMI_PHY_CONF0_GEN2_PDDQ_OFFSET = 4, + HDMI_PHY_CONF0_GEN2_TXPWRON_MASK = 0x8, + HDMI_PHY_CONF0_GEN2_TXPWRON_OFFSET = 3, + HDMI_PHY_CONF0_SELDATAENPOL_MASK = 0x2, + HDMI_PHY_CONF0_SELDATAENPOL_OFFSET = 1, + HDMI_PHY_CONF0_SELDIPIF_MASK = 0x1, + HDMI_PHY_CONF0_SELDIPIF_OFFSET = 0, + + /* phy_tst0 field values */ + HDMI_PHY_TST0_TSTCLR_MASK = 0x20, + HDMI_PHY_TST0_TSTCLR_OFFSET = 5, + + /* phy_stat0 field values */ + HDMI_PHY_HPD = 0x02, + HDMI_PHY_TX_PHY_LOCK = 0x01, + + /* phy_i2cm_slave_addr field values */ + HDMI_PHY_I2CM_SLAVE_ADDR_PHY_GEN2 = 0x69, + + /* phy_i2cm_operation_addr field values */ + HDMI_PHY_I2CM_OPERATION_ADDR_WRITE = 0x10, + + /* hdmi_phy_i2cm_int_addr */ + HDMI_PHY_I2CM_INT_ADDR_DONE_POL = 0x08, + + /* hdmi_phy_i2cm_ctlint_addr */ + HDMI_PHY_I2CM_CTLINT_ADDR_NAC_POL = 0x80, + HDMI_PHY_I2CM_CTLINT_ADDR_ARBITRATION_POL = 0x08, + + /* aud_conf0 field values */ + HDMI_AUD_CONF0_SW_AUDIO_FIFO_RST = 0x80, + HDMI_AUD_CONF0_I2S_SELECT = 0x20, + HDMI_AUD_CONF0_I2S_IN_EN_0 = 0x01, + HDMI_AUD_CONF0_I2S_IN_EN_1 = 0x02, + HDMI_AUD_CONF0_I2S_IN_EN_2 = 0x04, + HDMI_AUD_CONF0_I2S_IN_EN_3 = 0x08, + + /* aud_conf0 field values */ + HDMI_AUD_CONF1_I2S_MODE_STANDARD_MODE = 0x0, + HDMI_AUD_CONF1_I2S_WIDTH_16BIT = 0x10, + + /* aud_n3 field values */ + HDMI_AUD_N3_NCTS_ATOMIC_WRITE = 0x80, + HDMI_AUD_N3_AUDN19_16_MASK = 0x0f, + + /* aud_cts3 field values */ + HDMI_AUD_CTS3_N_SHIFT_OFFSET = 5, + HDMI_AUD_CTS3_N_SHIFT_MASK = 0xe0, + HDMI_AUD_CTS3_N_SHIFT_1 = 0, + HDMI_AUD_CTS3_N_SHIFT_16 = 0x20, + HDMI_AUD_CTS3_N_SHIFT_32 = 0x40, + HDMI_AUD_CTS3_N_SHIFT_64 = 0x60, + HDMI_AUD_CTS3_N_SHIFT_128 = 0x80, + HDMI_AUD_CTS3_N_SHIFT_256 = 0xa0, + HDMI_AUD_CTS3_CTS_MANUAL = 0x10, + HDMI_AUD_CTS3_AUDCTS19_16_MASK = 0x0f, + + /* aud_inputclkfs filed values */ + HDMI_AUD_INPUTCLKFS_128 = 0x0, + + /* mc_clkdis field values */ + HDMI_MC_CLKDIS_AUDCLK_DISABLE = 0x8, + HDMI_MC_CLKDIS_TMDSCLK_DISABLE = 0x2, + HDMI_MC_CLKDIS_PIXELCLK_DISABLE = 0x1, + + /* mc_swrstz field values */ + HDMI_MC_SWRSTZ_II2SSWRST_REQ = 0x08, + HDMI_MC_SWRSTZ_TMDSSWRST_REQ = 0x02, + + /* mc_flowctrl field values */ + HDMI_MC_FLOWCTRL_FEED_THROUGH_OFF_CSC_IN_PATH = 0x1, + HDMI_MC_FLOWCTRL_FEED_THROUGH_OFF_CSC_BYPASS = 0x0, + + /* mc_phyrstz field values */ + HDMI_MC_PHYRSTZ_ASSERT = 0x0, + HDMI_MC_PHYRSTZ_DEASSERT = 0x1, + + /* mc_heacphy_rst field values */ + HDMI_MC_HEACPHY_RST_ASSERT = 0x1, + + /* i2cm filed values */ + HDMI_I2CM_SLAVE_DDC_ADDR = 0x50, + HDMI_I2CM_SEGADDR_DDC = 0x30, + HDMI_I2CM_OP_RD8_EXT = 0x2, + HDMI_I2CM_OP_RD8 = 0x1, + HDMI_I2CM_DIV_FAST_STD_MODE = 0x8, + HDMI_I2CM_DIV_FAST_MODE = 0x8, + HDMI_I2CM_DIV_STD_MODE = 0x0, + HDMI_I2CM_SOFTRSTZ_MASK = 0x1, +}; + +struct hdmi_mpll_config { + u64 mpixelclock; + /* Mode of Operation and PLL Dividers Control Register */ + u32 cpce; + /* PLL Gmp Control Register */ + u32 gmp; + /* PLL Current Control Register */ + u32 curr; +}; + +struct hdmi_phy_config { + u64 mpixelclock; + u32 sym_ctr; /* clock symbol and transmitter control */ + u32 term; /* transmission termination value */ + u32 vlev_ctr; /* voltage level control */ +}; + +struct dw_hdmi { + ulong ioaddr; + const struct hdmi_mpll_config *mpll_cfg; + const struct hdmi_phy_config *phy_cfg; + u8 i2c_clk_high; + u8 i2c_clk_low; + u8 reg_io_width; + + int (*phy_set)(struct dw_hdmi *hdmi, uint mpixelclock); +}; + +int dw_hdmi_phy_cfg(struct dw_hdmi *hdmi, uint mpixelclock); +int dw_hdmi_phy_wait_for_hpd(struct dw_hdmi *hdmi); +void dw_hdmi_phy_init(struct dw_hdmi *hdmi); + +int dw_hdmi_enable(struct dw_hdmi *hdmi, const struct display_timing *edid); +int dw_hdmi_read_edid(struct dw_hdmi *hdmi, u8 *buf, int buf_size); +void dw_hdmi_init(struct dw_hdmi *hdmi); + +#endif
On 20 March 2017 at 16:01, Jernej Skrabec jernej.skrabec@siol.net wrote:
Designware HDMI controller and phy are used in other SoCs as well. Split out platform independent code.
DW HDMI has 8 bit registers but they can be represented as 32 bit registers as well. Add support to select access mode.
EDID reading code use reading by blocks which is not supported by other SoCs in general. Make it more general using byte by byte approach, which is also used in Linux driver.
Finally, not all DW HDMI controllers are accompanied with DW HDMI phy. Support custom phys by making controller code independent from phy code.
Signed-off-by: Jernej Skrabec jernej.skrabec@siol.net Tested-by: Nickey Yang nickey.yang@rock-chips.com Reviewed-by: Simon Glass sjg@chromium.org
Changes in v2:
- added tested by tag
- added reviewed by tag
arch/arm/include/asm/arch-rockchip/hdmi_rk3288.h | 456 -------------- drivers/video/dw_hdmi.c | 764 +++++++++++++++++++++++ drivers/video/rockchip/Makefile | 2 +- drivers/video/rockchip/rk_hdmi.c | 757 +--------------------- drivers/video/rockchip/rk_vop.c | 1 - include/dw_hdmi.h | 486 ++++++++++++++ 6 files changed, 1275 insertions(+), 1191 deletions(-) delete mode 100644 arch/arm/include/asm/arch-rockchip/hdmi_rk3288.h create mode 100644 drivers/video/dw_hdmi.c create mode 100644 include/dw_hdmi.h
Tested on firefly-rk3288: Tested-by: Simon Glass sjg@chromium.org Applied to u-boot-rockchip, thanks!
TCON unit has similar layout and functionality also on newer SoCs. This commit splits out TCON code for easier reuse later.
Signed-off-by: Jernej Skrabec jernej.skrabec@siol.net --- Changes in v2: - lcdc conversion to use struct display_timing is done in a new patch - fix issue with lcdc_enable() calls
arch/arm/include/asm/arch-sunxi/display.h | 103 --------------- arch/arm/include/asm/arch-sunxi/lcdc.h | 128 ++++++++++++++++++ drivers/video/Makefile | 2 +- drivers/video/sunxi/Makefile | 8 ++ drivers/video/sunxi/lcdc.c | 207 ++++++++++++++++++++++++++++++ drivers/video/{ => sunxi}/sunxi_display.c | 199 +++------------------------- 6 files changed, 362 insertions(+), 285 deletions(-) create mode 100644 arch/arm/include/asm/arch-sunxi/lcdc.h create mode 100644 drivers/video/sunxi/Makefile create mode 100644 drivers/video/sunxi/lcdc.c rename drivers/video/{ => sunxi}/sunxi_display.c (86%)
diff --git a/arch/arm/include/asm/arch-sunxi/display.h b/arch/arm/include/asm/arch-sunxi/display.h index b64f310b8b..93803addfb 100644 --- a/arch/arm/include/asm/arch-sunxi/display.h +++ b/arch/arm/include/asm/arch-sunxi/display.h @@ -157,52 +157,6 @@ struct sunxi_de_be_reg { u32 output_color_coef[12]; /* 0x9d0 */ };
-struct sunxi_lcdc_reg { - u32 ctrl; /* 0x00 */ - u32 int0; /* 0x04 */ - u32 int1; /* 0x08 */ - u8 res0[0x04]; /* 0x0c */ - u32 tcon0_frm_ctrl; /* 0x10 */ - u32 tcon0_frm_seed[6]; /* 0x14 */ - u32 tcon0_frm_table[4]; /* 0x2c */ - u8 res1[4]; /* 0x3c */ - u32 tcon0_ctrl; /* 0x40 */ - u32 tcon0_dclk; /* 0x44 */ - u32 tcon0_timing_active; /* 0x48 */ - u32 tcon0_timing_h; /* 0x4c */ - u32 tcon0_timing_v; /* 0x50 */ - u32 tcon0_timing_sync; /* 0x54 */ - u32 tcon0_hv_intf; /* 0x58 */ - u8 res2[0x04]; /* 0x5c */ - u32 tcon0_cpu_intf; /* 0x60 */ - u32 tcon0_cpu_wr_dat; /* 0x64 */ - u32 tcon0_cpu_rd_dat0; /* 0x68 */ - u32 tcon0_cpu_rd_dat1; /* 0x6c */ - u32 tcon0_ttl_timing0; /* 0x70 */ - u32 tcon0_ttl_timing1; /* 0x74 */ - u32 tcon0_ttl_timing2; /* 0x78 */ - u32 tcon0_ttl_timing3; /* 0x7c */ - u32 tcon0_ttl_timing4; /* 0x80 */ - u32 tcon0_lvds_intf; /* 0x84 */ - u32 tcon0_io_polarity; /* 0x88 */ - u32 tcon0_io_tristate; /* 0x8c */ - u32 tcon1_ctrl; /* 0x90 */ - u32 tcon1_timing_source; /* 0x94 */ - u32 tcon1_timing_scale; /* 0x98 */ - u32 tcon1_timing_out; /* 0x9c */ - u32 tcon1_timing_h; /* 0xa0 */ - u32 tcon1_timing_v; /* 0xa4 */ - u32 tcon1_timing_sync; /* 0xa8 */ - u8 res3[0x44]; /* 0xac */ - u32 tcon1_io_polarity; /* 0xf0 */ - u32 tcon1_io_tristate; /* 0xf4 */ - u8 res4[0x108]; /* 0xf8 */ - u32 mux_ctrl; /* 0x200 */ - u8 res5[0x1c]; /* 0x204 */ - u32 lvds_ana0; /* 0x220 */ - u32 lvds_ana1; /* 0x224 */ -}; - struct sunxi_hdmi_reg { u32 version_id; /* 0x000 */ u32 ctrl; /* 0x004 */ @@ -347,63 +301,6 @@ struct sunxi_tve_reg { #define SUNXI_DE_BE_OUTPUT_COLOR_CTRL_ENABLE 1
/* - * LCDC register constants. - */ -#define SUNXI_LCDC_X(x) (((x) - 1) << 16) -#define SUNXI_LCDC_Y(y) (((y) - 1) << 0) -#define SUNXI_LCDC_TCON_VSYNC_MASK (1 << 24) -#define SUNXI_LCDC_TCON_HSYNC_MASK (1 << 25) -#define SUNXI_LCDC_CTRL_IO_MAP_MASK (1 << 0) -#define SUNXI_LCDC_CTRL_IO_MAP_TCON0 (0 << 0) -#define SUNXI_LCDC_CTRL_IO_MAP_TCON1 (1 << 0) -#define SUNXI_LCDC_CTRL_TCON_ENABLE (1 << 31) -#define SUNXI_LCDC_TCON0_FRM_CTRL_RGB666 ((1 << 31) | (0 << 4)) -#define SUNXI_LCDC_TCON0_FRM_CTRL_RGB565 ((1 << 31) | (5 << 4)) -#define SUNXI_LCDC_TCON0_FRM_SEED 0x11111111 -#define SUNXI_LCDC_TCON0_FRM_TAB0 0x01010000 -#define SUNXI_LCDC_TCON0_FRM_TAB1 0x15151111 -#define SUNXI_LCDC_TCON0_FRM_TAB2 0x57575555 -#define SUNXI_LCDC_TCON0_FRM_TAB3 0x7f7f7777 -#define SUNXI_LCDC_TCON0_CTRL_CLK_DELAY(n) (((n) & 0x1f) << 4) -#define SUNXI_LCDC_TCON0_CTRL_ENABLE (1 << 31) -#define SUNXI_LCDC_TCON0_DCLK_DIV(n) ((n) << 0) -#define SUNXI_LCDC_TCON0_DCLK_ENABLE (0xf << 28) -#define SUNXI_LCDC_TCON0_TIMING_H_BP(n) (((n) - 1) << 0) -#define SUNXI_LCDC_TCON0_TIMING_H_TOTAL(n) (((n) - 1) << 16) -#define SUNXI_LCDC_TCON0_TIMING_V_BP(n) (((n) - 1) << 0) -#define SUNXI_LCDC_TCON0_TIMING_V_TOTAL(n) (((n) * 2) << 16) -#ifdef CONFIG_SUNXI_GEN_SUN6I -#define SUNXI_LCDC_TCON0_LVDS_CLK_SEL_TCON0 (1 << 20) -#else -#define SUNXI_LCDC_TCON0_LVDS_CLK_SEL_TCON0 0 /* NA */ -#endif -#define SUNXI_LCDC_TCON0_LVDS_INTF_BITWIDTH(n) ((n) << 26) -#define SUNXI_LCDC_TCON0_LVDS_INTF_ENABLE (1 << 31) -#define SUNXI_LCDC_TCON0_IO_POL_DCLK_PHASE(x) ((x) << 28) -#define SUNXI_LCDC_TCON1_CTRL_CLK_DELAY(n) (((n) & 0x1f) << 4) -#define SUNXI_LCDC_TCON1_CTRL_INTERLACE_ENABLE (1 << 20) -#define SUNXI_LCDC_TCON1_CTRL_ENABLE (1 << 31) -#define SUNXI_LCDC_TCON1_TIMING_H_BP(n) (((n) - 1) << 0) -#define SUNXI_LCDC_TCON1_TIMING_H_TOTAL(n) (((n) - 1) << 16) -#define SUNXI_LCDC_TCON1_TIMING_V_BP(n) (((n) - 1) << 0) -#define SUNXI_LCDC_TCON1_TIMING_V_TOTAL(n) ((n) << 16) -#define SUNXI_LCDC_MUX_CTRL_SRC0_MASK (0xf << 0) -#define SUNXI_LCDC_MUX_CTRL_SRC0(x) ((x) << 0) -#define SUNXI_LCDC_MUX_CTRL_SRC1_MASK (0xf << 4) -#define SUNXI_LCDC_MUX_CTRL_SRC1(x) ((x) << 4) -#ifdef CONFIG_SUNXI_GEN_SUN6I -#define SUNXI_LCDC_LVDS_ANA0 0x40040320 -#define SUNXI_LCDC_LVDS_ANA0_EN_MB (1 << 31) -#define SUNXI_LCDC_LVDS_ANA0_DRVC (1 << 24) -#define SUNXI_LCDC_LVDS_ANA0_DRVD(x) ((x) << 20) -#else -#define SUNXI_LCDC_LVDS_ANA0 0x3f310000 -#define SUNXI_LCDC_LVDS_ANA0_UPDATE (1 << 22) -#endif -#define SUNXI_LCDC_LVDS_ANA1_INIT1 (0x1f << 26 | 0x1f << 10) -#define SUNXI_LCDC_LVDS_ANA1_INIT2 (0x1f << 16 | 0x1f << 00) - -/* * HDMI register constants. */ #define SUNXI_HDMI_X(x) (((x) - 1) << 0) diff --git a/arch/arm/include/asm/arch-sunxi/lcdc.h b/arch/arm/include/asm/arch-sunxi/lcdc.h new file mode 100644 index 0000000000..e4c8c160ed --- /dev/null +++ b/arch/arm/include/asm/arch-sunxi/lcdc.h @@ -0,0 +1,128 @@ +/* + * Sunxi platform timing controller register and constant defines + * + * (C) Copyright 2014 Hans de Goede hdegoede@redhat.com + * (C) Copyright 2017 Jernej Skrabec jernej.skrabec@siol.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _LCDC_H +#define _LCDC_H + +struct ctfb_res_modes; + +struct sunxi_lcdc_reg { + u32 ctrl; /* 0x00 */ + u32 int0; /* 0x04 */ + u32 int1; /* 0x08 */ + u8 res0[0x04]; /* 0x0c */ + u32 tcon0_frm_ctrl; /* 0x10 */ + u32 tcon0_frm_seed[6]; /* 0x14 */ + u32 tcon0_frm_table[4]; /* 0x2c */ + u8 res1[4]; /* 0x3c */ + u32 tcon0_ctrl; /* 0x40 */ + u32 tcon0_dclk; /* 0x44 */ + u32 tcon0_timing_active; /* 0x48 */ + u32 tcon0_timing_h; /* 0x4c */ + u32 tcon0_timing_v; /* 0x50 */ + u32 tcon0_timing_sync; /* 0x54 */ + u32 tcon0_hv_intf; /* 0x58 */ + u8 res2[0x04]; /* 0x5c */ + u32 tcon0_cpu_intf; /* 0x60 */ + u32 tcon0_cpu_wr_dat; /* 0x64 */ + u32 tcon0_cpu_rd_dat0; /* 0x68 */ + u32 tcon0_cpu_rd_dat1; /* 0x6c */ + u32 tcon0_ttl_timing0; /* 0x70 */ + u32 tcon0_ttl_timing1; /* 0x74 */ + u32 tcon0_ttl_timing2; /* 0x78 */ + u32 tcon0_ttl_timing3; /* 0x7c */ + u32 tcon0_ttl_timing4; /* 0x80 */ + u32 tcon0_lvds_intf; /* 0x84 */ + u32 tcon0_io_polarity; /* 0x88 */ + u32 tcon0_io_tristate; /* 0x8c */ + u32 tcon1_ctrl; /* 0x90 */ + u32 tcon1_timing_source; /* 0x94 */ + u32 tcon1_timing_scale; /* 0x98 */ + u32 tcon1_timing_out; /* 0x9c */ + u32 tcon1_timing_h; /* 0xa0 */ + u32 tcon1_timing_v; /* 0xa4 */ + u32 tcon1_timing_sync; /* 0xa8 */ + u8 res3[0x44]; /* 0xac */ + u32 tcon1_io_polarity; /* 0xf0 */ + u32 tcon1_io_tristate; /* 0xf4 */ + u8 res4[0x108]; /* 0xf8 */ + u32 mux_ctrl; /* 0x200 */ + u8 res5[0x1c]; /* 0x204 */ + u32 lvds_ana0; /* 0x220 */ + u32 lvds_ana1; /* 0x224 */ +}; + +/* + * LCDC register constants. + */ +#define SUNXI_LCDC_X(x) (((x) - 1) << 16) +#define SUNXI_LCDC_Y(y) (((y) - 1) << 0) +#define SUNXI_LCDC_TCON_VSYNC_MASK (1 << 24) +#define SUNXI_LCDC_TCON_HSYNC_MASK (1 << 25) +#define SUNXI_LCDC_CTRL_IO_MAP_MASK (1 << 0) +#define SUNXI_LCDC_CTRL_IO_MAP_TCON0 (0 << 0) +#define SUNXI_LCDC_CTRL_IO_MAP_TCON1 (1 << 0) +#define SUNXI_LCDC_CTRL_TCON_ENABLE (1 << 31) +#define SUNXI_LCDC_TCON0_FRM_CTRL_RGB666 ((1 << 31) | (0 << 4)) +#define SUNXI_LCDC_TCON0_FRM_CTRL_RGB565 ((1 << 31) | (5 << 4)) +#define SUNXI_LCDC_TCON0_FRM_SEED 