PINE64 Rock64 - How to get SPI driver working
Hello,
I just compiled U-Boot v2020.04 for a PINE64 Rock media board. It compiles fine without errors, but when I try to probe the on board flash I get an error:
=> sf probe Invalid bus 0 (err=-19) Failed to initialize SPI flash at 0:0 (error -19) =>
SPI is activated in the Device-Tree blob. I also added support to the Rockchip SPI driver (added IDS strings for this SoC).
In the device config I added the following:
CONFIG_SPI=y CONFIG_ROCKCHIP_SPI=y CONFIG_SPI_FLASH=y
But the driver still doesn't work. Output of DM (shortened):
=> dm tree [...] spi 0 [ ] rockchip_spi |-- spi@ff190000
spi_flash 0 [ ] spi_flash_std | `-- spiflash@0 [...]
What is missing? Is there a way to load driver?
Any kind of help is highly appreciated.
Hello,
I want to add a helper function to uboot i.e uboot# help will show a list of commands. I want to add 1 for my own private command. which file contains the list of cmd that will be displayed and the indirection? thanks -kamal
On Wed, May 20, 2020 at 8:58 AM Johannes Krottmayer krjdev@gmail.com wrote:
Hello,
-- Kind regards,
Johannes K.
Jagan may some idea here.
I would suggest you to add some log in the spi/flash driver for bind, probe and etc
to check what's wrong.
Thanks,
- Kever
On 2020/5/20 上午7:41, Johannes Krottmayer wrote:
Hello,
Hi Kever,
I think you answered the wrong person. :)
Okay, thanks for the suggestions.
I will check the sources. There was also a missing alias in the Device-Tree source. I have added the specific alias for the SPI bus. Now I'm getting the error code -2.
I'm new with U-Boot and the source code itself, but I think the problem occurs still in the device tree file for the specific board.
Cheers,
Johannes K.
Thanks,
- Kever
Hello,
On Fri, May 22, 2020 at 12:12 AM Johannes Krottmayer krjdev@gmail.com wrote:
Hi Kever,
Make sure you enable the driver for the actual flash chip too, some of the popular ones are: CONFIG_SPI_FLASH_WINBOND=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_GIGADEVICE=y
Cheers,
Johannes K.
Thanks,
- Kever
Hello,
Sorry for my late response.
Thanks for the suggestions.
I have enabled 'CONFIG_SPI_FLASH_GIGADEVICE'. But still getting the same error code (-2). On board is the GD25Q127C from Gigadevice.
The device ID for the operation code 0x9F according to the datasheet should be 0xC84018. I also found this device ID in the SPI-NOR IDS file.
I finally resolved the issue:
=> sf probe SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB =>
The flash device will be correctly detected. The problem was missing support in the clock driver of the SoC.
Should I release a patch for it?
Add U-Boot SPI support for the RK3328
Signed-off-by: Johannes Krottmayer krjdev@gmail.com Cc: Kever Yang kever.yang@rock-chips.com Cc: Jagan Teki jagan@amarulasolutions.com ---
It's a initial SPI support. Not sure if "rk3399_spi_params" is also needed. Probing of the SPI flash devices works. Tested with the PINE64 Rock64 board.
Okay?
