[U-Boot] [PATCH] MIPS: Flush data cache upon relocation
This patch now adds a flush to the data cache upon relocation. The current implementation is missing this. Only a comment states that it should be done. So let's really do it now.
Signed-off-by: Stefan Roese sr@denx.de --- cpu/mips/start.S | 28 +++++++++++++++++++++------- 1 files changed, 21 insertions(+), 7 deletions(-)
diff --git a/cpu/mips/start.S b/cpu/mips/start.S index 6a22302..0a69109 100644 --- a/cpu/mips/start.S +++ b/cpu/mips/start.S @@ -307,6 +307,7 @@ relocate_code: la t3, in_ram lw t2, -12(t3) /* t2 <-- uboot_end_data */ move t1, a2 + move s2, a2 /* s2 <-- destination address */
/* * Fix $gp: @@ -316,13 +317,21 @@ relocate_code: move t6, gp sub gp, CONFIG_SYS_MONITOR_BASE add gp, a2 /* gp now adjusted */ - sub t6, gp, t6 /* t6 <-- relocation offset */ + sub s1, gp, t6 /* s1 <-- relocation offset */
/* * t0 = source address * t1 = target address * t2 = source end address */ + + /* + * Save destination address and size for later usage in flush_cache() + */ + move s0, a1 /* save gd in s0 */ + move a0, t1 /* a0 <-- destination addr */ + sub a1, t2, t0 /* a1 <-- size */ + /* On the purple board we copy the code earlier in a special way * in order to solve flash problems */ @@ -338,9 +347,14 @@ relocate_code: /* If caches were enabled, we would have to flush them here. */
+ /* a0 & a1 are already set up for flush_cache(start, size) */ + la t9, flush_cache + jalr t9 + nop + /* Jump to where we've relocated ourselves. */ - addi t0, a2, in_ram - _start + addi t0, s2, in_ram - _start jr t0 nop
@@ -367,7 +381,7 @@ in_ram: 1: lw t1, 0(t4) beqz t1, 2f - add t1, t6 + add t1, s1 sw t1, 0(t4) 2: addi t2, 1 @@ -378,8 +392,8 @@ in_ram: */ lw t1, -12(t0) /* t1 <-- uboot_end_data */ lw t2, -8(t0) /* t2 <-- uboot_end */ - add t1, t6 /* adjust pointers */ - add t2, t6 + add t1, s1 /* adjust pointers */ + add t2, s1
sub t1, 4 1: @@ -387,10 +401,10 @@ in_ram: bltl t1, t2, 1b sw zero, 0(t1) /* delay slot */
- move a0, a1 + move a0, s0 /* a0 <-- gd */ la t9, board_init_r jr t9 - move a1, a2 /* delay slot */ + move a1, s2 /* delay slot */
.end relocate_code
Acked-by: Shinya Kuribayashi skuribay@ruby.dti.ne.jp
I've not tested with a real board, but it'll work. Thanks!
Shinya Kuribayashi
Stefan Roese