0x11111111 +#define SUNXI_LCDC_TCON0_FRM_TAB0 0x01010000 +#define SUNXI_LCDC_TCON0_FRM_TAB1 0x15151111 +#define SUNXI_LCDC_TCON0_FRM_TAB2 0x57575555 +#define SUNXI_LCDC_TCON0_FRM_TAB3 0x7f7f7777 +#define SUNXI_LCDC_TCON0_CTRL_CLK_DELAY(n) (((n) & 0x1f) << 4) +#define SUNXI_LCDC_TCON0_CTRL_ENABLE (1 << 31) +#define SUNXI_LCDC_TCON0_DCLK_DIV(n) ((n) << 0) +#define SUNXI_LCDC_TCON0_DCLK_ENABLE (0xf << 28) +#define SUNXI_LCDC_TCON0_TIMING_H_BP(n) (((n) - 1) << 0) +#define SUNXI_LCDC_TCON0_TIMING_H_TOTAL(n) (((n) - 1) << 16) +#define SUNXI_LCDC_TCON0_TIMING_V_BP(n) (((n) - 1) << 0) +#define SUNXI_LCDC_TCON0_TIMING_V_TOTAL(n) (((n) * 2) << 16) +#ifdef CONFIG_SUNXI_GEN_SUN6I +#define SUNXI_LCDC_TCON0_LVDS_CLK_SEL_TCON0 (1 << 20) +#else +#define SUNXI_LCDC_TCON0_LVDS_CLK_SEL_TCON0 0 /* NA */ +#endif +#define SUNXI_LCDC_TCON0_LVDS_INTF_BITWIDTH(n) ((n) << 26) +#define SUNXI_LCDC_TCON0_LVDS_INTF_ENABLE (1 << 31) +#define SUNXI_LCDC_TCON0_IO_POL_DCLK_PHASE(x) ((x) << 28) +#define SUNXI_LCDC_TCON1_CTRL_CLK_DELAY(n) (((n) & 0x1f) << 4) +#define SUNXI_LCDC_TCON1_CTRL_INTERLACE_ENABLE (1 << 20) +#define SUNXI_LCDC_TCON1_CTRL_ENABLE (1 << 31) +#define SUNXI_LCDC_TCON1_TIMING_H_BP(n) (((n) - 1) << 0) +#define SUNXI_LCDC_TCON1_TIMING_H_TOTAL(n) (((n) - 1) << 16) +#define SUNXI_LCDC_TCON1_TIMING_V_BP(n) (((n) - 1) << 0) +#define SUNXI_LCDC_TCON1_TIMING_V_TOTAL(n) ((n) << 16) +#define SUNXI_LCDC_MUX_CTRL_SRC0_MASK (0xf << 0) +#define SUNXI_LCDC_MUX_CTRL_SRC0(x) ((x) << 0) +#define SUNXI_LCDC_MUX_CTRL_SRC1_MASK (0xf << 4) +#define SUNXI_LCDC_MUX_CTRL_SRC1(x) ((x) << 4) +#ifdef CONFIG_SUNXI_GEN_SUN6I +#define SUNXI_LCDC_LVDS_ANA0 0x40040320 +#define SUNXI_LCDC_LVDS_ANA0_EN_MB (1 << 31) +#define SUNXI_LCDC_LVDS_ANA0_DRVC (1 << 24) +#define SUNXI_LCDC_LVDS_ANA0_DRVD(x) ((x) << 20) +#else +#define SUNXI_LCDC_LVDS_ANA0 0x3f310000 +#define SUNXI_LCDC_LVDS_ANA0_UPDATE (1 << 22) +#endif +#define SUNXI_LCDC_LVDS_ANA1_INIT1 (0x1f << 26 | 0x1f << 10) +#define SUNXI_LCDC_LVDS_ANA1_INIT2 (0x1f << 16 | 0x1f << 00) + +void lcdc_init(struct sunxi_lcdc_reg * const lcdc); +void lcdc_enable(struct sunxi_lcdc_reg * const lcdc, int depth); +void lcdc_tcon0_mode_set(struct sunxi_lcdc_reg * const lcdc, + const struct ctfb_res_modes *mode, + int clk_div, bool for_ext_vga_dac, + int depth, int dclk_phase); +void lcdc_tcon1_mode_set(struct sunxi_lcdc_reg * const lcdc, + const struct ctfb_res_modes *mode, + bool ext_hvsync, bool is_composite); + +#endif /* _LCDC_H */ diff --git a/drivers/video/Makefile b/drivers/video/Makefile index db34904a9a..7230fd9570 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -51,7 +51,6 @@ obj-$(CONFIG_VIDEO_MXS) += mxsfb.o videomodes.o obj-$(CONFIG_VIDEO_OMAP3) += omap3_dss.o obj-$(CONFIG_VIDEO_SANDBOX_SDL) += sandbox_sdl.o obj-$(CONFIG_VIDEO_SM501) += sm501.o -obj-$(CONFIG_VIDEO_SUNXI) += sunxi_display.o videomodes.o obj-$(CONFIG_VIDEO_TEGRA20) += tegra.o obj-$(CONFIG_VIDEO_VCXK) += bus_vcxk.o obj-$(CONFIG_VIDEO_VESA) += vesa.o @@ -64,3 +63,4 @@ obj-${CONFIG_EXYNOS_FB} += exynos/ obj-${CONFIG_VIDEO_ROCKCHIP} += rockchip/
obj-y += bridge/ +obj-y += sunxi/ diff --git a/drivers/video/sunxi/Makefile b/drivers/video/sunxi/Makefile new file mode 100644 index 0000000000..dfc9b47a1f --- /dev/null +++ b/drivers/video/sunxi/Makefile @@ -0,0 +1,8 @@ +# +# (C) Copyright 2000-2007 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_VIDEO_SUNXI) += sunxi_display.o lcdc.o ../videomodes.o diff --git a/drivers/video/sunxi/lcdc.c b/drivers/video/sunxi/lcdc.c new file mode 100644 index 0000000000..caf1859b0d --- /dev/null +++ b/drivers/video/sunxi/lcdc.c @@ -0,0 +1,207 @@ +/* + * Timing controller driver for Allwinner SoCs. + * + * (C) Copyright 2013-2014 Luc Verhaegen libv@skynet.be + * (C) Copyright 2014-2015 Hans de Goede hdegoede@redhat.com + * (C) Copyright 2017 Jernej Skrabec jernej.skrabec@siol.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> + +#include <asm/arch/lcdc.h> +#include <asm/io.h> + +#include "../videomodes.h" + +static int lcdc_get_clk_delay(const struct ctfb_res_modes *mode, int tcon) +{ + int delay; + + delay = mode->lower_margin + mode->vsync_len + + mode->upper_margin; + if (mode->vmode == FB_VMODE_INTERLACED) + delay /= 2; + if (tcon == 1) + delay -= 2; + + return (delay > 30) ? 30 : delay; +} + +void lcdc_init(struct sunxi_lcdc_reg * const lcdc) +{ + /* Init lcdc */ + writel(0, &lcdc->ctrl); /* Disable tcon */ + writel(0, &lcdc->int0); /* Disable all interrupts */ + + /* Disable tcon0 dot clock */ + clrbits_le32(&lcdc->tcon0_dclk, SUNXI_LCDC_TCON0_DCLK_ENABLE); + + /* Set all io lines to tristate */ + writel(0xffffffff, &lcdc->tcon0_io_tristate); + writel(0xffffffff, &lcdc->tcon1_io_tristate); +} + +void lcdc_enable(struct sunxi_lcdc_reg * const lcdc, int depth) +{ + setbits_le32(&lcdc->ctrl, SUNXI_LCDC_CTRL_TCON_ENABLE); +#ifdef CONFIG_VIDEO_LCD_IF_LVDS + setbits_le32(&lcdc->tcon0_lvds_intf, SUNXI_LCDC_TCON0_LVDS_INTF_ENABLE); + setbits_le32(&lcdc->lvds_ana0, SUNXI_LCDC_LVDS_ANA0); +#ifdef CONFIG_SUNXI_GEN_SUN6I + udelay(2); /* delay at least 1200 ns */ + setbits_le32(&lcdc->lvds_ana0, SUNXI_LCDC_LVDS_ANA0_EN_MB); + udelay(2); /* delay at least 1200 ns */ + setbits_le32(&lcdc->lvds_ana0, SUNXI_LCDC_LVDS_ANA0_DRVC); + if (depth == 18) + setbits_le32(&lcdc->lvds_ana0, SUNXI_LCDC_LVDS_ANA0_DRVD(0x7)); + else + setbits_le32(&lcdc->lvds_ana0, SUNXI_LCDC_LVDS_ANA0_DRVD(0xf)); +#else + setbits_le32(&lcdc->lvds_ana0, SUNXI_LCDC_LVDS_ANA0_UPDATE); + udelay(2); /* delay at least 1200 ns */ + setbits_le32(&lcdc->lvds_ana1, SUNXI_LCDC_LVDS_ANA1_INIT1); + udelay(1); /* delay at least 120 ns */ + setbits_le32(&lcdc->lvds_ana1, SUNXI_LCDC_LVDS_ANA1_INIT2); + setbits_le32(&lcdc->lvds_ana0, SUNXI_LCDC_LVDS_ANA0_UPDATE); +#endif +#endif +} + +void lcdc_tcon0_mode_set(struct sunxi_lcdc_reg * const lcdc, + const struct ctfb_res_modes *mode, + int clk_div, bool for_ext_vga_dac, + int depth, int dclk_phase) +{ + int bp, clk_delay, total, val; + + /* Use tcon0 */ + clrsetbits_le32(&lcdc->ctrl, SUNXI_LCDC_CTRL_IO_MAP_MASK, + SUNXI_LCDC_CTRL_IO_MAP_TCON0); + + clk_delay = lcdc_get_clk_delay(mode, 0); + writel(SUNXI_LCDC_TCON0_CTRL_ENABLE | + SUNXI_LCDC_TCON0_CTRL_CLK_DELAY(clk_delay), &lcdc->tcon0_ctrl); + + writel(SUNXI_LCDC_TCON0_DCLK_ENABLE | + SUNXI_LCDC_TCON0_DCLK_DIV(clk_div), &lcdc->tcon0_dclk); + + writel(SUNXI_LCDC_X(mode->xres) | + SUNXI_LCDC_Y(mode->yres), &lcdc->tcon0_timing_active); + + bp = mode->hsync_len + mode->left_margin; + total = mode->xres + mode->right_margin + bp; + writel(SUNXI_LCDC_TCON0_TIMING_H_TOTAL(total) | + SUNXI_LCDC_TCON0_TIMING_H_BP(bp), &lcdc->tcon0_timing_h); + + bp = mode->vsync_len + mode->upper_margin; + total = mode->yres + mode->lower_margin + bp; + writel(SUNXI_LCDC_TCON0_TIMING_V_TOTAL(total) | + SUNXI_LCDC_TCON0_TIMING_V_BP(bp), &lcdc->tcon0_timing_v); + +#ifdef CONFIG_VIDEO_LCD_IF_PARALLEL + writel(SUNXI_LCDC_X(mode->hsync_len) | + SUNXI_LCDC_Y(mode->vsync_len), &lcdc->tcon0_timing_sync); + + writel(0, &lcdc->tcon0_hv_intf); + writel(0, &lcdc->tcon0_cpu_intf); +#endif +#ifdef CONFIG_VIDEO_LCD_IF_LVDS + val = (depth == 18) ? 1 : 0; + writel(SUNXI_LCDC_TCON0_LVDS_INTF_BITWIDTH(val) | + SUNXI_LCDC_TCON0_LVDS_CLK_SEL_TCON0, &lcdc->tcon0_lvds_intf); +#endif + + if (depth == 18 || depth == 16) { + writel(SUNXI_LCDC_TCON0_FRM_SEED, &lcdc->tcon0_frm_seed[0]); + writel(SUNXI_LCDC_TCON0_FRM_SEED, &lcdc->tcon0_frm_seed[1]); + writel(SUNXI_LCDC_TCON0_FRM_SEED, &lcdc->tcon0_frm_seed[2]); + writel(SUNXI_LCDC_TCON0_FRM_SEED, &lcdc->tcon0_frm_seed[3]); + writel(SUNXI_LCDC_TCON0_FRM_SEED, &lcdc->tcon0_frm_seed[4]); + writel(SUNXI_LCDC_TCON0_FRM_SEED, &lcdc->tcon0_frm_seed[5]); + writel(SUNXI_LCDC_TCON0_FRM_TAB0, &lcdc->tcon0_frm_table[0]); + writel(SUNXI_LCDC_TCON0_FRM_TAB1, &lcdc->tcon0_frm_table[1]); + writel(SUNXI_LCDC_TCON0_FRM_TAB2, &lcdc->tcon0_frm_table[2]); + writel(SUNXI_LCDC_TCON0_FRM_TAB3, &lcdc->tcon0_frm_table[3]); + writel(((depth == 18) ? + SUNXI_LCDC_TCON0_FRM_CTRL_RGB666 : + SUNXI_LCDC_TCON0_FRM_CTRL_RGB565), + &lcdc->tcon0_frm_ctrl); + } + + val = SUNXI_LCDC_TCON0_IO_POL_DCLK_PHASE(dclk_phase); + if (!(mode->sync & FB_SYNC_HOR_HIGH_ACT)) + val |= SUNXI_LCDC_TCON_HSYNC_MASK; + if (!(mode->sync & FB_SYNC_VERT_HIGH_ACT)) + val |= SUNXI_LCDC_TCON_VSYNC_MASK; + +#ifdef CONFIG_VIDEO_VGA_VIA_LCD_FORCE_SYNC_ACTIVE_HIGH + if (for_ext_vga_dac) + val = 0; +#endif + writel(val, &lcdc->tcon0_io_polarity); + + writel(0, &lcdc->tcon0_io_tristate); +} + +void lcdc_tcon1_mode_set(struct sunxi_lcdc_reg * const lcdc, + const struct ctfb_res_modes *mode, + bool ext_hvsync, bool is_composite) +{ + int bp, clk_delay, total, val, yres; + + /* Use tcon1 */ + clrsetbits_le32(&lcdc->ctrl, SUNXI_LCDC_CTRL_IO_MAP_MASK, + SUNXI_LCDC_CTRL_IO_MAP_TCON1); + + clk_delay = lcdc_get_clk_delay(mode, 1); + writel(SUNXI_LCDC_TCON1_CTRL_ENABLE | + ((mode->vmode == FB_VMODE_INTERLACED) ? + SUNXI_LCDC_TCON1_CTRL_INTERLACE_ENABLE : 0) | + SUNXI_LCDC_TCON1_CTRL_CLK_DELAY(clk_delay), &lcdc->tcon1_ctrl); + + yres = mode->yres; + if (mode->vmode == FB_VMODE_INTERLACED) + yres /= 2; + writel(SUNXI_LCDC_X(mode->xres) | SUNXI_LCDC_Y(yres), + &lcdc->tcon1_timing_source); + writel(SUNXI_LCDC_X(mode->xres) | SUNXI_LCDC_Y(yres), + &lcdc->tcon1_timing_scale); + writel(SUNXI_LCDC_X(mode->xres) | SUNXI_LCDC_Y(yres), + &lcdc->tcon1_timing_out); + + bp = mode->hsync_len + mode->left_margin; + total = mode->xres + mode->right_margin + bp; + writel(SUNXI_LCDC_TCON1_TIMING_H_TOTAL(total) | + SUNXI_LCDC_TCON1_TIMING_H_BP(bp), &lcdc->tcon1_timing_h); + + bp = mode->vsync_len + mode->upper_margin; + total = mode->yres + mode->lower_margin + bp; + if (mode->vmode == FB_VMODE_NONINTERLACED) + total *= 2; + writel(SUNXI_LCDC_TCON1_TIMING_V_TOTAL(total) | + SUNXI_LCDC_TCON1_TIMING_V_BP(bp), &lcdc->tcon1_timing_v); + + writel(SUNXI_LCDC_X(mode->hsync_len) | + SUNXI_LCDC_Y(mode->vsync_len), &lcdc->tcon1_timing_sync); + + if (ext_hvsync) { + val = 0; + if (mode->sync & FB_SYNC_HOR_HIGH_ACT) + val |= SUNXI_LCDC_TCON_HSYNC_MASK; + if (mode->sync & FB_SYNC_VERT_HIGH_ACT) + val |= SUNXI_LCDC_TCON_VSYNC_MASK; + writel(val, &lcdc->tcon1_io_polarity); + + clrbits_le32(&lcdc->tcon1_io_tristate, + SUNXI_LCDC_TCON_VSYNC_MASK | + SUNXI_LCDC_TCON_HSYNC_MASK); + } + +#ifdef CONFIG_MACH_SUN5I + if (is_composite) + clrsetbits_le32(&lcdc->mux_ctrl, SUNXI_LCDC_MUX_CTRL_SRC0_MASK, + SUNXI_LCDC_MUX_CTRL_SRC0(1)); +#endif +} diff --git a/drivers/video/sunxi_display.c b/drivers/video/sunxi/sunxi_display.c similarity index 86% rename from drivers/video/sunxi_display.c rename to drivers/video/sunxi/sunxi_display.c index 6f8ee01c10..48192ef87e 100644 --- a/drivers/video/sunxi_display.c +++ b/drivers/video/sunxi/sunxi_display.c @@ -12,6 +12,7 @@ #include <asm/arch/clock.h> #include <asm/arch/display.h> #include <asm/arch/gpio.h> +#include <asm/arch/lcdc.h> #include <asm/arch/pwm.h> #include <asm/global_data.h> #include <asm/gpio.h> @@ -23,10 +24,10 @@ #include <i2c.h> #include <malloc.h> #include <video_fb.h> -#include "videomodes.h" -#include "anx9804.h" -#include "hitachi_tx18d42vm_lcd.h" -#include "ssd2828.h" +#include "../videomodes.h" +#include "../anx9804.h" +#include "../hitachi_tx18d42vm_lcd.h" +#include "../ssd2828.h"
#ifdef CONFIG_VIDEO_LCD_BL_PWM_ACTIVE_LOW #define PWM_ON 0 @@ -650,45 +651,7 @@ static void sunxi_lcdc_init(void) #endif #endif
- /* Init lcdc */ - writel(0, &lcdc->ctrl); /* Disable tcon */ - writel(0, &lcdc->int0); /* Disable all interrupts */ - - /* Disable tcon0 dot clock */ - clrbits_le32(&lcdc->tcon0_dclk, SUNXI_LCDC_TCON0_DCLK_ENABLE); - - /* Set all io lines to tristate */ - writel(0xffffffff, &lcdc->tcon0_io_tristate); - writel(0xffffffff, &lcdc->tcon1_io_tristate); -} - -static void sunxi_lcdc_enable(void) -{ - struct sunxi_lcdc_reg * const lcdc = - (struct sunxi_lcdc_reg *)SUNXI_LCD0_BASE; - - setbits_le32(&lcdc->ctrl, SUNXI_LCDC_CTRL_TCON_ENABLE); -#ifdef CONFIG_VIDEO_LCD_IF_LVDS - setbits_le32(&lcdc->tcon0_lvds_intf, SUNXI_LCDC_TCON0_LVDS_INTF_ENABLE); - setbits_le32(&lcdc->lvds_ana0, SUNXI_LCDC_LVDS_ANA0); -#ifdef CONFIG_SUNXI_GEN_SUN6I - udelay(2); /* delay at least 1200 ns */ - setbits_le32(&lcdc->lvds_ana0, SUNXI_LCDC_LVDS_ANA0_EN_MB); - udelay(2); /* delay at least 1200 ns */ - setbits_le32(&lcdc->lvds_ana0, SUNXI_LCDC_LVDS_ANA0_DRVC); - if (sunxi_display.depth == 18) - setbits_le32(&lcdc->lvds_ana0, SUNXI_LCDC_LVDS_ANA0_DRVD(0x7)); - else - setbits_le32(&lcdc->lvds_ana0, SUNXI_LCDC_LVDS_ANA0_DRVD(0xf)); -#else - setbits_le32(&lcdc->lvds_ana0, SUNXI_LCDC_LVDS_ANA0_UPDATE); - udelay(2); /* delay at least 1200 ns */ - setbits_le32(&lcdc->lvds_ana1, SUNXI_LCDC_LVDS_ANA1_INIT1); - udelay(1); /* delay at least 120 ns */ - setbits_le32(&lcdc->lvds_ana1, SUNXI_LCDC_LVDS_ANA1_INIT2); - setbits_le32(&lcdc->lvds_ana0, SUNXI_LCDC_LVDS_ANA0_UPDATE); -#endif -#endif + lcdc_init(lcdc); }
static void sunxi_lcdc_panel_enable(void) @@ -758,25 +721,12 @@ static void sunxi_lcdc_backlight_enable(void) gpio_direction_output(pin, PWM_ON); }
