[U-Boot] [PATCH] travis.yml: some adaptions
- adapt to build with eldk-5.4 - add more targets for building with buildman: - freescale -x arm,m68k,aarch64 - arm1136 - arm1176 - arm720t - arm920t - davinci - kirkwood
Signed-off-by: Heiko Schocher hs@denx.de
--- ti and kirkwood boards show errors, this should be fixed from the board maintainers, see build here: https://travis-ci.org/hsdenx/u-boot/builds/53150150
ti boards: see: https://travis-ci.org/hsdenx/u-boot/jobs/53150166#L466
Building current source for 30 boards (30 threads, 2 jobs per thread) arm: + am335x_evm_usbspl +(am335x_evm_usbspl) armv5te-ld.bfd: u-boot-spl section `.rodata' will not fit in region `.sram' +(am335x_evm_usbspl) armv5te-ld.bfd: region `.sram' overflowed by 6972 bytes +(am335x_evm_usbspl) make[2]: *** [spl/u-boot-spl] Error 1 +(am335x_evm_usbspl) make[1]: *** [spl/u-boot-spl] Error 2 +(am335x_evm_usbspl) make: *** [sub-make] Error 2 29 0 1 /30 am335x_evm_nor
The command "${TEST_CMD}" exited with 128.
kirkwood boards: see: https://travis-ci.org/hsdenx/u-boot/jobs/53150172#L466
Building current source for 35 boards (32 threads, 1 job per thread) arm: + openrd_base +(openrd_base) u-boot.bin exceeds file size limit: +(openrd_base) limit: 393216 bytes +(openrd_base) actual: 411124 bytes +(openrd_base) excess: 17908 bytes +(openrd_base) make[1]: *** [u-boot.bin] Error 1 +(openrd_base) make: *** [sub-make] Error 2 arm: + openrd_client +(openrd_client) u-boot.bin exceeds file size limit: +(openrd_client) limit: 393216 bytes +(openrd_client) actual: 411200 bytes +(openrd_client) excess: 17984 bytes +(openrd_client) make[1]: *** [u-boot.bin] Error 1 +(openrd_client) make: *** [sub-make] Error 2 arm: + openrd_ultimate +(openrd_ultimate) u-boot.bin exceeds file size limit: +(openrd_ultimate) limit: 393216 bytes +(openrd_ultimate) actual: 411176 bytes +(openrd_ultimate) excess: 17960 bytes +(openrd_ultimate) make[1]: *** [u-boot.bin] Error 1 +(openrd_ultimate) make: *** [sub-make] Error 2 32 0 3 /35 sheevaplug The command "${TEST_CMD}" exited with 128.
.travis.yml | 115 ++++++++++++++++++++++++++++++++++++++++++++++-------------- 1 file changed, 89 insertions(+), 26 deletions(-)
diff --git a/.travis.yml b/.travis.yml index 923c9dd..1d5c18a 100644 --- a/.travis.yml +++ b/.travis.yml @@ -10,7 +10,7 @@ cache:
install: # install U-Boot build dependencies - - sudo apt-get install -qq cppcheck sloccount sparse bc libsdl-dev gcc-arm-linux-gnueabi gcc-arm-linux-gnueabihf + - sudo apt-get install -qq cppcheck sloccount sparse bc libsdl-dev build-essential # install latest device tree compiler - git clone --depth=1 https://git.kernel.org/pub/scm/utils/dtc/dtc.git /tmp/dtc - make -j4 -C /tmp/dtc @@ -18,11 +18,17 @@ install: - export BUILDMAN_ROOT="root:" - export BUILDMAN_MIPS="mips:" - export BUILDMAN_PPC="ppc:" - - echo -e "[toolchain]\n${BUILDMAN_ROOT} /\n" > ~/.buildman - - echo -e "${BUILDMAN_MIPS} /opt/eldk-5.4/mips/sysroots/i686-eldk-linux/usr/bin/mips32-linux/" >> ~/.buildman - - echo -e "${BUILDMAN_PPC} /opt/eldk-5.4/powerpc/sysroots/i686-eldk-linux/usr/bin/powerpc-linux/" >> ~/.buildman + - export BUILDMAN_ARM="arm:" + - export BUILDMAN_SANDBOX="sandbox:" + - echo -e "[toolchain]\n${BUILDMAN_ROOT} /\n" > ~/.buildman + - echo -e "${BUILDMAN_MIPS} /opt/eldk-5.4/mips/sysroots/i686-eldk-linux/usr/bin/mips32-linux/\n" >> ~/.buildman + - echo -e "${BUILDMAN_PPC} /opt/eldk-5.4/powerpc/sysroots/i686-eldk-linux/usr/bin/powerpc-linux/\n" >> ~/.buildman + - echo -e "${BUILDMAN_ARM} /opt/eldk-5.4/armv5te/sysroots/i686-eldk-linux/usr/bin/armv5te-linux-gnueabi/\n" >> ~/.buildman + - echo -e "${BUILDMAN_SANDBOX} /usr/bin/gcc\n" >> ~/.buildman - export BUILDMAN_ALIAS="x86:" - - echo -e "[toolchain-alias]\n${BUILDMAN_ALIAS} i386" >> ~/.buildman + - export BUILDMAN_ALIAS_ARM="arm:" + - echo -e "\n\n[toolchain-alias]\n${BUILDMAN_ALIAS} i386\n" >> ~/.buildman + - echo -e "${BUILDMAN_ALIAS_ARM} armv5te\n" >> ~/.buildman - cat ~/.buildman
