[U-Boot] [PATCH ARM 3/4] s3c24x0 code-style clean-up
Changes the s3c24x0 files to meet the code style requirements.
Signed-off-by: Kevin Morfitt kevin.morfitt@fearnside-systems.co.uk ---
checkpatch.pl reports no errors.
board/MAI/AmigaOneG3SE/video.c | 1 - board/mpl/common/common_util.h | 1 + board/mpl/common/flash.c | 1 - board/mpl/vcma9/cmd_vcma9.c | 9 - board/mpl/vcma9/vcma9.c | 27 ++-- board/mpl/vcma9/vcma9.h | 6 +- board/samsung/smdk2400/smdk2400.c | 12 +- board/sbc2410x/sbc2410x.c | 6 +- board/trab/auto_update.c | 30 +--- board/trab/cmd_trab.c | 213 +++++++++++------------- board/trab/rs485.c | 16 +- board/trab/trab.c | 43 ++--- board/trab/trab.h | 38 +++++ board/trab/trab_fkt.c | 331 ++++++++++++++++--------------------- board/trab/tsc2000.c | 12 +- board/trab/tsc2000.h | 1 + board/trab/vfd.c | 70 ++++---- common/cmd_version.c | 2 - common/cmd_vfd.c | 2 - common/main.c | 5 +- drivers/i2c/s3c24x0_i2c.c | 71 ++++----- drivers/video/cfb_console.c | 1 - include/common.h | 14 ++ lib_generic/display_options.c | 2 - 24 files changed, 418 insertions(+), 496 deletions(-) create mode 100644 board/trab/trab.h
diff --git a/board/MAI/AmigaOneG3SE/video.c b/board/MAI/AmigaOneG3SE/video.c index e24e28b..e8d1f64 100644 --- a/board/MAI/AmigaOneG3SE/video.c +++ b/board/MAI/AmigaOneG3SE/video.c @@ -478,7 +478,6 @@ void video_easteregg(void) #endif
extern block_dev_desc_t * ide_get_dev(int dev); -extern char version_string[];
void video_banner(void) { diff --git a/board/mpl/common/common_util.h b/board/mpl/common/common_util.h index 29cd14f..9978ce4 100644 --- a/board/mpl/common/common_util.h +++ b/board/mpl/common/common_util.h @@ -42,4 +42,5 @@ void check_env(void); void doc_init (void); #endif
+int do_mplcommon(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); #endif /* _COMMON_UTIL_H_ */ diff --git a/board/mpl/common/flash.c b/board/mpl/common/flash.c index 682f0e7..2e40610 100644 --- a/board/mpl/common/flash.c +++ b/board/mpl/common/flash.c @@ -159,7 +159,6 @@ unsigned long flash_init (void) #if !defined(CONFIG_PATI) unsigned long size_b1,flashcr,size_reg; int mode; - extern char version_string; char *p = &version_string;
/* Since we are relocated, we can set-up the CS finally */ diff --git a/board/mpl/vcma9/cmd_vcma9.c b/board/mpl/vcma9/cmd_vcma9.c index 49558d8..10dcd8e 100644 --- a/board/mpl/vcma9/cmd_vcma9.c +++ b/board/mpl/vcma9/cmd_vcma9.c @@ -43,15 +43,6 @@ static uchar cs8900_chksum(ushort data)
DECLARE_GLOBAL_DATA_PTR;
-extern void print_vcma9_info(void); -extern int vcma9_cantest(int); -extern int vcma9_nandtest(void); -extern int vcma9_nanderase(void); -extern int vcma9_nandread(ulong); -extern int vcma9_nandwrite(ulong); -extern int vcma9_dactest(int); -extern int do_mplcommon(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); - /* ------------------------------------------------------------------------- */
int do_vcma9(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) diff --git a/board/mpl/vcma9/vcma9.c b/board/mpl/vcma9/vcma9.c index 9a7c0fa..5401664 100644 --- a/board/mpl/vcma9/vcma9.c +++ b/board/mpl/vcma9/vcma9.c @@ -137,22 +137,19 @@ int board_init(void) * NAND flash initialization. */ #if defined(CONFIG_CMD_NAND) -extern ulong -nand_probe(ulong physadr); - - static inline void NF_Reset(void) { int i;
NF_SetCE(NFCE_LOW); - NF_Cmd(0xFF); /* reset command */ - for (i = 0; i < 10; i++); /* tWB = 100ns. */ - NF_WaitRB(); /* wait 200~500us; */ + NF_Cmd(0xFF); /* reset command */ + /* tWB = 100ns. */ + for (i = 0; i < 10; i++) + /* delay */; + NF_WaitRB(); /* wait 200~500us; */ NF_SetCE(NFCE_HIGH); }
- static inline void NF_Init(void) { #define TACLS 0 @@ -187,36 +184,36 @@ static u8 Get_PLD_ID(void) { VCMA9_PLD * const pld = VCMA9_get_base_PLD();
- return (pld->ID); + return pld->ID; }
static u8 Get_PLD_BOARD(void) { VCMA9_PLD * const pld = VCMA9_get_base_PLD();
- return (pld->BOARD); + return pld->BOARD; }
static u8 Get_PLD_SDRAM(void) { VCMA9_PLD * const pld = VCMA9_get_base_PLD();
- return (pld->SDRAM); + return pld->SDRAM; }
static u8 Get_PLD_Version(void) { - return ((Get_PLD_ID() >> 4) & 0x0F); + return (Get_PLD_ID() >> 4) & 0x0F; }
static u8 Get_PLD_Revision(void) { - return (Get_PLD_ID() & 0x0F); + return Get_PLD_ID() & 0x0F; }
static uchar Get_Board_PCB(void) { - return (((Get_PLD_BOARD() >> 4) & 0x03) + 'A'); + return ((Get_PLD_BOARD() >> 4) & 0x03) + 'A'; }
static u8 Get_SDRAM_ChipNr(void) @@ -307,7 +304,7 @@ int checkboard(void) s[5] = 0; Show_VCMA9_Info(s, &s[6]); } - return (0); + return 0; }
int last_stage_init(void) diff --git a/board/mpl/vcma9/vcma9.h b/board/mpl/vcma9/vcma9.h index e1ec1fe..adc7673 100644 --- a/board/mpl/vcma9/vcma9.h +++ b/board/mpl/vcma9/vcma9.h @@ -27,7 +27,8 @@