-static int sunxi_lcdc_get_clk_delay(const struct ctfb_res_modes *mode, int tcon) -{ - int delay; - - delay = mode->lower_margin + mode->vsync_len + mode->upper_margin; - if (mode->vmode == FB_VMODE_INTERLACED) - delay /= 2; - if (tcon == 1) - delay -= 2; - - return (delay > 30) ? 30 : delay; -} - static void sunxi_lcdc_tcon0_mode_set(const struct ctfb_res_modes *mode, bool for_ext_vga_dac) { struct sunxi_lcdc_reg * const lcdc = (struct sunxi_lcdc_reg *)SUNXI_LCD0_BASE; - int bp, clk_delay, clk_div, clk_double, pin, total, val; + int clk_div, clk_double, pin;
#if defined CONFIG_MACH_SUN8I && defined CONFIG_VIDEO_LCD_IF_LVDS for (pin = SUNXI_GPD(18); pin <= SUNXI_GPD(27); pin++) { @@ -796,73 +746,8 @@ static void sunxi_lcdc_tcon0_mode_set(const struct ctfb_res_modes *mode,
sunxi_lcdc_pll_set(0, mode->pixclock_khz, &clk_div, &clk_double);
- /* Use tcon0 */ - clrsetbits_le32(&lcdc->ctrl, SUNXI_LCDC_CTRL_IO_MAP_MASK, - SUNXI_LCDC_CTRL_IO_MAP_TCON0); - - clk_delay = sunxi_lcdc_get_clk_delay(mode, 0); - writel(SUNXI_LCDC_TCON0_CTRL_ENABLE | - SUNXI_LCDC_TCON0_CTRL_CLK_DELAY(clk_delay), &lcdc->tcon0_ctrl); - - writel(SUNXI_LCDC_TCON0_DCLK_ENABLE | - SUNXI_LCDC_TCON0_DCLK_DIV(clk_div), &lcdc->tcon0_dclk); - - writel(SUNXI_LCDC_X(mode->xres) | SUNXI_LCDC_Y(mode->yres), - &lcdc->tcon0_timing_active); - - bp = mode->hsync_len + mode->left_margin; - total = mode->xres + mode->right_margin + bp; - writel(SUNXI_LCDC_TCON0_TIMING_H_TOTAL(total) | - SUNXI_LCDC_TCON0_TIMING_H_BP(bp), &lcdc->tcon0_timing_h); - - bp = mode->vsync_len + mode->upper_margin; - total = mode->yres + mode->lower_margin + bp; - writel(SUNXI_LCDC_TCON0_TIMING_V_TOTAL(total) | - SUNXI_LCDC_TCON0_TIMING_V_BP(bp), &lcdc->tcon0_timing_v); - -#ifdef CONFIG_VIDEO_LCD_IF_PARALLEL - writel(SUNXI_LCDC_X(mode->hsync_len) | SUNXI_LCDC_Y(mode->vsync_len), - &lcdc->tcon0_timing_sync); - - writel(0, &lcdc->tcon0_hv_intf); - writel(0, &lcdc->tcon0_cpu_intf); -#endif -#ifdef CONFIG_VIDEO_LCD_IF_LVDS - val = (sunxi_display.depth == 18) ? 1 : 0; - writel(SUNXI_LCDC_TCON0_LVDS_INTF_BITWIDTH(val) | - SUNXI_LCDC_TCON0_LVDS_CLK_SEL_TCON0, &lcdc->tcon0_lvds_intf); -#endif - - if (sunxi_display.depth == 18 || sunxi_display.depth == 16) { - writel(SUNXI_LCDC_TCON0_FRM_SEED, &lcdc->tcon0_frm_seed[0]); - writel(SUNXI_LCDC_TCON0_FRM_SEED, &lcdc->tcon0_frm_seed[1]); - writel(SUNXI_LCDC_TCON0_FRM_SEED, &lcdc->tcon0_frm_seed[2]); - writel(SUNXI_LCDC_TCON0_FRM_SEED, &lcdc->tcon0_frm_seed[3]); - writel(SUNXI_LCDC_TCON0_FRM_SEED, &lcdc->tcon0_frm_seed[4]); - writel(SUNXI_LCDC_TCON0_FRM_SEED, &lcdc->tcon0_frm_seed[5]); - writel(SUNXI_LCDC_TCON0_FRM_TAB0, &lcdc->tcon0_frm_table[0]); - writel(SUNXI_LCDC_TCON0_FRM_TAB1, &lcdc->tcon0_frm_table[1]); - writel(SUNXI_LCDC_TCON0_FRM_TAB2, &lcdc->tcon0_frm_table[2]); - writel(SUNXI_LCDC_TCON0_FRM_TAB3, &lcdc->tcon0_frm_table[3]); - writel(((sunxi_display.depth == 18) ? - SUNXI_LCDC_TCON0_FRM_CTRL_RGB666 : - SUNXI_LCDC_TCON0_FRM_CTRL_RGB565), - &lcdc->tcon0_frm_ctrl); - } - - val = SUNXI_LCDC_TCON0_IO_POL_DCLK_PHASE(CONFIG_VIDEO_LCD_DCLK_PHASE); - if (!(mode->sync & FB_SYNC_HOR_HIGH_ACT)) - val |= SUNXI_LCDC_TCON_HSYNC_MASK; - if (!(mode->sync & FB_SYNC_VERT_HIGH_ACT)) - val |= SUNXI_LCDC_TCON_VSYNC_MASK; - -#ifdef CONFIG_VIDEO_VGA_VIA_LCD_FORCE_SYNC_ACTIVE_HIGH - if (for_ext_vga_dac) - val = 0; -#endif - writel(val, &lcdc->tcon0_io_polarity); - - writel(0, &lcdc->tcon0_io_tristate); + lcdc_tcon0_mode_set(lcdc, mode, clk_div, for_ext_vga_dac, + sunxi_display.depth, CONFIG_VIDEO_LCD_DCLK_PHASE); }
#if defined CONFIG_VIDEO_HDMI || defined CONFIG_VIDEO_VGA || defined CONFIG_VIDEO_COMPOSITE @@ -872,65 +757,15 @@ static void sunxi_lcdc_tcon1_mode_set(const struct ctfb_res_modes *mode, { struct sunxi_lcdc_reg * const lcdc = (struct sunxi_lcdc_reg *)SUNXI_LCD0_BASE; - int bp, clk_delay, total, val, yres; - - /* Use tcon1 */ - clrsetbits_le32(&lcdc->ctrl, SUNXI_LCDC_CTRL_IO_MAP_MASK, - SUNXI_LCDC_CTRL_IO_MAP_TCON1);
- clk_delay = sunxi_lcdc_get_clk_delay(mode, 1); - writel(SUNXI_LCDC_TCON1_CTRL_ENABLE | - ((mode->vmode == FB_VMODE_INTERLACED) ? - SUNXI_LCDC_TCON1_CTRL_INTERLACE_ENABLE : 0) | - SUNXI_LCDC_TCON1_CTRL_CLK_DELAY(clk_delay), &lcdc->tcon1_ctrl); - - yres = mode->yres; - if (mode->vmode == FB_VMODE_INTERLACED) - yres /= 2; - writel(SUNXI_LCDC_X(mode->xres) | SUNXI_LCDC_Y(yres), - &lcdc->tcon1_timing_source); - writel(SUNXI_LCDC_X(mode->xres) | SUNXI_LCDC_Y(yres), - &lcdc->tcon1_timing_scale); - writel(SUNXI_LCDC_X(mode->xres) | SUNXI_LCDC_Y(yres), - &lcdc->tcon1_timing_out); - - bp = mode->hsync_len + mode->left_margin; - total = mode->xres + mode->right_margin + bp; - writel(SUNXI_LCDC_TCON1_TIMING_H_TOTAL(total) | - SUNXI_LCDC_TCON1_TIMING_H_BP(bp), &lcdc->tcon1_timing_h); - - bp = mode->vsync_len + mode->upper_margin; - total = mode->yres + mode->lower_margin + bp; - if (mode->vmode == FB_VMODE_NONINTERLACED) - total *= 2; - writel(SUNXI_LCDC_TCON1_TIMING_V_TOTAL(total) | - SUNXI_LCDC_TCON1_TIMING_V_BP(bp), &lcdc->tcon1_timing_v); - - writel(SUNXI_LCDC_X(mode->hsync_len) | SUNXI_LCDC_Y(mode->vsync_len), - &lcdc->tcon1_timing_sync); + lcdc_tcon1_mode_set(lcdc, mode, use_portd_hvsync, + sunxi_is_composite());
if (use_portd_hvsync) { sunxi_gpio_set_cfgpin(SUNXI_GPD(26), SUNXI_GPD_LCD0); sunxi_gpio_set_cfgpin(SUNXI_GPD(27), SUNXI_GPD_LCD0); - - val = 0; - if (mode->sync & FB_SYNC_HOR_HIGH_ACT) - val |= SUNXI_LCDC_TCON_HSYNC_MASK; - if (mode->sync & FB_SYNC_VERT_HIGH_ACT) - val |= SUNXI_LCDC_TCON_VSYNC_MASK; - writel(val, &lcdc->tcon1_io_polarity); - - clrbits_le32(&lcdc->tcon1_io_tristate, - SUNXI_LCDC_TCON_VSYNC_MASK | - SUNXI_LCDC_TCON_HSYNC_MASK); }
-#ifdef CONFIG_MACH_SUN5I - if (sunxi_is_composite()) - clrsetbits_le32(&lcdc->mux_ctrl, SUNXI_LCDC_MUX_CTRL_SRC0_MASK, - SUNXI_LCDC_MUX_CTRL_SRC0(1)); -#endif - sunxi_lcdc_pll_set(1, mode->pixclock_khz, clk_div, clk_double); } #endif /* CONFIG_VIDEO_HDMI || defined CONFIG_VIDEO_VGA || CONFIG_VIDEO_COMPOSITE */ @@ -1212,6 +1047,8 @@ static void sunxi_mode_set(const struct ctfb_res_modes *mode, unsigned int address) { int __maybe_unused clk_div, clk_double; + struct sunxi_lcdc_reg * const lcdc = + (struct sunxi_lcdc_reg *)SUNXI_LCD0_BASE;
switch (sunxi_display.monitor) { case sunxi_monitor_none: @@ -1223,7 +1060,7 @@ static void sunxi_mode_set(const struct ctfb_res_modes *mode, sunxi_lcdc_tcon1_mode_set(mode, &clk_div, &clk_double, 0); sunxi_hdmi_mode_set(mode, clk_div, clk_double); sunxi_composer_enable(); - sunxi_lcdc_enable(); + lcdc_enable(lcdc, sunxi_display.depth); sunxi_hdmi_enable(); #endif break; @@ -1253,7 +1090,7 @@ static void sunxi_mode_set(const struct ctfb_res_modes *mode, sunxi_composer_mode_set(mode, address); sunxi_lcdc_tcon0_mode_set(mode, false); sunxi_composer_enable(); - sunxi_lcdc_enable(); + lcdc_enable(lcdc, sunxi_display.depth); #ifdef CONFIG_VIDEO_LCD_SSD2828 sunxi_ssd2828_init(mode); #endif @@ -1265,13 +1102,13 @@ static void sunxi_mode_set(const struct ctfb_res_modes *mode, sunxi_lcdc_tcon1_mode_set(mode, &clk_div, &clk_double, 1); sunxi_tvencoder_mode_set(); sunxi_composer_enable(); - sunxi_lcdc_enable(); + lcdc_enable(lcdc, sunxi_display.depth); sunxi_tvencoder_enable(); #elif defined CONFIG_VIDEO_VGA_VIA_LCD sunxi_composer_mode_set(mode, address); sunxi_lcdc_tcon0_mode_set(mode, true); sunxi_composer_enable(); - sunxi_lcdc_enable(); + lcdc_enable(lcdc, sunxi_display.depth); sunxi_vga_external_dac_enable(); #endif break; @@ -1284,7 +1121,7 @@ static void sunxi_mode_set(const struct ctfb_res_modes *mode, sunxi_lcdc_tcon1_mode_set(mode, &clk_div, &clk_double, 0); sunxi_tvencoder_mode_set(); sunxi_composer_enable(); - sunxi_lcdc_enable(); + lcdc_enable(lcdc, sunxi_display.depth); sunxi_tvencoder_enable(); #endif break;
Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
Thanks! Maxime
Video driver for older Allwinner SoCs uses cfb console framework which in turn uses struct ctfb_res_modes to hold timing informations. However, DM video framework uses different structure - struct display_timing.
It makes more sense to convert lcdc to use new timing structure because all new drivers should use DM video framework and older drivers might be rewritten to use new framework too.
Signed-off-by: Jernej Skrabec jernej.skrabec@siol.net --- Changes in v2: - new patch
arch/arm/include/asm/arch-sunxi/lcdc.h | 6 ++-- drivers/video/sunxi/lcdc.c | 64 ++++++++++++++++------------------ drivers/video/sunxi/sunxi_display.c | 35 +++++++++++++++++-- 3 files changed, 67 insertions(+), 38 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/lcdc.h b/arch/arm/include/asm/arch-sunxi/lcdc.h index e4c8c160ed..a751698b4f 100644 --- a/arch/arm/include/asm/arch-sunxi/lcdc.h +++ b/arch/arm/include/asm/arch-sunxi/lcdc.h @@ -10,7 +10,7 @@ #ifndef _LCDC_H #define _LCDC_H
-struct ctfb_res_modes; +#include <fdtdec.h>
struct sunxi_lcdc_reg { u32 ctrl; /* 0x00 */ @@ -118,11 +118,11 @@ struct sunxi_lcdc_reg { void lcdc_init(struct sunxi_lcdc_reg * const lcdc); void lcdc_enable(struct sunxi_lcdc_reg * const lcdc, int depth); void lcdc_tcon0_mode_set(struct sunxi_lcdc_reg * const lcdc, - const struct ctfb_res_modes *mode, + const struct display_timing *mode, int clk_div, bool for_ext_vga_dac, int depth, int dclk_phase); void lcdc_tcon1_mode_set(struct sunxi_lcdc_reg * const lcdc, - const struct ctfb_res_modes *mode, + const struct display_timing *mode, bool ext_hvsync, bool is_composite);
#endif /* _LCDC_H */ diff --git a/drivers/video/sunxi/lcdc.c b/drivers/video/sunxi/lcdc.c index caf1859b0d..8c8fb2e4ee 100644 --- a/drivers/video/sunxi/lcdc.c +++ b/drivers/video/sunxi/lcdc.c @@ -13,15 +13,13 @@ #include <asm/arch/lcdc.h> #include <asm/io.h>
-#include "../videomodes.h" - -static int lcdc_get_clk_delay(const struct ctfb_res_modes *mode, int tcon) +static int lcdc_get_clk_delay(const struct display_timing *mode, int tcon) { int delay;
- delay = mode->lower_margin + mode->vsync_len + - mode->upper_margin; - if (mode->vmode == FB_VMODE_INTERLACED) + delay = mode->vfront_porch.typ + mode->vsync_len.typ + + mode->vback_porch.typ; + if (mode->flags & DISPLAY_FLAGS_INTERLACED) delay /= 2; if (tcon == 1) delay -= 2; @@ -70,7 +68,7 @@ void lcdc_enable(struct sunxi_lcdc_reg * const lcdc, int depth) }
void lcdc_tcon0_mode_set(struct sunxi_lcdc_reg * const lcdc, - const struct ctfb_res_modes *mode, + const struct display_timing *mode, int clk_div, bool for_ext_vga_dac, int depth, int dclk_phase) { @@ -87,22 +85,22 @@ void lcdc_tcon0_mode_set(struct sunxi_lcdc_reg * const lcdc, writel(SUNXI_LCDC_TCON0_DCLK_ENABLE | SUNXI_LCDC_TCON0_DCLK_DIV(clk_div), &lcdc->tcon0_dclk);
- writel(SUNXI_LCDC_X(mode->xres) | - SUNXI_LCDC_Y(mode->yres), &lcdc->tcon0_timing_active); + writel(SUNXI_LCDC_X(mode->hactive.typ) | + SUNXI_LCDC_Y(mode->vactive.typ), &lcdc->tcon0_timing_active);
- bp = mode->hsync_len + mode->left_margin; - total = mode->xres + mode->right_margin + bp; + bp = mode->hsync_len.typ + mode->hback_porch.typ; + total = mode->hactive.typ + mode->hfront_porch.typ + bp; writel(SUNXI_LCDC_TCON0_TIMING_H_TOTAL(total) | SUNXI_LCDC_TCON0_TIMING_H_BP(bp), &lcdc->tcon0_timing_h);
- bp = mode->vsync_len + mode->upper_margin; - total = mode->yres + mode->lower_margin + bp; + bp = mode->vsync_len.typ + mode->vback_porch.typ; + total = mode->vactive.typ + mode->vfront_porch.typ + bp; writel(SUNXI_LCDC_TCON0_TIMING_V_TOTAL(total) | SUNXI_LCDC_TCON0_TIMING_V_BP(bp), &lcdc->tcon0_timing_v);
#ifdef CONFIG_VIDEO_LCD_IF_PARALLEL - writel(SUNXI_LCDC_X(mode->hsync_len) | - SUNXI_LCDC_Y(mode->vsync_len), &lcdc->tcon0_timing_sync); + writel(SUNXI_LCDC_X(mode->hsync_len.typ) | + SUNXI_LCDC_Y(mode->vsync_len.typ), &lcdc->tcon0_timing_sync);
writel(0, &lcdc->tcon0_hv_intf); writel(0, &lcdc->tcon0_cpu_intf); @@ -131,9 +129,9 @@ void lcdc_tcon0_mode_set(struct sunxi_lcdc_reg * const lcdc, }
val = SUNXI_LCDC_TCON0_IO_POL_DCLK_PHASE(dclk_phase); - if (!(mode->sync & FB_SYNC_HOR_HIGH_ACT)) + if (mode->flags & DISPLAY_FLAGS_HSYNC_LOW) val |= SUNXI_LCDC_TCON_HSYNC_MASK; - if (!(mode->sync & FB_SYNC_VERT_HIGH_ACT)) + if (mode->flags & DISPLAY_FLAGS_VSYNC_LOW) val |= SUNXI_LCDC_TCON_VSYNC_MASK;
#ifdef CONFIG_VIDEO_VGA_VIA_LCD_FORCE_SYNC_ACTIVE_HIGH @@ -146,7 +144,7 @@ void lcdc_tcon0_mode_set(struct sunxi_lcdc_reg * const lcdc, }
void lcdc_tcon1_mode_set(struct sunxi_lcdc_reg * const lcdc, - const struct ctfb_res_modes *mode, + const struct display_timing *mode, bool ext_hvsync, bool is_composite) { int bp, clk_delay, total, val, yres; @@ -157,40 +155,40 @@ void lcdc_tcon1_mode_set(struct sunxi_lcdc_reg * const lcdc,
clk_delay = lcdc_get_clk_delay(mode, 1); writel(SUNXI_LCDC_TCON1_CTRL_ENABLE | - ((mode->vmode == FB_VMODE_INTERLACED) ? + ((mode->flags & DISPLAY_FLAGS_INTERLACED) ? SUNXI_LCDC_TCON1_CTRL_INTERLACE_ENABLE : 0) | SUNXI_LCDC_TCON1_CTRL_CLK_DELAY(clk_delay), &lcdc->tcon1_ctrl);
- yres = mode->yres; - if (mode->vmode == FB_VMODE_INTERLACED) + yres = mode->vactive.typ; + if (mode->flags & DISPLAY_FLAGS_INTERLACED) yres /= 2; - writel(SUNXI_LCDC_X(mode->xres) | SUNXI_LCDC_Y(yres), + writel(SUNXI_LCDC_X(mode->hactive.typ) | SUNXI_LCDC_Y(yres), &lcdc->tcon1_timing_source); - writel(SUNXI_LCDC_X(mode->xres) | SUNXI_LCDC_Y(yres), + writel(SUNXI_LCDC_X(mode->hactive.typ) | SUNXI_LCDC_Y(yres), &lcdc->tcon1_timing_scale); - writel(SUNXI_LCDC_X(mode->xres) | SUNXI_LCDC_Y(yres), + writel(SUNXI_LCDC_X(mode->hactive.typ) | SUNXI_LCDC_Y(yres), &lcdc->tcon1_timing_out);
