[PATCH v5 0/7] Add EFI HTTP boot support
This series adds the EFI HTTP boot support. User can add the URI device path with "efidebug boot add" command. efibootmgr handles the URI device path, download the specified file using wget, mount the downloaded image with blkmap, then boot with the default file(e.g. EFI/BOOT/BOOTAA64.EFI).
This version still does not include the test.
To enable EFI HTTP boot, we need to enable the following Kconfig options. CONFIG_CMD_DNS CONFIG_CMD_WGET CONFIG_BLKMAP
On the Socionext Developerbox, enter the following commands then debian installer is downloaded into "loadaddr" and installer automatically starts. => dhcp => setenv serverip 192.168.1.1 => efidebug boot add -u 3 debian-netinst http://ftp.riken.jp/Linux/debian/debian-cd/12.1.0/arm64/iso-cd/debian-12.1.0... => efidebug boot order 3 => bootefi bootmgr
Note that this debian installer can not proceed the installation bacause RAM disk of installer image is not recogniged by the kernel. I'm still investigating this issue, but drivers/nvdimm/of_pmem.c in linux will be one of the solution to recognize RAM disk from kernel. (In EDK2, the equivalent solution is called ACPI NFIT.)
On QEMU, I can not make DNS work from the QEMU guest. The following commands work on qemu_arm64(manually set the http server ip in URI). => dhcp => setenv gatewayip 10.0.2.2 => setenv httpserverip 134.160.38.1 => efidebug boot add -u 3 debian-netinst http://134.160.38.1/Linux/debian/debian-cd/12.1.0/arm64/iso-cd/debian-12.1.0... => efidebug boot order 3 => bootefi bootmgr
[TODO] - add test - stricter wget uri check - omit the dns process if the given uri has ip address -> this will be supported when the lwip migration completes - uri device path support in eficonfig
[change log] v4 -> v5 - add missing else statement - add NULL check of efi_dp_find_obj() call - update document to remove "limitation"
v3 -> v4 - patch#8 is added to simplify the bootmgr default boot process - add function comments
v2 -> v3 - Patch#6 is added, reserve the whole ramdisk memory region - remove .efi file extension check for PE-COFF image - use "if IS_ENABLED(..)" as much as possible - 1024 should be sizeof(net_boot_file_name) - call net_set_state(NETLOOP_FAIL) when wget encounters error - describe DNS ip address host name limitation in document
v1 -> v2 - carve out the network handling(wget and dns code) under net/wget.c - carve out ramdisk creation code under drivers/block/blkmap_helper.c - wget supports the valid range check to store the received blocks using lmb - support when the downloaded image have no partiton table but a file system - not start the .efi file in try_load_entry() - call efi_check_pe() for .efi file to check the file is PE-COFF image - add documentation for EFI HTTP Boot
Masahisa Kojima (7): net: wget: prevent overwriting reserved memory net: wget: add wget with dns utility function blk: blkmap: add ramdisk creation utility function efi_loader: support boot from URI device path cmd: efidebug: add uri device path doc: uefi: add HTTP Boot support efi_loader: create BlockIo device boot option
cmd/efidebug.c | 50 +++++++ doc/develop/uefi/uefi.rst | 30 ++++ drivers/block/Makefile | 1 + drivers/block/blkmap.c | 15 -- drivers/block/blkmap_helper.c | 53 +++++++ include/blkmap.h | 29 ++++ include/efi_loader.h | 3 + include/net.h | 17 +++ lib/efi_loader/efi_bootmgr.c | 248 ++++++++++++++++++++++++++++--- lib/efi_loader/efi_device_path.c | 20 +++ lib/efi_loader/efi_dt_fixup.c | 2 +- net/wget.c | 206 ++++++++++++++++++++++++- 12 files changed, 634 insertions(+), 40 deletions(-) create mode 100644 drivers/block/blkmap_helper.c
This introduces the valid range check to store the received blocks using lmb. The same logic is implemented in tftp.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- net/wget.c | 80 +++++++++++++++++++++++++++++++++++++++++++++++++----- 1 file changed, 73 insertions(+), 7 deletions(-)
diff --git a/net/wget.c b/net/wget.c index 2dbfeb1a1d..a48a8cb624 100644 --- a/net/wget.c +++ b/net/wget.c @@ -4,16 +4,20 @@ * Copyright Duncan Hare dh@synoia.com 2017 */
+#include <asm/global_data.h> #include <command.h> #include <common.h> #include <display_options.h> #include <env.h> #include <image.h> +#include <lmb.h> #include <mapmem.h> #include <net.h> #include <net/tcp.h> #include <net/wget.h>
+DECLARE_GLOBAL_DATA_PTR; + static const char bootfile1[] = "GET "; static const char bootfile3[] = " HTTP/1.0\r\n\r\n"; static const char http_eom[] = "\r\n\r\n"; @@ -55,6 +59,29 @@ static unsigned int retry_tcp_ack_num; /* TCP retry acknowledge number*/ static unsigned int retry_tcp_seq_num; /* TCP retry sequence number */ static int retry_len; /* TCP retry length */
+static ulong wget_load_size; + +/** + * wget_init_max_size() - initialize maximum load size + * + * Return: 0 if success, -1 if fails + */ +static int wget_init_load_size(void) +{ + struct lmb lmb; + phys_size_t max_size; + + lmb_init_and_reserve(&lmb, gd->bd, (void *)gd->fdt_blob); + + max_size = lmb_get_free_size(&lmb, image_load_addr); + if (!max_size) + return -1; + + wget_load_size = max_size; + + return 0; +} + /** * store_block() - store block in memory * @src: source of data @@ -63,10 +90,25 @@ static int retry_len; /* TCP retry length */ */ static inline int store_block(uchar *src, unsigned int offset, unsigned int len) { + ulong store_addr = image_load_addr + offset; ulong newsize = offset + len; uchar *ptr;
