[PATCH v4] imx: imx8qm: cgtqmx8: switch to binman
Switch to use binman to pack images
Signed-off-by: Oliver Graute oliver.graute@kococonnector.com Reviewed-by: Fabio Estevam festevam@denx.de Reviewed-by: Simon Glass sjg@chromium.org
--- Changes for v4 - rebased on master
Changes for v3 -added Reviewed-by - rebased on master
arch/arm/dts/imx8qm-cgtqmx8.dts | 1 + arch/arm/mach-imx/imx8/Kconfig | 1 + board/congatec/cgtqmx8/imximage.cfg | 4 ++-- configs/cgtqmx8_defconfig | 2 +- doc/board/congatec/cgtqmx8.rst | 3 +-- 5 files changed, 6 insertions(+), 5 deletions(-)
diff --git a/arch/arm/dts/imx8qm-cgtqmx8.dts b/arch/arm/dts/imx8qm-cgtqmx8.dts index 555c357f6f..919d00644f 100644 --- a/arch/arm/dts/imx8qm-cgtqmx8.dts +++ b/arch/arm/dts/imx8qm-cgtqmx8.dts @@ -12,6 +12,7 @@ /memreserve/ 0x80000000 0x00020000;
#include "fsl-imx8qm.dtsi" +#include "imx8qm-u-boot.dtsi"
/ { model = "Congatec QMX8 Qseven series"; diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index ba2a38c7f7..a0036a32b5 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -76,6 +76,7 @@ config TARGET_IMX8QM_MEK
config TARGET_CONGA_QMX8 bool "Support congatec conga-QMX8 board" + select BINMAN select BOARD_LATE_INIT select SUPPORT_SPL select IMX8QM diff --git a/board/congatec/cgtqmx8/imximage.cfg b/board/congatec/cgtqmx8/imximage.cfg index 5ecde0c530..43035088e3 100644 --- a/board/congatec/cgtqmx8/imximage.cfg +++ b/board/congatec/cgtqmx8/imximage.cfg @@ -4,8 +4,8 @@ */
-/* Boot from SD, sector size 0x400 */ -BOOT_FROM SD 0x400 +BOOT_FROM sd + /* SoC type IMX8QM */ SOC_TYPE IMX8QM /* Append seco container image */ diff --git a/configs/cgtqmx8_defconfig b/configs/cgtqmx8_defconfig index ddc65a06b9..6b72afa80d 100644 --- a/configs/cgtqmx8_defconfig +++ b/configs/cgtqmx8_defconfig @@ -21,7 +21,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80200000 CONFIG_REMAKE_ELF=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTCOMMAND=y diff --git a/doc/board/congatec/cgtqmx8.rst b/doc/board/congatec/cgtqmx8.rst index bccdef2f16..16711a844d 100644 --- a/doc/board/congatec/cgtqmx8.rst +++ b/doc/board/congatec/cgtqmx8.rst @@ -57,8 +57,7 @@ Build U-Boot $ export ATF_LOAD_ADDR=0x80000000 $ export BL33_LOAD_ADDR=0x80020000 $ make cgtqmx8_defconfig - $ make u-boot.bin - $ make flash.bin + $ make
Flash the binary into the SD card ---------------------------------
Reviewed-by: Peng Fan peng.fan@nxp.com
Changes for v4
- rebased on master
- rebased on master
- select BINMAN select BOARD_LATE_INIT select SUPPORT_SPL select IMX8QM
- /* SoC type IMX8QM */ SOC_TYPE IMX8QM /* Append seco container image */
$ make u-boot.bin
$ make flash.bin
$ make
Oliver Graute
Peng Fan