arch/arm/dts/rk3328-u-boot.dtsi | 5 +++++ drivers/clk/rockchip/clk_rk3328.c | 31 +++++++++++++++++++++++++++++++ drivers/spi/rk_spi.c | 2 ++ 3 files changed, 38 insertions(+)
diff --git a/arch/arm/dts/rk3328-u-boot.dtsi b/arch/arm/dts/rk3328-u-boot.dtsi index c69e13e11e..c980daae99 100644 --- a/arch/arm/dts/rk3328-u-boot.dtsi +++ b/arch/arm/dts/rk3328-u-boot.dtsi @@ -7,6 +7,7 @@ aliases { mmc0 = &emmc; mmc1 = &sdmmc; + spi0 = &spi0; };
chosen { @@ -66,3 +67,7 @@ &usb20_otg { hnp-srp-disable; }; + +&spi0 { + u-boot,dm-pre-reloc; +}; diff --git a/drivers/clk/rockchip/clk_rk3328.c b/drivers/clk/rockchip/clk_rk3328.c index 02d3b08efa..bd95ab832b 100644 --- a/drivers/clk/rockchip/clk_rk3328.c +++ b/drivers/clk/rockchip/clk_rk3328.c @@ -555,6 +555,31 @@ static ulong rk3328_saradc_set_clk(struct rk3328_cru *cru, uint hz) return rk3328_saradc_get_clk(cru); }
+static ulong rk3328_spi_get_clk(struct rk3328_cru *cru) +{ + u32 div, val; + + val = readl(&cru->clksel_con[24]); + div = (val & CLK_SPI_DIV_CON_MASK) >> CLK_SPI_DIV_CON_SHIFT; + + return DIV_TO_RATE(OSC_HZ, div); +} + +static ulong rk3328_spi_set_clk(struct rk3328_cru *cru, uint hz) +{ + u32 src_clk_div; + + src_clk_div = GPLL_HZ / hz; + assert(src_clk_div < 128); + + rk_clrsetreg(&cru->clksel_con[24], + CLK_PWM_PLL_SEL_MASK | CLK_PWM_DIV_CON_MASK, + CLK_PWM_PLL_SEL_GPLL << CLK_PWM_PLL_SEL_SHIFT | + (src_clk_div - 1) << CLK_PWM_DIV_CON_SHIFT); + + return rk3328_spi_get_clk(cru); +} + static ulong rk3328_clk_get_rate(struct clk *clk) { struct rk3328_clk_priv *priv = dev_get_priv(clk->dev); @@ -581,6 +606,9 @@ static ulong rk3328_clk_get_rate(struct clk *clk) case SCLK_SARADC: rate = rk3328_saradc_get_clk(priv->cru); break; + case SCLK_SPI: + rate = rk3328_spi_get_clk(priv->cru); + break; default: return -ENOENT; } @@ -617,6 +645,9 @@ static ulong rk3328_clk_set_rate(struct clk *clk, ulong rate) case SCLK_SARADC: ret = rk3328_saradc_set_clk(priv->cru, rate); break; + case SCLK_SPI: + ret = rk3328_spi_set_clk(priv->cru, rate); + break; case DCLK_LCDC: case SCLK_PDM: case SCLK_RTC32K: diff --git a/drivers/spi/rk_spi.c b/drivers/spi/rk_spi.c index 833cb04922..0495e04945 100644 --- a/drivers/spi/rk_spi.c +++ b/drivers/spi/rk_spi.c @@ -545,7 +545,9 @@ const struct rockchip_spi_params rk3399_spi_params = { };
static const struct udevice_id rockchip_spi_ids[] = { + { .compatible = "rockchip,rk3066-spi" }, { .compatible = "rockchip,rk3288-spi" }, + { .compatible = "rockchip,rk3328-spi" }, { .compatible = "rockchip,rk3368-spi", .data = (ulong)&rk3399_spi_params }, { .compatible = "rockchip,rk3399-spi",
Add SPI Flash support for the PINE64 Rock64 board
Initial SPI Flash support.
Okay?
arch/arm/dts/rk3328-rock64-u-boot.dtsi | 6 ++++++ configs/rock64-rk3328_defconfig | 2 ++ 2 files changed, 8 insertions(+)
diff --git a/arch/arm/dts/rk3328-rock64-u-boot.dtsi b/arch/arm/dts/rk3328-rock64-u-boot.dtsi index f076075076..7340ef95f1 100644 --- a/arch/arm/dts/rk3328-rock64-u-boot.dtsi +++ b/arch/arm/dts/rk3328-rock64-u-boot.dtsi @@ -46,3 +46,9 @@ &vcc_sd { u-boot,dm-spl; }; + +&spi0 { + spi_flash: spiflash@0 { + u-boot,dm-pre-reloc; + }; +}; diff --git a/configs/rock64-rk3328_defconfig b/configs/rock64-rk3328_defconfig index f123826358..0a51e51a0c 100644 --- a/configs/rock64-rk3328_defconfig +++ b/configs/rock64-rk3328_defconfig @@ -97,3 +97,5 @@ CONFIG_SPL_TINY_MEMSET=y CONFIG_TPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y CONFIG_SMBIOS_MANUFACTURER="pine64" +CONFIG_ROCKCHIP_SPI=y +CONFIG_SPI_FLASH_GIGADEVICE=y
Hi Johannes,
The changes look good to me, but you need to split the patch into 3 patches:
- rk3328 clock driver;
- rkspi driver;
- rk3328-u-boot.dtsi
BTW: the patch no need reply-to previous mail, you can make a new thread.
