[U-Boot-Users] Open Firmware support questions
Hi All,
I've been working with the u-boot OF support and have some questions, but don't know who to ask.
It appears that Pantelis Antoniou submitted the original ft_build.[ch] code http://patchwork.ozlabs.org/linuxppc/patch?id=2238 but there is no copyright or license information in the files. Are these files his or did they come from somewhere else?
My current state of affairs (not quite ready for prime time) is in: http://www.cideas.us/cgi-bin/gitweb.cgi?p=u-boot/u-boot-pq2fads.git;a=summar...
Things I'm working on: * Added a "of" command to dump the blob * Works well enough but is not in its final form * Required a change to vsprintf to parse a "ll" (long long) attribute as well as the existing "q" attribute for 64 bit entries. * Printing a 64 bit entry (example: interrupt "reg" value has two 32 bit entries) doesn't work properly. Example print: interrupt-controller@f8200000 { linux,phandle = <0xf8200000>; #address-cells = <0x00000000>; #interrupt-cells = <0x00000002>; interrupt-controller; reg = <0x00000000f8200004>; built-in; device_type = "pci-pic"; }; The reg value <0x00000000f8200004> should print <0xf8200000f8200004> or, better(?), <0xf8200000 f8200004> The "better" format listed above is how it appears in the *.dts tree definition, but the ft_dump.c routine doesn't appear to do that format. It sees the size value of 8 and prints it as a single long long rather than two longs (should be just a formatting issue, but currently the print is broken). Note that the tree itself appears to be OK, looking at the ASM output file.
* Looking at improving(?) the build mechanism * Use the "asm" output format rather than a binary dump and then regeneration via xxd. * My thought (unimplemented as of yet) is to append "_of" to the configuration so "PQ2FADS-ZU_lowboot_config" would become "PQ2FADS-ZU_lowboot_config_of" for the OF version. The configuration mechanism would then add the definition FTOBJS := pq2fads.o to the "include/config.mk" file. * Questions: * Is the "_of" tag reasonable or is there a better way? I'm assuming we don't want to force everybody with an ADS-type board over to using OF. * Where should we put the original *.dts files? I picked up the original mpc8260ads.dts file from the kernel source, Vitaly Bordug's repository: linux-2.6-PQ/arch/powerpc/boot/dts/mpc8272ads.dts
I forgot what the agreement ended up being for ownership between the kernel people and Wolfgang (if there was any agreement ;-). gvb
On Mon, 2006-10-09 at 08:36, Jerry Van Baren wrote:
Hi All,
Hi Jerry,
Well, several of us (Matt, myself, Mark Greer, Vitaly, etc) might be able to help some.
Yes.
He wrote them and made them freely available.
Cool.
- Added a "of" command to dump the blob
- Works well enough but is not in its final form
- Required a change to vsprintf to parse a "ll" (long long) attribute as well as the existing "q" attribute for 64 bit entries.
Changes like that were submitted to the list here last January by myself, and then by Matt McClintock around May, (IIRC), and can currently be found in various trees supporting OF concepts such as his tree on opensource.freescale.com and mine on jdl.com, called u-boot-86xx. (It also has 85xx bits in it too.)
- Printing a 64 bit entry (example: interrupt "reg" value has two 32 bit entries) doesn't work properly. Example print: interrupt-controller@f8200000 { linux,phandle = <0xf8200000>; #address-cells = <0x00000000>; #interrupt-cells = <0x00000002>; interrupt-controller; reg = <0x00000000f8200004>; built-in; device_type = "pci-pic"; }; The reg value <0x00000000f8200004> should print <0xf8200000f8200004> or, better(?), <0xf8200000 f8200004> The "better" format listed above is how it appears in the *.dts tree definition, but the ft_dump.c routine doesn't appear to do that format. It sees the size value of 8 and prints it as a single long long rather than two longs (should be just a formatting issue, but currently the print is broken). Note that the tree itself appears to be OK, looking at the ASM output file.
You might compare your support here with what Matt and I have made available too.
- Looking at improving(?) the build mechanism
- Use the "asm" output format rather than a binary dump and then regeneration via xxd.
We've removed the binary parts out of U-Boot entirely. It now downloads the .dtb files directly.
- My thought (unimplemented as of yet) is to append "_of" to the configuration so "PQ2FADS-ZU_lowboot_config" would become "PQ2FADS-ZU_lowboot_config_of" for the OF version. The configuration mechanism would then add the definition FTOBJS := pq2fads.o to the "include/config.mk" file.
- Questions:
- Is the "_of" tag reasonable or is there a better way? I'm assuming we don't want to force everybody with an ADS-type board over to using OF.
- Where should we put the original *.dts files? I picked up the original mpc8260ads.dts file from the kernel source, Vitaly Bordug's repository: linux-2.6-PQ/arch/powerpc/boot/dts/mpc8272ads.dts
If Vitaly isn't coordinating with us, we'll need to smack him around some. :-)
gvb
Well, if you managed to coordinate your patches with the work Matt, Vitaly and I have been doing, it would be much appreciated!
Thanks, jdl
Hi All,
Hi Jerry,
Yes.
OK, but even if they are in the public domain, that still needs to be declared because (in the USofA at least) stuff is copyright by default. With no disclaimers the files are assumed to be copyright with no licensing for us to use them. IANAL, your lawyer may disagree :-)
[snip]
Thanks, jdl
Absolutely! Thanks for the hints of where to look for existing work.
Best regards, gvb
Jerry Van Baren
Jon Loeliger