- bp = mode->hsync_len + mode->left_margin; - total = mode->xres + mode->right_margin + bp; + bp = mode->hsync_len.typ + mode->hback_porch.typ; + total = mode->hactive.typ + mode->hfront_porch.typ + bp; writel(SUNXI_LCDC_TCON1_TIMING_H_TOTAL(total) | SUNXI_LCDC_TCON1_TIMING_H_BP(bp), &lcdc->tcon1_timing_h);
- bp = mode->vsync_len + mode->upper_margin; - total = mode->yres + mode->lower_margin + bp; - if (mode->vmode == FB_VMODE_NONINTERLACED) + bp = mode->vsync_len.typ + mode->vback_porch.typ; + total = mode->vactive.typ + mode->vfront_porch.typ + bp; + if (!(mode->flags & DISPLAY_FLAGS_INTERLACED)) total *= 2; writel(SUNXI_LCDC_TCON1_TIMING_V_TOTAL(total) | SUNXI_LCDC_TCON1_TIMING_V_BP(bp), &lcdc->tcon1_timing_v);
- writel(SUNXI_LCDC_X(mode->hsync_len) | - SUNXI_LCDC_Y(mode->vsync_len), &lcdc->tcon1_timing_sync); + writel(SUNXI_LCDC_X(mode->hsync_len.typ) | + SUNXI_LCDC_Y(mode->vsync_len.typ), &lcdc->tcon1_timing_sync);
if (ext_hvsync) { val = 0; - if (mode->sync & FB_SYNC_HOR_HIGH_ACT) + if (mode->flags & DISPLAY_FLAGS_HSYNC_HIGH) val |= SUNXI_LCDC_TCON_HSYNC_MASK; - if (mode->sync & FB_SYNC_VERT_HIGH_ACT) + if (mode->flags & DISPLAY_FLAGS_VSYNC_HIGH) val |= SUNXI_LCDC_TCON_VSYNC_MASK; writel(val, &lcdc->tcon1_io_polarity);
diff --git a/drivers/video/sunxi/sunxi_display.c b/drivers/video/sunxi/sunxi_display.c index 48192ef87e..92c9d06054 100644 --- a/drivers/video/sunxi/sunxi_display.c +++ b/drivers/video/sunxi/sunxi_display.c @@ -721,12 +721,40 @@ static void sunxi_lcdc_backlight_enable(void) gpio_direction_output(pin, PWM_ON); }
+static void sunxi_ctfb_mode_to_display_timing(const struct ctfb_res_modes *mode, + struct display_timing *timing) +{ + timing->pixelclock.typ = mode->pixclock_khz * 1000; + + timing->hactive.typ = mode->xres; + timing->hfront_porch.typ = mode->right_margin; + timing->hback_porch.typ = mode->left_margin; + timing->hsync_len.typ = mode->hsync_len; + + timing->vactive.typ = mode->yres; + timing->vfront_porch.typ = mode->lower_margin; + timing->vback_porch.typ = mode->upper_margin; + timing->vsync_len.typ = mode->vsync_len; + + if (mode->sync & FB_SYNC_HOR_HIGH_ACT) + timing->flags |= DISPLAY_FLAGS_HSYNC_HIGH; + else + timing->flags |= DISPLAY_FLAGS_HSYNC_LOW; + if (mode->sync & FB_SYNC_VERT_HIGH_ACT) + timing->flags |= DISPLAY_FLAGS_VSYNC_HIGH; + else + timing->flags |= DISPLAY_FLAGS_VSYNC_LOW; + if (mode->vmode == FB_VMODE_INTERLACED) + timing->flags |= DISPLAY_FLAGS_INTERLACED; +} + static void sunxi_lcdc_tcon0_mode_set(const struct ctfb_res_modes *mode, bool for_ext_vga_dac) { struct sunxi_lcdc_reg * const lcdc = (struct sunxi_lcdc_reg *)SUNXI_LCD0_BASE; int clk_div, clk_double, pin; + struct display_timing timing;
#if defined CONFIG_MACH_SUN8I && defined CONFIG_VIDEO_LCD_IF_LVDS for (pin = SUNXI_GPD(18); pin <= SUNXI_GPD(27); pin++) { @@ -746,7 +774,8 @@ static void sunxi_lcdc_tcon0_mode_set(const struct ctfb_res_modes *mode,
- lcdc_tcon0_mode_set(lcdc, mode, clk_div, for_ext_vga_dac, + sunxi_ctfb_mode_to_display_timing(mode, &timing); + lcdc_tcon0_mode_set(lcdc, &timing, clk_div, for_ext_vga_dac, sunxi_display.depth, CONFIG_VIDEO_LCD_DCLK_PHASE); }
@@ -757,8 +786,10 @@ static void sunxi_lcdc_tcon1_mode_set(const struct ctfb_res_modes *mode, { struct sunxi_lcdc_reg * const lcdc = (struct sunxi_lcdc_reg *)SUNXI_LCD0_BASE; + struct display_timing timing;
- lcdc_tcon1_mode_set(lcdc, mode, use_portd_hvsync, + sunxi_ctfb_mode_to_display_timing(mode, &timing); + lcdc_tcon1_mode_set(lcdc, &timing, use_portd_hvsync, sunxi_is_composite());
Thanks! Maxime
Changes in v2:
- new patch
This is needed for HDMI, which will be added later.
Signed-off-by: Jernej Skrabec jernej.skrabec@siol.net Reviewed-by: Simon Glass sjg@chromium.org --- Changes in v2: - add reviewed by tag - constant style fix
arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 54 +++++++++++++++++++++++++++ arch/arm/mach-sunxi/clock_sun6i.c | 40 +++++++++++++++++++- drivers/video/sunxi/lcdc.c | 4 ++ include/configs/sun50i.h | 2 + include/configs/sun8i.h | 4 ++ scripts/config_whitelist.txt | 1 + 6 files changed, 104 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h index 1aefd5a64c..a44ea77576 100644 --- a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h +++ b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h @@ -67,13 +67,22 @@ struct sunxi_ccm_reg { u32 dram_pll_cfg; /* 0xf8 PLL_DDR cfg register, A33 only */ u32 mbus_reset; /* 0xfc MBUS reset control, A33 only */ u32 dram_clk_gate; /* 0x100 DRAM module gating */ +#ifdef CONFIG_SUNXI_DE2 + u32 de_clk_cfg; /* 0x104 DE module clock */ +#else u32 be0_clk_cfg; /* 0x104 BE0 module clock */ +#endif u32 be1_clk_cfg; /* 0x108 BE1 module clock */ u32 fe0_clk_cfg; /* 0x10c FE0 module clock */ u32 fe1_clk_cfg; /* 0x110 FE1 module clock */ u32 mp_clk_cfg; /* 0x114 MP module clock */ +#ifdef CONFIG_SUNXI_DE2 + u32 lcd0_clk_cfg; /* 0x118 LCD0 module clock */ + u32 lcd1_clk_cfg; /* 0x11c LCD1 module clock */ +#else u32 lcd0_ch0_clk_cfg; /* 0x118 LCD0 CH0 module clock */ u32 lcd1_ch0_clk_cfg; /* 0x11c LCD1 CH0 module clock */ +#endif u32 reserved14[3]; u32 lcd0_ch1_clk_cfg; /* 0x12c LCD0 CH1 module clock */ u32 lcd1_ch1_clk_cfg; /* 0x130 LCD1 CH1 module clock */ @@ -85,7 +94,11 @@ struct sunxi_ccm_reg { u32 dmic_clk_cfg; /* 0x148 Digital Mic module clock*/ u32 reserved15; u32 hdmi_clk_cfg; /* 0x150 HDMI module clock */ +#ifdef CONFIG_SUNXI_DE2 + u32 hdmi_slow_clk_cfg; /* 0x154 HDMI slow module clock */ +#else u32 ps_clk_cfg; /* 0x154 PS module clock */ +#endif u32 mtc_clk_cfg; /* 0x158 MTC module clock */ u32 mbus0_clk_cfg; /* 0x15c MBUS0 module clock */ u32 mbus1_clk_cfg; /* 0x160 MBUS1 module clock */ @@ -193,6 +206,7 @@ struct sunxi_ccm_reg { #define CCM_PLL3_CTRL_N_MASK (0x7f << CCM_PLL3_CTRL_N_SHIFT) #define CCM_PLL3_CTRL_N(n) ((((n) - 1) & 0x7f) << 8) #define CCM_PLL3_CTRL_INTEGER_MODE (0x1 << 24) +#define CCM_PLL3_CTRL_LOCK (0x1 << 28) #define CCM_PLL3_CTRL_EN (0x1 << 31)
#define CCM_PLL5_CTRL_M(n) ((((n) - 1) & 0x3) << 0) @@ -222,6 +236,16 @@ struct sunxi_ccm_reg { #define CCM_MIPI_PLL_CTRL_LDO_EN (0x3 << 22) #define CCM_MIPI_PLL_CTRL_EN (0x1 << 31)
+#define CCM_PLL10_CTRL_M_SHIFT 0 +#define CCM_PLL10_CTRL_M_MASK (0xf << CCM_PLL10_CTRL_M_SHIFT) +#define CCM_PLL10_CTRL_M(n) ((((n) - 1) & 0xf) << 0) +#define CCM_PLL10_CTRL_N_SHIFT 8 +#define CCM_PLL10_CTRL_N_MASK (0x7f << CCM_PLL10_CTRL_N_SHIFT) +#define CCM_PLL10_CTRL_N(n) ((((n) - 1) & 0x7f) << 8) +#define CCM_PLL10_CTRL_INTEGER_MODE (0x1 << 24) +#define CCM_PLL10_CTRL_LOCK (0x1 << 28) +#define CCM_PLL10_CTRL_EN (0x1 << 31) + #define CCM_PLL11_CTRL_N(n) ((((n) - 1) & 0x3f) << 8) #define CCM_PLL11_CTRL_SIGMA_DELTA_EN (0x1 << 24) #define CCM_PLL11_CTRL_UPD (0x1 << 30) @@ -273,9 +297,15 @@ struct sunxi_ccm_reg { #define AHB_GATE_OFFSET_DRC0 25 #define AHB_GATE_OFFSET_DE_FE0 14 #define AHB_GATE_OFFSET_DE_BE0 12 +#define AHB_GATE_OFFSET_DE 12 #define AHB_GATE_OFFSET_HDMI 11 +#ifndef CONFIG_SUNXI_DE2 #define AHB_GATE_OFFSET_LCD1 5 #define AHB_GATE_OFFSET_LCD0 4 +#else +#define AHB_GATE_OFFSET_LCD1 4 +#define AHB_GATE_OFFSET_LCD0 3 +#endif
#define CCM_MMC_CTRL_M(x) ((x) - 1) #define CCM_MMC_CTRL_OCLK_DLY(x) ((x) << 8) @@ -357,6 +387,12 @@ struct sunxi_ccm_reg { #define CCM_LCD_CH1_CTRL_PLL7_2X (3 << 24) #define CCM_LCD_CH1_CTRL_GATE (0x1 << 31)
+#define CCM_LCD0_CTRL_GATE (0x1 << 31) +#define CCM_LCD0_CTRL_M(n) ((((n) - 1) & 0xf) << 0) + +#define CCM_LCD1_CTRL_GATE (0x1 << 31) +#define CCM_LCD1_CTRL_M(n) ((((n) - 1) & 0xf) << 0) + #define CCM_HDMI_CTRL_M(n) ((((n) - 1) & 0xf) << 0) #define CCM_HDMI_CTRL_PLL_MASK (3 << 24) #define CCM_HDMI_CTRL_PLL3 (0 << 24) @@ -366,6 +402,8 @@ struct sunxi_ccm_reg { #define CCM_HDMI_CTRL_DDC_GATE (0x1 << 30) #define CCM_HDMI_CTRL_GATE (0x1 << 31)
+#define CCM_HDMI_SLOW_CTRL_DDC_GATE (1 << 31) + #if defined(CONFIG_MACH_SUN50I) #define MBUS_CLK_DEFAULT 0x81000002 /* PLL6x2 / 3 */ #elif defined(CONFIG_MACH_SUN8I) @@ -393,9 +431,16 @@ struct sunxi_ccm_reg { #define AHB_RESET_OFFSET_DRC0 25 #define AHB_RESET_OFFSET_DE_FE0 14 #define AHB_RESET_OFFSET_DE_BE0 12 +#define AHB_RESET_OFFSET_DE 12 #define AHB_RESET_OFFSET_HDMI 11 +#define AHB_RESET_OFFSET_HDMI2 10 +#ifndef CONFIG_SUNXI_DE2 #define AHB_RESET_OFFSET_LCD1 5 #define AHB_RESET_OFFSET_LCD0 4 +#else +#define AHB_RESET_OFFSET_LCD1 4 +#define AHB_RESET_OFFSET_LCD0 3 +#endif
/* ahb_reset2 offsets */ #define AHB_RESET_OFFSET_EPHY 2 @@ -418,6 +463,13 @@ struct sunxi_ccm_reg { #define CCM_DE_CTRL_PLL10 (5 << 24) #define CCM_DE_CTRL_GATE (1 << 31)
+/* CCM bits common to all Display Engine 2.0 clock ctrl regs */ +#define CCM_DE2_CTRL_M(n) ((((n) - 1) & 0xf) << 0) +#define CCM_DE2_CTRL_PLL_MASK (3 << 24) +#define CCM_DE2_CTRL_PLL6_2X (0 << 24) +#define CCM_DE2_CTRL_PLL10 (1 << 24) +#define CCM_DE2_CTRL_GATE (0x1 << 31) + /* CCU security switch, H3 only */ #define CCM_SEC_SWITCH_MBUS_NONSEC (1 << 2) #define CCM_SEC_SWITCH_BUS_NONSEC (1 << 1) @@ -426,7 +478,9 @@ struct sunxi_ccm_reg { #ifndef __ASSEMBLY__ void clock_set_pll1(unsigned int hz); void clock_set_pll3(unsigned int hz); +void clock_set_pll3_factors(int m, int n); void clock_set_pll5(unsigned int clk, bool sigma_delta_enable); +void clock_set_pll10(unsigned int hz); void clock_set_pll11(unsigned int clk, bool sigma_delta_enable); void clock_set_mipi_pll(unsigned int hz); unsigned int clock_get_pll3(void); diff --git a/arch/arm/mach-sunxi/clock_sun6i.c b/arch/arm/mach-sunxi/clock_sun6i.c index 3c8c53fcf7..7a59f4cd74 100644 --- a/arch/arm/mach-sunxi/clock_sun6i.c +++ b/arch/arm/mach-sunxi/clock_sun6i.c @@ -35,7 +35,7 @@ void clock_init_safe(void) clrbits_le32(&prcm->pll_ctrl1, PRCM_PLL_CTRL_LDO_KEY_MASK); #endif
-#ifdef CONFIG_MACH_SUN8I_R40 +#if defined(CONFIG_MACH_SUN8I_R40) || defined(CONFIG_MACH_SUN50I) /* Set PLL lock enable bits and switch to old lock mode */ writel(GENMASK(12, 0), &ccm->pll_lock_ctrl); #endif @@ -150,6 +150,22 @@ void clock_set_pll3(unsigned int clk) &ccm->pll3_cfg); }
+#ifdef CONFIG_SUNXI_DE2 +void clock_set_pll3_factors(int m, int n) +{ + struct sunxi_ccm_reg * const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + + /* PLL3 rate = 24000000 * n / m */ + writel(CCM_PLL3_CTRL_EN | CCM_PLL3_CTRL_INTEGER_MODE | + CCM_PLL3_CTRL_N(n) | CCM_PLL3_CTRL_M(m), + &ccm->pll3_cfg); + + while (!(readl(&ccm->pll3_cfg) & CCM_PLL3_CTRL_LOCK)) + ; +} +#endif + void clock_set_pll5(unsigned int clk, bool sigma_delta_enable) { struct sunxi_ccm_reg * const ccm = @@ -222,6 +238,28 @@ done: } #endif
+#ifdef CONFIG_SUNXI_DE2 +void clock_set_pll10(unsigned int clk) +{ + struct sunxi_ccm_reg * const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + const int m = 2; /* 12 MHz steps */ + + if (clk == 0) { + clrbits_le32(&ccm->pll10_cfg, CCM_PLL10_CTRL_EN); + return; + } + + /* PLL10 rate = 24000000 * n / m */ + writel(CCM_PLL10_CTRL_EN | CCM_PLL10_CTRL_INTEGER_MODE | + CCM_PLL10_CTRL_N(clk / (24000000 / m)) | CCM_PLL10_CTRL_M(m), + &ccm->pll10_cfg); + + while (!(readl(&ccm->pll10_cfg) & CCM_PLL10_CTRL_LOCK)) + ; +} +#endif + #if defined(CONFIG_MACH_SUN8I_A33) || defined(CONFIG_MACH_SUN50I) void clock_set_pll11(unsigned int clk, bool sigma_delta_enable) { diff --git a/drivers/video/sunxi/lcdc.c b/drivers/video/sunxi/lcdc.c index 8c8fb2e4ee..7d215b713e 100644 --- a/drivers/video/sunxi/lcdc.c +++ b/drivers/video/sunxi/lcdc.c @@ -74,9 +74,11 @@ void lcdc_tcon0_mode_set(struct sunxi_lcdc_reg * const lcdc, { int bp, clk_delay, total, val;
+#ifndef CONFIG_SUNXI_DE2 /* Use tcon0 */ clrsetbits_le32(&lcdc->ctrl, SUNXI_LCDC_CTRL_IO_MAP_MASK, SUNXI_LCDC_CTRL_IO_MAP_TCON0); +#endif
clk_delay = lcdc_get_clk_delay(mode, 0); writel(SUNXI_LCDC_TCON0_CTRL_ENABLE | @@ -149,9 +151,11 @@ void lcdc_tcon1_mode_set(struct sunxi_lcdc_reg * const lcdc, { int bp, clk_delay, total, val, yres;
+#ifndef CONFIG_SUNXI_DE2 /* Use tcon1 */ clrsetbits_le32(&lcdc->ctrl, SUNXI_LCDC_CTRL_IO_MAP_MASK, SUNXI_LCDC_CTRL_IO_MAP_TCON1); +#endif
clk_delay = lcdc_get_clk_delay(mode, 1); writel(SUNXI_LCDC_TCON1_CTRL_ENABLE | diff --git a/include/configs/sun50i.h b/include/configs/sun50i.h index 1b7bfb6c22..146f7f4e1b 100644 --- a/include/configs/sun50i.h +++ b/include/configs/sun50i.h @@ -21,6 +21,8 @@ #define GICD_BASE 0x1c81000 #define GICC_BASE 0x1c82000
+#define CONFIG_SUNXI_DE2 + /* * Include common sunxi configuration where most the settings are */ diff --git a/include/configs/sun8i.h b/include/configs/sun8i.h index a4c3fb69e4..c42b901107 100644 --- a/include/configs/sun8i.h +++ b/include/configs/sun8i.h @@ -25,6 +25,10 @@ #define CONFIG_SUNXI_USB_PHYS 2 #endif
+#ifdef CONFIG_MACH_SUNXI_H3_H5 +#define CONFIG_SUNXI_DE2 +#endif + /* * Include common sunxi configuration where most the settings are */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 8e5dc36fa7..ba0eb12665 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -3102,6 +3102,7 @@ CONFIG_STV0991_HZ_CLOCK CONFIG_ST_SMI CONFIG_SUN4 CONFIG_SUNXI_AHCI +CONFIG_SUNXI_DE2 CONFIG_SUNXI_EMAC CONFIG_SUNXI_GMAC CONFIG_SUNXI_GPIO
- Include common sunxi configuration where most the settings are
This should be a Kconfig option.