#include <asm/arch/s3c24x0_cpu.h>
-extern int mem_test(unsigned long start, unsigned long ramsize, int mode); +int mem_test(unsigned long start, unsigned long ramsize, int mode); +int vcma9_cantest(int); void print_vcma9_info(void);
#if defined(CONFIG_CMD_NAND) @@ -81,7 +82,8 @@ static inline void NF_WaitRB(void) { struct s3c2410_nand * const nand = s3c2410_get_base_nand();
- while (!(nand->NFSTAT & (1 << 0))); + while (!(nand->NFSTAT & (1 << 0))) + /* Wait */; }
static inline void NF_Write(u8 data) diff --git a/board/samsung/smdk2400/smdk2400.c b/board/samsung/smdk2400/smdk2400.c index 5825ce9..a1b0e0c 100644 --- a/board/samsung/smdk2400/smdk2400.c +++ b/board/samsung/smdk2400/smdk2400.c @@ -33,18 +33,13 @@ DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_MODEM_SUPPORT static int key_pressed(void); -int mdm_init (bd_t *); -extern void disable_putc(void); -extern void enable_putc(void); -extern int hwflow_onoff(int); -extern int do_mdm_init; /* defined in common/main.c */ #endif /* CONFIG_MODEM_SUPPORT */
/* * Miscellaneous platform dependent initialisations */
-int board_init (void) +int board_init(void) { struct s3c24x0_clock_power * const clk_power = s3c24x0_get_base_clock_power(); @@ -93,7 +88,7 @@ int board_init (void) return 0; }
-int dram_init (void) +int dram_init(void) { gd->bd->bi_dram[0].start = PHYS_SDRAM_1; gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; @@ -105,9 +100,8 @@ int dram_init (void) static int key_pressed(void) { int rc; - if (1) { /* check for button push here, now just return 1 */ + if (1) /* check for button push here, now just return 1 */ rc = 1; - }
return rc; } diff --git a/board/sbc2410x/sbc2410x.c b/board/sbc2410x/sbc2410x.c index b7bbcf2..548852f 100644 --- a/board/sbc2410x/sbc2410x.c +++ b/board/sbc2410x/sbc2410x.c @@ -86,7 +86,7 @@ int board_init(void) clk_power->MPLLCON = ((M_MDIV << 12) + (M_PDIV << 4) + M_SDIV);
/* some delay between MPLL and UPLL */ - delay (4000); + delay(4000);
/* configure UPLL */ clk_power->UPLLCON = ((U_M_MDIV << 12) + (U_M_PDIV << 4) + U_M_SDIV); @@ -136,7 +136,6 @@ int dram_init(void) }
#if defined(CONFIG_CMD_NAND) -extern ulong nand_probe(ulong physadr);
static inline void NF_Reset(void) { @@ -144,7 +143,8 @@ static inline void NF_Reset(void)
NF_SetCE(NFCE_LOW); NF_Cmd(0xFF); /* reset command */ - for (i = 0; i < 10; i++); /* tWB = 100ns. */ + for (i = 0; i < 10; i++) + /* tWB = 100ns. */; NF_WaitRB(); /* wait 200~500us; */ NF_SetCE(NFCE_HIGH); } diff --git a/board/trab/auto_update.c b/board/trab/auto_update.c index bcb8505..4f30c23 100644 --- a/board/trab/auto_update.c +++ b/board/trab/auto_update.c @@ -27,6 +27,12 @@ #include <image.h> #include <asm/byteorder.h> #include <usb.h> +#include <fat.h> +#include <i2c.h> +#include <flash.h> +#include <asm/arch/s3c24x0_cpu.h> +#include "tsc2000.h" +#include "trab.h"
#ifdef CONFIG_SYS_HUSH_PARSER #include <hush.h> @@ -187,24 +193,6 @@ struct flash_layout aufl_layout[AU_MAXFILES - 3] = { \ /* the app is the largest image */ #define MAX_LOADSZ ausize[IDX_APP]
-/* externals */ -extern int fat_register_device(block_dev_desc_t *, int); -extern int file_fat_detectfs(void); -extern long file_fat_read(const char *, void *, unsigned long); -extern int i2c_read (unsigned char, unsigned int, int , unsigned char* , int); -extern int i2c_write (uchar, uint, int , uchar* , int); -#ifdef CONFIG_VFD -extern int trab_vfd (ulong); -extern int transfer_pic(unsigned char, unsigned char *, int, int); -#endif -extern int flash_sect_erase(ulong, ulong); -extern int flash_sect_protect (int, ulong, ulong); -extern int flash_write (char *, ulong, ulong); -/* change char* to void* to shutup the compiler */ -extern int i2c_write_multiple (uchar, uint, int, void *, int); -extern int i2c_read_multiple (uchar, uint, int, void *, int); -extern int u_boot_hush_start(void); - int au_check_cksum_valid(int idx, long nbytes) { @@ -442,15 +430,15 @@ au_update_eeprom(int idx) /* write the time field into EEPROM */ off = auee_off[idx].time; val = image_get_time (hdr); - i2c_write_multiple(0x54, off, 1, &val, sizeof(val)); + i2c_write_multiple(0x54, off, 1, (uchar *)&val, sizeof(val)); /* write the size field into EEPROM */ off = auee_off[idx].size; val = image_get_data_size (hdr); - i2c_write_multiple(0x54, off, 1, &val, sizeof(val)); + i2c_write_multiple(0x54, off, 1, (uchar *)&val, sizeof(val)); /* write the dcrc field into EEPROM */ off = auee_off[idx].dcrc; val = image_get_dcrc (hdr); - i2c_write_multiple(0x54, off, 1, &val, sizeof(val)); + i2c_write_multiple(0x54, off, 1, (uchar *)&val, sizeof(val)); /* enable the power switch */ *CPLD_VFD_BK &= ~POWER_OFF; return 0; diff --git a/board/trab/cmd_trab.c b/board/trab/cmd_trab.c index bba9084..2c31d50 100644 --- a/board/trab/cmd_trab.c +++ b/board/trab/cmd_trab.c @@ -27,6 +27,9 @@ #include <command.h> #include <asm/arch/s3c24x0_cpu.h> #include <rtc.h> +#include <i2c.h> +#include "tsc2000.h" +#include "trab.h"
