Re: [U-Boot] [PATCH 2/6] dm: gpio: hi6220: Add a hi6220 GPIO driver model driver.
On Tuesday, May 12, 2015 at 03:38:28 PM, Peter Griffin wrote:
Hi!
This patch adds support for the GPIO perif found on hi6220 SoC.
Signed-off-by: Peter Griffin peter.griffin@linaro.org
arch/arm/include/asm/arch-armv8/gpio.h | 47 +++++++++++++++++ drivers/gpio/Makefile | 2 + drivers/gpio/hi6220_gpio.c | 95 ++++++++++++++++++++++++++++++++++ 3 files changed, 144 insertions(+) create mode 100644 arch/arm/include/asm/arch-armv8/gpio.h create mode 100644 drivers/gpio/hi6220_gpio.c
diff --git a/arch/arm/include/asm/arch-armv8/gpio.h b/arch/arm/include/asm/arch-armv8/gpio.h new file mode 100644 index 0000000..162c2d9 --- /dev/null +++ b/arch/arm/include/asm/arch-armv8/gpio.h @@ -0,0 +1,47 @@ +/*
- Copyright (C) 2015 Linaro
- Peter Griffin peter.griffin@linaro.org
+#ifndef _HI6220_GPIO_H_ +#define _HI6220_GPIO_H_
+#define HI6220_GPIO0_BASE (void *)0xf8011000
You should drop the explicit cast, that's nasty.
Also, why don't you define this as a HI6220_GPIO_BASE(bank) instead? That'd trim down the number of macros and from what I see, it should be rather easy to do ...
#define HI6220_GPIO_BASE(bank) (((bank < 4) ? 0xf8012000 : (0xf7020000 - 0x4000)) + (0x1000 * bank))
+#define HI6220_GPIO1_BASE (void *)0xf8012000 +#define HI6220_GPIO2_BASE (void *)0xf8013000 +#define HI6220_GPIO3_BASE (void *)0xf8014000 +#define HI6220_GPIO4_BASE (void *)0xf7020000 +#define HI6220_GPIO5_BASE (void *)0xf7021000 +#define HI6220_GPIO6_BASE (void *)0xf7022000 +#define HI6220_GPIO7_BASE (void *)0xf7023000 +#define HI6220_GPIO8_BASE (void *)0xf7024000 +#define HI6220_GPIO9_BASE (void *)0xf7025000 +#define HI6220_GPIO10_BASE (void *)0xf7026000 +#define HI6220_GPIO11_BASE (void *)0xf7027000 +#define HI6220_GPIO12_BASE (void *)0xf7028000 +#define HI6220_GPIO13_BASE (void *)0xf7029000 +#define HI6220_GPIO14_BASE (void *)0xf702a000 +#define HI6220_GPIO15_BASE (void *)0xf702b000 +#define HI6220_GPIO16_BASE (void *)0xf702c000 +#define HI6220_GPIO17_BASE (void *)0xf702d000 +#define HI6220_GPIO18_BASE (void *)0xf702e000 +#define HI6220_GPIO19_BASE (void *)0xf702f000
But are these even used in the driver anywhere ?
+#define BIT(x) (1 << (x))
This macro should be placed into common header files.
+#define HI6220_GPIO_PER_BANK 8 +#define HI6220_GPIO_DIR 0x400
+struct gpio_bank {
- u8 *base; /* address of registers in physical memory */
Should be void __iomem *, no ?
+/* Information about a GPIO bank */ +struct hikey_gpio_platdata {
- int bank_index;
- void *base; /* address of registers in physical memory */
+#endif /* _HI6220_GPIO_H_ */
[snip]
We'll fix that once Jagan's series comes in which gives everyone BIT().
Hi Marek,
Thanks for reviewing.
If I drop the cast I get lots of
include/asm/arch/gpio.h:11:32: warning: initialization makes pointer from integer without a cast
compiler warnings.
Yes good idea, I will do it like you suggest in V2. Currently I have
#define HI6220_GPIO_BASE(bank) (void *)(((bank < 4) ? 0xf8011000 : \ 0xf7020000 - 0x4000) + (0x1000 * bank))
To avoid the warnings mentioned above.
<snip>
They are currently used in the hikey.c board file which defines the hikey_gpio_platdata structure.
Although thinking about it some more this should be moved from the hikey board file to the driver as it is SoC specific rather than board specific.
+struct gpio_bank {
Will fix in v2.
regards,
Peter.
On Wednesday, May 13, 2015 at 02:00:13 PM, Peter Griffin wrote:
Hi Marek,
Hi!
compiler warnings.
But this is gpio.h header for your architecture, so maybe fix it there too?
Yup, or maybe even make it an inline function so you get proper typechecking?
<snip>
This is specific to the CPU, so this should be in arch-<something> .
+struct gpio_bank {
Will fix in v2.
Thanks! Also, please wait a bit for other reviews before sending V2 :)
Peter Griffin