Looks good otherwise, thanks! Maxime
Dne torek, 21. marec 2017 ob 20:34:33 CET je Maxime Ripard napisal(a):
#endif
+CONFIG_SUNXI_DE2
So hidden option in board/sunxi/Kconfig will probably be the best then?
VIDEO_DE2 option added in patch 5 should depend on that symbol then.
Regards, Jernej
-- Maxime Ripard, Free Electrons Embedded Linux and Kernel engineering http://free-electrons.com
#endif
+CONFIG_SUNXI_DE2
Yes, I guess, but I'm not entirely sure why you need two different options there?
Maxime
Dne sreda, 22. marec 2017 ob 08:45:48 CET je Maxime Ripard napisal(a):
#endif
+CONFIG_SUNXI_DE2
I used define for CONFIG_SUNXI_DE2 here because SoC has or has not DE2 IP block and that is not a choice. Option in patch 5 is configurable and gives opportunity to build video driver or skip it, whithout influencing clock structure.
I could make only one option, but then it would have to be configurable, which doesn't really make sense from patch 4 perspective, because, as I already stated before, this is property of the SoC.
Which solution do you prefer? One option, define and option (as it is now) or two options?
Frankly, none of them is ideal. Best solution would be to convert clocks to use driver model framework.
Regards, Jernej
#endif
+CONFIG_SUNXI_DE2
I guess you could make a hidden Kconfig option selected by the relevant MACH_ options.
As a general basis, we move away from the old-style config options, so adding any new !Kconfig options isn't really an option.
Maxime
Dne petek, 24. marec 2017 ob 16:53:07 CET je Maxime Ripard napisal(a):
#endif
+CONFIG_SUNXI_DE2
Ok.
Do you mind if I switch from 16 BPP to 32 BPP in patch 5? efifb linux driver doesn't work well with 16 BPP.
Regards, Jernej
On Mon, Mar 20, 2017 at 11:01:25PM +0100, Jernej Skrabec wrote: > diff --git a/include/configs/sun50i.h b/include/configs/sun50i.h > index 1b7bfb6c22..146f7f4e1b 100644 > --- a/include/configs/sun50i.h > +++ b/include/configs/sun50i.h > @@ -21,6 +21,8 @@ > > #define GICD_BASE 0x1c81000 > #define GICC_BASE 0x1c82000 > > +#define CONFIG_SUNXI_DE2 > + > > /* > > * Include common sunxi configuration where most the settings are > */ > > diff --git a/include/configs/sun8i.h b/include/configs/sun8i.h > index a4c3fb69e4..c42b901107 100644 > --- a/include/configs/sun8i.h > +++ b/include/configs/sun8i.h > @@ -25,6 +25,10 @@ > > #define CONFIG_SUNXI_USB_PHYS 2 > > #endif > > +#ifdef CONFIG_MACH_SUNXI_H3_H5 > +#define CONFIG_SUNXI_DE2 > +#endif > + > > /* > > * Include common sunxi configuration where most the settings are > */ > > diff --git a/scripts/config_whitelist.txt > b/scripts/config_whitelist.txt > index 8e5dc36fa7..ba0eb12665 100644 > --- a/scripts/config_whitelist.txt > +++ b/scripts/config_whitelist.txt > @@ -3102,6 +3102,7 @@ CONFIG_STV0991_HZ_CLOCK > > CONFIG_ST_SMI > CONFIG_SUN4 > CONFIG_SUNXI_AHCI > > +CONFIG_SUNXI_DE2 > > CONFIG_SUNXI_EMAC > CONFIG_SUNXI_GMAC > CONFIG_SUNXI_GPIO
Ok.
Not at all, I think it's also what we use in the previous SoCs.
Maxime
This commit adds support for HDMI output.
arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 8 + arch/arm/include/asm/arch-sunxi/display2.h | 124 +++++++++ board/sunxi/Kconfig | 10 + drivers/video/sunxi/Makefile | 1 + drivers/video/sunxi/sunxi_de2.c | 258 ++++++++++++++++++ drivers/video/sunxi/sunxi_dw_hdmi.c | 389 ++++++++++++++++++++++++++++ include/configs/sunxi-common.h | 5 + 7 files changed, 795 insertions(+) create mode 100644 arch/arm/include/asm/arch-sunxi/display2.h create mode 100644 drivers/video/sunxi/sunxi_de2.c create mode 100644 drivers/video/sunxi/sunxi_dw_hdmi.c
diff --git a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h index ea672fe844..3ce46d024e 100644 --- a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h +++ b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h @@ -18,6 +18,8 @@ #define SUNXI_SRAM_D_BASE 0x00010000 /* 4 kiB */ #define SUNXI_SRAM_B_BASE 0x00020000 /* 64 kiB (secure) */
+#define SUNXI_DE2_BASE 0x01000000 + #ifdef CONFIG_MACH_SUN8I_A83T #define SUNXI_CPUCFG_BASE 0x01700000 #endif @@ -46,7 +48,9 @@ #define SUNXI_USB1_BASE 0x01c14000 #endif #define SUNXI_SS_BASE 0x01c15000 +#if !defined(CONFIG_MACH_SUNXI_H3_H5) && !defined(CONFIG_MACH_SUN50I) #define SUNXI_HDMI_BASE 0x01c16000 +#endif #define SUNXI_SPI2_BASE 0x01c17000 #define SUNXI_SATA_BASE 0x01c18000 #ifdef CONFIG_SUNXI_GEN_SUN4I @@ -164,6 +168,10 @@ defined(CONFIG_MACH_SUN50I) #define SUNXI_MP_BASE 0x01e80000 #define SUNXI_AVG_BASE 0x01ea0000
+#if defined(CONFIG_MACH_SUNXI_H3_H5) || defined(CONFIG_MACH_SUN50I) +#define SUNXI_HDMI_BASE 0x01ee0000 +#endif + #define SUNXI_RTC_BASE 0x01f00000 #define SUNXI_PRCM_BASE 0x01f01400
diff --git a/arch/arm/include/asm/arch-sunxi/display2.h b/arch/arm/include/asm/arch-sunxi/display2.h new file mode 100644 index 0000000000..b5875f9605 --- /dev/null +++ b/arch/arm/include/asm/arch-sunxi/display2.h @@ -0,0 +1,124 @@ +/* + * Sunxi platform display controller register and constant defines + * + * (C) Copyright 2017 Jernej Skrabec jernej.skrabec@siol.net + * + * Based on out of tree Linux DRM driver defines: + * Copyright (C) 2016 Jean-Francois Moine moinejf@free.fr + * Copyright (c) 2016 Allwinnertech Co., Ltd. +* + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _SUNXI_DISPLAY2_H +#define _SUNXI_DISPLAY2_H + +/* internal clock settings */ +struct de_clk { + u32 gate_cfg; + u32 bus_cfg; + u32 rst_cfg; + u32 div_cfg; + u32 sel_cfg; +}; + +/* global control */ +struct de_glb { + u32 ctl; + u32 status; + u32 dbuff; + u32 size; +}; + +/* alpha blending */ +struct de_bld { + u32 fcolor_ctl; + struct { + u32 fcolor; + u32 insize; + u32 offset; + u32 dum; + } attr[4]; + u32 dum0[15]; + u32 route; + u32 premultiply; + u32 bkcolor; + u32 output_size; + u32 bld_mode[4]; + u32 dum1[4]; + u32 ck_ctl; + u32 ck_cfg; + u32 dum2[2]; + u32 ck_max[4]; + u32 dum3[4]; + u32 ck_min[4]; + u32 dum4[3]; + u32 out_ctl; +}; + +/* VI channel */ +struct de_vi { + struct { + u32 attr; + u32 size; + u32 coord; + u32 pitch[3]; + u32 top_laddr[3]; + u32 bot_laddr[3]; + } cfg[4]; + u32 fcolor[4]; + u32 top_haddr[3]; + u32 bot_haddr[3]; + u32 ovl_size[2]; + u32 hori[2]; + u32 vert[2]; +}; + +struct de_ui { + struct { + u32 attr; + u32 size; + u32 coord; + u32 pitch; + u32 top_laddr; + u32 bot_laddr; + u32 fcolor; + u32 dum; + } cfg[4]; + u32 top_haddr; + u32 bot_haddr; + u32 ovl_size; +}; + +/* + * DE register constants. + */ +#define SUNXI_DE2_MUX0_BASE (SUNXI_DE2_BASE + 0x100000) +#define SUNXI_DE2_MUX1_BASE (SUNXI_DE2_BASE + 0x200000) + +#define SUNXI_DE2_MUX_GLB_REGS 0x00000 +#define SUNXI_DE2_MUX_BLD_REGS 0x01000 +#define SUNXI_DE2_MUX_CHAN_REGS 0x02000 +#define SUNXI_DE2_MUX_CHAN_SZ 0x1000 +#define SUNXI_DE2_MUX_VSU_REGS 0x20000 +#define SUNXI_DE2_MUX_GSU1_REGS 0x30000 +#define SUNXI_DE2_MUX_GSU2_REGS 0x40000 +#define SUNXI_DE2_MUX_GSU3_REGS 0x50000 +#define SUNXI_DE2_MUX_FCE_REGS 0xa0000 +#define SUNXI_DE2_MUX_BWS_REGS 0xa2000 +#define SUNXI_DE2_MUX_LTI_REGS 0xa4000 +#define SUNXI_DE2_MUX_PEAK_REGS 0xa6000 +#define SUNXI_DE2_MUX_ASE_REGS 0xa8000 +#define SUNXI_DE2_MUX_FCC_REGS 0xaa000 +#define SUNXI_DE2_MUX_DCSC_REGS 0xb0000 + +#define SUNXI_DE2_FORMAT_XRGB_8888 4 +#define SUNXI_DE2_FORMAT_RGB_565 10 + +#define SUNXI_DE2_MUX_GLB_CTL_EN (1 << 0) +#define SUNXI_DE2_UI_CFG_ATTR_EN (1 << 0) +#define SUNXI_DE2_UI_CFG_ATTR_FMT(f) ((f & 0xf) << 8) + +#define SUNXI_DE2_WH(w, h) (((h - 1) << 16) | (w - 1)) + +#endif /* _SUNXI_DISPLAY2_H */ diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 3e0e262473..7347ad61cd 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -704,6 +704,16 @@ config VIDEO_LCD_TL059WV5C0
endchoice
+config VIDEO_DE2 + bool"Display Engine 2 video driver" + depends on MACH_SUNXI_H3_H5 || MACH_SUN50I + select DM_VIDEO + select DISPLAY + default y + ---help--- + Say y here if you want to build DE2 video driver which is present on + newer SoCs. Currently only HDMI output is supported. +
config GMAC_TX_DELAY int "GMAC Transmit Clock Delay Chain" diff --git a/drivers/video/sunxi/Makefile b/drivers/video/sunxi/Makefile index dfc9b47a1f..b8afd892ad 100644 --- a/drivers/video/sunxi/Makefile +++ b/drivers/video/sunxi/Makefile @@ -6,3 +6,4 @@ #
obj-$(CONFIG_VIDEO_SUNXI) += sunxi_display.o lcdc.o ../videomodes.o +obj-$(CONFIG_VIDEO_DE2) += sunxi_de2.o sunxi_dw_hdmi.o lcdc.o ../dw_hdmi.o diff --git a/drivers/video/sunxi/sunxi_de2.c b/drivers/video/sunxi/sunxi_de2.c new file mode 100644 index 0000000000..47872b4c6d --- /dev/null +++ b/drivers/video/sunxi/sunxi_de2.c @@ -0,0 +1,258 @@ +/* + * Allwinner DE2 display driver + * + * (C) Copyright 2017 Jernej Skrabec jernej.skrabec@siol.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <display.h> +#include <dm.h> +#include <edid.h> +#include <video.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/display2.h> +#include <dm/device-internal.h> +#include <dm/uclass-internal.h> + +DECLARE_GLOBAL_DATA_PTR; + +enum { + /* Maximum LCD size we support */ + LCD_MAX_WIDTH = 3840, + LCD_MAX_HEIGHT = 2160, + LCD_MAX_LOG2_BPP = VIDEO_BPP32, +}; + +static void sunxi_de2_composer_init(void) +{ + struct sunxi_ccm_reg * const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + +#ifdef CONFIG_MACH_SUN50I + u32 reg_value; + + /* set SRAM for video use (A64 only) */ + reg_value = readl(SUNXI_SRAMC_BASE + 0x04); + reg_value &= ~(0x01 << 24); + writel(reg_value, SUNXI_SRAMC_BASE + 0x04); +#endif + + clock_set_pll10(432000000); + + /* Set DE parent to pll10 */ + clrsetbits_le32(&ccm->de_clk_cfg, CCM_DE2_CTRL_PLL_MASK, + CCM_DE2_CTRL_PLL10); + + /* Set ahb gating to pass */ + setbits_le32(&ccm->ahb_reset1_cfg, 1 << AHB_RESET_OFFSET_DE); + setbits_le32(&ccm->ahb_gate1, 1 << AHB_GATE_OFFSET_DE); + + /* Clock on */ + setbits_le32(&ccm->de_clk_cfg, CCM_DE2_CTRL_GATE); +} + +static void sunxi_de2_mode_set(int mux, const struct display_timing *mode, + int bpp, ulong address) +{ + ulong de_mux_base = (mux == 0) ? + SUNXI_DE2_MUX0_BASE : SUNXI_DE2_MUX1_BASE; + struct de_clk * const de_clk_regs = + (struct de_clk *)(SUNXI_DE2_BASE); + struct de_glb * const de_glb_regs = + (struct de_glb *)(de_mux_base + + SUNXI_DE2_MUX_GLB_REGS); + struct de_bld * const de_bld_regs = + (struct de_bld *)(de_mux_base + + SUNXI_DE2_MUX_BLD_REGS); + struct de_ui * const de_ui_regs = + (struct de_ui *)(de_mux_base + + SUNXI_DE2_MUX_CHAN_REGS + + SUNXI_DE2_MUX_CHAN_SZ * 1); + u32 size = SUNXI_DE2_WH(mode->hactive.typ, mode->vactive.typ); + int channel; + u32 format; + + /* enable clock */ +#ifdef CONFIG_MACH_SUN8I_H3 + setbits_le32(&de_clk_regs->rst_cfg, (mux == 0) ? 1 : 4); +#else + setbits_le32(&de_clk_regs->rst_cfg, BIT(mux)); +#endif + setbits_le32(&de_clk_regs->gate_cfg, BIT(mux)); + setbits_le32(&de_clk_regs->bus_cfg, BIT(mux)); + + clrbits_le32(&de_clk_regs->sel_cfg, 1); + + writel(SUNXI_DE2_MUX_GLB_CTL_EN, &de_glb_regs->ctl); + writel(0, &de_glb_regs->status); + writel(1, &de_glb_regs->dbuff); + writel(size, &de_glb_regs->size); + + for (channel = 0; channel < 4; channel++) { + void *ch = (void *)(de_mux_base + SUNXI_DE2_MUX_CHAN_REGS + + SUNXI_DE2_MUX_CHAN_SZ * channel); + memset(ch, 0, (channel == 0) ? + sizeof(struct de_vi) : sizeof(struct de_ui)); + } + memset(de_bld_regs, 0, sizeof(struct de_bld)); + + writel(0x00000101, &de_bld_regs->fcolor_ctl); + + writel(1, &de_bld_regs->route); + + writel(0, &de_bld_regs->premultiply); + writel(0xff000000, &de_bld_regs->bkcolor); + + writel(0x03010301, &de_bld_regs->bld_mode[0]); + + writel(size, &de_bld_regs->output_size); + writel(mode->flags & DISPLAY_FLAGS_INTERLACED ? 2 : 0, + &de_bld_regs->out_ctl); + writel(0, &de_bld_regs->ck_ctl); + + writel(0xff000000, &de_bld_regs->attr[0].fcolor); + writel(size, &de_bld_regs->attr[0].insize); + + /* Disable all other units */ + writel(0, de_mux_base + SUNXI_DE2_MUX_VSU_REGS); + writel(0, de_mux_base + SUNXI_DE2_MUX_GSU1_REGS); + writel(0, de_mux_base + SUNXI_DE2_MUX_GSU2_REGS); + writel(0, de_mux_base + SUNXI_DE2_MUX_GSU3_REGS); + writel(0, de_mux_base + SUNXI_DE2_MUX_FCE_REGS); + writel(0, de_mux_base + SUNXI_DE2_MUX_BWS_REGS); + writel(0, de_mux_base + SUNXI_DE2_MUX_LTI_REGS); + writel(0, de_mux_base + SUNXI_DE2_MUX_PEAK_REGS); + writel(0, de_mux_base + SUNXI_DE2_MUX_ASE_REGS); + writel(0, de_mux_base + SUNXI_DE2_MUX_FCC_REGS); + writel(0, de_mux_base + SUNXI_DE2_MUX_DCSC_REGS); + + switch (bpp) { + case 16: + format = SUNXI_DE2_UI_CFG_ATTR_FMT(SUNXI_DE2_FORMAT_RGB_565); + break; + case 32: + default: + format = SUNXI_DE2_UI_CFG_ATTR_FMT(SUNXI_DE2_FORMAT_XRGB_8888); + break; + } + + writel(SUNXI_DE2_UI_CFG_ATTR_EN | format, &de_ui_regs->cfg[0].attr); + writel(size, &de_ui_regs->cfg[0].size); + writel(0, &de_ui_regs->cfg[0].coord); + writel((bpp / 8) * mode->hactive.typ, &de_ui_regs->cfg[0].pitch); + writel(address, &de_ui_regs->cfg[0].top_laddr); + writel(size, &de_ui_regs->ovl_size); + + /* apply settings */ + writel(1, &de_glb_regs->dbuff); +} + +static int sunxi_de2_init(struct udevice *dev, ulong fbbase, + enum video_log2_bpp l2bpp, + struct udevice *disp, int mux) +{ + struct video_priv *uc_priv = dev_get_uclass_priv(dev); + struct display_timing timing; + struct display_plat *disp_uc_plat; + int ret; + + disp_uc_plat = dev_get_uclass_platdata(disp); + debug("Using device '%s', disp_uc_priv=%p\n", disp->name, disp_uc_plat); + if (display_in_use(disp)) { + debug(" - device in use\n"); + return -EBUSY; + } + + disp_uc_plat->source_id = mux; + + ret = device_probe(disp); + if (ret) { + debug("%s: device '%s' display won't probe (ret=%d)\n", + __func__, dev->name, ret); + return ret; + } + + ret = display_read_timing(disp, &timing); + if (ret) { + debug("%s: Failed to read timings\n", __func__); + return ret; + } + + sunxi_de2_composer_init(); + sunxi_de2_mode_set(mux, &timing, 1 << l2bpp, fbbase); + + ret = display_enable(disp, 1 << l2bpp, &timing); + if (ret) { + debug("%s: Failed to enable display\n", __func__); + return ret; + } + + uc_priv->xsize = timing.hactive.typ; + uc_priv->ysize = timing.vactive.typ; + uc_priv->bpix = l2bpp; + debug("fb=%lx, size=%d %d\n", fbbase, uc_priv->xsize, uc_priv->ysize); + + return 0; +} + +static int sunxi_de2_probe(struct udevice *dev) +{ + struct video_uc_platdata *plat = dev_get_uclass_platdata(dev); + struct udevice *disp; + int ret; + int mux; + + /* Before relocation we don't need to do anything */ + if (!