/* * TRAB board specific commands. Especially commands for burn-in and function @@ -100,23 +103,14 @@
/* misc */
-/* externals */ -extern int memory_post_tests(unsigned long start, unsigned long size); -extern int i2c_write(uchar, uint, int, uchar *, int); -extern int i2c_read(uchar, uint, int , uchar *, int); -extern void tsc2000_reg_init(void); -extern s32 tsc2000_contact_temp(void); -extern void tsc2000_spi_init(void); - /* function declarations */ -int do_dip(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); -int do_vcc5v(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); -int do_burn_in(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); -int do_contact_temp(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); -int do_burn_in_status(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); -int i2c_write_multiple(uchar chip, uint addr, int alen, uchar *buffer, int len); -int i2c_read_multiple(uchar chip, uint addr, int alen, uchar *buffer, int len); -int do_temp_log(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); +static int do_dip(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); +static int do_vcc5v(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); +static int do_burn_in(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); +static int do_contact_temp(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); +static int do_burn_in_status(cmd_tbl_t *cmdtp, int flag, int argc, + char *argv[]); +static int do_temp_log(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]);
/* helper functions */ static void adc_init(void); @@ -177,18 +171,18 @@ int do_burn_in(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) if (global_vars_write_to_eeprom() != 0) { printf("%s: error writing global_vars to eeprom\n", __FUNCTION__); - return (1); + return 1; }
if (read_max_cycles() != 0) { printf("%s: error reading max_cycles from eeprom\n", __FUNCTION__); - return (1); + return 1; }
if (max_cycles == 0) { printf("%s: error, burn in max_cycles = 0\n", __FUNCTION__); - return (1); + return 1; }
status = 0; @@ -246,10 +240,10 @@ int do_burn_in(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
if (status == 0) { led_blink(); /* endless loop!! */ - return (0); + return 0; } else { led_set(0); - return (1); + return 1; } }
@@ -269,9 +263,9 @@ int do_dip(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 1; }
- if ((dip = read_dip()) == -1) { + dip = read_dip(); + if (dip == -1) return 1; - }
for (i = 0; i < 4; i++) { if ((dip & (1 << i)) == 0) @@ -299,9 +293,9 @@ int do_vcc5v(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 1; }
- if ((vcc5v = read_vcc5v()) == -1) { - return (1); - } + vcc5v = read_vcc5v(); + if (vcc5v == -1) + return 1;
printf("%d", (vcc5v / 1000)); printf(".%d", (vcc5v % 1000) / 100); @@ -345,30 +339,24 @@ int do_burn_in_status(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) }
if (i2c_read_multiple(I2C_EEPROM_DEV_ADDR, EE_ADDR_STATUS, 1, - (unsigned char *)&status, 1)) { - return (1); - } + (unsigned char *)&status, 1)) + return 1; if (i2c_read_multiple(I2C_EEPROM_DEV_ADDR, EE_ADDR_PASS_CYCLES, 1, - (unsigned char *)&pass_cycles, 2)) { - return (1); - } + (unsigned char *)&pass_cycles, 2)) + return 1; if (i2c_read_multiple(I2C_EEPROM_DEV_ADDR, EE_ADDR_FIRST_ERROR_CYCLE, - 1, (unsigned char *)&first_error_cycle, 2)) { - return (1); - } + 1, (unsigned char *)&first_error_cycle, 2)) + return 1; if (i2c_read_multiple(I2C_EEPROM_DEV_ADDR, EE_ADDR_FIRST_ERROR_NUM, - 1, (unsigned char *) &first_error_num, 1)) { - return (1); - } + 1, (unsigned char *)&first_error_num, 1)) + return 1; if (i2c_read_multiple(I2C_EEPROM_DEV_ADDR, EE_ADDR_FIRST_ERROR_NAME, 1, (unsigned char *)first_error_name, - sizeof(first_error_name))) { - return (1); - } + sizeof(first_error_name))) + return 1;
- if (read_max_cycles() != 0) { - return (1); - } + if (read_max_cycles() != 0) + return 1;
printf("max_cycles = %d\n", max_cycles); printf("status = %d\n", status); @@ -406,10 +394,11 @@ static int read_dip(void)
for (i = 7; i > 3; i--) {
- if ((adc_val = adc_read(i)) == -1) { + adc_val = adc_read(i); + if (adc_val == -1) { printf("%s: Channel %d could not be read\n", __FUNCTION__, i); - return (-1); + return -1; }
/* @@ -420,7 +409,7 @@ static int read_dip(void) if (adc_val < 368) result |= (1 << (i - 4)); } - return (result); + return result; }
static int read_vcc5v(void) @@ -429,9 +418,10 @@ static int read_vcc5v(void)
/* VCC5V is connected to channel 2 */
