[PATCH v3 0/5] cmd: add scmi command
"Scmi" command will be re-introduced per Michal's request. The functionality is the same as I put it in my patch set of adding SCMI base protocol support, but made some tweak to make UT, "ut dm scmi_cmd," more flexible and tolerable when enabling/disabling a specific SCMI protocol for test purpose.
Each commit may have some change history inherited from the preceding patch series.
Test ==== The patch series was tested on the following platforms: * sandbox
Prerequisite: ============= * This patch series is based on the latest master.
Changes: ======== v3(Nov 14, 2023) * return -EAGAIN if we want to skip a test. * use CONFIG_IS_ENABLED() rather than IS_ENABLED(). * remove goto by introducing a function in sandbox implementation. v2(Nov 13, 2023) * localize global variables to avoid pytest errors.
AKASHI Takahiro (5): test: dm: skip scmi tests against disabled protocols firmware: scmi: support protocols on sandbox only if enabled cmd: add scmi command for SCMI firmware doc: cmd: add documentation for scmi test: dm: add scmi command test
cmd/Kconfig | 9 + cmd/Makefile | 1 + cmd/scmi.c | 384 +++++++++++++++++++ configs/sandbox_defconfig | 1 + doc/usage/cmd/scmi.rst | 126 ++++++ doc/usage/index.rst | 1 + drivers/firmware/scmi/sandbox-scmi_agent.c | 30 +- drivers/firmware/scmi/sandbox-scmi_devices.c | 78 ++-- test/dm/scmi.c | 93 +++++ 9 files changed, 686 insertions(+), 37 deletions(-) create mode 100644 cmd/scmi.c create mode 100644 doc/usage/cmd/scmi.rst
This is a precautionary change to make scmi tests workable whether or not a specific protocol be enabled. If a given protocol is not configured, we skip the test by returning -EAGAIN.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- v9 * return -EAGAIN if we want to skip a test * use CONFIG_IS_ENABLED() rather than IS_ENABLED() --- test/dm/scmi.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/test/dm/scmi.c b/test/dm/scmi.c index da45314f2e4c..582485471fff 100644 --- a/test/dm/scmi.c +++ b/test/dm/scmi.c @@ -217,6 +217,9 @@ static int dm_test_scmi_power_domains(struct unit_test_state *uts) u8 *name; int ret;
+ if (!CONFIG_IS_ENABLED(SCMI_POWER_DOMAIN)) + return -EAGAIN; + /* preparation */ ut_assertok(load_sandbox_scmi_test_devices(uts, &agent, &dev)); ut_assertnonnull(agent); @@ -317,6 +320,9 @@ static int dm_test_scmi_clocks(struct unit_test_state *uts) int ret_dev; int ret;
+ if (!CONFIG_IS_ENABLED(CLK_SCMI)) + return -EAGAIN; + ret = load_sandbox_scmi_test_devices(uts, &agent, &dev); if (ret) return ret; @@ -382,6 +388,9 @@ static int dm_test_scmi_resets(struct unit_test_state *uts) struct udevice *agent_dev, *reset_dev, *dev = NULL; int ret;
+ if (!CONFIG_IS_ENABLED(RESET_SCMI)) + return -EAGAIN; + ret = load_sandbox_scmi_test_devices(uts, &agent, &dev); if (ret) return ret; @@ -418,6 +427,9 @@ static int dm_test_scmi_voltage_domains(struct unit_test_state *uts) struct udevice *dev; struct udevice *regul0_dev;
+ if (!CONFIG_IS_ENABLED(DM_REGULATOR_SCMI)) + return -EAGAIN; + ut_assertok(load_sandbox_scmi_test_devices(uts, &agent, &dev));
scmi_devices = sandbox_scmi_devices_ctx(dev);
On Mon, 13 Nov 2023 at 19:14, AKASHI Takahiro takahiro.akashi@linaro.org wrote:
v9
- return -EAGAIN if we want to skip a test
- use CONFIG_IS_ENABLED() rather than IS_ENABLED()
This change will be useful when we manually test SCMI on sandbox by enabling/disabling a specific SCMI protocol.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- v9 * use CONFIG_IS_ENABLED() rather than IS_ENABLED() * remove goto by introducing a not_supported() function --- drivers/firmware/scmi/sandbox-scmi_agent.c | 30 ++++++-- drivers/firmware/scmi/sandbox-scmi_devices.c | 78 ++++++++++++-------- 2 files changed, 71 insertions(+), 37 deletions(-)