env: @@ -40,6 +46,10 @@ before_script: - if [[ "${INSTALL_TOOLCHAIN}" == *ppc* ]]; then sh eldk-eglibc-i686-powerpc-toolchain-gmae-5.4.sh -y ; fi - if [[ "${INSTALL_TOOLCHAIN}" == *mips* ]]; then wget ftp://ftp.denx.de/pub/eldk/5.4/targets/mips/eldk-eglibc-i686-mips-toolchain-gmae-5.4.sh ; fi - if [[ "${INSTALL_TOOLCHAIN}" == *mips* ]]; then sh eldk-eglibc-i686-mips-toolchain-gmae-5.4.sh -y ; fi + - if [[ "${INSTALL_TOOLCHAIN}" == *arm* ]]; then wget ftp://ftp.denx.de/pub/eldk/5.4/targets/armv5te/eldk-eglibc-i686-arm-toolchain-gmae-5.4.sh ; fi + - if [[ "${INSTALL_TOOLCHAIN}" == *arm* ]]; then sh eldk-eglibc-i686-arm-toolchain-gmae-5.4.sh -y ; fi + - if [[ "${INSTALL_TOOLCHAIN}" == *arm* ]]; then ls -al /opt/eldk-5.4/armv5te/sysroots/i686-eldk-linux/usr/bin/armv5te-linux-gnueabi ; fi + - if [[ "${INSTALL_TOOLCHAIN}" == *i386* ]]; then ./tools/buildman/buildman sandbox --fetch-arch i386 ; fi
script: # the execution sequence for each test @@ -54,19 +64,24 @@ matrix: # each env setting here is a dedicated build - env: - TEST_CMD="./MAKEALL -a arm -v atmel" - CROSS_COMPILE="arm-linux-gnueabi-" + INSTALL_TOOLCHAIN="arm" + CROSS_COMPILE="/opt/eldk-5.4/armv5te/sysroots/i686-eldk-linux/usr/bin/armv5te-linux-gnueabi/arm-linux-gnueabi-" - env: - TEST_CMD="./MAKEALL -a arm -v denx" - CROSS_COMPILE="arm-linux-gnueabi-" + INSTALL_TOOLCHAIN="arm" + CROSS_COMPILE="/opt/eldk-5.4/armv5te/sysroots/i686-eldk-linux/usr/bin/armv5te-linux-gnueabi/arm-linux-gnueabi-" - env: - TEST_CMD="./MAKEALL -a arm -v freescale" - CROSS_COMPILE="arm-linux-gnueabi-" + INSTALL_TOOLCHAIN="arm" + CROSS_COMPILE="/opt/eldk-5.4/armv5te/sysroots/i686-eldk-linux/usr/bin/armv5te-linux-gnueabi/arm-linux-gnueabi-" - env: - TEST_CMD="./MAKEALL -a arm -v siemens" - CROSS_COMPILE="arm-linux-gnueabi-" + INSTALL_TOOLCHAIN="arm" + CROSS_COMPILE="/opt/eldk-5.4/armv5te/sysroots/i686-eldk-linux/usr/bin/armv5te-linux-gnueabi/arm-linux-gnueabi-" - env: - TEST_CMD="./MAKEALL -a arm -v ti" - CROSS_COMPILE="arm-linux-gnueabi-" + INSTALL_TOOLCHAIN="arm" + CROSS_COMPILE="/opt/eldk-5.4/armv5te/sysroots/i686-eldk-linux/usr/bin/armv5te-linux-gnueabi/arm-linux-gnueabi-" - env: - TEST_CONFIG_CMD="make sandbox_defconfig" TEST_CMD="make -j4" @@ -82,45 +97,93 @@ matrix: INSTALL_TOOLCHAIN="mips" CROSS_COMPILE="/opt/eldk-5.4/mips/sysroots/i686-eldk-linux/usr/bin/mips32-linux/mips-linux-" - env: - - TEST_CMD="tools/buildman/buildman --list-error-boards atmel" + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman --list-error-boards atmel -x avr32" + INSTALL_TOOLCHAIN="arm" - env: - - TEST_CMD="tools/buildman/buildman --list-error-boards denx" + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman --list-error-boards denx" + INSTALL_TOOLCHAIN="arm" - env: - - TEST_CMD="tools/buildman/buildman --list-error-boards freescale arm" + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman --list-error-boards freescale -x powerpc,m68k,aarch64" + INSTALL_TOOLCHAIN="arm" - env: - - TEST_CMD="tools/buildman/buildman --list-error-boards siemens" + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman --list-error-boards freescale -x arm,m68k,aarch64" + INSTALL_TOOLCHAIN="ppc" + - env: + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman --list-error-boards