- if ((result = adc_read(2)) == -1) { + result = adc_read(2); + if (result == -1) { printf("%s: VCC5V could not be read\n", __FUNCTION__); - return (-1); + return -1; } /* * Calculate voltage value. Split in two parts because there is no @@ -440,41 +430,42 @@ static int read_vcc5v(void) */ result = result * 10 * 1000 / 1023; /* result in mV */
static int test_dip(void) { static int first_run = 1; static int first_dip; + int this_dip;
if (first_run) { - if ((first_dip = read_dip()) == -1) { - return (1); - } + first_dip = read_dip(); + if (first_dip == -1) + return 1; first_run = 0; debug("%s: first_dip=%d\n", __FUNCTION__, first_dip); } - if (first_dip != read_dip()) { - return (1); - } else { - return (0); - } + this_dip = read_dip(); + if (first_dip != this_dip) + return 1; + else + return 0; }
static int test_vcc5v(void) { int vcc5v;
if ((vcc5v > VCC5V_MAX) || (vcc5v < VCC5V_MIN)) { printf("%s: vcc5v[V/100]=%d\n", __FUNCTION__, vcc5v); - return (1); + return 1; } else { - return (0); + return 0; } }
@@ -495,16 +486,15 @@ static int test_rotary_switch(void) debug("%s: first_rs=%d\n", __FUNCTION__, first_rs); }
- if (first_rs != ((*CPLD_ROTARY_SWITCH >> 16) & 0x7)) { - return (1); - } else { - return (0); - } + if (first_rs != ((*CPLD_ROTARY_SWITCH >> 16) & 0x7)) + return 1; + else + return 0; }
static int test_sram(void) { - return (memory_post_tests(SRAM_ADDR, SRAM_SIZE)); + return memory_post_tests(SRAM_ADDR, SRAM_SIZE); }
static int test_eeprom(void) @@ -515,14 +505,12 @@ static int test_eeprom(void) /* write test string 1, read back and verify */ if (i2c_write_multiple(I2C_EEPROM_DEV_ADDR, EE_ADDR_TEST, 1, (unsigned char *)EEPROM_TEST_STRING_1, - sizeof(EEPROM_TEST_STRING_1))) { - return (1); - } + sizeof(EEPROM_TEST_STRING_1))) + return 1;
if (i2c_read_multiple(I2C_EEPROM_DEV_ADDR, EE_ADDR_TEST, 1, - temp, sizeof(EEPROM_TEST_STRING_1))) { - return (1); - } + temp, sizeof(EEPROM_TEST_STRING_1))) + return 1;
if (strcmp((char *)temp, EEPROM_TEST_STRING_1) != 0) { result = 1; @@ -533,14 +521,12 @@ static int test_eeprom(void) if (result == 0) { if (i2c_write_multiple(I2C_EEPROM_DEV_ADDR, EE_ADDR_TEST, 1, (unsigned char *)EEPROM_TEST_STRING_2, - sizeof(EEPROM_TEST_STRING_2))) { - return (1); - } + sizeof(EEPROM_TEST_STRING_2))) + return 1;
if (i2c_read_multiple(I2C_EEPROM_DEV_ADDR, EE_ADDR_TEST, 1, - temp, sizeof(EEPROM_TEST_STRING_2))) { - return (1); - } + temp, sizeof(EEPROM_TEST_STRING_2))) + return 1;
if (strcmp((char *)temp, EEPROM_TEST_STRING_2) != 0) { result = 1; @@ -548,7 +534,7 @@ static int test_eeprom(void) __FUNCTION__, temp); } } - return (result); + return result; }
static int test_contact_temp(void) @@ -559,9 +545,9 @@ static int test_contact_temp(void)
if ((contact_temp < MIN_CONTACT_TEMP) || (contact_temp > MAX_CONTACT_TEMP)) - return (1); + return 1; else - return (0); + return 0; }
int i2c_write_multiple(uchar chip, uint addr, int alen, @@ -572,24 +558,18 @@ int i2c_write_multiple(uchar chip, uint addr, int alen, if (alen != 1) { printf("%s: addr len other than 1 not supported\n", __FUNCTION__); - return (1); + return 1; }
for (i = 0; i < len; i++) { if (i2c_write(chip, addr+i, alen, buffer+i, 1)) { printf("%s: could not write to i2c device %d" ", addr %d\n", __FUNCTION__, chip, addr); - return (1); + return 1; } -#if 0 - printf("chip=%#x, addr+i=%#x+%d=%p, alen=%d, *buffer+i=" - "%#x+%d=%p="%.1s"\n", chip, addr, i, addr+i, - alen, buffer, i, buffer+i, buffer+i); -#endif - udelay(30000); } - return (0); + return 0; }
int i2c_read_multiple(uchar chip, uint addr, int alen, @@ -600,17 +580,17 @@ int i2c_read_multiple(uchar chip, uint addr, int alen, if (alen != 1) { printf("%s: addr len other than 1 not supported\n", __FUNCTION__); - return (1); + return 1; }
for (i = 0; i < len; i++) { if (i2c_read(chip, addr+i, alen, buffer+i, 1)) { printf("%s: could not read from i2c device %#x" ", addr %d\n", __FUNCTION__, chip, addr); - return (1); + return 1; } } - return (0); + return 0; }
static int adc_read(unsigned int channel) @@ -653,7 +633,7 @@ static int adc_read(unsigned int channel) */ udelay(1000);
static void adc_init(void) @@ -729,27 +709,22 @@ static void sdelay(unsigned long seconds) static int global_vars_write_to_eeprom(void) { if (i2c_write_multiple(I2C_EEPROM_DEV_ADDR, EE_ADDR_STATUS, 1, - (unsigned char *) &status, 1)) { - return (1); - } + (unsigned char *) &status, 1)) + return 1; if (i2c_write_multiple(I2C_EEPROM_DEV_ADDR, EE_ADDR_PASS_CYCLES, 1, - (unsigned char *) &pass_cycles, 2)) { - return (1); - } + (unsigned char *) &pass_cycles, 2)) + return 1; if (i2c_write_multiple(I2C_EEPROM_DEV_ADDR, EE_ADDR_FIRST_ERROR_CYCLE, - 1, (unsigned char *) &first_error_cycle, 2)) { - return (1); - } + 1, (unsigned char *) &first_error_cycle, 2)) + return 1; if (i2c_write_multiple(I2C_EEPROM_DEV_ADDR, EE_ADDR_FIRST_ERROR_NUM, - 1, (unsigned char *) &first_error_num, 1)) { - return (1); - } + 1, (unsigned char *) &first_error_num, 1)) + return 1; if (i2c_write_multiple(I2C_EEPROM_DEV_ADDR, EE_ADDR_FIRST_ERROR_NAME, 1, (unsigned char *) first_error_name, - sizeof(first_error_name))) { - return (1); - } - return (0); + sizeof(first_error_name))) + return 1; + return 0; }
