[U-Boot] [PATCH] fdt: allow bootdelay to be specified via device tree
This can be useful to force bootcmd to execute as soon as U-Boot has started.
My use-case is: An SoC-specific tool pushes U-Boot into RAM, along with an image to be written to device boot flash, with the DT config property "bootcmd" set to contain a command to write that image to flash. In this scenario, we don't want to allow any stale bootdelay value taken from the current flash content to affect how long it takes before the flashing process starts.
Signed-off-by: Stephen Warren swarren@nvidia.com --- common/main.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/common/main.c b/common/main.c index 953ef29..6bfd9f0 100644 --- a/common/main.c +++ b/common/main.c @@ -429,6 +429,11 @@ void main_loop (void) s = getenv ("bootdelay"); bootdelay = s ? (int)simple_strtol(s, NULL, 10) : CONFIG_BOOTDELAY;
+#ifdef CONFIG_OF_CONTROL + bootdelay = fdtdec_get_config_int(gd->fdt_blob, "bootdelay", + bootdelay); +#endif + debug ("### main_loop entered: bootdelay=%d\n\n", bootdelay);
#if defined(CONFIG_MENU_SHOW)
Hi Stephen,
On Tue, May 14, 2013 at 11:02 AM, Stephen Warren swarren@wwwdotorg.org wrote:
Nice idea.
Jerry, does this patch look OK, or do you have comments on it? Thanks.
Hi Stephen,
I'm good with the patch.
Acked-by: Gerald Van Baren vanbaren@cideas.com
Thanks, gvb
On 06/02/2013 06:44 AM, Gerald Van Baren wrote:
Hi Stephen,
Oh, I'm not sure who you're expecting to apply this then; I assume since it was a DT-related feature it'd be applied to your DT tree. Are you expecting Tom Rini to apply it to the main U-Boot repo?
Hi Stephen,
Ahh, one of those fuzzy gray areas... the patch is to main.c, I mostly focus on files in the libfdt subdirectory. I can apply it via the FDT repo.
Tom Rini, do you have any preference?
The merge window closed May 11 and the original patch was emailed on May 14... is it a candidate to go into the July 15 release? It is a simple patch arguably fixing a bug, but it did miss the window.
Thanks, gvb
Signed-off-by: Stephen Warren swarren@nvidia.com Acked-by: Simon Glass sjg@chromium.org Acked-by: Gerald Van Baren vanbaren@cideas.com
participants (6)
Gerald Van Baren
Jerry Van Baren
Stephen Warren
Stephen Warren
