[GIT PULL] Please pull u-boot-imx-master-20240415
Hi Tom,
Please pull from u-boot-imx/master, thanks.
The following changes since commit b03b49046af5dfca599d2ce8f0aafed89b97aa91:
Merge https://source.denx.de/u-boot/custodians/u-boot-usb (2024-04-14 15:58:31 -0600)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-master-20240415
for you to fetch changes up to 8ecb0931940cc19728d686b9dba06585f4d93709:
clk: imx93: fix anatop base (2024-04-15 08:09:41 -0300)
u-boot-imx-master-20240415 --------------------------
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/20348
- Update the imx_rgpio2p to only access one address as per the dt-schema. - Remove unused imx9_cpu.c file. - Only use the LPUART ipg clk for i.MX7ULP. - Use the correct anatop base for accessing the PLL clocks on i.MX93. ---------------------------------------------------------------- Peng Fan (4): gpio: imx_rgpio2p: support one address serial: lpuart: use ipg clk for i.MX7ULP cpu: drop imx9_cpu clk: imx93: fix anatop base
drivers/clk/imx/clk-imx93.c | 2 +- drivers/cpu/imx9_cpu.c | 224 ----------------------------------------- drivers/gpio/imx_rgpio2p.c | 42 +++++++- drivers/serial/serial_lpuart.c | 42 +++++--- 4 files changed, 65 insertions(+), 245 deletions(-) delete mode 100644 drivers/cpu/imx9_cpu.c
On Mon, Apr 15, 2024 at 09:33:40AM -0300, Fabio Estevam wrote:
Hi Tom,
Fabio Estevam
