[PATCH v2] net: zynq: Add support for PHY configuration in SGMII mode
SGMII configuration depends on proper GT setting that's why when node has phys property call PSGTR driver to configure it properly.
Changes in v2: - Handle also cases where phy reference doesn't exist which means that u-boot doesn't need to configure it (configured via psu_init for example) - Error out where reference exists but driver is not compiled in - reported by Sean
drivers/net/zynq_gem.c | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index 5cbe8d28304b..ac658cd6b5e9 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -12,6 +12,7 @@ #include <common.h> #include <cpu_func.h> #include <dm.h> +#include <generic-phy.h> #include <log.h> #include <net.h> #include <netdev.h> @@ -716,6 +717,24 @@ static int zynq_gem_probe(struct udevice *dev) struct zynq_gem_priv *priv = dev_get_priv(dev); int ret;
+ if (priv->interface == PHY_INTERFACE_MODE_SGMII) { + struct phy phy; + + ret = generic_phy_get_by_index(dev, 0, &phy); + if (!ret) { + ret = generic_phy_init(&phy); + if (ret) + return ret; + + ret = generic_phy_power_on(&phy); + if (ret) + return ret; + } else if (ret != -ENOENT) { + debug("could not get phy (err %d)\n", ret); + return ret; + } + } + ret = zynq_gem_reset_init(dev); if (ret) return ret;
Changes in v2:
struct phy phy;
if (!ret) {
if (ret)
return ret;
if (ret)
return ret;
return ret;
-- 2.34.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Changes in v2:
- if (priv->interface == PHY_INTERFACE_MODE_SGMII) {
struct phy phy;
if (!ret) {
if (ret)
return ret;
if (ret)
return ret;
return ret;
- ret = zynq_gem_reset_init(dev); if (ret) return ret;
Reviewed-by: Sean Anderson sean.anderson@seco.com
Ășt 14. 12. 2021 v 13:42 odesĂlatel Michal Simek michal.simek@xilinx.com napsal:
Changes in v2:
struct phy phy;
if (!ret) {
if (ret)
return ret;
if (ret)
return ret;
return ret;
-- 2.34.1
Please ignore this v2. I need to send v3 because there must be a reset between init and power on. I will send a new version on phy driver with this function.
Thanks, Michal
Michal Simek
Michal Simek
Ramon Fried
Sean Anderson