- ptr = map_sysmem(image_load_addr + offset, len); + if (IS_ENABLED(CONFIG_LMB)) { + ulong end_addr = image_load_addr + wget_load_size; + + if (!end_addr) + end_addr = ULONG_MAX; + + if (store_addr < image_load_addr || + store_addr + len > end_addr) { + printf("\nwget error: "); + printf("trying to overwrite reserved memory...\n"); + return -1; + } + } + + ptr = map_sysmem(store_addr, len); memcpy(ptr, src, len); unmap_sysmem(ptr);
@@ -240,25 +282,39 @@ static void wget_connected(uchar *pkt, unsigned int tcp_seq_num,
net_boot_file_size = 0;
- if (len > hlen) - store_block(pkt + hlen, 0, len - hlen); + if (len > hlen) { + if (store_block(pkt + hlen, 0, len - hlen) != 0) { + wget_loop_state = NETLOOP_FAIL; + wget_fail("wget: store error\n", tcp_seq_num, tcp_ack_num, action); + net_set_state(NETLOOP_FAIL); + return; + } + }
debug_cond(DEBUG_WGET, "wget: Connected Pkt %p hlen %x\n", pkt, hlen);
for (i = 0; i < pkt_q_idx; i++) { + int err; + ptr1 = map_sysmem( (phys_addr_t)(pkt_q[i].pkt), pkt_q[i].len); - store_block(ptr1, - pkt_q[i].tcp_seq_num - - initial_data_seq_num, - pkt_q[i].len); + err = store_block(ptr1, + pkt_q[i].tcp_seq_num - + initial_data_seq_num, + pkt_q[i].len); unmap_sysmem(ptr1); debug_cond(DEBUG_WGET, "wget: Connctd pkt Q %p len %x\n", pkt_q[i].pkt, pkt_q[i].len); + if (err) { + wget_loop_state = NETLOOP_FAIL; + wget_fail("wget: store error\n", tcp_seq_num, tcp_ack_num, action); + net_set_state(NETLOOP_FAIL); + return; + } } } } @@ -330,6 +386,7 @@ static void wget_handler(uchar *pkt, u16 dport, len) != 0) { wget_fail("wget: store error\n", tcp_seq_num, tcp_ack_num, action); + net_set_state(NETLOOP_FAIL); return; }
@@ -420,6 +477,15 @@ void wget_start(void) debug_cond(DEBUG_WGET, "\nwget:Load address: 0x%lx\nLoading: *\b", image_load_addr);
+ if (IS_ENABLED(CONFIG_LMB)) { + if (wget_init_load_size()) { + printf("\nwget error: "); + printf("trying to overwrite reserved memory...\n"); + net_set_state(NETLOOP_FAIL); + return; + } + } + net_set_timeout_handler(wget_timeout, wget_timeout_handler); tcp_set_tcp_handler(wget_handler);
On Wed, Sep 27, 2023 at 12:37 PM Masahisa Kojima masahisa.kojima@linaro.org wrote:
- Copyright Duncan Hare dh@synoia.com 2017
- wget_init_max_size() - initialize maximum load size
- Return: 0 if success, -1 if fails
struct lmb lmb;
if (!max_size)
return -1;
- store_block() - store block in memory
- @src: source of data
if (!end_addr)
return -1;
if (len > hlen)
if (len > hlen) {
return;
} debug_cond(DEBUG_WGET, "wget: Connected Pkt %p hlen %x\n", pkt, hlen); for (i = 0; i < pkt_q_idx; i++) {
int err;
store_block(ptr1,
pkt_q[i].len);
if (err) {
return;
return;
-- 2.34.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Current wget takes the target uri in this format: "<http server ip>:<file path>" e.g.) 192.168.1.1:/bar The http server ip address must be resolved before calling wget.
This commit adds the utility function runs wget with dhs. User can call wget with the uri like "http://foo/bar".
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- include/net.h | 9 +++++++++ net/wget.c | 54 +++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 63 insertions(+)
diff --git a/include/net.h b/include/net.h index e254df7d7f..57889d8b7a 100644 --- a/include/net.h +++ b/include/net.h @@ -926,4 +926,13 @@ void eth_set_enable_bootdevs(bool enable); static inline void eth_set_enable_bootdevs(bool enable) {} #endif
+/** + * wget_with_dns() - runs dns host IP address resulution before wget + * + * @dst_addr: destination address to download the file + * @uri: uri string of target file of wget + * Return: downloaded file size, negative if failed + */ +int wget_with_dns(ulong dst_addr, char *uri); + #endif /* __NET_H__ */ diff --git a/net/wget.c b/net/wget.c index a48a8cb624..4801e28eb9 100644 --- a/net/wget.c +++ b/net/wget.c @@ -15,6 +15,7 @@ #include <net.h> #include <net/tcp.h> #include <net/wget.h> +#include <stdlib.h>
@@ -504,3 +505,56 @@ void wget_start(void)
wget_send(TCP_SYN, 0, 0, 0); } + +#if (IS_ENABLED(CONFIG_CMD_DNS)) +int wget_with_dns(ulong dst_addr, char *uri) +{ + int ret; + char *s, *host_name, *file_name, *str_copy; + + /* + * Download file using wget. + * + * U-Boot wget takes the target uri in this format. + * "<http server ip>:<file path>" e.g.) 192.168.1.1:/sample/test.iso + * Need to resolve the http server ip address before starting wget. + */ + str_copy = strdup(uri); + if (!str_copy) + return -ENOMEM; + + s = str_copy + strlen("http://"); + host_name = strsep(&s, "/"); + if (!s) { + log_err("Error: invalied uri, no file path\n"); + ret = -EINVAL; + goto out; + } + file_name = s; + + /* TODO: If the given uri has ip address for the http server, skip dns */ + net_dns_resolve = host_name; + net_dns_env_var = "httpserverip"; + if (net_loop(DNS) < 0) { + log_err("Error: dns lookup of %s failed, check setup\n", net_dns_resolve); + ret = -EINVAL; + goto out; + } + s = env_get("httpserverip"); + if (!s) { + ret = -EINVAL; + goto out; + } + + strlcpy(net_boot_file_name, s, sizeof(net_boot_file_name)); + strlcat(net_boot_file_name, ":/", sizeof(net_boot_file_name)); /* append '/' which is removed by strsep() */ + strlcat(net_boot_file_name, file_name, sizeof(net_boot_file_name)); + image_load_addr = dst_addr; + ret = net_loop(WGET); + +out: + free(str_copy); + + return ret; +} +#endif