siemens" + INSTALL_TOOLCHAIN="arm" + - env: + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman --list-error-boards ti" + INSTALL_TOOLCHAIN="arm" + - env: + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman --list-error-boards arm1136" + INSTALL_TOOLCHAIN="arm" + - env: + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman --list-error-boards arm1176" + INSTALL_TOOLCHAIN="arm" - env: - - TEST_CMD="tools/buildman/buildman --list-error-boards ti" + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman --list-error-boards arm720t" + INSTALL_TOOLCHAIN="arm" - env: - - TEST_CMD="tools/buildman/buildman mips" + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman --list-error-boards arm920t" + INSTALL_TOOLCHAIN="arm" + - env: + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman --list-error-boards davinci" + INSTALL_TOOLCHAIN="arm" + - env: + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman --list-error-boards kirkwood" + INSTALL_TOOLCHAIN="arm" + - env: + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman mips" INSTALL_TOOLCHAIN="mips" - env: - - TEST_CMD="tools/buildman/buildman mpc5xx" + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman mpc5xx" INSTALL_TOOLCHAIN="ppc" - env: - - TEST_CMD="tools/buildman/buildman mpc8xx" + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman mpc8xx" INSTALL_TOOLCHAIN="ppc" - env: - - TEST_CMD="tools/buildman/buildman mpc5xxx" + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman mpc5xxx" INSTALL_TOOLCHAIN="ppc" - env: - - TEST_CMD="tools/buildman/buildman mpc512x" + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman mpc512x" INSTALL_TOOLCHAIN="ppc" - env: - - TEST_CMD="tools/buildman/buildman mpc8260" + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman mpc8260" INSTALL_TOOLCHAIN="ppc" - env: - - TEST_CMD="tools/buildman/buildman mpc83xx" + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman mpc83xx" INSTALL_TOOLCHAIN="ppc" - env: - - TEST_CMD="tools/buildman/buildman mpc85xx" + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman mpc85xx" INSTALL_TOOLCHAIN="ppc" - env: - - TEST_CMD="tools/buildman/buildman mpc86xx" + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman mpc86xx" INSTALL_TOOLCHAIN="ppc" - - env: - - TEST_CMD="tools/buildman/buildman --list-error-boards sandbox x86" + - TEST_CONFIG_CMD="tools/buildman/buildman --list-tool-chains" + TEST_CMD="tools/buildman/buildman --list-error-boards sandbox x86" + INSTALL_TOOLCHAIN="i386"
# QA jobs for code analytics # static code analysis with cppcheck (we can add --enable=all later)
Thanks Heiko!
This is a great step towards *build everything* on public servers.
-----Original Message----- From: Heiko Schocher [mailto:hs@denx.de] Sent: Donnerstag, 5. März 2015 09:02 To: u-boot@lists.denx.de Cc: Heiko Schocher; Prafulla Wadaskar; Tom Rini; Meier, Roger; Luka Perkov Subject: [PATCH] travis.yml: some adaptions
- arm1136
- arm1176
- arm720t
- arm920t
- davinci
- kirkwood
Reviewed-by: Roger Meier r.meier@siemens.com
regards -roger
On Thu, Mar 05, 2015 at 11:02:05AM +0000, Meier, Roger wrote:
Thanks Heiko!
On that note, I'm using eldk-5.5.3 for ARM, the kernel.org toolchains for avr32, m68k and sh4, eldk-5.6 for powerpc/mips and a Linaro toolchain for aarch64 for my testing.
Hello Tom,
Am 05.03.2015 15:43, schrieb Tom Rini:
Thanks Heiko!
I just prepare a patch for adding arc, avr32, m68k and sh4 to the build on travis.
bye, Heiko
- arm1136
- arm1176
- arm720t
- arm920t
- davinci
- kirkwood
Signed-off-by: Heiko Schocher hs@denx.de Reviewed-by: Roger Meier r.meier@siemens.com
Heiko Schocher
Meier, Roger