diff --git a/drivers/firmware/scmi/sandbox-scmi_agent.c b/drivers/firmware/scmi/sandbox-scmi_agent.c index d13180962662..cc9011c7312f 100644 --- a/drivers/firmware/scmi/sandbox-scmi_agent.c +++ b/drivers/firmware/scmi/sandbox-scmi_agent.c @@ -66,10 +66,10 @@ struct scmi_channel { };
static u8 protocols[] = { - SCMI_PROTOCOL_ID_POWER_DOMAIN, - SCMI_PROTOCOL_ID_CLOCK, - SCMI_PROTOCOL_ID_RESET_DOMAIN, - SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN, + CONFIG_IS_ENABLED(SCMI_POWER_DOMAIN, (SCMI_PROTOCOL_ID_POWER_DOMAIN,)) + CONFIG_IS_ENABLED(CLK_SCMI, (SCMI_PROTOCOL_ID_CLOCK,)) + CONFIG_IS_ENABLED(RESET_SCMI, (SCMI_PROTOCOL_ID_RESET_DOMAIN,)) + CONFIG_IS_ENABLED(DM_REGULATOR_SCMI, (SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN,)) };
#define NUM_PROTOCOLS ARRAY_SIZE(protocols) @@ -1124,6 +1124,13 @@ unsigned int sandbox_scmi_channel_id(struct udevice *dev) return chan->channel_id; }
+static int sandbox_proto_not_supported(struct scmi_msg *msg) +{ + *(u32 *)msg->out_msg = SCMI_NOT_SUPPORTED; + + return 0; +} + static int sandbox_scmi_test_process_msg(struct udevice *dev, struct scmi_channel *channel, struct scmi_msg *msg) @@ -1160,6 +1167,9 @@ static int sandbox_scmi_test_process_msg(struct udevice *dev, } break; case SCMI_PROTOCOL_ID_POWER_DOMAIN: + if (!CONFIG_IS_ENABLED(SCMI_POWER_DOMAIN)) + return sandbox_proto_not_supported(msg); + switch (msg->message_id) { case SCMI_PROTOCOL_VERSION: return sandbox_scmi_pwd_protocol_version(dev, msg); @@ -1180,6 +1190,9 @@ static int sandbox_scmi_test_process_msg(struct udevice *dev, } break; case SCMI_PROTOCOL_ID_CLOCK: + if (!CONFIG_IS_ENABLED(CLK_SCMI)) + return sandbox_proto_not_supported(msg); + switch (msg->message_id) { case SCMI_PROTOCOL_ATTRIBUTES: return sandbox_scmi_clock_protocol_attribs(dev, msg); @@ -1196,6 +1209,9 @@ static int sandbox_scmi_test_process_msg(struct udevice *dev, } break; case SCMI_PROTOCOL_ID_RESET_DOMAIN: + if (!CONFIG_IS_ENABLED(RESET_SCMI)) + return sandbox_proto_not_supported(msg); + switch (msg->message_id) { case SCMI_RESET_DOMAIN_ATTRIBUTES: return sandbox_scmi_rd_attribs(dev, msg); @@ -1206,6 +1222,9 @@ static int sandbox_scmi_test_process_msg(struct udevice *dev, } break; case SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN: + if (!CONFIG_IS_ENABLED(DM_REGULATOR_SCMI)) + return sandbox_proto_not_supported(msg); + switch (msg->message_id) { case SCMI_VOLTAGE_DOMAIN_ATTRIBUTES: return sandbox_scmi_voltd_attribs(dev, msg); @@ -1224,8 +1243,7 @@ static int sandbox_scmi_test_process_msg(struct udevice *dev, case SCMI_PROTOCOL_ID_SYSTEM: case SCMI_PROTOCOL_ID_PERF: case SCMI_PROTOCOL_ID_SENSOR: - *(u32 *)msg->out_msg = SCMI_NOT_SUPPORTED; - return 0; + return sandbox_proto_not_supported(msg); default: break; } diff --git a/drivers/firmware/scmi/sandbox-scmi_devices.c b/drivers/firmware/scmi/sandbox-scmi_devices.c index facb5b06ffb5..603e2bb40aff 100644 --- a/drivers/firmware/scmi/sandbox-scmi_devices.c +++ b/drivers/firmware/scmi/sandbox-scmi_devices.c @@ -62,12 +62,13 @@ static int sandbox_scmi_devices_remove(struct udevice *dev) if (!devices) return 0;
- for (n = 0; n < SCMI_TEST_DEVICES_RD_COUNT; n++) { - int ret2 = reset_free(devices->reset + n); + if (CONFIG_IS_ENABLED(RESET_SCMI)) + for (n = 0; n < SCMI_TEST_DEVICES_RD_COUNT; n++) { + int ret2 = reset_free(devices->reset + n);
- if (ret2 && !ret) - ret = ret2; - } + if (ret2 && !ret) + ret = ret2; + }
return ret; } @@ -89,39 +90,53 @@ static int sandbox_scmi_devices_probe(struct udevice *dev) .regul_count = SCMI_TEST_DEVICES_VOLTD_COUNT, };
