[U-Boot] [RFC] drivers: net: phy: atheros: apply the previous register setting for AR8031 to fix the voltage peak issue
Apply the previous setting for the reserved bits in SetDes Test and System Mode Control register to avoid the voltage peak issue while we do the IEEE PHY comformance test --- drivers/net/phy/atheros.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index b34cdd3d87..82fe228604 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -28,6 +28,8 @@ static int ar8021_config(struct phy_device *phydev)
static int ar8031_config(struct phy_device *phydev) { + int regval; + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID || phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) { phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, @@ -44,6 +46,10 @@ static int ar8031_config(struct phy_device *phydev) AR803x_RGMII_RX_CLK_DLY); }
+ phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, AR803x_DEBUG_REG_5); + regval = phy_read(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG); + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, regval | 0x3C47); + phydev->supported = phydev->drv->features;
genphy_config_aneg(phydev);
Seems reasonable. Was this tested on HW? If so, please add a tested tag.
Thanks, -Joe
int regval;
phydev->supported = phydev->drv->features; genphy_config_aneg(phydev);
-- 2.11.0
2017-02-02 10:01 GMT-08:00 Joe Hershberger joe.hershberger@gmail.com:
Thank you for your feedback. Yes, it's been tested and with signal measurement results on our project platforms. I will submit the patch with a tested tag again.
Thanks, -Joe
int regval;
-- 2.11.0
int regval;
It would also be good if you move this "0x3C47" to a #define and include a comment about what it means.
-- 2.11.0
Tested on Advantech DMS-BA16 board Tested-by: Ken Lin ken.lin@advantech.com Signed-off-by: Ken Lin ken.lin@advantech.com --- drivers/net/phy/atheros.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index b34cdd3d87..87e8fc55d4 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -17,6 +17,8 @@ #define AR803x_DEBUG_REG_0 0x0 #define AR803x_RGMII_RX_CLK_DLY 0x8000
+#define AR803x_SERDES_TEST_DEFAULT 0x3C47 + static int ar8021_config(struct phy_device *phydev) { phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); @@ -28,6 +30,8 @@ static int ar8021_config(struct phy_device *phydev)
static int ar8031_config(struct phy_device *phydev) { + int regval; + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID || phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) { phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, @@ -44,6 +48,10 @@ static int ar8031_config(struct phy_device *phydev) AR803x_RGMII_RX_CLK_DLY); }
+ phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, AR803x_DEBUG_REG_5); + regval = phy_read(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG); + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, regval | AR803x_SERDES_TEST_DEFAULT); + phydev->supported = phydev->drv->features;
Joe Hershberger
ken <Ken Lin>
Ken Lin
Yung-Ching LIN