(gd->flags & GD_FLG_RELOC)) + return 0; + + ret = uclass_find_device_by_name(UCLASS_DISPLAY, + "sunxi_dw_hdmi", &disp); + if (ret) { + debug("%s: hdmi display not found (ret=%d)\n", __func__, ret); + return ret; + } + + if (IS_ENABLED(CONFIG_MACH_SUNXI_H3_H5)) + mux = 0; + else + mux = 1; + + ret = sunxi_de2_init(dev, plat->base, VIDEO_BPP16, disp, mux); + if (ret) + return ret; + + video_set_flush_dcache(dev, 1); + + return 0; +} + +static int sunxi_de2_bind(struct udevice *dev) +{ + struct video_uc_platdata *plat = dev_get_uclass_platdata(dev); + + plat->size = LCD_MAX_WIDTH * LCD_MAX_HEIGHT * + (1 << LCD_MAX_LOG2_BPP) / 8; + + return 0; +} + +static const struct video_ops sunxi_de2_ops = { +}; + +U_BOOT_DRIVER(sunxi_de2) = { + .name = "sunxi_de2", + .id = UCLASS_VIDEO, + .ops = &sunxi_de2_ops, + .bind = sunxi_de2_bind, + .probe = sunxi_de2_probe, + .flags = DM_FLAG_PRE_RELOC, +}; + +U_BOOT_DEVICE(sunxi_de2) = { + .name = "sunxi_de2" +}; diff --git a/drivers/video/sunxi/sunxi_dw_hdmi.c b/drivers/video/sunxi/sunxi_dw_hdmi.c new file mode 100644 index 0000000000..33920a2b67 --- /dev/null +++ b/drivers/video/sunxi/sunxi_dw_hdmi.c @@ -0,0 +1,389 @@ +/* + * Allwinner DW HDMI bridge + * + * (C) Copyright 2017 Jernej Skrabec jernej.skrabec@siol.net + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <display.h> +#include <dm.h> +#include <dw_hdmi.h> +#include <edid.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/lcdc.h> + +struct sunxi_dw_hdmi_priv { + struct dw_hdmi hdmi; + int mux; +}; + +struct sunxi_hdmi_phy { + u32 pol; + u32 res1[3]; + u32 read_en; + u32 unscramble; + u32 res2[2]; + u32 ctrl; + u32 unk1; + u32 unk2; + u32 pll; + u32 clk; + u32 unk3; + u32 status; +}; + +#define HDMI_PHY_OFFS 0x10000 + +static int sunxi_dw_hdmi_get_divider(uint clock) +{ + /* + * Due to missing documentaion of HDMI PHY, we know correct + * settings only for following four PHY dividers. Select one + * based on clock speed. + */ + if (clock <= 27000000) + return 11; + else if (clock <= 74250000) + return 4; + else if (clock <= 148500000) + return 2; + else + return 1; +} + +static void sunxi_dw_hdmi_phy_init(void) +{ + struct sunxi_hdmi_phy * const phy = + (struct sunxi_hdmi_phy *)(SUNXI_HDMI_BASE + HDMI_PHY_OFFS); + unsigned long tmo; + u32 tmp; + + /* + * HDMI PHY settings are taken as-is from Allwinner BSP code. + * There is no documentation. + */ + writel(0, &phy->ctrl); + setbits_le32(&phy->ctrl, BIT(0)); + udelay(5); + setbits_le32(&phy->ctrl, BIT(16)); + setbits_le32(&phy->ctrl, BIT(1)); + udelay(10); + setbits_le32(&phy->ctrl, BIT(2)); + udelay(5); + setbits_le32(&phy->ctrl, BIT(3)); + udelay(40); + setbits_le32(&phy->ctrl, BIT(19)); + udelay(100); + setbits_le32(&phy->ctrl, BIT(18)); + setbits_le32(&phy->ctrl, 7 << 4); + + /* Note that Allwinner code doesn't fail in case of timeout */ + tmo = timer_get_us() + 2000; + while ((readl(&phy->status) & 0x80) == 0) { + if (timer_get_us() > tmo) { + printf("Warning: HDMI PHY init timeout!\n"); + break; + } + } + + setbits_le32(&phy->ctrl, 0xf << 8); + setbits_le32(&phy->ctrl, BIT(7)); + + writel(0x39dc5040, &phy->pll); + writel(0x80084343, &phy->clk); + udelay(10000); + writel(1, &phy->unk3); + setbits_le32(&phy->pll, BIT(25)); + udelay(100000); + tmp = (readl(&phy->status) & 0x1f800) >> 11; + setbits_le32(&phy->pll, BIT(31) | BIT(30)); + setbits_le32(&phy->pll, tmp); + writel(0x01FF0F7F, &phy->ctrl); + writel(0x80639000, &phy->unk1); + writel(0x0F81C405, &phy->unk2); + + /* enable read access to HDMI controller */ + writel(0x54524545, &phy->read_en); + /* descramble register offsets */ + writel(0x42494E47, &phy->unscramble); +} + +static int sunxi_dw_hdmi_get_plug_in_status(void) +{ + struct sunxi_hdmi_phy * const phy = + (struct sunxi_hdmi_phy *)(SUNXI_HDMI_BASE + HDMI_PHY_OFFS); + + return !!(readl(&phy->status) & (1 << 19)); +} + +static int sunxi_dw_hdmi_wait_for_hpd(void) +{ + ulong start; + + start = get_timer(0); + do { + if (sunxi_dw_hdmi_get_plug_in_status()) + return 0; + udelay(100); + } while (get_timer(start) < 300); + + return -1; +} + +static void sunxi_dw_hdmi_phy_set(uint clock) +{ + struct sunxi_hdmi_phy * const phy = + (struct sunxi_hdmi_phy *)(SUNXI_HDMI_BASE + HDMI_PHY_OFFS); + int div = sunxi_dw_hdmi_get_divider(clock); + u32 tmp; + + /* + * Unfortunately, we don't know much about those magic + * numbers. They are taken from Allwinner BSP driver. + */ + switch (div) { + case 1: + writel(0x30dc5fc0, &phy->pll); + writel(0x800863C0, &phy->clk); + mdelay(10); + writel(0x00000001, &phy->unk3); + setbits_le32(&phy->pll, BIT(25)); + mdelay(200); + tmp = (readl(&phy->status) & 0x1f800) >> 11; + setbits_le32(&phy->pll, BIT(31) | BIT(30)); + if (tmp < 0x3d) + setbits_le32(&phy->pll, tmp + 2); + else + setbits_le32(&phy->pll, 0x3f); + mdelay(100); + writel(0x01FFFF7F, &phy->ctrl); + writel(0x8063b000, &phy->unk1); + writel(0x0F8246B5, &phy->unk2); + break; + case 2: + writel(0x39dc5040, &phy->pll); + writel(0x80084381, &phy->clk); + mdelay(10); + writel(0x00000001, &phy->unk3); + setbits_le32(&phy->pll, BIT(25)); + mdelay(100); + tmp = (readl(&phy->status) & 0x1f800) >> 11; + setbits_le32(&phy->pll, BIT(31) | BIT(30)); + setbits_le32(&phy->pll, tmp); + writel(0x01FFFF7F, &phy->ctrl); + writel(0x8063a800, &phy->unk1); + writel(0x0F81C485, &phy->unk2); + break; + case 4: + writel(0x39dc5040, &phy->pll); + writel(0x80084343, &phy->clk); + mdelay(10); + writel(0x00000001, &phy->unk3); + setbits_le32(&phy->pll, BIT(25)); + mdelay(100); + tmp = (readl(&phy->status) & 0x1f800) >> 11; + setbits_le32(&phy->pll, BIT(31) | BIT(30)); + setbits_le32(&phy->pll, tmp); + writel(0x01FFFF7F, &phy->ctrl); + writel(0x8063b000, &phy->unk1); + writel(0x0F81C405, &phy->unk2); + break; + case 11: + writel(0x39dc5040, &phy->pll); + writel(0x8008430a, &phy->clk); + mdelay(10); + writel(0x00000001, &phy->unk3); + setbits_le32(&phy->pll, BIT(25)); + mdelay(100); + tmp = (readl(&phy->status) & 0x1f800) >> 11; + setbits_le32(&phy->pll, BIT(31) | BIT(30)); + setbits_le32(&phy->pll, tmp); + writel(0x01FFFF7F, &phy->ctrl); + writel(0x8063b000, &phy->unk1); + writel(0x0F81C405, &phy->unk2); + break; + } +} + +static void sunxi_dw_hdmi_pll_set(uint clk_khz) +{ + int value, n, m, div = 0, diff; + int best_n = 0, best_m = 0, best_diff = 0x0FFFFFFF; + + div = sunxi_dw_hdmi_get_divider(clk_khz * 1000); + + /* + * Find the lowest divider resulting in a matching clock. If there + * is no match, pick the closest lower clock, as monitors tend to + * not sync to higher frequencies. + */ + for (m = 1; m <= 16; m++) { + n = (m * div * clk_khz) / 24000; + + if ((n >= 1) && (n <= 128)) { + value = (24000 * n) / m / div; + diff = clk_khz - value; + if (diff < best_diff) { + best_diff = diff; + best_m = m; + best_n = n; + } + } + } + + clock_set_pll3_factors(best_m, best_n); + debug("dotclock: %dkHz = %dkHz: (24MHz * %d) / %d / %d\n", + clk_khz, (clock_get_pll3() / 1000) / div, + best_n, best_m, div); +} + +static void sunxi_dw_hdmi_lcdc_init(int mux, const struct display_timing *edid, + int bpp) +{ + struct sunxi_ccm_reg * const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + int div = sunxi_dw_hdmi_get_divider(edid->pixelclock.typ); + struct sunxi_lcdc_reg *lcdc; + + if (mux == 0) { + lcdc = (struct sunxi_lcdc_reg *)SUNXI_LCD0_BASE; + + /* Reset off */ + setbits_le32(&ccm->ahb_reset1_cfg, 1 << AHB_RESET_OFFSET_LCD0); + + /* Clock on */ + setbits_le32(&ccm->ahb_gate1, 1 << AHB_GATE_OFFSET_LCD0); + writel(CCM_LCD0_CTRL_GATE | CCM_LCD0_CTRL_M(div), + &ccm->lcd0_clk_cfg); + } else { + lcdc = (struct sunxi_lcdc_reg *)SUNXI_LCD1_BASE; + + /* Reset off */ + setbits_le32(&ccm->ahb_reset1_cfg, 1 << AHB_RESET_OFFSET_LCD1); + + /* Clock on */ + setbits_le32(&ccm->ahb_gate1, 1 << AHB_GATE_OFFSET_LCD1); + writel(CCM_LCD1_CTRL_GATE | CCM_LCD1_CTRL_M(div), + &ccm->lcd1_clk_cfg); + } + + lcdc_init(lcdc); + lcdc_tcon1_mode_set(lcdc, edid, false, false); + lcdc_enable(lcdc, bpp); +} + +static int sunxi_dw_hdmi_phy_cfg(struct dw_hdmi *hdmi, uint mpixelclock) +{ + sunxi_dw_hdmi_pll_set(mpixelclock/1000); + sunxi_dw_hdmi_phy_set(mpixelclock); + + return 0; +} + +static int sunxi_dw_hdmi_read_edid(struct udevice *dev, u8 *buf, int buf_size) +{ + struct sunxi_dw_hdmi_priv *priv = dev_get_priv(dev); + + return dw_hdmi_read_edid(&priv->hdmi, buf, buf_size); +} + +static int sunxi_dw_hdmi_enable(struct udevice *dev, int panel_bpp, + const struct display_timing *edid) +{ + struct sunxi_hdmi_phy * const phy = + (struct sunxi_hdmi_phy *)(SUNXI_HDMI_BASE + HDMI_PHY_OFFS); + struct sunxi_dw_hdmi_priv *priv = dev_get_priv(dev); + int ret; + + ret = dw_hdmi_enable(&priv->hdmi, edid); + if (ret) + return ret; + + sunxi_dw_hdmi_lcdc_init(priv->mux, edid, panel_bpp); + + /* + * Condition in original code is a bit weird. This is attempt + * to make it more reasonable and it works. It could be that + * bits and conditions are related and should be separated. + */ + if (!((edid->flags & DISPLAY_FLAGS_HSYNC_HIGH) && + (edid->flags & DISPLAY_FLAGS_VSYNC_HIGH))) { + setbits_le32(&phy->pol, 0x300); + } + + setbits_le32(&phy->ctrl, 0xf << 12); + + /* + * This is last hdmi access before boot, so scramble addresses + * again or othwerwise BSP driver won't work. Dummy read is + * needed or otherwise last write doesn't get written correctly. + */ + (void)readb(SUNXI_HDMI_BASE); + writel(0, &phy->unscramble); + + return 0; +} + +static int sunxi_dw_hdmi_probe(struct udevice *dev) +{ + struct display_plat *uc_plat = dev_get_uclass_platdata(dev); + struct sunxi_dw_hdmi_priv *priv = dev_get_priv(dev); + struct sunxi_ccm_reg * const ccm = + (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + int ret; + + /* Set pll3 to 297 MHz */ + clock_set_pll3(297000000); + + /* Set hdmi parent to pll3 */ + clrsetbits_le32(&ccm->hdmi_clk_cfg, CCM_HDMI_CTRL_PLL_MASK, + CCM_HDMI_CTRL_PLL3); + + /* Set ahb gating to pass */ + setbits_le32(&ccm->ahb_reset1_cfg, 1 << AHB_RESET_OFFSET_HDMI); + setbits_le32(&ccm->ahb_reset1_cfg, 1 << AHB_RESET_OFFSET_HDMI2); + setbits_le32(&ccm->ahb_gate1, 1 << AHB_GATE_OFFSET_HDMI); + setbits_le32(&ccm->hdmi_slow_clk_cfg, CCM_HDMI_SLOW_CTRL_DDC_GATE); + + /* Clock on */ + setbits_le32(&ccm->hdmi_clk_cfg, CCM_HDMI_CTRL_GATE); + + sunxi_dw_hdmi_phy_init(); + + ret = sunxi_dw_hdmi_wait_for_hpd(); + if (ret < 0) { + debug("hdmi can not get hpd signal\n"); + return -1; + } + + priv->hdmi.ioaddr = SUNXI_HDMI_BASE; + priv->hdmi.i2c_clk_high = 0xd8; + priv->hdmi.i2c_clk_low = 0xfe; + priv->hdmi.reg_io_width = 1; + priv->hdmi.phy_set = sunxi_dw_hdmi_phy_cfg; + priv->mux = uc_plat->source_id; + + dw_hdmi_init(&priv->hdmi); + + return 0; +} + +static const struct dm_display_ops sunxi_dw_hdmi_ops = { + .read_edid = sunxi_dw_hdmi_read_edid, + .enable = sunxi_dw_hdmi_enable, +}; + +U_BOOT_DRIVER(sunxi_dw_hdmi) = { + .name = "sunxi_dw_hdmi", + .id = UCLASS_DISPLAY, + .ops = &sunxi_dw_hdmi_ops, + .probe = sunxi_dw_hdmi_probe, + .priv_auto_alloc_size = sizeof(struct sunxi_dw_hdmi_priv), +}; + +U_BOOT_DEVICE(sunxi_dw_hdmi) = { + .name = "sunxi_dw_hdmi" +}; diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 5c9657ad13..936eda5c9b 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -463,6 +463,11 @@ extern int soft_i2c_gpio_scl; #define CONSOLE_STDOUT_SETTINGS \ "stdout=serial,vga\0" \ "stderr=serial,vga\0" +#elif CONFIG_DM_VIDEO +#define CONFIG_SYS_WHITE_ON_BLACK +#define CONSOLE_STDOUT_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" #else #define CONSOLE_STDOUT_SETTINGS \ "stdout=serial\0" \
Thanks! Maxime
Because DE2 driver is enabled by default, it is nice to disable it on all boards which don't have any video output. List of such boards is also much shorter.
Signed-off-by: Jernej Skrabec jernej.skrabec@siol.net --- Changes in v2: - invert logic (disable instead of enable)
configs/nanopi_neo_air_defconfig | 1 + configs/nanopi_neo_defconfig | 1 + configs/orangepi_zero_defconfig | 1 + 3 files changed, 3 insertions(+)
diff --git a/configs/nanopi_neo_air_defconfig b/configs/nanopi_neo_air_defconfig index 9598bd5cd5..5400d37bd1 100644 --- a/configs/nanopi_neo_air_defconfig +++ b/configs/nanopi_neo_air_defconfig @@ -15,3 +15,4 @@ CONFIG_SPL=y # CONFIG_SPL_ISO_PARTITION is not set # CONFIG_SPL_EFI_PARTITION is not set CONFIG_USB_EHCI_HCD=y +# CONFIG_VIDEO_DE2 is not set diff --git a/configs/nanopi_neo_defconfig b/configs/nanopi_neo_defconfig index 89f5687884..5afd5d565a 100644 --- a/configs/nanopi_neo_defconfig +++ b/configs/nanopi_neo_defconfig @@ -16,3 +16,4 @@ CONFIG_SPL=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y +# CONFIG_VIDEO_DE2 is not set diff --git a/configs/orangepi_zero_defconfig b/configs/orangepi_zero_defconfig index abb3fcf307..f5947d121b 100644 --- a/configs/orangepi_zero_defconfig +++ b/configs/orangepi_zero_defconfig @@ -15,3 +15,4 @@ CONFIG_SUN8I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_SPL_SPI_SUNXI=y CONFIG_SPL_SPI_FLASH_SUPPORT=y +# CONFIG_VIDEO_DE2 is not set
Thanks, Maxime
The A64 uses the AXP803 as its PMIC.