- ret = power_domain_get_by_index(dev, priv->devices.pwdom, 0); - if (ret) { - dev_err(dev, "%s: Failed on power domain\n", __func__); - return ret; - } - - for (n = 0; n < SCMI_TEST_DEVICES_CLK_COUNT; n++) { - ret = clk_get_by_index(dev, n, priv->devices.clk + n); + if (CONFIG_IS_ENABLED(SCMI_POWER_DOMAIN)) { + ret = power_domain_get_by_index(dev, priv->devices.pwdom, 0); if (ret) { - dev_err(dev, "%s: Failed on clk %zu\n", __func__, n); + dev_err(dev, "%s: Failed on power domain\n", __func__); return ret; } }
- for (n = 0; n < SCMI_TEST_DEVICES_RD_COUNT; n++) { - ret = reset_get_by_index(dev, n, priv->devices.reset + n); - if (ret) { - dev_err(dev, "%s: Failed on reset %zu\n", __func__, n); - goto err_reset; + if (CONFIG_IS_ENABLED(CLK_SCMI)) { + for (n = 0; n < SCMI_TEST_DEVICES_CLK_COUNT; n++) { + ret = clk_get_by_index(dev, n, priv->devices.clk + n); + if (ret) { + dev_err(dev, "%s: Failed on clk %zu\n", + __func__, n); + return ret; + } } }
- for (n = 0; n < SCMI_TEST_DEVICES_VOLTD_COUNT; n++) { - char name[32]; - - ret = snprintf(name, sizeof(name), "regul%zu-supply", n); - assert(ret >= 0 && ret < sizeof(name)); + if (CONFIG_IS_ENABLED(RESET_SCMI)) { + for (n = 0; n < SCMI_TEST_DEVICES_RD_COUNT; n++) { + ret = reset_get_by_index(dev, n, + priv->devices.reset + n); + if (ret) { + dev_err(dev, "%s: Failed on reset %zu\n", + __func__, n); + goto err_reset; + } + } + }
- ret = device_get_supply_regulator(dev, name, - priv->devices.regul + n); - if (ret) { - dev_err(dev, "%s: Failed on voltd %zu\n", __func__, n); - goto err_regul; + if (CONFIG_IS_ENABLED(DM_REGULATOR_SCMI)) { + for (n = 0; n < SCMI_TEST_DEVICES_VOLTD_COUNT; n++) { + char name[32]; + + ret = snprintf(name, sizeof(name), "regul%zu-supply", + n); + assert(ret >= 0 && ret < sizeof(name)); + + ret = device_get_supply_regulator(dev, name, + priv->devices.regul + + n); + if (ret) { + dev_err(dev, "%s: Failed on voltd %zu\n", + __func__, n); + goto err_regul; + } } }
@@ -130,8 +145,9 @@ static int sandbox_scmi_devices_probe(struct udevice *dev) err_regul: n = SCMI_TEST_DEVICES_RD_COUNT; err_reset: - for (; n > 0; n--) - reset_free(priv->devices.reset + n - 1); + if (CONFIG_IS_ENABLED(RESET_SCMI)) + for (; n > 0; n--) + reset_free(priv->devices.reset + n - 1);
return ret; }
v9
- remove goto by introducing a not_supported() function
This command, "scmi", may provide a command line interface to various SCMI protocols. It supports at least initially SCMI base protocol and is intended mainly for debug purpose.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Etienne Carriere etienne.carriere@foss.st.com --- v8 (actually v2 as SCMI cmd) * localize global variables to avoid pytest errors v3 * describe that arguments are in hex at a help message * modify the code for dynamically allocated agent names v2 * remove sub command category, 'scmi base', for simplicity --- cmd/Kconfig | 9 ++ cmd/Makefile | 1 + cmd/scmi.c | 384 +++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 394 insertions(+) create mode 100644 cmd/scmi.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index df6d71c103f9..ca9f742dcf78 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -2559,6 +2559,15 @@ config CMD_CROS_EC a number of sub-commands for performing EC tasks such as updating its flash, accessing a small saved context area and talking to the I2C bus behind the EC (if there is one). + +config CMD_SCMI + bool "Enable scmi command" + depends on SCMI_FIRMWARE + default n + help + This command provides user interfaces to several SCMI (System + Control and Management Interface) protocols available on Arm + platforms to manage system resources. endmenu
