Simon,
For Tegra186 support, I'd like to introduce a reset subsystem into U-Boot, to support the reset DT bindings[1]. It'd be equivalent to the existing reset subsystem in Linux. This binding/subsystem does/would control reset of e.g. individual HW blocks in an SoC, or individual chips on the board.
It looks like there's already a "reset" uclass (include/reset.h, drivers/misc/reset*.c). However, that seems to address a slightly different case; CPU- or system-level reset rather than individual blocks.
I'd like to propose renaming the existing uclass to sysreset (system reset) to allow the new per-block/-module reset uclass/subsystem just "reset". Does that make sense to you, or should I name the new uclass/subsystem e.g. "module_reset"?
An alternative might be to extend the existing U-Boot reset subsystem to cover the new use-case too. However, U-Boot's existing concepts of warm vs. cold vs. power reset, and reset_walk_halt() don't exist in the reset DT bindings, so my instinct is that combining the two doesn't make sense semantically; I believe the sysreset API is a higher level concept that may use the raw capabilities of the new reset API in some HW-specific implementations.
[1] http://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/Document... (in particular, reset.txt)
Hi Stephen,
On 11 May 2016 at 12:45, Stephen Warren swarren@wwwdotorg.org wrote:
Simon,
Yes that is fine with me. I've been thinking the same thing. 'sysreset' seems like a reasonable name.
Stephen Warren
