[GIT PULL] TI changes for v2020.10-rc4
Hi Tom, Please find the pull request for v2020.10-rc4 containing TI specific changes. This is critical for booting mainline linux K3 devices. Please consider this as critical fix and merge this PR.
Travis CI build: https://travis-ci.org/github/lokeshvutla/u-boot/builds/722678033
The following changes since commit 9f04a634ef331b4fc6b3e677f276156192a413c7:
Merge branch '2020-08-27-misc-fixes' (2020-08-28 08:51:37 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-ti.git tags/ti-v2020.10-rc4
for you to fetch changes up to b892b6d1e0afef8d47f256d5b3ca4687bed1bee3:
ti: common: Remove additional i2c read for board detection (2020-08-31 14:40:28 +0530)
---------------------------------------------------------------- - Update to ABI 3.0 - Fix i2c write in eeprom driver ---------------------------------------------------------------- Lokesh Vutla (3): firmware: ti_sci: drop the device ids to resource id translation table firmware: ti_sci: Drop unused structure ti_sci_rm_type_map arm: dts: k3-am65: Update the RM resource types
Michal Simek (1): ti: common: Remove additional i2c read for board detection
arch/arm/dts/k3-am65-mcu.dtsi | 12 ++++---- board/ti/common/board_detect.c | 18 ++++-------- drivers/firmware/ti_sci.c | 62 ++---------------------------------------- 3 files changed, 15 insertions(+), 77 deletions(-)
Lokesh Vutla
