[U-Boot-Users] U-boot support arm926ejs
Hi, Now I am debugging the board which use Marvell 5182 core, which core is arm9, but I can not seem any information from Serial port. I have traced the code with GPIO LED port, from that I can seem there are something wrong in DDR RAM, maybe hardware. Since the arm core use memory to init all the decide: init_fnc_t *init_sequence[] = { cpu_init, /* basic cpu dependent setup */ board_init, /* basic board dependent setup */ interrupt_init, /* set up exceptions */ env_init, /* initialize environment */ init_baudrate, /* initialze baudrate settings */ serial_init, /* serial communications setup */ console_init_f, /* stage 1 init of console */ display_banner, /* say that we are here */ dram_init, /* configure available RAM banks */ #ifndef CONFIG_MARVELL display_dram_config, #endif #if defined(CONFIG_VCMA9) checkboard, #endif NULL, }; in function start_armboot But in powerpc the code use DCache to run the init part, so that even if the ram does not work normally, we can see information from serial port, could it run in arm core 5182 system. If yes, how to change that.
Could wolf or some other expert answer my questions? Thanks much! Best Wishes Jack Zhao USI SH R&D Center 86-021-58966996-1122
Use a debugger to find out what exactly is happening.
I don't understand what you mean. Missing console output has nothing to do with RAM; you have console output long before even touching RAM.
You misunderstand. Dcache has *nothing* to do with this.
All this code is running from flash, both on ARM and on PowerPC.
This has nothing to do with each other.
Thanks But In 5182 system, when I plug out the ddr memory in demo board, nothing appeared in serial port, while I can see information in powerpc 8347 system.
-----邮件原件----- 发件人: wd@denx.de [mailto:wd@denx.de] 发送时间: 2006年7月4日 19:30 收件人: jack zhao 抄送: u-boot-users@lists.sourceforge.net 主题: Re: [U-Boot-Users] U-boot support arm926ejs
traced
wrong
the
jack zhao