menu "Filesystem commands" diff --git a/cmd/Makefile b/cmd/Makefile index 9a6790cc1708..320f0b5266eb 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -159,6 +159,7 @@ obj-$(CONFIG_CMD_SATA) += sata.o obj-$(CONFIG_CMD_NVME) += nvme.o obj-$(CONFIG_SANDBOX) += sb.o obj-$(CONFIG_CMD_SF) += sf.o +obj-$(CONFIG_CMD_SCMI) += scmi.o obj-$(CONFIG_CMD_SCSI) += scsi.o disk.o obj-$(CONFIG_CMD_SHA1SUM) += sha1sum.o obj-$(CONFIG_CMD_SEAMA) += seama.o diff --git a/cmd/scmi.c b/cmd/scmi.c new file mode 100644 index 000000000000..664062c4eff5 --- /dev/null +++ b/cmd/scmi.c @@ -0,0 +1,384 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * SCMI (System Control and Management Interface) utility command + * + * Copyright (c) 2023 Linaro Limited + * Author: AKASHI Takahiro + */ + +#include <command.h> +#include <exports.h> +#include <scmi_agent.h> +#include <scmi_agent-uclass.h> +#include <stdlib.h> +#include <asm/types.h> +#include <dm/device.h> +#include <dm/uclass.h> /* uclass_get_device */ +#include <linux/bitfield.h> +#include <linux/bitops.h> + +struct { + enum scmi_std_protocol id; + const char *name; +} protocol_name[] = { + {SCMI_PROTOCOL_ID_BASE, "Base"}, + {SCMI_PROTOCOL_ID_POWER_DOMAIN, "Power domain management"}, + {SCMI_PROTOCOL_ID_SYSTEM, "System power management"}, + {SCMI_PROTOCOL_ID_PERF, "Performance domain management"}, + {SCMI_PROTOCOL_ID_CLOCK, "Clock management"}, + {SCMI_PROTOCOL_ID_SENSOR, "Sensor management"}, + {SCMI_PROTOCOL_ID_RESET_DOMAIN, "Reset domain management"}, + {SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN, "Voltage domain management"}, +}; + +/** + * get_agent() - get SCMI agent device + * + * Return: Pointer to SCMI agent device on success, NULL on failure + */ +static struct udevice *get_agent(void) +{ + struct udevice *agent; + + if (uclass_get_device(UCLASS_SCMI_AGENT, 0, &agent)) { + printf("Cannot find any SCMI agent\n"); + return NULL; + } + + return agent; +} + +/** + * get_base_proto() - get SCMI base protocol device + * @agent: SCMI agent device + * + * Return: Pointer to SCMI base protocol device on success, + * NULL on failure + */ +static struct udevice *get_base_proto(struct udevice *agent) +{ + struct udevice *base_proto; + + if (!agent) { + agent = get_agent(); + if (!agent) + return NULL; + } + + base_proto = scmi_get_protocol(agent, SCMI_PROTOCOL_ID_BASE); + if (!base_proto) { + printf("SCMI base protocol not found\n"); + return NULL; + } + + return base_proto; +} + +/** + * get_proto_name() - get the name of SCMI protocol + * + * @id: SCMI Protocol ID + * + * Get the printable name of the protocol, @id + * + * Return: Name string on success, NULL on failure + */ +static const char *get_proto_name(enum scmi_std_protocol id) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(protocol_name); i++) + if (id == protocol_name[i].id) + return protocol_name[i].name; + + return NULL; +} + +/** + * do_scmi_info() - get the information of SCMI services + * + * @cmdtp: Command table + * @flag: Command flag + * @argc: Number of arguments + * @argv: Argument array + * + * Get the information of SCMI services using various interfaces + * provided by the Base protocol. + * + * Return: CMD_RET_SUCCESS on success, CMD_RET_RET_FAILURE on failure + */ +static int do_scmi_info(struct cmd_tbl *cmdtp, int flag, int argc, + char * const argv[]) +{ + struct udevice *agent, *base_proto; + u32 agent_id, num_protocols; + u8 *agent_name, *protocols; + int i, ret; + + if (argc != 1) + return CMD_RET_USAGE; + + agent = get_agent(); + if (!agent) + return CMD_RET_FAILURE; + base_proto = get_base_proto(agent); + if (!base_proto) + return CMD_RET_FAILURE; + + printf("SCMI