Thanks,
- Kever
Okay?
spi0 = &spi0;
chosen {
+&spi0 {
- u-boot,dm-pre-reloc;
- u32 div, val;
- val = readl(&cru->clksel_con[24]);
- div = (val & CLK_SPI_DIV_CON_MASK) >> CLK_SPI_DIV_CON_SHIFT;
- return DIV_TO_RATE(OSC_HZ, div);
- u32 src_clk_div;
- src_clk_div = GPLL_HZ / hz;
- assert(src_clk_div < 128);
- rk_clrsetreg(&cru->clksel_con[24],
- return rk3328_spi_get_clk(cru);
- static ulong rk3328_clk_get_rate(struct clk *clk) { struct rk3328_clk_priv *priv = dev_get_priv(clk->dev);
- case SCLK_SPI:
default: return -ENOENT; }break;
- case SCLK_SPI:
case DCLK_LCDC: case SCLK_PDM: case SCLK_RTC32K:break;
- { .compatible = "rockchip,rk3066-spi" }, { .compatible = "rockchip,rk3288-spi" },
- { .compatible = "rockchip,rk3328-spi" }, { .compatible = "rockchip,rk3368-spi", .data = (ulong)&rk3399_spi_params }, { .compatible = "rockchip,rk3399-spi",
Hi Johannes,
Do you have plan to update for this patch?
Thanks,
- Kever
On 2020/7/8 下午6:08, Kever Yang wrote:
Hi Johannes,
rkspi driver;
rk3328-u-boot.dtsi
Thanks,
- Kever
Okay?
diff --git a/arch/arm/dts/rk3328-u-boot.dtsi b/arch/arm/dts/rk3328-u-boot.dtsi index c69e13e11e..c980daae99 100644 --- a/arch/arm/dts/rk3328-u-boot.dtsi +++ b/arch/arm/dts/rk3328-u-boot.dtsi @@ -7,6 +7,7 @@ aliases { mmc0 = &emmc; mmc1 = &sdmmc; + spi0 = &spi0; }; chosen { @@ -66,3 +67,7 @@ &usb20_otg { hnp-srp-disable; };
+&spi0 { + u-boot,dm-pre-reloc; +}; diff --git a/drivers/clk/rockchip/clk_rk3328.c b/drivers/clk/rockchip/clk_rk3328.c index 02d3b08efa..bd95ab832b 100644 --- a/drivers/clk/rockchip/clk_rk3328.c +++ b/drivers/clk/rockchip/clk_rk3328.c @@ -555,6 +555,31 @@ static ulong rk3328_saradc_set_clk(struct rk3328_cru *cru, uint hz) return rk3328_saradc_get_clk(cru); } +static ulong rk3328_spi_get_clk(struct rk3328_cru *cru) +{ + u32 div, val;
static ulong rk3328_clk_get_rate(struct clk *clk) { struct rk3328_clk_priv *priv = dev_get_priv(clk->dev); @@ -581,6 +606,9 @@ static ulong rk3328_clk_get_rate(struct clk *clk) case SCLK_SARADC: rate = rk3328_saradc_get_clk(priv->cru); break; + case SCLK_SPI: + rate = rk3328_spi_get_clk(priv->cru); + break; default: return -ENOENT; } @@ -617,6 +645,9 @@ static ulong rk3328_clk_set_rate(struct clk *clk, ulong rate) case SCLK_SARADC: ret = rk3328_saradc_set_clk(priv->cru, rate); break; + case SCLK_SPI: + ret = rk3328_spi_set_clk(priv->cru, rate); + break; case DCLK_LCDC: case SCLK_PDM: case SCLK_RTC32K: diff --git a/drivers/spi/rk_spi.c b/drivers/spi/rk_spi.c index 833cb04922..0495e04945 100644 --- a/drivers/spi/rk_spi.c +++ b/drivers/spi/rk_spi.c @@ -545,7 +545,9 @@ const struct rockchip_spi_params rk3399_spi_params = { }; static const struct udevice_id rockchip_spi_ids[] = { + { .compatible = "rockchip,rk3066-spi" }, { .compatible = "rockchip,rk3288-spi" }, + { .compatible = "rockchip,rk3328-spi" }, { .compatible = "rockchip,rk3368-spi", .data = (ulong)&rk3399_spi_params }, { .compatible = "rockchip,rk3399-spi",
Hi Kever,
On 18.07.20 at 05:02, Kever Yang wrote:
Hi Johannes,
I think this thread is obsolete. You have already applied the improved two patch (RK3328, PINE64 Rock64) series later in a new thread.
Many thanks for the apply.
Kind regards,
Johannes K.
Thanks,
- Kever
Hi Johannes,
rkspi driver;
rk3328-u-boot.dtsi
Thanks,
- Kever
Okay?
Johannes Krottmayer
Kamal R. Prasad
Kever Yang
Peter Robinson