Signed-off-by: Icenowy Zheng icenowy@aosc.xyz Signed-off-by: Jernej Skrabec jernej.skrabec@siol.net ---
arch/arm/mach-sunxi/Makefile | 3 + arch/arm/mach-sunxi/pmic_bus.c | 6 +- arch/arm/mach-sunxi/rsb.c | 2 +- board/sunxi/board.c | 31 ++--- drivers/power/Kconfig | 87 ++++++++------ drivers/power/Makefile | 1 + drivers/power/axp803.c | 256 +++++++++++++++++++++++++++++++++++++++++ drivers/power/axp818.c | 2 +- include/axp803.h | 73 ++++++++++++ include/axp_pmic.h | 3 + 10 files changed, 414 insertions(+), 50 deletions(-) create mode 100644 drivers/power/axp803.c create mode 100644 include/axp803.h
diff --git a/arch/arm/mach-sunxi/Makefile b/arch/arm/mach-sunxi/Makefile index efab4811ee..861a52c6d0 100644 --- a/arch/arm/mach-sunxi/Makefile +++ b/arch/arm/mach-sunxi/Makefile @@ -19,9 +19,11 @@ endif obj-$(CONFIG_MACH_SUN6I) += prcm.o obj-$(CONFIG_MACH_SUN8I) += prcm.o obj-$(CONFIG_MACH_SUN9I) += prcm.o +obj-$(CONFIG_MACH_SUN50I) += prcm.o obj-$(CONFIG_MACH_SUN6I) += p2wi.o obj-$(CONFIG_MACH_SUN8I) += rsb.o obj-$(CONFIG_MACH_SUN9I) += rsb.o +obj-$(CONFIG_MACH_SUN50I) += rsb.o obj-$(CONFIG_MACH_SUN4I) += clock_sun4i.o obj-$(CONFIG_MACH_SUN5I) += clock_sun4i.o obj-$(CONFIG_MACH_SUN6I) += clock_sun6i.o @@ -37,6 +39,7 @@ obj-$(CONFIG_MACH_SUN9I) += clock_sun9i.o gtbus_sun9i.o obj-$(CONFIG_AXP152_POWER) += pmic_bus.o obj-$(CONFIG_AXP209_POWER) += pmic_bus.o obj-$(CONFIG_AXP221_POWER) += pmic_bus.o +obj-$(CONFIG_AXP803_POWER) += pmic_bus.o obj-$(CONFIG_AXP809_POWER) += pmic_bus.o obj-$(CONFIG_AXP818_POWER) += pmic_bus.o
diff --git a/arch/arm/mach-sunxi/pmic_bus.c b/arch/arm/mach-sunxi/pmic_bus.c index 7c57f02792..0ac64a97cf 100644 --- a/arch/arm/mach-sunxi/pmic_bus.c +++ b/arch/arm/mach-sunxi/pmic_bus.c @@ -36,7 +36,7 @@ int pmic_bus_init(void) if (!needs_init) return 0;
-#if defined CONFIG_AXP221_POWER || defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER +#if defined CONFIG_AXP221_POWER || defined CONFIG_AXP803_POWER || defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER # ifdef CONFIG_MACH_SUN6I p2wi_init(); ret = p2wi_change_to_p2wi_mode(AXP221_CHIP_ADDR, AXP221_CTRL_ADDR, @@ -62,7 +62,7 @@ int pmic_bus_read(u8 reg, u8 *data) return i2c_read(AXP152_I2C_ADDR, reg, 1, data, 1); #elif defined CONFIG_AXP209_POWER return i2c_read(AXP209_I2C_ADDR, reg, 1, data, 1); -#elif defined CONFIG_AXP221_POWER || defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER +#elif defined CONFIG_AXP221_POWER || defined CONFIG_AXP803_POWER || defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER # ifdef CONFIG_MACH_SUN6I return p2wi_read(reg, data); # else @@ -77,7 +77,7 @@ int pmic_bus_write(u8 reg, u8 data) return i2c_write(AXP152_I2C_ADDR, reg, 1, &data, 1); #elif defined CONFIG_AXP209_POWER return i2c_write(AXP209_I2C_ADDR, reg, 1, &data, 1); -#elif defined CONFIG_AXP221_POWER || defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER +#elif defined CONFIG_AXP221_POWER || defined CONFIG_AXP803_POWER || defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER # ifdef CONFIG_MACH_SUN6I return p2wi_write(reg, data); # else diff --git a/arch/arm/mach-sunxi/rsb.c b/arch/arm/mach-sunxi/rsb.c index 6fd11f1529..28d05e962a 100644 --- a/arch/arm/mach-sunxi/rsb.c +++ b/arch/arm/mach-sunxi/rsb.c @@ -20,7 +20,7 @@ static int rsb_set_device_mode(void);
static void rsb_cfg_io(void) { -#ifdef CONFIG_MACH_SUN8I +#if defined CONFIG_MACH_SUN8I || defined CONFIG_MACH_SUN50I sunxi_gpio_set_cfgpin(SUNXI_GPL(0), SUN8I_GPL_R_RSB); sunxi_gpio_set_cfgpin(SUNXI_GPL(1), SUN8I_GPL_R_RSB); sunxi_gpio_set_pull(SUNXI_GPL(0), 1); diff --git a/board/sunxi/board.c b/board/sunxi/board.c index b9660128e5..75e53bebbd 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -487,26 +487,27 @@ void sunxi_board_init(void) #endif
#if defined CONFIG_AXP152_POWER || defined CONFIG_AXP209_POWER || \ - defined CONFIG_AXP221_POWER || defined CONFIG_AXP809_POWER || \ - defined CONFIG_AXP818_POWER + defined CONFIG_AXP221_POWER || defined CONFIG_AXP803_POWER || \ + defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER power_failed = axp_init();
-#if defined CONFIG_AXP221_POWER || defined CONFIG_AXP809_POWER || \ - defined CONFIG_AXP818_POWER +#if defined CONFIG_AXP221_POWER || defined CONFIG_AXP803_POWER || \ + defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER power_failed |= axp_set_dcdc1(CONFIG_AXP_DCDC1_VOLT); #endif power_failed |= axp_set_dcdc2(CONFIG_AXP_DCDC2_VOLT); power_failed |= axp_set_dcdc3(CONFIG_AXP_DCDC3_VOLT); -#if !defined(CONFIG_AXP209_POWER) && !defined(CONFIG_AXP818_POWER) +#if !defined(CONFIG_AXP209_POWER) && !defined(CONFIG_AXP803_POWER) && \ + !defined(CONFIG_AXP818_POWER) power_failed |= axp_set_dcdc4(CONFIG_AXP_DCDC4_VOLT); #endif -#if defined CONFIG_AXP221_POWER || defined CONFIG_AXP809_POWER || \ - defined CONFIG_AXP818_POWER +#if defined CONFIG_AXP221_POWER || defined CONFIG_AXP803_POWER || \ + defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER power_failed |= axp_set_dcdc5(CONFIG_AXP_DCDC5_VOLT); #endif
-#if defined CONFIG_AXP221_POWER || defined CONFIG_AXP809_POWER || \ - defined CONFIG_AXP818_POWER +#if defined CONFIG_AXP221_POWER || defined CONFIG_AXP803_POWER || \ + defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER power_failed |= axp_set_aldo1(CONFIG_AXP_ALDO1_VOLT); #endif power_failed |= axp_set_aldo2(CONFIG_AXP_ALDO2_VOLT); @@ -517,8 +518,8 @@ void sunxi_board_init(void) power_failed |= axp_set_aldo4(CONFIG_AXP_ALDO4_VOLT); #endif
-#if defined(CONFIG_AXP221_POWER) || defined(CONFIG_AXP809_POWER) || \ - defined(CONFIG_AXP818_POWER) +#if defined(CONFIG_AXP221_POWER) || defined(CONFIG_AXP803_POWER) || \ + defined(CONFIG_AXP809_POWER) || defined(CONFIG_AXP818_POWER) power_failed |= axp_set_dldo(1, CONFIG_AXP_DLDO1_VOLT); power_failed |= axp_set_dldo(2, CONFIG_AXP_DLDO2_VOLT); #if !defined CONFIG_AXP809_POWER @@ -530,13 +531,17 @@ void sunxi_board_init(void) power_failed |= axp_set_eldo(3, CONFIG_AXP_ELDO3_VOLT); #endif
-#ifdef CONFIG_AXP818_POWER +#if defined CONFIG_AXP803_POWER || defined CONFIG_AXP818_POWER power_failed |= axp_set_fldo(1, CONFIG_AXP_FLDO1_VOLT); power_failed |= axp_set_fldo(2, CONFIG_AXP_FLDO2_VOLT); +#endif + +#ifdef CONFIG_AXP818_POWER power_failed |= axp_set_fldo(3, CONFIG_AXP_FLDO3_VOLT); #endif
-#if defined CONFIG_AXP809_POWER || defined CONFIG_AXP818_POWER +#if defined CONFIG_AXP803_POWER || defined CONFIG_AXP809_POWER || \ + defined CONFIG_AXP818_POWER power_failed |= axp_set_sw(IS_ENABLED(CONFIG_AXP_SW_ON)); #endif #endif diff --git a/drivers/power/Kconfig b/drivers/power/Kconfig index 64e5bc2f74..4907002ed6 100644 --- a/drivers/power/Kconfig +++ b/drivers/power/Kconfig @@ -11,8 +11,9 @@ choice depends on ARCH_SUNXI default AXP209_POWER if MACH_SUN4I || MACH_SUN5I || MACH_SUN7I default AXP221_POWER if MACH_SUN6I || MACH_SUN8I_A23 || MACH_SUN8I_A33 + default AXP803_POWER if MACH_SUN50I default AXP818_POWER if MACH_SUN8I_A83T - default SUNXI_NO_PMIC if MACH_SUNXI_H3_H5 || MACH_SUN50I + default SUNXI_NO_PMIC if MACH_SUNXI_H3_H5
config SUNXI_NO_PMIC bool "board without a pmic" @@ -43,6 +44,13 @@ config AXP221_POWER Select this to enable support for the axp221/axp223 pmic found on most A23 and A31 boards.
+config AXP803_POWER + bool "axp803 pmic support" + depends on MACH_SUN50I + select CMD_POWEROFF + ---help--- + Say y here to enable support for the axp803 pmic found on A64 boards. + config AXP809_POWER bool "axp809 pmic support" depends on MACH_SUN9I @@ -69,25 +77,25 @@ endchoice
config AXP_DCDC1_VOLT int "axp pmic dcdc1 voltage" - depends on AXP221_POWER || AXP809_POWER || AXP818_POWER - default 3300 if AXP818_POWER + depends on AXP221_POWER || AXP803_POWER || AXP809_POWER || AXP818_POWER + default 3300 if AXP818_POWER || MACH_SUN50I default 3000 if MACH_SUN6I || MACH_SUN8I || MACH_SUN9I ---help--- Set the voltage (mV) to program the axp pmic dcdc1 at, set to 0 to disable dcdc1. On A23 / A31 / A33 (axp221) boards dcdc1 is used for generic 3.3V IO voltage for external devices like the lcd-panal and sdcard interfaces, etc. On most boards dcdc1 is undervolted to 3.0V to - save battery. On A31 devices dcdc1 is also used for VCC-IO. On A83T - dcdc1 is used for VCC-IO, nand, usb0, sd , etc. On A80 dcdc1 normally - powers some of the pingroups, NAND/eMMC, SD/MMC, and USB OTG. + save battery. On A31 devices dcdc1 is also used for VCC-IO. On A83T and + A64 dcdc1 is used for VCC-IO, nand, usb0, sd , etc. On A80 dcdc1 + normally powers some of the pingroups, NAND/eMMC, SD/MMC, and USB OTG.
config AXP_DCDC2_VOLT int "axp pmic dcdc2 voltage" - depends on AXP152_POWER || AXP209_POWER || AXP221_POWER || AXP809_POWER || AXP818_POWER + depends on AXP152_POWER || AXP209_POWER || AXP221_POWER || AXP803_POWER || AXP809_POWER || AXP818_POWER default 900 if AXP818_POWER default 1400 if AXP152_POWER || AXP209_POWER default 1200 if MACH_SUN6I - default 1100 if MACH_SUN8I + default 1100 if MACH_SUN8I || MACH_SUN50I default 0 if MACH_SUN9I ---help--- Set the voltage (mV) to program the axp pmic dcdc2 at, set to 0 to @@ -97,15 +105,17 @@ config AXP_DCDC2_VOLT On A23/A33 boards dcdc2 is used for VDD-SYS and should be 1.1V. On A80 boards dcdc2 powers the GPU and can be left off. On A83T boards dcdc2 is used for VDD-CPUA(cluster 0) and should be 0.9V. + On A64 boards dcdc2 is used with dcdc3 for VDD-CPU and should be 1.1V.
config AXP_DCDC3_VOLT int "axp pmic dcdc3 voltage" - depends on AXP152_POWER || AXP209_POWER || AXP221_POWER || AXP809_POWER || AXP818_POWER + depends on AXP152_POWER || AXP209_POWER || AXP221_POWER || AXP803_POWER || AXP809_POWER || AXP818_POWER default 900 if AXP809_POWER || AXP818_POWER default 1500 if AXP152_POWER default 1250 if AXP209_POWER default 1200 if MACH_SUN6I || MACH_SUN8I - ---help--- + default 1100 if MACH_SUN50I +---help--- Set the voltage (mV) to program the axp pmic dcdc3 at, set to 0 to disable dcdc3. On A10(s) / A13 / A20 boards with an axp209 dcdc3 is VDD-INT-DLL and @@ -114,39 +124,42 @@ config AXP_DCDC3_VOLT On A23 / A31 / A33 boards dcdc3 is VDD-CPU and should be 1.2V. On A80 boards dcdc3 is used for VDD-CPUA(cluster 0) and should be 0.9V. On A83T boards dcdc3 is used for VDD-CPUB(cluster 1) and should be 0.9V. + On A64 boards dcdc3 is used with dcdc2 for VDD-CPU and should be 1.1V.
config AXP_DCDC4_VOLT int "axp pmic dcdc4 voltage" - depends on AXP152_POWER || AXP221_POWER || AXP809_POWER || AXP818_POWER + depends on AXP152_POWER || AXP221_POWER || AXP803_POWER || AXP809_POWER || AXP818_POWER default 1250 if AXP152_POWER default 1200 if MACH_SUN6I default 0 if MACH_SUN8I default 900 if MACH_SUN9I + default 0 if MACH_SUN50I ---help--- Set the voltage (mV) to program the axp pmic dcdc4 at, set to 0 to disable dcdc4. On A10s boards with an axp152 dcdc4 is VDD-INT-DLL and should be 1.25V. On A31 boards dcdc4 is used for VDD-SYS and should be 1.2V. - On A23 / A33 boards dcdc4 is unused and should be disabled. + On A23 / A33 / A64 boards dcdc4 is unused and should be disabled. On A80 boards dcdc4 powers VDD-SYS, HDMI, USB OTG and should be 0.9V. On A83T boards dcdc4 is used for VDD-GPU.
config AXP_DCDC5_VOLT int "axp pmic dcdc5 voltage" - depends on AXP221_POWER || AXP809_POWER || AXP818_POWER - default 1500 if MACH_SUN6I || MACH_SUN8I || MACH_SUN9I + depends on AXP221_POWER || AXP803_POWER || AXP809_POWER || AXP818_POWER + default 1500 if MACH_SUN6I || MACH_SUN8I || MACH_SUN9I || MACH_SUN50I ---help--- Set the voltage (mV) to program the axp pmic dcdc5 at, set to 0 to disable dcdc5. - On A23 / A31 / A33 / A80 / A83T boards dcdc5 is VCC-DRAM and + On A23 / A31 / A33 / A64 / A80 / A83T boards dcdc5 is VCC-DRAM and should be 1.5V, 1.35V if DDR3L is used.
config AXP_ALDO1_VOLT int "axp pmic (a)ldo1 voltage" - depends on AXP221_POWER || AXP809_POWER || AXP818_POWER + depends on AXP221_POWER || AXP803_POWER || AXP809_POWER || AXP818_POWER default 0 if MACH_SUN6I default 1800 if MACH_SUN8I_A83T default 3000 if MACH_SUN8I || MACH_SUN9I + default 2800 if MACH_SUN50I ---help--- Set the voltage (mV) to program the axp pmic aldo1 at, set to 0 to disable aldo1. @@ -155,14 +168,16 @@ config AXP_ALDO1_VOLT On A80 boards aldo1 powers the USB hosts and should be 3.0V. On A83T / H8 boards aldo1 is used for MIPI CSI, DSI, HDMI, EFUSE, and should be 1.8V. + On A64 boards aldo1 powers PE pingroup and CSI and should be 2.8V.
config AXP_ALDO2_VOLT int "axp pmic (a)ldo2 voltage" - depends on AXP152_POWER || AXP209_POWER || AXP221_POWER || AXP809_POWER || AXP818_POWER + depends on AXP152_POWER || AXP209_POWER || AXP221_POWER || AXP803_POWER || AXP809_POWER || AXP818_POWER default 3000 if AXP152_POWER || AXP209_POWER default 0 if MACH_SUN6I || MACH_SUN9I default 1800 if MACH_SUN8I_A83T default 2500 if MACH_SUN8I + default 1800 if MACH_SUN50I ---help--- Set the voltage (mV) to program the axp pmic aldo2 at, set to 0 to disable aldo2. @@ -173,17 +188,19 @@ config AXP_ALDO2_VOLT On A80 boards aldo2 powers PB pingroup and camera IO and can be left off. On A83T / H8 boards aldo2 powers VDD-DLL, VCC18-PLL, CPVDD, VDD18-ADC, LPDDR2, and the codec. It should be 1.8V. + On A64 boards aldo2 powers PL pingroup and should be 1.8V.
config AXP_ALDO3_VOLT int "axp pmic (a)ldo3 voltage" - depends on AXP209_POWER || AXP221_POWER || AXP809_POWER || AXP818_POWER + depends on AXP209_POWER || AXP221_POWER || AXP803_POWER || AXP809_POWER || AXP818_POWER default 0 if AXP209_POWER || MACH_SUN9I - default 3000 if MACH_SUN6I || MACH_SUN8I + default 3000 if MACH_SUN6I || MACH_SUN8I || MACH_SUN50I ---help--- Set the voltage (mV) to program the axp pmic aldo3 at, set to 0 to disable aldo3. On A10(s) / A13 / A20 boards aldo3 should be 2.8V. - On A23 / A31 / A33 boards aldo3 is VCC-PLL and AVCC and should be 3.0V. + On A23 / A31 / A33 / A64 boards aldo3 is VCC-PLL and AVCC + and should be 3.0V. On A80 boards aldo3 is normally not used. On A83T / H8 boards aldo3 is AVCC, VCC-PL, and VCC-LED, and should be 3.0V. @@ -199,17 +216,19 @@ config AXP_ALDO4_VOLT
config AXP_DLDO1_VOLT int "axp pmic dldo1 voltage" - depends on AXP221_POWER || AXP809_POWER || AXP818_POWER + depends on AXP221_POWER || AXP803_POWER || AXP809_POWER || AXP818_POWER + default 3300 if MACH_SUN50I default 0 ---help--- Set the voltage (mV) to program the axp pmic dldo1 at, set to 0 to disable dldo1. On sun6i (A31) boards with ethernet dldo1 is often used to power the ethernet phy. On A23, A33 and A80 boards this is often - used to power the wifi. + used to power the wifi. On A64 boards this is often used to power the + HDMI.
config AXP_DLDO2_VOLT int "axp pmic dldo2 voltage" - depends on AXP221_POWER || AXP809_POWER || AXP818_POWER + depends on AXP221_POWER || AXP803_POWER || AXP809_POWER || AXP818_POWER default 3000 if MACH_SUN9I default 0 ---help--- @@ -219,7 +238,7 @@ config AXP_DLDO2_VOLT
config AXP_DLDO3_VOLT int "axp pmic dldo3 voltage" - depends on AXP221_POWER || AXP818_POWER + depends on AXP221_POWER || AXP803_POWER || AXP818_POWER default 0 ---help--- Set the voltage (mV) to program the axp pmic dldo3 at, set to 0 to @@ -227,7 +246,7 @@ config AXP_DLDO3_VOLT
config AXP_DLDO4_VOLT int "axp pmic dldo4 voltage" - depends on AXP221_POWER || AXP818_POWER + depends on AXP221_POWER || AXP803_POWER || AXP818_POWER default 0 ---help--- Set the voltage (mV) to program the axp pmic dldo4 at, set to 0 to @@ -235,15 +254,17 @@ config AXP_DLDO4_VOLT
config AXP_ELDO1_VOLT int "axp pmic eldo1 voltage" - depends on AXP221_POWER || AXP809_POWER || AXP818_POWER + depends on AXP221_POWER || AXP803_POWER || AXP809_POWER || AXP818_POWER + default 1800 if MACH_SUN50I default 0 ---help--- Set the voltage (mV) to program the axp pmic eldo1 at, set to 0 to disable eldo1. + On A64 boards it's used for the codec and should be 1.8V.
config AXP_ELDO2_VOLT int "axp pmic eldo2 voltage" - depends on AXP221_POWER || AXP809_POWER || AXP818_POWER + depends on AXP221_POWER || AXP803_POWER || AXP809_POWER || AXP818_POWER default 0 ---help--- Set the voltage (mV) to program the axp pmic eldo2 at, set to 0 to @@ -251,7 +272,7 @@ config AXP_ELDO2_VOLT
config AXP_ELDO3_VOLT int "axp pmic eldo3 voltage" - depends on AXP221_POWER || AXP809_POWER || AXP818_POWER + depends on AXP221_POWER || AXP803_POWER || AXP809_POWER || AXP818_POWER default 3000 if MACH_SUN9I default 0 ---help--- @@ -263,8 +284,8 @@ config AXP_ELDO3_VOLT
config AXP_FLDO1_VOLT int "axp pmic fldo1 voltage" - depends on AXP818_POWER - default 0 if MACH_SUN8I_A83T + depends on AXP803_POWER || AXP818_POWER + default 0 ---help--- Set the voltage (mV) to program the axp pmic fldo1 at, set to 0 to disable fldo1. @@ -273,11 +294,13 @@ config AXP_FLDO1_VOLT
config AXP_FLDO2_VOLT int "axp pmic fldo2 voltage" - depends on AXP818_POWER + depends on AXP803_POWER || AXP818_POWER + default 1100 if MACH_SUN50I default 900 if MACH_SUN8I_A83T ---help--- Set the voltage (mV) to program the axp pmic fldo2 at, set to 0 to disable fldo2. + On A64 boards fldo2 is VCC-CPUS and should be 1.1V. On A83T / H8 boards fldo2 is VCC-CPUS and should be 0.9V.