- wget_with_dns() - runs dns host IP address resulution before wget
- @dst_addr: destination address to download the file
- @uri: uri string of target file of wget
- Return: downloaded file size, negative if failed
int ret;
if (!str_copy)
return -ENOMEM;
if (!s) {
ret = -EINVAL;
goto out;
file_name = s;
ret = -EINVAL;
goto out;
if (!s) {
ret = -EINVAL;
goto out;
+out:
free(str_copy);
return ret;
2.34.1
User needs to call several functions to create the ramdisk with blkmap. This adds the utility function to create blkmap device and mount the ramdisk.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- drivers/block/Makefile | 1 + drivers/block/blkmap.c | 15 ---------- drivers/block/blkmap_helper.c | 53 +++++++++++++++++++++++++++++++++++ include/blkmap.h | 29 +++++++++++++++++++ 4 files changed, 83 insertions(+), 15 deletions(-) create mode 100644 drivers/block/blkmap_helper.c
diff --git a/drivers/block/Makefile b/drivers/block/Makefile index a161d145fd..c3ccfc03e5 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -15,6 +15,7 @@ endif obj-$(CONFIG_SANDBOX) += sandbox.o host-uclass.o host_dev.o obj-$(CONFIG_$(SPL_TPL_)BLOCK_CACHE) += blkcache.o obj-$(CONFIG_BLKMAP) += blkmap.o +obj-$(CONFIG_BLKMAP) += blkmap_helper.o
obj-$(CONFIG_EFI_MEDIA) += efi-media-uclass.o obj-$(CONFIG_EFI_MEDIA_SANDBOX) += sb_efi_media.o diff --git a/drivers/block/blkmap.c b/drivers/block/blkmap.c index 2bb0acc20f..4e95997f61 100644 --- a/drivers/block/blkmap.c +++ b/drivers/block/blkmap.c @@ -66,21 +66,6 @@ struct blkmap_slice { void (*destroy)(struct blkmap *bm, struct blkmap_slice *bms); };
-/** - * struct blkmap - Block map - * - * Data associated with a blkmap. - * - * @label: Human readable name of this blkmap - * @blk: Underlying block device - * @slices: List of slices associated with this blkmap - */ -struct blkmap { - char *label; - struct udevice *blk; - struct list_head slices; -}; - static bool blkmap_slice_contains(struct blkmap_slice *bms, lbaint_t blknr) { return (blknr >= bms->blknr) && (blknr < (bms->blknr + bms->blkcnt)); diff --git a/drivers/block/blkmap_helper.c b/drivers/block/blkmap_helper.c new file mode 100644 index 0000000000..0f80035f57 --- /dev/null +++ b/drivers/block/blkmap_helper.c @@ -0,0 +1,53 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * blkmap helper function + * + * Copyright (c) 2023, Linaro Limited + */ + +#include <blk.h> +#include <blkmap.h> +#include <dm/device.h> +#include <dm/device-internal.h> + +int blkmap_create_ramdisk(const char *label, ulong image_addr, int image_size, + struct udevice **devp) +{ + int ret; + lbaint_t blknum; + struct blkmap *bm; + struct blk_desc *desc; + struct udevice *bm_dev; + + ret = blkmap_create(label, &bm_dev); + if (ret) { + log_err("failed to create blkmap\n"); + return ret; + } + + bm = dev_get_plat(bm_dev); + desc = dev_get_uclass_plat(bm->blk); + blknum = image_size >> desc->log2blksz; + ret = blkmap_map_pmem(bm_dev, 0, blknum, image_addr); + if (ret) { + log_err("Unable to map %#llx at block %d : %d\n", + (unsigned long long)image_addr, 0, ret); + goto err; + } + log_info("Block %d+0x" LBAF " mapped to %#llx\n", 0, blknum, + (unsigned long long)image_addr); + + ret = device_probe(bm->blk); + if (ret) + goto err; + + if (devp) + *devp = bm_dev; + + return 0; + +err: + blkmap_destroy(bm_dev); + + return ret; +} diff --git a/include/blkmap.h b/include/blkmap.h index af54583c7d..0d87e6db6b 100644 --- a/include/blkmap.h +++ b/include/blkmap.h @@ -7,6 +7,23 @@ #ifndef _BLKMAP_H #define _BLKMAP_H
+#include <dm/lists.h> + +/** + * struct blkmap - Block map + * + * Data associated with a blkmap. + * + * @label: Human readable name of this blkmap + * @blk: Underlying block device + * @slices: List of slices associated with this blkmap + */ +struct blkmap { + char *label; + struct udevice *blk; + struct list_head slices; +}; + /** * blkmap_map_linear() - Map region of other block device * @@ -74,4 +91,16 @@ int blkmap_create(const char *label, struct udevice **devp); */ int blkmap_destroy(struct udevice *dev);
+/** + * blkmap_create_ramdisk() - Create new ramdisk with blkmap + * + * @label: Label of the new blkmap + * @image_addr: Target memory start address of this mapping + * @image_size: Target memory size of this mapping + * @devp: Updated with the address of the created blkmap device + * Returns: 0 on success, negative error code on failure + */ +int blkmap_create_ramdisk(const char *label, ulong image_addr, int image_size, + struct udevice **devp); + #endif /* _BLKMAP_H */
you should actually build them only when it is enabled also for SPL/TPL
It means use style like this.
obj-$(CONFIG_$(SPL_TPL_)BLKMAP) += blkmap.o obj-$(CONFIG_$(SPL_TPL_)BLKMAP) += blkmap_helper.o
Thanks, Michal
Hi Michal,
I will fix it.
