[U-Boot] [PATCH v3] davinci: cleanup davinci_sync_env_enetaddr() fucntion
check for the return status for eth_getenv_enetaddr_by_index() and eth_setenv_enetaddr() functions and print appropriate message on failure.
Signed-off-by: Manjunath Hadli manjunath.hadli@ti.com Cc: Tom Rini trini@ti.com Cc: Mike Frysinger vapier@gentoo.org Cc: Wolfgang Denk wd@denx.de --- Changes for v3: undo conversion of debug statement to printf().
Changes for v2: Removed additional check of comparing ethernet address is all zeros, As the core code already calls is_valid_ether_addr() and one of the checks in there is for all zeros.
arch/arm/cpu/arm926ejs/davinci/misc.c | 9 ++++++--- 1 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/davinci/misc.c b/arch/arm/cpu/arm926ejs/davinci/misc.c index 5f510b6..c310c69 100644 --- a/arch/arm/cpu/arm926ejs/davinci/misc.c +++ b/arch/arm/cpu/arm926ejs/davinci/misc.c @@ -101,9 +101,10 @@ void davinci_emac_mii_mode_sel(int mode_sel) void davinci_sync_env_enetaddr(uint8_t *rom_enetaddr) { uint8_t env_enetaddr[6]; + int ret;
- eth_getenv_enetaddr_by_index("eth", 0, env_enetaddr); - if (!memcmp(env_enetaddr, "\0\0\0\0\0\0", 6)) { + ret = eth_getenv_enetaddr_by_index("eth", 0, env_enetaddr); + if (ret) { /* * There is no MAC address in the environment, so we * initialize it from the value in the EEPROM. @@ -111,8 +112,10 @@ void davinci_sync_env_enetaddr(uint8_t *rom_enetaddr) debug("### Setting environment from EEPROM MAC address = " ""%pM"\n", env_enetaddr); - eth_setenv_enetaddr("ethaddr", rom_enetaddr); + ret = !eth_setenv_enetaddr("ethaddr", rom_enetaddr); } + if (!ret) + printf("Failed to set mac address from EEPROM\n"); } #endif /* CONFIG_DRIVER_TI_EMAC */
Acked-by: Mike Frysinger vapier@gentoo.org -mike
Manjunath Hadli <manjunath.hadli <at> ti.com> writes:
I am upgrading from v2011.12 (as I have some ubifsmount issues and don't want to debug this on an old ubi) and I saw that setting the MAC address from EEPROM is broken.
- ret = eth_getenv_enetaddr_by_index("eth", 0, env_enetaddr);
- if (ret) {
In case there is no mac address in the environment the net/eth.c code will set env_enetaddr to all 0. This means that is_valid_ether_addr inside eth_getenv_enetaddr will return 0 (as of not valid). That also means that the below function will not be called.
I assume the right fix is to change the condition to !ret.
}ret = !eth_setenv_enetaddr("ethaddr", rom_enetaddr);
- if (!ret)
adding %d for 'ret' would be nice.
Holger Freyther
Manjunath Hadli
Mike Frysinger