static void global_vars_init(void) @@ -796,16 +771,15 @@ static void test_function_table_init(void) static int read_max_cycles(void) { if (i2c_read_multiple(I2C_EEPROM_DEV_ADDR, EE_ADDR_MAX_CYCLES, 1, - (unsigned char *) &max_cycles, 2) != 0) { - return (1); - } + (unsigned char *) &max_cycles, 2) != 0) + return 1;
static int dummy(void) { - return (0); + return 0; }
int do_temp_log(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) @@ -821,9 +795,8 @@ int do_temp_log(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 1; }
- if (argc > 1) { + if (argc > 1) delay = simple_strtoul(argv[1], NULL, 10); - }
tsc2000_spi_init(); while (1) { diff --git a/board/trab/rs485.c b/board/trab/rs485.c index 2dfd202..79f8cc4 100644 --- a/board/trab/rs485.c +++ b/board/trab/rs485.c @@ -62,7 +62,8 @@ static void rs485_setbrg(void) uart->UCON = 0x245; uart->UBRDIV = reg;
- for (i = 0; i < 100; i++); + for (i = 0; i < 100; i++) + ; }
static void rs485_cfgio(void) @@ -91,7 +92,7 @@ int rs485_init(void) rs485_cfgio(); rs485_setbrg();
/* @@ -103,8 +104,8 @@ int rs485_getc(void) { struct s3c24x0_uart * const uart = s3c24x0_get_base_uart(UART_NR);
- /* wait for character to arrive */ - while (!(uart->UTRSTAT & 0x1)); + while (!(uart->UTRSTAT & 0x1)) + /* wait for character to arrive */;
return uart->URXH & 0xff; } @@ -116,8 +117,8 @@ void rs485_putc(const char c) { struct s3c24x0_uart * const uart = s3c24x0_get_base_uart(UART_NR);
- /* wait for room in the tx FIFO */ - while (!(uart->UTRSTAT & 0x2)); + while (!(uart->UTRSTAT & 0x2)) + /* wait for room in the tx FIFO */;
uart->UTXH = c;
@@ -138,9 +139,8 @@ int rs485_tstc(void)
void rs485_puts(const char *s) { - while (*s) { + while (*s) rs485_putc(*s++); - } }
/* diff --git a/board/trab/trab.c b/board/trab/trab.c index 0175d77..80016bc 100644 --- a/board/trab/trab.c +++ b/board/trab/trab.c @@ -28,6 +28,7 @@ #include <malloc.h> #include <asm/arch/s3c24x0_cpu.h> #include <command.h> +#include "trab.h"
@@ -40,8 +41,6 @@ static void tsc2000_set_brightness(void); #endif #ifdef CONFIG_MODEM_SUPPORT static int key_pressed(void); -extern void disable_putc(void); -extern int do_mdm_init; /* defined in common/main.c */
/* * We need a delay of at least 500 us after turning on the VFD clock @@ -67,9 +66,6 @@ static void udelay_no_timer(int usec)
int board_init() { -#if defined(CONFIG_VFD) - extern int vfd_init_clocks(void); -#endif struct s3c24x0_clock_power * const clk_power = s3c24x0_get_base_clock_power(); struct s3c24x0_gpio * const gpio = s3c24x0_get_base_gpio(); @@ -93,12 +89,12 @@ int board_init() gpio->PBUP = 0xffff; /* INPUT nCTS0 nRTS0 TXD[1] TXD[0] RXD[1] RXD[0] */ /* 00, 10, 10, 10, 10, 10, 10 */ - gpio->PFCON = (2 << 0) | (2 << 2) | (2 << 4) | \ - (2 << 6) | (2 << 8) | (2 << 10); + gpio->PFCON = (2 << 0) | (2 << 2) | (2 << 4) | + (2 << 6) | (2 << 8) | (2 << 10); #ifdef CONFIG_HWFLOW /* do not pull up RXD0, RXD1, TXD0, TXD1, CTS0, RTS0 */ - gpio->PFUP = (1 << 0) | (1 << 1) | (1 << 2) | \ - (1 << 3) | (1 << 4) | (1 << 5); + gpio->PFUP = (1 << 0) | (1 << 1) | (1 << 2) | + (1 << 3) | (1 << 4) | (1 << 5); #else /* do not pull up RXD0, RXD1, TXD0, TXD1 */ gpio->PFUP = (1 << 0) | (1 << 1) | (1 << 2) | (1 << 3); @@ -173,23 +169,19 @@ int misc_init_r(void) * version variable has to be set this early, because so it * could be used in script files on an usb stick, which * might be called during do_auto_update() */ - extern char version_string[]; - - setenv ("ver", version_string); + setenv("ver", (char *)version_string); } #endif /* CONFIG_VERSION_VARIABLE */
#ifdef CONFIG_AUTO_UPDATE { - extern int do_auto_update(void); /* this has priority over all else */ do_auto_update(); } #endif
- for (i = 0; i < KEYBD_KEY_NUM; ++i) { + for (i = 0; i < KEYBD_KEY_NUM; ++i) keybd_env[i] = '0' + ((kbd_data >> i) & 1); - } keybd_env[i] = '\0'; debug("** Setting keybd="%s"\n", keybd_env); setenv("keybd", keybd_env); @@ -201,14 +193,12 @@ int misc_init_r(void) debug("** Setting preboot="%s"\n", str); setenv("preboot", str); /* set or delete definition */ #endif /* CONFIG_PREBOOT */ - if (str != NULL) { + if (str != NULL) free(str); - } - #ifdef CONFIG_SYS_BRIGHTNESS tsc2000_set_brightness(); #endif - return (0); + return 0; }