Thanks, Masahisa Kojima
Thanks, Michal
This supports to boot from the URI device path. When user selects the URI device path, bootmgr downloads the file using wget into the address specified by loadaddr env variable. If the file is .iso or .img file, mount the image with blkmap then try to boot with the default file(e.g. EFI/BOOT/BOOTAA64.EFI). If the file is PE-COFF file, load and start the downloaded file.
The buffer used to download the ISO image file must be reserved to avoid the unintended access to the image. For PE-COFF file case, this memory reservation is done in LoadImage Boot Service.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- include/efi_loader.h | 2 + lib/efi_loader/efi_bootmgr.c | 198 +++++++++++++++++++++++++++++++++- lib/efi_loader/efi_dt_fixup.c | 2 +- 3 files changed, 200 insertions(+), 2 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index 4a29ddaef4..c4207edc91 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -554,6 +554,8 @@ void efi_runtime_detach(void); /* efi_convert_pointer() - convert pointer to virtual address */ efi_status_t EFIAPI efi_convert_pointer(efi_uintn_t debug_disposition, void **address); +/* add reserved memory to memory map */ +void efi_reserve_memory(u64 addr, u64 size, bool nomap); /* Carve out DT reserved memory ranges */ void efi_carve_out_dt_rsv(void *fdt); /* Purge unused kaslr-seed */ diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index a40762c74c..a5030d50c0 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -7,10 +7,14 @@
#define LOG_CATEGORY LOGC_EFI
+#include <blk.h> +#include <blkmap.h> #include <common.h> #include <charset.h> +#include <dm.h> #include <log.h> #include <malloc.h> +#include <net.h> #include <efi_default_filename.h> #include <efi_loader.h> #include <efi_variable.h> @@ -168,6 +172,187 @@ out: return ret; }
+/** + * mount_image() - mount the image with blkmap + * + * @lo_label u16 label string of load option + * @image_addr: image address + * @image_size image size + * Return: pointer to the UCLASS_BLK udevice, NULL if failed + */ +static struct udevice *mount_image(u16 *lo_label, ulong image_addr, int image_size) +{ + int err; + struct blkmap *bm; + struct udevice *bm_dev; + char *label = NULL, *p; + + label = efi_alloc(utf16_utf8_strlen(lo_label) + 1); + if (!label) + return NULL; + + p = label; + utf16_utf8_strcpy(&p, lo_label); + err = blkmap_create_ramdisk(label, image_addr, image_size, &bm_dev); + if (err) { + efi_free_pool(label); + return NULL; + } + bm = dev_get_plat(bm_dev); + + efi_free_pool(label); + + return bm->blk; +} + +/** + * try_load_default_file() - try to load the default file + * + * Search the device having EFI_SIMPLE_FILE_SYSTEM_PROTOCOL, + * then try to load with the default boot file(e.g. EFI/BOOT/BOOTAA64.EFI). + * + * @dev pointer to the UCLASS_BLK or UCLASS_PARTITION udevice + * @image_handle: pointer to handle for newly installed image + * Return: status code + */ +static efi_status_t try_load_default_file(struct udevice *dev, + efi_handle_t *image_handle) +{ + efi_status_t ret; + efi_handle_t handle; + struct efi_handler *handler; + struct efi_device_path *file_path; + struct efi_device_path *device_path; + + if (dev_tag_get_ptr(dev, DM_TAG_EFI, (void **)&handle)) { + log_warning("DM_TAG_EFI not found\n"); + return EFI_INVALID_PARAMETER; + } + + ret = efi_search_protocol(handle, + &efi_simple_file_system_protocol_guid, &handler); + if (ret != EFI_SUCCESS) + return ret; + + ret = EFI_CALL(bs->open_protocol(handle, &efi_guid_device_path, + (void **)&device_path, efi_root, NULL, + EFI_OPEN_PROTOCOL_GET_PROTOCOL)); + if (ret != EFI_SUCCESS) + return ret; + + file_path = expand_media_path(device_path); + ret = EFI_CALL(efi_load_image(true, efi_root, file_path, NULL, 0, + image_handle)); + + efi_free_pool(file_path); + + return ret; +} + +/** + * load_default_file_from_blk_dev() - load the default file + * + * @blk pointer to the UCLASS_BLK udevice + * @handle: pointer to handle for newly installed image + * Return: status code + */ +static efi_status_t load_default_file_from_blk_dev(struct udevice *blk, + efi_handle_t *handle) +{ + efi_status_t ret; + struct udevice *partition; + + /* image that has no partition table but a file system */ + ret = try_load_default_file(blk, handle); + if (ret == EFI_SUCCESS) + return ret; + + /* try the partitions */ + device_foreach_child(partition, blk) { + enum uclass_id id; + + id = device_get_uclass_id(partition); + if (id != UCLASS_PARTITION) + continue; + + ret = try_load_default_file(partition, handle); + if (ret == EFI_SUCCESS) + return ret; + } + + return EFI_NOT_FOUND; +} + +/** + * try_load_from_uri_path() - Handle the URI device path + * + * @uridp: uri device path + * @lo_label label of load option + * @handle: pointer to handle for newly installed image + * Return: status code + */ +static efi_status_t try_load_from_uri_path(struct efi_device_path_uri *uridp, + u16 *lo_label, + efi_handle_t *handle) +{ + char *s; + int uri_len; + int image_size; + efi_status_t ret; + ulong image_addr; + + s = env_get("loadaddr"); + if (!s) { + log_err("Error: loadaddr is not set\n"); + return EFI_INVALID_PARAMETER; + } + image_addr = hextoul(s, NULL); + image_size = wget_with_dns(image_addr, uridp->uri); + if (image_size < 0) + return EFI_INVALID_PARAMETER; + + /* + * If the file extension is ".iso" or ".img", mount it and try to load + * the default file. + * If the file is PE-COFF image, load the downloaded file. + */ + uri_len = strlen(uridp->uri); /* todo: directly use uridp->uri */ + if (!strncmp(&uridp->uri[uri_len - 4], ".iso", 4) || + !strncmp(&uridp->uri[uri_len - 4], ".img", 4)) { + struct udevice *blk; + + blk = mount_image(lo_label, image_addr, image_size); + if (!blk) + return EFI_INVALID_PARAMETER; + + ret = load_default_file_from_blk_dev(blk, handle); + if (ret != EFI_SUCCESS) + return ret; + + /* whole ramdisk must be reserved */ + efi_reserve_memory(image_addr, image_size, true); + } else if (efi_check_pe((void *)image_addr, image_size, NULL) == EFI_SUCCESS) { + efi_handle_t mem_handle = NULL; + struct efi_device_path *file_path = NULL; + + file_path = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, + (uintptr_t)image_addr, image_size); + ret = efi_install_multiple_protocol_interfaces( + &mem_handle, &efi_guid_device_path, file_path, NULL); + if (ret != EFI_SUCCESS) + return EFI_INVALID_PARAMETER; + + ret = EFI_CALL(efi_load_image(false, efi_root, file_path, + (void *)image_addr, image_size, + handle)); + } else { + log_err("Error: file type is not supported\n"); + return EFI_INVALID_PARAMETER; + } + + return ret; +} + /** * try_load_entry() - try to load image for boot option * @@ -185,7 +370,7 @@ static efi_status_t try_load_entry(u16 n, efi_handle_t *handle, { struct efi_load_option lo; u16 varname[9]; - void *load_option; + void *load_option = NULL; efi_uintn_t size; efi_status_t ret;
@@ -211,6 +396,17 @@ static efi_status_t try_load_entry(u16 n, efi_handle_t *handle, if (EFI_DP_TYPE(lo.file_path, MEDIA_DEVICE, FILE_PATH)) { /* file_path doesn't contain a device path */ ret = try_load_from_short_path(lo.file_path, handle); + } else if (EFI_DP_TYPE(lo.file_path, MESSAGING_DEVICE, MSG_URI)) { + if (IS_ENABLED(CONFIG_BLKMAP) && + IS_ENABLED(CONFIG_CMD_WGET) && + IS_ENABLED(CONFIG_CMD_DNS)) { + ret = try_load_from_uri_path( + (struct efi_device_path_uri *) + lo.file_path, + lo.label, handle); + } else { + ret = EFI_LOAD_ERROR; + } } else { file_path = expand_media_path(lo.file_path); ret = EFI_CALL(efi_load_image(true, efi_root, file_path, diff --git a/lib/efi_loader/efi_dt_fixup.c b/lib/efi_loader/efi_dt_fixup.c index 838023c78f..edc515b9ff 100644 --- a/lib/efi_loader/efi_dt_fixup.c +++ b/lib/efi_loader/efi_dt_fixup.c @@ -22,7 +22,7 @@ const efi_guid_t efi_guid_dt_fixup_protocol = EFI_DT_FIXUP_PROTOCOL_GUID; * @nomap: indicates that the memory range shall not be accessed by the * UEFI payload */ -static void efi_reserve_memory(u64 addr, u64 size, bool nomap) +void efi_reserve_memory(u64 addr, u64 size, bool nomap) { int type; efi_uintn_t ret;
Hi Kojima-san,
- try_load_default_file() - try to load the default file
- Search the device having EFI_SIMPLE_FILE_SYSTEM_PROTOCOL,
- then try to load with the default boot file(e.g. EFI/BOOT/BOOTAA64.EFI).
- @dev pointer to the UCLASS_BLK or UCLASS_PARTITION udevice
- @image_handle: pointer to handle for newly installed image
- Return: status code
- efi_status_t ret;
- efi_handle_t handle;
- struct efi_handler *handler;
- struct efi_device_path *file_path;
- struct efi_device_path *device_path;
- if (dev_tag_get_ptr(dev, DM_TAG_EFI, (void **)&handle)) {
- ret = efi_search_protocol(handle,
- if (ret != EFI_SUCCESS)
return ret;
- ret = EFI_CALL(bs->open_protocol(handle, &efi_guid_device_path,
return ret;
- file_path = expand_media_path(device_path);
- ret = EFI_CALL(efi_load_image(true, efi_root, file_path, NULL, 0,
image_handle));
- efi_free_pool(file_path);
- return ret;
We've discussed this on v4, but I am replying here, since you sent a v5 in the meantime. What I ideally wanted to do here is - Add the boot option automatically once the disk gets mount (you've already sent a patch for that) - Since the boot option is automatically added we could instead of searching for BOOTAA64.EFI search for matches with a load option of '1234567'. Is there some timing issue that I am missing which doesnt allow us to do that ?
