[U-Boot] [PATCH 1/1] test: call hexdump tests via `ut lib`
The unit tests in test/lib/hexdump.c are not related to the device tree. So they should be executed via `ut lib` and not via `ut dm`.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- test/lib/hexdump.c | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/test/lib/hexdump.c b/test/lib/hexdump.c index 567b57686a..5dccf43886 100644 --- a/test/lib/hexdump.c +++ b/test/lib/hexdump.c @@ -6,7 +6,8 @@
#include <common.h> #include <hexdump.h> -#include <dm/test.h> +#include <test/lib.h> +#include <test/test.h> #include <test/ut.h>
static int lib_test_hex_to_bin(struct unit_test_state *uts) @@ -32,7 +33,7 @@ static int lib_test_hex_to_bin(struct unit_test_state *uts) return 0; }
-DM_TEST(lib_test_hex_to_bin, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); +LIB_TEST(lib_test_hex_to_bin, 0);
static int lib_test_hex2bin(struct unit_test_state *uts) { @@ -62,7 +63,7 @@ static int lib_test_hex2bin(struct unit_test_state *uts) return 0; }
-DM_TEST(lib_test_hex2bin, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); +LIB_TEST(lib_test_hex2bin, 0);
static int lib_test_bin2hex(struct unit_test_state *uts) { @@ -92,4 +93,4 @@ static int lib_test_bin2hex(struct unit_test_state *uts) return 0; }
-DM_TEST(lib_test_bin2hex, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); +LIB_TEST(lib_test_bin2hex, 0);
Am 11.02.2019 um 18:29 schrieb Heinrich Schuchardt:
Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
Excellent idea, I'll send the same for test/lib/lmb.c.
Thanks, Simon
Hello Tom,
please, consider the patch for v2019-07.
Best regards
Heinrich
Thanks, Simon
diff --git a/test/lib/hexdump.c b/test/lib/hexdump.c index 567b57686a..5dccf43886 100644 --- a/test/lib/hexdump.c +++ b/test/lib/hexdump.c @@ -6,7 +6,8 @@ #include <common.h> #include <hexdump.h> -#include <dm/test.h> +#include <test/lib.h> +#include <test/test.h> #include <test/ut.h> static int lib_test_hex_to_bin(struct unit_test_state *uts) @@ -32,7 +33,7 @@ static int lib_test_hex_to_bin(struct unit_test_state *uts) return 0; } -DM_TEST(lib_test_hex_to_bin, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); +LIB_TEST(lib_test_hex_to_bin, 0); static int lib_test_hex2bin(struct unit_test_state *uts) { @@ -62,7 +63,7 @@ static int lib_test_hex2bin(struct unit_test_state *uts) return 0; } -DM_TEST(lib_test_hex2bin, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); +LIB_TEST(lib_test_hex2bin, 0); static int lib_test_bin2hex(struct unit_test_state *uts) { @@ -92,4 +93,4 @@ static int lib_test_bin2hex(struct unit_test_state *uts) return 0; } -DM_TEST(lib_test_bin2hex, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); +LIB_TEST(lib_test_bin2hex, 0);
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com
Simon Goldschmidt