#ifdef CONFIG_PREBOOT @@ -297,11 +287,11 @@ static char *key_match(ulong kbd_data) cmd_name, getenv(cmd_name) ? getenv(cmd_name) : "<UNDEFINED>"); - return (getenv(cmd_name)); + return getenv(cmd_name); } } debug("key_match: no match\n"); - return (NULL); + return NULL; } #endif /* CONFIG_PREBOOT */
@@ -328,7 +318,7 @@ U_BOOT_CMD(kbd, 1, 1, do_kbd, "read keyboard status", ""); #ifdef CONFIG_MODEM_SUPPORT static int key_pressed(void) { - return (compare_magic(KBD_DATA, CONFIG_MODEM_KEY_MAGIC) == 0); + return compare_magic(KBD_DATA, CONFIG_MODEM_KEY_MAGIC) == 0; } #endif /* CONFIG_MODEM_SUPPORT */
@@ -370,9 +360,8 @@ static void spi_init(void) spi->ch[0].SPCON = 0x1A;
/* Dummy byte ensures clock to be low. */ - for (i = 0; i < 10; i++) { + for (i = 0; i < 10; i++) spi->ch[0].SPTDAT = 0xFF; - } wait_transmit_done(); }
@@ -380,8 +369,8 @@ static void wait_transmit_done(void) { struct s3c24x0_spi * const spi = s3c24x0_get_base_spi();
- /* wait until transfer is done */ - while (!(spi->ch[0].SPSTA & 0x01)); + while (!(spi->ch[0].SPSTA & 0x01)) + /* wait until transfer is done */; }
static void tsc2000_write(unsigned int page, unsigned int reg, @@ -417,7 +406,7 @@ static void tsc2000_set_brightness(void)
i = getenv_r("brightness", tmp, sizeof(tmp)); br = (i > 0) ? (int)simple_strtoul(tmp, NULL, 10) : - CONFIG_SYS_BRIGHTNESS; + CONFIG_SYS_BRIGHTNESS;
tsc2000_write(0, 0xb, br & 0xff); } diff --git a/board/trab/trab.h b/board/trab/trab.h new file mode 100644 index 0000000..9eb2702 --- /dev/null +++ b/board/trab/trab.h @@ -0,0 +1,38 @@ +/* + * Functions to access the TSC2000 controller on TRAB board (used for scanning + * thermo sensors) + * + * Copyright (C) 2009 Kevin Morfitt, kevin.morfitt@fearnside-systems.co.uk + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#if defined(CONFIG_VFD) +int vfd_init_clocks(void); +#endif +#ifdef CONFIG_AUTO_UPDATE +int do_auto_update(void); +#endif +#if defined(CONFIG_CMD_I2C) +int i2c_write_multiple(uchar chip, uint addr, int alen, + uchar *buffer, int len); +int i2c_read_multiple(uchar chip, uint addr, int alen, + uchar *buffer, int len); +#endif + diff --git a/board/trab/trab_fkt.c b/board/trab/trab_fkt.c index b9a2bb9..da0c3b1 100644 --- a/board/trab/trab_fkt.c +++ b/board/trab/trab_fkt.c @@ -105,31 +105,31 @@ #define ADC_ECFLG 0x8000
/* function test functions */ -int do_dip(void); -int do_info(void); -int do_vcc5v(void); -int do_vcc12v(void); -int do_buttons(void); -int do_fill_level(void); -int do_rotary_switch(void); -int do_pressure(void); -int do_v_bat(void); -int do_vfd_id(void); -int do_buzzer(char **); -int do_led(char **); -int do_full_bridge(char **); -int do_dac(char **); -int do_motor_contact(void); -int do_motor(char **); -int do_pwm(char **); -int do_thermo(char **); -int do_touch(char **); -int do_rs485(char **); -int do_serial_number(char **); -int do_crc16(void); -int do_power_switch(void); -int do_gain(char **); -int do_eeprom(char **); +static int do_dip(void); +static int do_info(void); +static int do_vcc5v(void); +static int do_vcc12v(void); +static int do_buttons(void); +static int do_fill_level(void); +static int do_rotary_switch(void); +static int do_pressure(void); +static int do_v_bat(void); +static int do_vfd_id(void); +static int do_buzzer(char **); +static int do_led(char **); +static int do_full_bridge(char **); +static int do_dac(char **); +static int do_motor_contact(void); +static int do_motor(char **); +static int do_pwm(char **); +static int do_thermo(char **); +static int do_touch(char **); +static int do_rs485(char **); +static int do_serial_number(char **); +static int do_crc16(void); +static int do_power_switch(void); +static int do_gain(char **); +static int do_eeprom(char **);
/* helper functions */ static void adc_init(void); @@ -152,10 +152,10 @@ static unsigned short updcrc(unsigned short icrc, unsigned char *icp, #if defined(CONFIG_CMD_I2C) static int trab_eeprom_read(char **argv); static int trab_eeprom_write(char **argv); -int i2c_write_multiple(uchar chip, uint addr, int alen, uchar *buffer, - int len); -int i2c_read_multiple(uchar chip, uint addr, int alen, uchar *buffer, - int len); +static int i2c_write_multiple(uchar chip, uint addr, int alen, uchar *buffer, + int len); +static int i2c_read_multiple(uchar chip, uint addr, int alen, uchar *buffer, + int len); #endif