Cheers /Ilias
Hi Ilias,
On Fri, 29 Sept 2023 at 20:48, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Kojima-san,
efi_status_t ret;
return ret;
return ret;
image_handle));
return ret;
Sorry, I probably misunderstood your design. What kind of boot option is automatically added when the disk is detected? Could you share your thoughts about the trigger to search for matches with a load option of '1234567'?
Cheers /Ilias
On Fri, 29 Sept 2023 at 14:35, Masahisa Kojima masahisa.kojima@linaro.org wrote:
Hi Ilias,
Hi Kojima-san,
efi_status_t ret;
return ret;
return ret;
image_handle));
return ret;
You've recently fixed the CI errors and reported this [0]. Once that gets merged every time a new disk is added, it will be automatically be scanned for BOOTXXX.efi files. If we do find such files, they will be added to the efi bootmgr list of available options. We do mark these with a '1234567' in the optional data.
Once that path gets merged, wouldn't it be simpler to just scan for boot options with '1234567' in the load options on the mounted image, instead of rescanning it for BOOTXXX.efi?
[0] https://lore.kernel.org/u-boot/20230927010436.1503621-1-masahisa.kojima@lina...
Thanks /Ilias
Cheers /Ilias
This adds the URI device path option for 'boot add' subcommand. User can add the URI load option for downloading ISO image file or EFI application through network. Currently HTTP is only supported.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- cmd/efidebug.c | 50 +++++++++++++++++++++++++++++++++++ include/net.h | 8 ++++++ net/wget.c | 72 ++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 130 insertions(+)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index 0be3af3e76..f2fd6ba71d 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -19,6 +19,7 @@ #include <log.h> #include <malloc.h> #include <mapmem.h> +#include <net.h> #include <part.h> #include <search.h> #include <linux/ctype.h> @@ -829,6 +830,52 @@ static int do_efi_boot_add(struct cmd_tbl *cmdtp, int flag, argc -= 1; argv += 1; break; +#if (IS_ENABLED(CONFIG_BLKMAP) && IS_ENABLED(CONFIG_CMD_WGET) && IS_ENABLED(CONFIG_CMD_DNS)) + case 'u': + { + char *pos; + int uridp_len; + struct efi_device_path_uri *uridp; + + if (argc < 3 || lo.label) { + r = CMD_RET_USAGE; + goto out; + } + id = (int)hextoul(argv[1], &endp); + if (*endp != '\0' || id > 0xffff) + return CMD_RET_USAGE; + + efi_create_indexed_name(var_name16, sizeof(var_name16), + "Boot", id); + + label = efi_convert_string(argv[2]); + if (!label) + return CMD_RET_FAILURE; + lo.label = label; + + uridp_len = sizeof(struct efi_device_path) + strlen(argv[3]) + 1; + fp_free = efi_alloc(uridp_len + sizeof(END)); + uridp = (struct efi_device_path_uri *)fp_free; + uridp->dp.type = DEVICE_PATH_TYPE_MESSAGING_DEVICE; + uridp->dp.sub_type = DEVICE_PATH_SUB_TYPE_MSG_URI; + uridp->dp.length = uridp_len; + if (!wget_validate_uri(argv[3])) { + printf("ERROR: invalid URI\n"); + r = CMD_RET_FAILURE; + goto out; + } + + strcpy(uridp->uri, argv[3]); + pos = (char *)uridp + uridp_len; + memcpy(pos, &END, sizeof(END)); + fp_size += uridp_len + sizeof(END); + file_path = (struct efi_device_path *)uridp; + argc -= 3; + argv += 3; + break; + } +#endif + default: r = CMD_RET_USAGE; goto out; @@ -1492,6 +1539,9 @@ static char efidebug_help_text[] = " -b|-B <bootid> <label> <interface> <devnum>[:<part>] <file path>\n" " -i|-I <interface> <devnum>[:<part>] <initrd file path>\n" " (-b, -i for short form device path)\n" +#if (IS_ENABLED(CONFIG_BLKMAP) && IS_ENABLED(CONFIG_CMD_WGET) && IS_ENABLED(CONFIG_CMD_DNS)) + " -u <bootid> <label> <uri>\n" +#endif " -s '<optional data>'\n" "efidebug boot rm <bootid#1> [<bootid#2> [<bootid#3> [...]]]\n" " - delete UEFI BootXXXX variables\n" diff --git a/include/net.h b/include/net.h index 57889d8b7a..c748974573 100644 --- a/include/net.h +++ b/include/net.h @@ -935,4 +935,12 @@ static inline void eth_set_enable_bootdevs(bool enable) {} */ int wget_with_dns(ulong dst_addr, char *uri);
+/** + * wget_validate_uri() - varidate the uri + * + * @uri: uri string of target file of wget + * Return: true if uri is valid, false if uri is invalid + */ +bool wget_validate_uri(char *uri); + #endif /* __NET_H__ */ diff --git a/net/wget.c b/net/wget.c index 4801e28eb9..6a4d22be32 100644 --- a/net/wget.c +++ b/net/wget.c @@ -558,3 +558,75 @@ out: return ret; } #endif + +/** + * wget_validate_uri() - validate the uri for wget + * + * @uri: uri string + * Return: true on success, false on failure + */ +bool wget_validate_uri(char *uri) +{ + char c; + bool ret = true; + char *str_copy, *s, *authority; + + /* TODO: strict uri conformance check */ + + /* + * Uri is expected to be correctly percent encoded. + * This is the minimum check, control codes(0x1-0x19, 0x7F, except '\0') + * and space character(0x20) are not allowed. + */ + for (c = 0x1; c < 0x21; c++) { + if (strchr(uri, c)) { + printf("invalid character is used\n"); + return false; + } + } + if (strchr(uri, 0x7f)) { + printf("invalid character is used\n"); + return false; + } + + /* + * This follows the current U-Boot wget implementation. + * scheme: only "http:" is supported + * authority: + * - user information: not supported + * - host: supported + * - port: not supported(always use the default port) + */ + if (strncmp(uri, "http://", 7)) { + printf("only http:// is supported\n"); + return false; + } + str_copy = strdup(uri); + if (!str_copy) + return false; + + s = str_copy + strlen("http://"); + authority = strsep(&s, "/"); + if (!s) { + printf("invalid uri, no file path\n"); + ret = false; + goto out; + } + s = strchr(authority, '@'); + if (s) { + printf("user information is not supported\n"); + ret = false; + goto out; + } + s = strchr(authority, ':'); + if (s) { + printf("user defined port is not supported\n"); + ret = false; + goto out; + } + +out: + free(str_copy); + + return ret; +}
On Wed, 27 Sept 2023 at 15:38, Masahisa Kojima masahisa.kojima@linaro.org wrote:
case 'u':
char *pos;
int uridp_len;
r = CMD_RET_USAGE;
goto out;
sizeof(var_name16),
"Boot", id);
if (!label)
lo.label = label;
goto out;
argc -= 3;
argv += 3;
break;
- wget_validate_uri() - varidate the uri
- Return: true if uri is valid, false if uri is invalid
- wget_validate_uri() - validate the uri for wget
- @uri: uri string
- Return: true on success, false on failure
It's better to have a comment description in one place. You already have it in the header file. And even here the text is a little bit differ.