config AXP_FLDO3_VOLT @@ -290,7 +313,7 @@ config AXP_FLDO3_VOLT
config AXP_SW_ON bool "axp pmic sw on" - depends on AXP809_POWER || AXP818_POWER + depends on AXP803_POWER || AXP809_POWER || AXP818_POWER default n ---help--- Enable to turn on axp pmic sw. diff --git a/drivers/power/Makefile b/drivers/power/Makefile index b43523e628..1449e875ce 100644 --- a/drivers/power/Makefile +++ b/drivers/power/Makefile @@ -9,6 +9,7 @@ obj-$(CONFIG_AS3722_POWER) += as3722.o obj-$(CONFIG_AXP152_POWER) += axp152.o obj-$(CONFIG_AXP209_POWER) += axp209.o obj-$(CONFIG_AXP221_POWER) += axp221.o +obj-$(CONFIG_AXP803_POWER) += axp803.o obj-$(CONFIG_AXP809_POWER) += axp809.o obj-$(CONFIG_AXP818_POWER) += axp818.o obj-$(CONFIG_EXYNOS_TMU) += exynos-tmu.o diff --git a/drivers/power/axp803.c b/drivers/power/axp803.c new file mode 100644 index 0000000000..93b9d95234 --- /dev/null +++ b/drivers/power/axp803.c @@ -0,0 +1,256 @@ +/* + * AXP803 driver based on AXP818 driver + * + * Based on axp818.c + * (C) Copyright 2015 Vishnu Patekar vishnuptekar0510@gmail.com + * + * Based on axp221.c + * (C) Copyright 2014 Hans de Goede hdegoede@redhat.com + * (C) Copyright 2013 Oliver Schinagl oliver@schinagl.nl + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <errno.h> +#include <asm/arch/gpio.h> +#include <asm/arch/pmic_bus.h> +#include <axp_pmic.h> + +static u8 axp803_mvolt_to_cfg(int mvolt, int min, int max, int div) +{ + if (mvolt < min) + mvolt = min; + else if (mvolt > max) + mvolt = max; + + return (mvolt - min) / div; +} + +int axp_set_dcdc1(unsigned int mvolt) +{ + int ret; + u8 cfg = axp803_mvolt_to_cfg(mvolt, 1600, 3400, 100); + + if (mvolt == 0) + return pmic_bus_clrbits(AXP803_OUTPUT_CTRL1, + AXP803_OUTPUT_CTRL1_DCDC1_EN); + + ret = pmic_bus_write(AXP803_DCDC1_CTRL, cfg); + if (ret) + return ret; + + return pmic_bus_setbits(AXP803_OUTPUT_CTRL1, + AXP803_OUTPUT_CTRL1_DCDC1_EN); +} + +int axp_set_dcdc2(unsigned int mvolt) +{ + int ret; + u8 cfg; + + if (mvolt >= 1220) + cfg = 70 + axp803_mvolt_to_cfg(mvolt, 1220, 1300, 20); + else + cfg = axp803_mvolt_to_cfg(mvolt, 500, 1200, 10); + + if (mvolt == 0) + return pmic_bus_clrbits(AXP803_OUTPUT_CTRL1, + AXP803_OUTPUT_CTRL1_DCDC2_EN); + + ret = pmic_bus_write(AXP803_DCDC2_CTRL, cfg); + if (ret) + return ret; + + return pmic_bus_setbits(AXP803_OUTPUT_CTRL1, + AXP803_OUTPUT_CTRL1_DCDC2_EN); +} + +int axp_set_dcdc3(unsigned int mvolt) +{ + int ret; + u8 cfg; + + if (mvolt >= 1220) + cfg = 70 + axp803_mvolt_to_cfg(mvolt, 1220, 1300, 20); + else + cfg = axp803_mvolt_to_cfg(mvolt, 500, 1200, 10); + + if (mvolt == 0) + return pmic_bus_clrbits(AXP803_OUTPUT_CTRL1, + AXP803_OUTPUT_CTRL1_DCDC3_EN); + + ret = pmic_bus_write(AXP803_DCDC3_CTRL, cfg); + if (ret) + return ret; + + return pmic_bus_setbits(AXP803_OUTPUT_CTRL1, + AXP803_OUTPUT_CTRL1_DCDC3_EN); +} + +int axp_set_dcdc5(unsigned int mvolt) +{ + int ret; + u8 cfg; + + if (mvolt >= 1140) + cfg = 32 + axp803_mvolt_to_cfg(mvolt, 1140, 1840, 20); + else + cfg = axp803_mvolt_to_cfg(mvolt, 800, 1120, 10); + + if (mvolt == 0) + return pmic_bus_clrbits(AXP803_OUTPUT_CTRL1, + AXP803_OUTPUT_CTRL1_DCDC5_EN); + + ret = pmic_bus_write(AXP803_DCDC5_CTRL, cfg); + if (ret) + return ret; + + return pmic_bus_setbits(AXP803_OUTPUT_CTRL1, + AXP803_OUTPUT_CTRL1_DCDC5_EN); +} + +int axp_set_aldo(int aldo_num, unsigned int mvolt) +{ + int ret; + u8 cfg; + + if (aldo_num < 1 || aldo_num > 3) + return -EINVAL; + + if (mvolt == 0) + return pmic_bus_clrbits(AXP803_OUTPUT_CTRL3, + AXP803_OUTPUT_CTRL3_ALDO1_EN << (aldo_num - 1)); + + cfg = axp803_mvolt_to_cfg(mvolt, 700, 3300, 100); + ret = pmic_bus_write(AXP803_ALDO1_CTRL + (aldo_num - 1), cfg); + if (ret) + return ret; + + return pmic_bus_setbits(AXP803_OUTPUT_CTRL3, + AXP803_OUTPUT_CTRL3_ALDO1_EN << (aldo_num - 1)); +} + +/* TODO: re-work other AXP drivers to consolidate ALDO functions. */ +int axp_set_aldo1(unsigned int mvolt) +{ + return axp_set_aldo(1, mvolt); +} + +int axp_set_aldo2(unsigned int mvolt) +{ + return axp_set_aldo(2, mvolt); +} + +int axp_set_aldo3(unsigned int mvolt) +{ + return axp_set_aldo(3, mvolt); +} + +int axp_set_dldo(int dldo_num, unsigned int mvolt) +{ + int ret; + u8 cfg; + + if (dldo_num < 1 || dldo_num > 4) + return -EINVAL; + + if (mvolt == 0) + return pmic_bus_clrbits(AXP803_OUTPUT_CTRL2, + AXP803_OUTPUT_CTRL2_DLDO1_EN << (dldo_num - 1)); + + cfg = axp803_mvolt_to_cfg(mvolt, 700, 3300, 100); + if (dldo_num == 2 && mvolt > 3300) + cfg += 1 + axp803_mvolt_to_cfg(mvolt, 3400, 4200, 200); + ret = pmic_bus_write(AXP803_DLDO1_CTRL + (dldo_num - 1), cfg); + if (ret) + return ret; + + return pmic_bus_setbits(AXP803_OUTPUT_CTRL2, + AXP803_OUTPUT_CTRL2_DLDO1_EN << (dldo_num - 1)); +} + +int axp_set_eldo(int eldo_num, unsigned int mvolt) +{ + int ret; + u8 cfg; + + if (eldo_num < 1 || eldo_num > 3) + return -EINVAL; + + if (mvolt == 0) + return pmic_bus_clrbits(AXP803_OUTPUT_CTRL2, + AXP803_OUTPUT_CTRL2_ELDO1_EN << (eldo_num - 1)); + + cfg = axp803_mvolt_to_cfg(mvolt, 700, 1900, 50); + ret = pmic_bus_write(AXP803_ELDO1_CTRL + (eldo_num - 1), cfg); + if (ret) + return ret; + + return pmic_bus_setbits(AXP803_OUTPUT_CTRL2, + AXP803_OUTPUT_CTRL2_ELDO1_EN << (eldo_num - 1)); +} + +int axp_set_fldo(int fldo_num, unsigned int mvolt) +{ + int ret; + u8 cfg; + + if (fldo_num < 1 || fldo_num > 2) + return -EINVAL; + + if (mvolt == 0) + return pmic_bus_clrbits(AXP803_OUTPUT_CTRL3, + AXP803_OUTPUT_CTRL3_FLDO1_EN << (fldo_num - 1)); + + cfg = axp803_mvolt_to_cfg(mvolt, 700, 1450, 50); + ret = pmic_bus_write(AXP803_FLDO1_CTRL + (fldo_num - 1), cfg); + if (ret) + return ret; + + return pmic_bus_setbits(AXP803_OUTPUT_CTRL3, + AXP803_OUTPUT_CTRL3_FLDO1_EN << (fldo_num - 1)); +} + +int axp_set_sw(bool on) +{ + if (on) + return pmic_bus_setbits(AXP803_OUTPUT_CTRL2, + AXP803_OUTPUT_CTRL2_SW_EN); + + return pmic_bus_clrbits(AXP803_OUTPUT_CTRL2, + AXP803_OUTPUT_CTRL2_SW_EN); +} + +int axp_init(void) +{ + u8 axp_chip_id; + int ret; + + ret = pmic_bus_init(); + if (ret) + return ret; + + ret = pmic_bus_read(AXP803_CHIP_ID, &axp_chip_id); + if (ret) + return ret; + + if (!(axp_chip_id == 0x51)) + return -ENODEV; + else + return ret; + + return 0; +} + +int do_poweroff(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + pmic_bus_write(AXP803_SHUTDOWN, AXP803_SHUTDOWN_POWEROFF); + + /* infinite loop during shutdown */ + while (1) + ; + + /* not reached */ + return 0; +} diff --git a/drivers/power/axp818.c b/drivers/power/axp818.c index af4d7a6903..ad0c330ca5 100644 --- a/drivers/power/axp818.c +++ b/drivers/power/axp818.c @@ -162,7 +162,7 @@ int axp_set_dldo(int dldo_num, unsigned int mvolt) cfg = axp818_mvolt_to_cfg(mvolt, 700, 3300, 100); if (dldo_num == 2 && mvolt > 3300) cfg += 1 + axp818_mvolt_to_cfg(mvolt, 3400, 4200, 200); - ret = pmic_bus_write(AXP818_ELDO1_CTRL + (dldo_num - 1), cfg); + ret = pmic_bus_write(AXP818_DLDO1_CTRL + (dldo_num - 1), cfg); if (ret) return ret;
diff --git a/include/axp803.h b/include/axp803.h new file mode 100644 index 0000000000..b382f3a5ec --- /dev/null +++ b/include/axp803.h @@ -0,0 +1,73 @@ +/* + * (C) Copyright 2016 Icenowy Zheng icenowy@aosc.xyz + * + * Based on axp818.h, which is: + * (C) Copyright 2015 Vishnu Patekar vishnupatekar0510@gmail.com + * + * X-Powers AXP803 Power Management IC driver + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#define AXP803_CHIP_ID 0x03 + +#define AXP803_OUTPUT_CTRL1 0x10 +#define AXP803_OUTPUT_CTRL1_DCDC1_EN (1 << 0) +#define AXP803_OUTPUT_CTRL1_DCDC2_EN (1 << 1) +#define AXP803_OUTPUT_CTRL1_DCDC3_EN (1 << 2) +#define AXP803_OUTPUT_CTRL1_DCDC4_EN (1 << 3) +#define AXP803_OUTPUT_CTRL1_DCDC5_EN (1 << 4) +#define AXP803_OUTPUT_CTRL1_DCDC6_EN (1 << 5) +#define AXP803_OUTPUT_CTRL2 0x12 +#define AXP803_OUTPUT_CTRL2_ELDO1_EN (1 << 0) +#define AXP803_OUTPUT_CTRL2_ELDO2_EN (1 << 1) +#define AXP803_OUTPUT_CTRL2_ELDO3_EN (1 << 2) +#define AXP803_OUTPUT_CTRL2_DLDO1_EN (1 << 3) +#define AXP803_OUTPUT_CTRL2_DLDO2_EN (1 << 4) +#define AXP803_OUTPUT_CTRL2_DLDO3_EN (1 << 5) +#define AXP803_OUTPUT_CTRL2_DLDO4_EN (1 << 6) +#define AXP803_OUTPUT_CTRL2_SW_EN (1 << 7) +#define AXP803_OUTPUT_CTRL3 0x13 +#define AXP803_OUTPUT_CTRL3_FLDO1_EN (1 << 2) +#define AXP803_OUTPUT_CTRL3_FLDO2_EN (1 << 3) +#define AXP803_OUTPUT_CTRL3_ALDO1_EN (1 << 5) +#define AXP803_OUTPUT_CTRL3_ALDO2_EN (1 << 6) +#define AXP803_OUTPUT_CTRL3_ALDO3_EN (1 << 7) + +#define AXP803_DLDO1_CTRL 0x15 +#define AXP803_DLDO2_CTRL 0x16 +#define AXP803_DLDO3_CTRL 0x17 +#define AXP803_DLDO4_CTRL 0x18 +#define AXP803_ELDO1_CTRL 0x19 +#define AXP803_ELDO2_CTRL 0x1a +#define AXP803_ELDO3_CTRL 0x1b +#define AXP803_FLDO1_CTRL 0x1c +#define AXP803_FLDO2_CTRL 0x1d +#define AXP803_DCDC1_CTRL 0x20 +#define AXP803_DCDC2_CTRL 0x21 +#define AXP803_DCDC3_CTRL 0x22 +#define AXP803_DCDC4_CTRL 0x23 +#define AXP803_DCDC5_CTRL 0x24 +#define AXP803_DCDC6_CTRL 0x25 + +#define AXP803_ALDO1_CTRL 0x28 +#define AXP803_ALDO2_CTRL 0x29 +#define AXP803_ALDO3_CTRL 0x2a + +#define AXP803_SHUTDOWN 0x32 +#define AXP803_SHUTDOWN_POWEROFF (1 << 7) + +/* For axp_gpio.c */ +#define AXP_POWER_STATUS 0x00 +#define AXP_POWER_STATUS_VBUS_PRESENT (1 << 5) +#define AXP_VBUS_IPSOUT 0x30 +#define AXP_VBUS_IPSOUT_DRIVEBUS (1 << 2) +#define AXP_MISC_CTRL 0x8f +#define AXP_MISC_CTRL_N_VBUSEN_FUNC (1 << 4) +#define AXP_GPIO0_CTRL 0x90 +#define AXP_GPIO1_CTRL 0x92 +#define AXP_GPIO_CTRL_OUTPUT_LOW 0x00 /* Drive pin low */ +#define AXP_GPIO_CTRL_OUTPUT_HIGH 0x01 /* Drive pin high */ +#define AXP_GPIO_CTRL_INPUT 0x02 /* Input */ +#define AXP_GPIO_STATE 0x94 +#define AXP_GPIO_STATE_OFFSET 0 diff --git a/include/axp_pmic.h b/include/axp_pmic.h index d789ad8086..8cb4d5763c 100644 --- a/include/axp_pmic.h +++ b/include/axp_pmic.h @@ -16,6 +16,9 @@ #ifdef CONFIG_AXP221_POWER #include <axp221.h> #endif +#ifdef CONFIG_AXP803_POWER +#include <axp803.h> +#endif #ifdef CONFIG_AXP809_POWER #include <axp809.h> #endif
21.03.2017, 06:01, "Jernej Skrabec" jernej.skrabec@siol.net:
This series implements support for HDMI output. This is done using DM video framework and sharing the HDMI controller code with RK3288.
Patch 1 splits out RK3288 HDMI code in a way that it is appropriate for sharing with Allwinner SoCs.
Patch 2 splits out TCON code which is completely reusable on all Allwinner SoCs.
Patch 3 (new) converts commont TCON code to use DM video compatible timing structure.
Patch 4 adds all necessary clocks which are needed for Display Engine 2, TCON and HDMI.
Patch 5 implement actual DE2 and HDMI driver and patch 6 disables HDMI on all boards which don't have it (default is on).
Patch 7 is included here only for testing HDMI output on A64 due to missing power regulator support (AXP803). Another option is to use ATF which powers on HDMI. Such ATF can be found on Andre Przywara's github.
Code was tested on OrangePi 2 & OrangePi Plus 2E (both H3), OrangePi PC 2 (H5) and Pine64 (A64). It was also tested on RK3288 Tinker board. However, it was only compile tested for A10 and A20 targets.
I tested the patched U-Boot on A10 with HDMI and A13 with LCD, and it works properly.
This series was developed on u-boot-sunxi repository with additional, not yet merged, patch: https://patchwork.ozlabs.org/patch/735617/
Because already merged patches are not yet included in u-boot-sunxi repository, they need to be cherry picked from u-boot-rockchip: a0a2774aebdaa039ce787090c903cf47263f04c9 520c174b3564ae183f0e7c118dc8ce3770ae20b0
Best regards, Jernej Skrabec
Changes in v2:
- patch 1 & 2 were removed because they were merged
- collect reviewed by and tested by tags
- TCON split out patch is splitted in two patches
- fixed lcdc_enable() calls in video driver for old SoCs
- defconfigs should disable video driver, not enable it
- minor constant style fix
Icenowy Zheng (1): [DO NOT MERGE] sunxi: add AXP803 support
Jernej Skrabec (6): rockchip: video: Split out HDMI controller code sunxi: video: Split out TCON code sunxi: video: Convert lcdc to use struct display_timing sunxi: Add clock support for DE2/HDMI/TCON on newer SoCs sunxi: video: Add A64/H3/H5 HDMI driver sunxi: Disable DE2 video driver where not needed
arch/arm/include/asm/arch-rockchip/hdmi_rk3288.h | 456 -------------- arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 54 ++ arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 8 + arch/arm/include/asm/arch-sunxi/display.h | 103 --- arch/arm/include/asm/arch-sunxi/display2.h | 124 ++++ arch/arm/include/asm/arch-sunxi/lcdc.h | 128 ++++ arch/arm/mach-sunxi/Makefile | 3 + arch/arm/mach-sunxi/clock_sun6i.c | 40 +- arch/arm/mach-sunxi/pmic_bus.c | 6 +- arch/arm/mach-sunxi/rsb.c | 2 +- board/sunxi/Kconfig | 10 + board/sunxi/board.c | 31 +- configs/nanopi_neo_air_defconfig | 1 + configs/nanopi_neo_defconfig | 1 + configs/orangepi_zero_defconfig | 1 + drivers/power/Kconfig | 87 ++- drivers/power/Makefile | 1 + drivers/power/axp803.c | 256 ++++++++ drivers/power/axp818.c | 2 +- drivers/video/Makefile | 2 +- drivers/video/dw_hdmi.c | 764 +++++++++++++++++++++++ drivers/video/rockchip/Makefile | 2 +- drivers/video/rockchip/rk_hdmi.c | 757 +--------------------- drivers/video/rockchip/rk_vop.c | 1 - drivers/video/sunxi/Makefile | 9 + drivers/video/sunxi/lcdc.c | 209 +++++++ drivers/video/sunxi/sunxi_de2.c | 258 ++++++++ drivers/video/{ => sunxi}/sunxi_display.c | 220 ++----- drivers/video/sunxi/sunxi_dw_hdmi.c | 389 ++++++++++++ include/axp803.h | 73 +++ include/axp_pmic.h | 3 + include/configs/sun50i.h | 2 + include/configs/sun8i.h | 4 + include/configs/sunxi-common.h | 5 + include/dw_hdmi.h | 486 ++++++++++++++ scripts/config_whitelist.txt | 1 + 36 files changed, 2977 insertions(+), 1522 deletions(-) delete mode 100644 arch/arm/include/asm/arch-rockchip/hdmi_rk3288.h create mode 100644 arch/arm/include/asm/arch-sunxi/display2.h create mode 100644 arch/arm/include/asm/arch-sunxi/lcdc.h create mode 100644 drivers/power/axp803.c create mode 100644 drivers/video/dw_hdmi.c create mode 100644 drivers/video/sunxi/Makefile create mode 100644 drivers/video/sunxi/lcdc.c create mode 100644 drivers/video/sunxi/sunxi_de2.c rename drivers/video/{ => sunxi}/sunxi_display.c (87%) create mode 100644 drivers/video/sunxi/sunxi_dw_hdmi.c create mode 100644 include/axp803.h create mode 100644 include/dw_hdmi.h
-- 2.12.0
-- You received this message because you are subscribed to the Google Groups "linux-sunxi" group. To unsubscribe from this group and stop receiving emails from it, send an email to linux-sunxi+unsubscribe@googlegroups.com. For more options, visit https://groups.google.com/d/optout.
Hi Jernej,
This is a really nice piece of work, thank you!
Dne sobota, 01. april 2017 ob 06:20:52 CEST je Simon Glass napisal(a):
Hi Jernej,
I'm glad you like it! I will definetly send some follow up patches to improve dw_hdmi driver.
Regards, Jernej
participants (5)
Icenowy Zheng
Jernej Skrabec
Jernej Škrabec
Maxime Ripard