/* @@ -189,95 +189,68 @@ int trab_fkt(int argc, char *argv[]) case 1: break; case 2: - if (strcmp(argv[1], "info") == 0) { - return (do_info()); - } - if (strcmp(argv[1], "dip") == 0) { - return (do_dip()); - } - if (strcmp(argv[1], "vcc5v") == 0) { - return (do_vcc5v()); - } - if (strcmp(argv[1], "vcc12v") == 0) { - return (do_vcc12v()); - } - if (strcmp(argv[1], "buttons") == 0) { - return (do_buttons()); - } - if (strcmp(argv[1], "fill_level") == 0) { - return (do_fill_level()); - } - if (strcmp(argv[1], "rotary_switch") == 0) { - return (do_rotary_switch()); - } - if (strcmp(argv[1], "pressure") == 0) { - return (do_pressure()); - } - if (strcmp(argv[1], "v_bat") == 0) { - return (do_v_bat()); - } - if (strcmp(argv[1], "vfd_id") == 0) { - return (do_vfd_id()); - } - if (strcmp(argv[1], "motor_contact") == 0) { - return (do_motor_contact()); - } - if (strcmp(argv[1], "crc16") == 0) { - return (do_crc16()); - } - if (strcmp(argv[1], "power_switch") == 0) { - return (do_power_switch()); - } + if (strcmp(argv[1], "info") == 0) + return do_info(); + if (strcmp(argv[1], "dip") == 0) + return do_dip(); + if (strcmp(argv[1], "vcc5v") == 0) + return do_vcc5v(); + if (strcmp(argv[1], "vcc12v") == 0) + return do_vcc12v(); + if (strcmp(argv[1], "buttons") == 0) + return do_buttons(); + if (strcmp(argv[1], "fill_level") == 0) + return do_fill_level(); + if (strcmp(argv[1], "rotary_switch") == 0) + return do_rotary_switch(); + if (strcmp(argv[1], "pressure") == 0) + return do_pressure(); + if (strcmp(argv[1], "v_bat") == 0) + return do_v_bat(); + if (strcmp(argv[1], "vfd_id") == 0) + return do_vfd_id(); + if (strcmp(argv[1], "motor_contact") == 0) + return do_motor_contact(); + if (strcmp(argv[1], "crc16") == 0) + return do_crc16(); + if (strcmp(argv[1], "power_switch") == 0) + return do_power_switch(); break; case 3: - if (strcmp(argv[1], "full_bridge") == 0) { - return (do_full_bridge(argv)); - } - if (strcmp(argv[1], "dac") == 0) { - return (do_dac(argv)); - } - if (strcmp(argv[1], "motor") == 0) { - return (do_motor(argv)); - } - if (strcmp(argv[1], "pwm") == 0) { - return (do_pwm(argv)); - } - if (strcmp(argv[1], "thermo") == 0) { - return (do_thermo(argv)); - } - if (strcmp(argv[1], "touch") == 0) { - return (do_touch(argv)); - } - if (strcmp(argv[1], "serial_number") == 0) { - return (do_serial_number(argv)); - } - if (strcmp(argv[1], "buzzer") == 0) { - return (do_buzzer(argv)); - } - if (strcmp(argv[1], "gain") == 0) { - return (do_gain(argv)); - } + if (strcmp(argv[1], "full_bridge") == 0) + return do_full_bridge(argv); + if (strcmp(argv[1], "dac") == 0) + return do_dac(argv); + if (strcmp(argv[1], "motor") == 0) + return do_motor(argv); + if (strcmp(argv[1], "pwm") == 0) + return do_pwm(argv); + if (strcmp(argv[1], "thermo") == 0) + return do_thermo(argv); + if (strcmp(argv[1], "touch") == 0) + return do_touch(argv); + if (strcmp(argv[1], "serial_number") == 0) + return do_serial_number(argv); + if (strcmp(argv[1], "buzzer") == 0) + return do_buzzer(argv); + if (strcmp(argv[1], "gain") == 0) + return do_gain(argv); break; case 4: - if (strcmp(argv[1], "led") == 0) { - return (do_led(argv)); - } - if (strcmp(argv[1], "rs485") == 0) { - return (do_rs485(argv)); - } - if (strcmp(argv[1], "serial_number") == 0) { - return (do_serial_number(argv)); - } + if (strcmp(argv[1], "led") == 0) + return do_led(argv); + if (strcmp(argv[1], "rs485") == 0) + return do_rs485(argv); + if (strcmp(argv[1], "serial_number") == 0) + return do_serial_number(argv); break; case 5: - if (strcmp(argv[1], "eeprom") == 0) { - return (do_eeprom(argv)); - } + if (strcmp(argv[1], "eeprom") == 0) + return do_eeprom(argv); break; case 6: - if (strcmp(argv[1], "eeprom") == 0) { - return (do_eeprom(argv)); - } + if (strcmp(argv[1], "eeprom") == 0) + return do_eeprom(argv); break; default: break; @@ -290,7 +263,8 @@ int trab_fkt(int argc, char *argv[]) void hang(void) { puts("### ERROR ### Please RESET the board ###\n"); - for (;;); + for (;;) + /* Do nothing */; }
int do_info(void) @@ -431,7 +405,7 @@ static int adc_read(unsigned int channel) */ udelay(1000);
static void adc_init(void) @@ -607,7 +581,7 @@ int do_buzzer(char **argv) timers->TCON = (timers->TCON | UPDATE2 | RELOAD2) & ~INVERT2; timers->TCON = (timers->TCON | START2) & ~UPDATE2; - return (0); + return 0; } else if (strcmp(argv[2], "off") == 0) { /* stop */ @@ -617,7 +591,7 @@ int do_buzzer(char **argv) gpio->PDCON &= ~0xC000; gpio->PDCON |= 0x4000; gpio->PDDAT &= ~0x80; - return (0); + return 0; }
printf("%s: invalid parameter %s\n", __FUNCTION__, argv[2]); @@ -878,9 +852,8 @@ int do_touch(char **argv) { int i; for (i = 0; i < (TOUCH_TIMEOUT * 1000); i++) { - if (touch_check_pressed()) { + if (touch_check_pressed()) break; - } udelay(1000); /* pause 1 ms */ } } @@ -903,9 +876,8 @@ int do_touch(char **argv) { int i; for (i = 0; i < (TOUCH_TIMEOUT * 1000); i++) { - if (touch_check_pressed()) { + if (touch_check_pressed()) break; - } udelay(1000); /* pause 1 ms */ } } @@ -928,13 +900,14 @@ int do_touch(char **argv) #ifdef CONFIG_TOUCH_WAIT_PRESSED static void touch_wait_pressed(void) { - while (!(tsc2000_read(TSC2000_REG_ADC) & TC_PSM)); + while (!(tsc2000_read(TSC2000_REG_ADC) & TC_PSM)) + /* Wait */; }