char c;
bool ret = true;
'\0')
return false;
return false;
So you validate that only English characters exist in the url. There are urls with non English characters.
* authority:
* - host: supported
log_err()
return false;
if (!str_copy)
return false;
if (!s) {
ret = false;
goto out;
if (s) {
ret = false;
goto out;
if (s) {
ret = false;
goto out;
+out:
free(str_copy);
return ret;
2.34.1
case 'u':
char *pos;
int uridp_len;
r = CMD_RET_USAGE;
goto out;
"Boot", id);
if (!label)
lo.label = label;
goto out;
argc -= 3;
argv += 3;
break;
- @uri: uri string
OK, I will add a comment in the function header.
char c;
bool ret = true;
return false;
return false;
I only excluded the control codes and space(0x20), so non-English characters and UTF-8 encoded URIs can be available.
* authority:
* - host: supported
log_err()
OK, I will replace other printf() calls.
return false;
if (!str_copy)
return false;
if (!s) {
ret = false;
goto out;
if (s) {
ret = false;
goto out;
if (s) {
ret = false;
goto out;
+out:
free(str_copy);
return ret;
2.34.1
This adds the description about HTTP Boot.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- doc/develop/uefi/uefi.rst | 30 ++++++++++++++++++++++++++++++ 1 file changed, 30 insertions(+)
diff --git a/doc/develop/uefi/uefi.rst b/doc/develop/uefi/uefi.rst index a7a41f2fac..23b3da0f95 100644 --- a/doc/develop/uefi/uefi.rst +++ b/doc/develop/uefi/uefi.rst @@ -594,6 +594,36 @@ UEFI variables. Booting according to these variables is possible via:: As of U-Boot v2020.10 UEFI variables cannot be set at runtime. The U-Boot command 'efidebug' can be used to set the variables.
+UEFI HTTP Boot +~~~~~~~~~~~~~~ + +HTTP Boot provides the capability for system deployment and configuration +over the network. HTTP Boot can be activated by specifying:: + + CONFIG_CMD_DNS + CONFIG_CMD_WGET + CONFIG_BLKMAP + +Set up the load option specifying the target URI:: + + efidebug boot add -u 1 netinst http://foo/bar + +When this load option is selected as boot selection, resolve the +host ip address by dns, then download the file with wget. +If the downloaded file extension is .iso or .img file, efibootmgr tries to +mount the image and boot with the default file(e.g. EFI/BOOT/BOOTAA64.EFI). +If the downloaded file is PE-COFF image, load the downloaded file and +start it. + +The current implementation tries to resolve the IP address as a host name. +If the uri is like "http://192.168.1.1/foobar", +the dns process tries to resolve the host "192.168.1.1" and it will +end up with "host not found". + +We need to preset the "httpserverip" environment variable to proceed the wget:: + + setenv httpserverip 192.168.1.1 + Executing the built in hello world application ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Current efibootmgr automatically creates the boot options of all the disks and partitions installing SIMPLE_FILE_SYSTEM_PROTOCOL. These boot options are created to load and start the default file(e.g. EFI/BOOT/BOOTAA64.EFI).