device: %s\n", agent->name); + printf(" protocol version: 0x%x\n", scmi_version(agent)); + printf(" # of agents: %d\n", scmi_num_agents(agent)); + for (i = 0; i < scmi_num_agents(agent); i++) { + ret = scmi_base_discover_agent(base_proto, i, &agent_id, + &agent_name); + if (ret) { + if (ret != -EOPNOTSUPP) + printf("base_discover_agent() failed for id: %d (%d)\n", + i, ret); + break; + } + printf(" %c%2d: %s\n", i == scmi_agent_id(agent) ? '>' : ' ', + i, agent_name); + free(agent_name); + } + printf(" # of protocols: %d\n", scmi_num_protocols(agent)); + num_protocols = scmi_num_protocols(agent); + protocols = scmi_protocols(agent); + if (protocols) + for (i = 0; i < num_protocols; i++) + printf(" %s\n", get_proto_name(protocols[i])); + printf(" vendor: %s\n", scmi_vendor(agent)); + printf(" sub vendor: %s\n", scmi_sub_vendor(agent)); + printf(" impl version: 0x%x\n", scmi_impl_version(agent)); + + return CMD_RET_SUCCESS; +} + +/** + * do_scmi_set_dev() - set access permission to device + * + * @cmdtp: Command table + * @flag: Command flag + * @argc: Number of arguments + * @argv: Argument array + * + * Set access permission to device with SCMI_BASE_SET_DEVICE_PERMISSIONS + * + * Return: CMD_RET_SUCCESS on success, CMD_RET_RET_FAILURE on failure + */ +static int do_scmi_set_dev(struct cmd_tbl *cmdtp, int flag, int argc, + char * const argv[]) +{ + u32 agent_id, device_id, flags, attributes; + char *end; + struct udevice *base_proto; + int ret; + + if (argc != 4) + return CMD_RET_USAGE; + + agent_id = simple_strtoul(argv[1], &end, 16); + if (*end != '\0') + return CMD_RET_USAGE; + + device_id = simple_strtoul(argv[2], &end, 16); + if (*end != '\0') + return CMD_RET_USAGE; + + flags = simple_strtoul(argv[3], &end, 16); + if (*end != '\0') + return CMD_RET_USAGE; + + base_proto = get_base_proto(NULL); + if (!base_proto) + return CMD_RET_FAILURE; + + ret = scmi_base_protocol_message_attrs(base_proto, + SCMI_BASE_SET_DEVICE_PERMISSIONS, + &attributes); + if (ret) { + printf("This operation is not supported\n"); + return CMD_RET_FAILURE; + } + + ret = scmi_base_set_device_permissions(base_proto, agent_id, + device_id, flags); + if (ret) { + printf("%s access to device:%u failed (%d)\n", + flags ? "Allowing" : "Denying", device_id, ret); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; +} + +/** + * do_scmi_set_proto() - set protocol permission to device + * + * @cmdtp: Command table + * @flag: Command flag + * @argc: Number of arguments + * @argv: Argument array + * + * Set protocol permission to device with SCMI_BASE_SET_PROTOCOL_PERMISSIONS + * + * Return: CMD_RET_SUCCESS on success, CMD_RET_RET_FAILURE on failure + */ +static int do_scmi_set_proto(struct cmd_tbl *cmdtp, int flag, int argc, + char * const argv[]) +{ + u32 agent_id, device_id, protocol_id, flags, attributes; + char *end; + struct udevice *base_proto; + int ret; + + if (argc != 5) + return CMD_RET_USAGE; + + agent_id = simple_strtoul(argv[1], &end, 16); + if (*end != '\0') + return CMD_RET_USAGE; + + device_id = simple_strtoul(argv[2], &end, 16); + if (*end != '\0') + return CMD_RET_USAGE; + + protocol_id = simple_strtoul(argv[3], &end, 16); + if (*end != '\0') + return CMD_RET_USAGE; + + flags = simple_strtoul(argv[4], &end, 16); + if (*end != '\0') + return CMD_RET_USAGE; + + base_proto = get_base_proto(NULL); + if (!base_proto) + return CMD_RET_FAILURE; + + ret = scmi_base_protocol_message_attrs(base_proto, + SCMI_BASE_SET_PROTOCOL_PERMISSIONS, + &attributes); + if (ret) { + printf("This operation is not supported\n"); + return CMD_RET_FAILURE; + } + + ret = scmi_base_set_protocol_permissions(base_proto, agent_id, + device_id, protocol_id, + flags); + if (ret) { + printf("%s access to protocol:0x%x on device:%u failed (%d)\n", + flags ? "Allowing" : "Denying", protocol_id, device_id, + ret); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; +} + +/** + * do_scmi_reset() - reset platform resource settings + * + * @cmdtp: Command table + * @flag: Command flag + * @argc: Number of arguments + * @argv: Argument array + * + * Reset platform resource settings with BASE_RESET_AGENT_CONFIGURATION + * + * Return: CMD_RET_SUCCESS on success, CMD_RET_RET_FAILURE on failure + */ +static int do_scmi_reset(struct cmd_tbl *cmdtp, int flag, int argc, + char * const argv[]) +{ + u32 agent_id, flags, attributes; + char *end; + struct udevice *base_proto; + int ret; + + if (argc != 3) + return CMD_RET_USAGE; + + agent_id = simple_strtoul(argv[1], &end, 16); + if (*end != '\0') + return CMD_RET_USAGE; + + flags = simple_strtoul(argv[2], &end, 16); + if (*end != '\0') + return CMD_RET_USAGE; + + base_proto = get_base_proto(NULL); + if (!base_proto) + return CMD_RET_FAILURE; + + ret = scmi_base_protocol_message_attrs(base_proto, + SCMI_BASE_RESET_AGENT_CONFIGURATION, + &attributes); + if (ret) { + printf("Reset is not supported\n"); + return CMD_RET_FAILURE; + } + + ret = scmi_base_reset_agent_configuration(base_proto, agent_id, flags); + if (ret) { + printf("Reset failed (%d)\n", ret); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; +} + +static struct cmd_tbl cmd_scmi_sub[] = { + U_BOOT_CMD_MKENT(info, CONFIG_SYS_MAXARGS, 1, + do_scmi_info, "", ""), + U_BOOT_CMD_MKENT(perm_dev, CONFIG_SYS_MAXARGS, 1, + do_scmi_set_dev, "", ""), + U_BOOT_CMD_MKENT(perm_proto, CONFIG_SYS_MAXARGS, 1, + do_scmi_set_proto, "", ""), + U_BOOT_CMD_MKENT(reset, CONFIG_SYS_MAXARGS, 1, + do_scmi_reset, "", ""), +}; + +/** + * do_scmi() - SCMI utility + * + * @cmdtp: Command table + * @flag: Command flag + * @argc: Number of arguments + * @argv: Argument array + * + * Provide user interfaces to SCMI protocols. + * + * Return: CMD_RET_SUCCESS on success, + * CMD_RET_USAGE or CMD_RET_RET_FAILURE on failure + */ +static int do_scmi(struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]) +{ + struct cmd_tbl *cp; + + if (argc < 2) + return CMD_RET_USAGE; + + argc--; argv++; + + cp = find_cmd_tbl(argv[0], cmd_scmi_sub, ARRAY_SIZE(cmd_scmi_sub)); + if (!cp) + return CMD_RET_USAGE; + + return cp->cmd(cmdtp, flag, argc, argv); +} + +static char scmi_help_text[] = + " - SCMI utility\n" + " info - get the info of SCMI services\n" + " perm_dev <agent-id in hex> <device-id in hex> <flags in hex>\n" + " - set access permission to device\n" + " perm_proto <agent-id in hex> <device-id in hex> <protocol-id in hex> <flags in hex>\n" + " - set protocol permission to device\n" + " reset <agent-id in hex> <flags in hex>\n" + " - reset platform resource settings\n" + ""; + +U_BOOT_CMD(scmi, CONFIG_SYS_MAXARGS, 0, do_scmi, "SCMI utility", + scmi_help_text);
This is a help text for scmi command.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Etienne Carriere etienne.carriere@foss.st.com --- v6 * add the manual to doc/usage/index.rst v4 * s/tranport/transport/ v2 * add more descriptions about SCMI --- doc/usage/cmd/scmi.rst | 126 +++++++++++++++++++++++++++++++++++++++++ doc/usage/index.rst | 1 + 2 files changed, 127 insertions(+) create mode 100644 doc/usage/cmd/scmi.rst
