Re: [U-Boot] [PATCH v2]net: null check after pointer dereference
Author: Vishwas Srivastava vishu.kernel@gmail.com Date: Tue Jan 26 12:46:42 2016 +0530
NULL check is made after the pointer dereference in davinci-emac driver. This patch fixes this issue.
Signed-off-by: Vishwas Srivastava vishu.kernel@gmail.com CC: Joe Hershberger joe.hershberger@ni.com Reviewed-by: Tom Rini trini@konsulko.com
Changes for v2: -cleaned up the style format -addressed various comments given by Joe joe.hershberger@ni.com on the first version of the patch.
diff --git a/drivers/net/davinci_emac.c b/drivers/net/davinci_emac.c index 3f54a3f..a61374d 100644 --- a/drivers/net/davinci_emac.c +++ b/drivers/net/davinci_emac.c @@ -692,8 +692,10 @@ static int davinci_eth_rcv_packet (struct eth_device *dev) davinci_invalidate_rx_descs();
rx_curr_desc = emac_rx_active_head; + if (!rx_curr_desc) + return 0; status = rx_curr_desc->pkt_flag_len; - if ((rx_curr_desc) && ((status & EMAC_CPPI_OWNERSHIP_BIT) == 0)) { + if ((status & EMAC_CPPI_OWNERSHIP_BIT) == 0) { if (status & EMAC_CPPI_RX_ERROR_FRAME) { /* Error in packet - discard it and requeue desc */ printf ("WARN: emac_rcv_pkt: Error in packet\n");
On Thu, Jan 28, 2016 at 1:35 AM, Joe Hershberger joe.hershberger@gmail.com wrote:
On Tue, Jan 26, 2016 at 1:26 AM, Vishwas Srivastava vishu.kernel@gmail.com wrote:
Please fix the subject of this patch. No space in the "net :".
All of your commit logs should not have spaces in them (at the start of lines).
NULL check is made after the pointer dereference is davinci- emac driver. This patch fixes this issue. CC: Sergey Kubushyn <ksi@koi8.net>;Joe Hershberger <
joe.hershberger@ni.com>
Fix this format. One "Cc:" per line.
Signed-off-by: Vishwas Srivastava <vishu.kernel@gmail.com>
This belongs first... before the Cc:
diff --git a/drivers/net/davinci_emac.c b/drivers/net/davinci_emac.c index 3f54a3f..1966eb9 100644 --- a/drivers/net/davinci_emac.c +++ b/drivers/net/davinci_emac.c @@ -692,8 +692,10 @@ static int davinci_eth_rcv_packet (struct eth_device *dev) davinci_invalidate_rx_descs();
You need to run your patches through scripts/checkpatch.pl.
if (!rx_curr_desc)
Consider using tools/patman.
Thanks, -Joe
NULL check is made after the pointer dereference. This patch fixes this issue.
Signed-off-by: Vishwas Srivastava vishu.kernel@gmail.com CC: Joe Hershberger joe.hershberger@ni.com Reviewed-by: Tom Rini trini@konsulko.com Acked-by: Joe Hershberger joe.hershberger@ni.com Signed-off-by: Anatolij Gustschin agust@denx.de --- Changes in v3: - slightly edit subject and commit message - format patch properly
drivers/net/davinci_emac.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/net/davinci_emac.c b/drivers/net/davinci_emac.c index 6f2dc8d..b030498 100644 --- a/drivers/net/davinci_emac.c +++ b/drivers/net/davinci_emac.c @@ -692,8 +692,10 @@ static int davinci_eth_rcv_packet (struct eth_device *dev) davinci_invalidate_rx_descs();
Changes in v3:
Applied to u-boot-staging, thanks!
-- Anatolij
Anatolij Gustschin
Vishwas Srivastava