Now efibootmgr can scan the BlockIo device and try to boot with the default file on the fly, this commit creates the boot options only for the BlockIo devices exluding the logical partition.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- include/efi_loader.h | 1 + lib/efi_loader/efi_bootmgr.c | 50 ++++++++++++++++++++++---------- lib/efi_loader/efi_device_path.c | 20 +++++++++++++ 3 files changed, 55 insertions(+), 16 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index c4207edc91..cc292f0553 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -932,6 +932,7 @@ struct efi_device_path *efi_dp_from_lo(struct efi_load_option *lo, struct efi_device_path *efi_dp_concat(const struct efi_device_path *dp1, const struct efi_device_path *dp2); struct efi_device_path *search_gpt_dp_node(struct efi_device_path *device_path); +struct efi_device_path *efi_search_file_path_dp_node(struct efi_device_path *device_path); efi_status_t efi_deserialize_load_option(struct efi_load_option *lo, u8 *data, efi_uintn_t *size); unsigned long efi_serialize_load_option(struct efi_load_option *lo, u8 **data); diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index a5030d50c0..2da80428b4 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -387,7 +387,6 @@ static efi_status_t try_load_entry(u16 n, efi_handle_t *handle, }
if (lo.attributes & LOAD_OPTION_ACTIVE) { - struct efi_device_path *file_path; u32 attributes;
log_debug("trying to load "%ls" from %pD\n", lo.label, @@ -407,11 +406,17 @@ static efi_status_t try_load_entry(u16 n, efi_handle_t *handle, } else { ret = EFI_LOAD_ERROR; } - } else { - file_path = expand_media_path(lo.file_path); - ret = EFI_CALL(efi_load_image(true, efi_root, file_path, + } else if (efi_search_file_path_dp_node(lo.file_path)) { + ret = EFI_CALL(efi_load_image(true, efi_root, lo.file_path, NULL, 0, handle)); - efi_free_pool(file_path); + } else { + efi_handle_t h; + + h = efi_dp_find_obj(lo.file_path, &efi_block_io_guid, NULL); + if (h) + ret = load_default_file_from_blk_dev(h->dev, handle); + else + ret = EFI_LOAD_ERROR; } if (ret != EFI_SUCCESS) { log_warning("Loading %ls '%ls' failed\n", @@ -551,13 +556,13 @@ error: */ static efi_status_t efi_bootmgr_enumerate_boot_option(struct eficonfig_media_boot_option *opt, efi_handle_t *volume_handles, - efi_status_t count) + efi_uintn_t *count) { - u32 i; + u32 i, num = 0; struct efi_handler *handler; efi_status_t ret = EFI_SUCCESS;
- for (i = 0; i < count; i++) { + for (i = 0; i < *count; i++) { u16 *p; u16 dev_name[BOOTMENU_DEVICE_NAME_MAX]; char *optional_data; @@ -565,6 +570,16 @@ static efi_status_t efi_bootmgr_enumerate_boot_option(struct eficonfig_media_boo char buf[BOOTMENU_DEVICE_NAME_MAX]; struct efi_device_path *device_path; struct efi_device_path *short_dp; + struct efi_block_io *blkio; + + ret = efi_search_protocol(volume_handles[i], &efi_block_io_guid, &handler); + blkio = handler->protocol_interface; + /* + * The logical partition is excluded since the bootmgr tries to + * boot with the default file by scanning the default file on the fly. + */ + if (blkio->media->logical_partition) + continue;
ret = efi_search_protocol(volume_handles[i], &efi_guid_device_path, &handler); if (ret != EFI_SUCCESS) @@ -598,16 +613,18 @@ static efi_status_t efi_bootmgr_enumerate_boot_option(struct eficonfig_media_boo * to store guid, instead of realloc the load_option. */ lo.optional_data = "1234567"; - opt[i].size = efi_serialize_load_option(&lo, (u8 **)&opt[i].lo); - if (!opt[i].size) { + opt[num].size = efi_serialize_load_option(&lo, (u8 **)&opt[num].lo); + if (!opt[num].size) { ret = EFI_OUT_OF_RESOURCES; goto out; } /* set the guid */ - optional_data = (char *)opt[i].lo + (opt[i].size - u16_strsize(u"1234567")); + optional_data = (char *)opt[num].lo + (opt[num].size - u16_strsize(u"1234567")); memcpy(optional_data, &efi_guid_bootmenu_auto_generated, sizeof(efi_guid_t)); + num++; }
+ *count = num; out: return ret; } @@ -837,8 +854,7 @@ efi_status_t efi_bootmgr_delete_boot_option(u16 boot_index) /** * efi_bootmgr_update_media_device_boot_option() - generate the media device boot option * - * This function enumerates all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL - * and generate the bootmenu entries. + * This function enumerates all BlockIo devices and add the boot option for it. * This function also provide the BOOT#### variable maintenance for * the media device entries. * - Automatically create the BOOT#### variable for the newly detected device, @@ -858,7 +874,7 @@ efi_status_t efi_bootmgr_update_media_device_boot_option(void) struct eficonfig_media_boot_option *opt = NULL;
ret = efi_locate_handle_buffer_int(BY_PROTOCOL, - &efi_simple_file_system_protocol_guid, + &efi_block_io_guid, NULL, &count, (efi_handle_t **)&volume_handles); if (ret != EFI_SUCCESS) @@ -870,8 +886,7 @@ efi_status_t efi_bootmgr_update_media_device_boot_option(void) goto out; }
- /* enumerate all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL */ - ret = efi_bootmgr_enumerate_boot_option(opt, volume_handles, count); + ret = efi_bootmgr_enumerate_boot_option(opt, volume_handles, &count); if (ret != EFI_SUCCESS) goto out;
@@ -890,6 +905,9 @@ efi_status_t efi_bootmgr_update_media_device_boot_option(void) u32 boot_index; u16 var_name[9];
+ if (!opt[i].size) + continue; + if (!opt[i].exist) { ret = efi_bootmgr_get_unused_bootoption(var_name, sizeof(var_name), &boot_index); diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index ed7214f3a3..a34ef3da68 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -1219,3 +1219,23 @@ struct efi_device_path *search_gpt_dp_node(struct efi_device_path *device_path)
return NULL; } + +/** + * efi_search_file_path_dp_node() - search file_path device path node + * + * @device_path: device path + * + * Return: pointer to the DEVICE_PATH_SUB_TYPE_FILE_PATH device path node + */ +struct efi_device_path *efi_search_file_path_dp_node(struct efi_device_path *device_path) +{ + struct efi_device_path *dp = device_path; + + while (dp) { + if (EFI_DP_TYPE(dp, MEDIA_DEVICE, FILE_PATH)) + return dp; + dp = efi_dp_next(dp); + } + + return NULL; +}
participants (5)
Ilias Apalodimas
Masahisa Kojima
Maxim Uvarov
Michal Simek
Ramon Fried