diff --git a/doc/usage/cmd/scmi.rst b/doc/usage/cmd/scmi.rst new file mode 100644 index 000000000000..9ea7e0e41dad --- /dev/null +++ b/doc/usage/cmd/scmi.rst @@ -0,0 +1,126 @@ +.. SPDX-License-Identifier: GPL-2.0+: + +scmi command +============ + +Synopsis +-------- + +:: + + scmi info + scmi perm_dev <agent id> <device id> <flags> + scmi perm_proto <agent id> <device id> <protocol id> <flags> + scmi reset <agent id> <flags> + +Description +----------- + +Arm System Control and Management Interface (SCMI hereafter) is a set of +standardised interfaces to manage system resources, like clocks, power +domains, pin controls, reset and so on, in a system-wide manner. + +An entity which provides those services is called a SCMI firmware (or +SCMI server if you like) may be placed/implemented by EL3 software or +by a dedicated system control processor (SCP) or else. + +A user of SCMI interfaces, including U-Boot, is called a SCMI agent and +may issues commands, which are defined in each protocol for specific system +resources, to SCMI server via a communication channel, called a transport. +Those interfaces are independent from the server's implementation thanks to +a transport layer. + +For more details, see the `SCMI specification`_. + +While most of system resources managed under SCMI protocols are implemented +and handled as standard U-Boot devices, for example clk_scmi, scmi command +provides additional management functionality against SCMI server. + +scmi info +~~~~~~~~~ + Show base information about SCMI server and supported protocols + +scmi perm_dev +~~~~~~~~~~~~~ + Allow or deny access permission to the device + +scmi perm_proto +~~~~~~~~~~~~~~~ + Allow or deny access to the protocol on the device + +scmi reset +~~~~~~~~~~ + Reset the already-configured permissions against the device + +Parameters are used as follows: + +<agent id> + SCMI Agent ID, hex value + +<device id> + SCMI Device ID, hex value + + Please note that what a device means is not defined + in the specification. + +<protocol id> + SCMI Protocol ID, hex value + + It must not be 0x10 (base protocol) + +<flags> + Flags to control the action, hex value + + 0 to deny, 1 to allow. The other values are reserved and allowed + values may depend on the implemented version of SCMI server in + the future. See SCMI specification for more details. + +Example +------- + +Obtain basic information about SCMI server: + +:: + + => scmi info + SCMI device: scmi + protocol version: 0x20000 + # of agents: 3 + 0: platform + > 1: OSPM + 2: PSCI + # of protocols: 4 + Power domain management + Performance domain management + Clock management + Sensor management + vendor: Linaro + sub vendor: PMWG + impl version: 0x20b0000 + +Ask for access permission to device#0: + +:: + + => scmi perm_dev 1 0 1 + +Reset configurations with all access permission settings retained: + +:: + + => scmi reset 1 0 + +Configuration +------------- + +The scmi command is only available if CONFIG_CMD_SCMI=y. +Default n because this command is mainly for debug purpose. + +Return value +------------ + +The return value ($?) is set to 0 if the operation succeeded, +1 if the operation failed or -1 if the operation failed due to +a syntax error. + +.. _`SCMI specification`: https://developer.arm.com/documentation/den0056/e/?lang=en diff --git a/doc/usage/index.rst b/doc/usage/index.rst index d8e23fcacffb..1a626c03c237 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -94,6 +94,7 @@ Shell commands cmd/rng cmd/saves cmd/sbi + cmd/scmi cmd/scp03 cmd/seama cmd/setexpr
In this test, "scmi" command is tested against different sub-commands. Please note that scmi command is for debug purpose and is not intended in production system.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Etienne Carriere etienne.carriere@foss.st.com --- v9 * return -EAGAIN if we want to skip a test * use CONFIG_IS_ENABLED() rather than IS_ENABLED() v7 * make test assertions more flexible depending on the number of provided protocols v4 * move 'base'-related changes to the prior commit * add CONFIG_CMD_SCMI to sandbox_defconfig v3 * change char to u8 in vendor/agent names v2 * use helper functions, removing direct uses of ops --- configs/sandbox_defconfig | 1 + test/dm/scmi.c | 81 +++++++++++++++++++++++++++++++++++++++ 2 files changed, 82 insertions(+)
diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index bc5bcb2a6237..c550af93b0ca 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -121,6 +121,7 @@ CONFIG_CMD_REGULATOR=y CONFIG_CMD_AES=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y +CONFIG_CMD_SCMI=y CONFIG_CMD_BTRFS=y CONFIG_CMD_CBFS=y CONFIG_CMD_CRAMFS=y diff --git a/test/dm/scmi.c b/test/dm/scmi.c index 582485471fff..e80667ef72a3 100644 --- a/test/dm/scmi.c +++ b/test/dm/scmi.c @@ -19,6 +19,7 @@ #include <scmi_agent.h> #include <scmi_agent-uclass.h> #include <scmi_protocols.h> +#include <vsprintf.h> #include <asm/scmi_test.h> #include <dm/device-internal.h> #include <dm/test.h> @@ -206,6 +207,86 @@ static int dm_test_scmi_base(struct unit_test_state *uts)
DM_TEST(dm_test_scmi_base, UT_TESTF_SCAN_FDT);
+static int dm_test_scmi_cmd(struct unit_test_state *uts) +{ + struct udevice *agent_dev; + int num_proto = 0; + char cmd_out[30]; + + if (!CONFIG_IS_ENABLED(CMD_SCMI)) + return -EAGAIN; + + /* preparation */ + ut_assertok(uclass_get_device_by_name(UCLASS_SCMI_AGENT, "scmi", + &agent_dev)); + ut_assertnonnull(agent_dev); + + /* + * Estimate the number of provided protocols. + * This estimation is correct as far as a corresponding + * protocol support is added to sandbox fake serer. + */ + if (CONFIG_IS_ENABLED(POWER_DOMAIN)) + num_proto++; + if (CONFIG_IS_ENABLED(CLK_SCMI)) + num_proto++; + if (CONFIG_IS_ENABLED(RESET_SCMI)) + num_proto++; + if (CONFIG_IS_ENABLED(DM_REGULATOR_SCMI)) + num_proto++; + + /* scmi info */ + ut_assertok(run_command("scmi info", 0)); + + ut_assert_nextline("SCMI device: scmi"); + snprintf(cmd_out, 30, " protocol version: 0x%x", + SCMI_BASE_PROTOCOL_VERSION); + ut_assert_nextline(cmd_out); + ut_assert_nextline(" # of agents: 2"); + ut_assert_nextline(" 0: platform"); + ut_assert_nextline(" > 1: OSPM"); + snprintf(cmd_out, 30, " # of protocols: %d", num_proto); + ut_assert_nextline(cmd_out); + if (CONFIG_IS_ENABLED(SCMI_POWER_DOMAIN)) + ut_assert_nextline(" Power domain management"); + if (CONFIG_IS_ENABLED(CLK_SCMI)) + ut_assert_nextline(" Clock management"); + if (CONFIG_IS_ENABLED(RESET_SCMI)) + ut_assert_nextline(" Reset domain management"); + if (CONFIG_IS_ENABLED(DM_REGULATOR_SCMI)) + ut_assert_nextline(" Voltage domain management"); + ut_assert_nextline(" vendor: U-Boot"); + ut_assert_nextline(" sub vendor: Sandbox"); + ut_assert_nextline(" impl version: 0x1"); + + ut_assert_console_end(); + + /* scmi perm_dev */ + ut_assertok(run_command("scmi perm_dev 1 0 1", 0)); + ut_assert_console_end(); + + ut_assert(run_command("scmi perm_dev 1 0 0", 0)); + ut_assert_nextline("Denying access to device:0 failed (-13)"); + ut_assert_console_end(); + + /* scmi perm_proto */ + ut_assertok(run_command("scmi perm_proto 1 0 14 1", 0)); + ut_assert_console_end(); + + ut_assert(run_command("scmi perm_proto 1 0 14 0", 0)); + ut_assert_nextline("Denying access to protocol:0x14 on device:0 failed (-13)"); + ut_assert_console_end(); + + /* scmi reset */ + ut_assert(run_command("scmi reset 1 1", 0)); + ut_assert_nextline("Reset failed (-13)"); + ut_assert_console_end(); + + return 0; +} + +DM_TEST(dm_test_scmi_cmd, UT_TESTF_SCAN_FDT); + static int dm_test_scmi_power_domains(struct unit_test_state *uts) { struct sandbox_scmi_agent *agent;
AKASHI Takahiro