#else static int touch_check_pressed(void) { - return (tsc2000_read(TSC2000_REG_ADC) & TC_PSM); + return tsc2000_read(TSC2000_REG_ADC) & TC_PSM; } #endif /* CONFIG_TOUCH_WAIT_PRESSED */
@@ -948,23 +921,19 @@ static int touch_write_clibration_values(int calib_point, int x, int y)
if (calib_point == CALIB_TL) { if (i2c_write_multiple(I2C_EEPROM_DEV_ADDR, TOUCH_X0, 1, - (unsigned char *)&x, 2)) { + (unsigned char *)&x, 2)) return 1; - } if (i2c_write_multiple(I2C_EEPROM_DEV_ADDR, TOUCH_Y0, 1, - (unsigned char *)&y, 2)) { + (unsigned char *)&y, 2)) return 1; - }
/* verify written values */ if (i2c_read_multiple(I2C_EEPROM_DEV_ADDR, TOUCH_X0, 1, - (unsigned char *)&x_verify, 2)) { + (unsigned char *)&x_verify, 2)) return 1; - } if (i2c_read_multiple(I2C_EEPROM_DEV_ADDR, TOUCH_Y0, 1, - (unsigned char *)&y_verify, 2)) { + (unsigned char *)&y_verify, 2)) return 1; - } if ((y != y_verify) || (x != x_verify)) { print_identifier(); printf("error: verify error\n"); @@ -974,23 +943,19 @@ static int touch_write_clibration_values(int calib_point, int x, int y) } else if (calib_point == CALIB_DR) { if (i2c_write_multiple(I2C_EEPROM_DEV_ADDR, TOUCH_X1, 1, - (unsigned char *)&x, 2)) { + (unsigned char *)&x, 2)) return 1; - } if (i2c_write_multiple(I2C_EEPROM_DEV_ADDR, TOUCH_Y1, 1, - (unsigned char *)&y, 2)) { + (unsigned char *)&y, 2)) return 1; - }
/* verify written values */ if (i2c_read_multiple(I2C_EEPROM_DEV_ADDR, TOUCH_X1, 1, - (unsigned char *)&x_verify, 2)) { + (unsigned char *)&x_verify, 2)) return 1; - } if (i2c_read_multiple(I2C_EEPROM_DEV_ADDR, TOUCH_Y1, 1, - (unsigned char *)&y_verify, 2)) { + (unsigned char *)&y_verify, 2)) return 1; - } if ((y != y_verify) || (x != x_verify)) { print_identifier(); printf("error: verify error\n"); @@ -1002,7 +967,7 @@ static int touch_write_clibration_values(int calib_point, int x, int y) #else printf("No I2C support enabled (CONFIG_CMD_I2C), could not write " "to EEPROM\n"); - return (1); + return 1; #endif }
@@ -1022,24 +987,23 @@ int do_rs485(char **argv) int timeout; char data[RS485_MAX_RECEIVE_BUF_LEN];
- if (strcmp(argv[2], "send") == 0) { - return (rs485_send_line(argv[3])); - } + if (strcmp(argv[2], "send") == 0) + return rs485_send_line(argv[3]); else if (strcmp(argv[2], "receive") == 0) { timeout = simple_strtoul(argv[3], NULL, 10); if (rs485_receive_chars(data, timeout) != 0) { print_identifier(); printf("## nothing received\n"); - return (1); + return 1; } else { print_identifier(); printf("%s\n", data); - return (0); + return 0; } } printf("%s: unknown command %s\n", __FUNCTION__, argv[2]); - return (1); /* unknown command, return error */ + return 1; /* unknown command, return error */ }
static int rs485_send_line(const char *data) @@ -1049,7 +1013,7 @@ static int rs485_send_line(const char *data) rs485_puts(data); rs485_putc('\n');
static int rs485_receive_chars(char *data, int timeout) @@ -1074,9 +1038,9 @@ static int rs485_receive_chars(char *data, int timeout) *data = '\0'; /* terminate string */
if (receive_count == 0) - return (1); + return 1; else - return (0); + return 0; }
int do_serial_number(char **argv) @@ -1088,31 +1052,30 @@ int do_serial_number(char **argv) if (i2c_read(I2C_EEPROM_DEV_ADDR, SERIAL_NUMBER, 1, (unsigned char *)&serial_number, 4)) { printf("could not read from eeprom\n"); - return (1); + return 1; } print_identifier(); printf("%08d\n", serial_number); - return (0); + return 0; } else if (strcmp(argv[2], "write") == 0) { serial_number = simple_strtoul(argv[3], NULL, 10); if (i2c_write(I2C_EEPROM_DEV_ADDR, SERIAL_NUMBER, 1, (unsigned char *)&serial_number, 4)) { printf("could not write to eeprom\n"); - return (1); + return 1; } - return (0); + return 0; } printf("%s: unknown command %s\n", __FUNCTION__, argv[2]); - return (1); /* unknown command, return error */ + return 1; /* unknown command, return error */ #else printf("No I2C support enabled (CONFIG_CMD_I2C), could not write " "to EEPROM\n"); - return (1); + return 1; #endif }
- int do_crc16(void) { #if defined(CONFIG_CMD_I2C) @@ -1121,7 +1084,7 @@ int do_crc16(void)
if (i2c_read(I2C_EEPROM_DEV_ADDR, 0, 1, buf, 60)) { printf("could not read from eeprom\n"); - return (1); + return 1; } crc = 0; /* start value of crc calculation */ crc = updcrc(crc, buf, 60); @@ -1132,13 +1095,13 @@ int do_crc16(void) if (i2c_write(I2C_EEPROM_DEV_ADDR, CRC16, 1, (unsigned char *)&crc, sizeof(crc))) { printf("could not read from eeprom\n"); - return (1); + return 1; } - return (0); + return 0; #else printf("No I2C support enabled (CONFIG_CMD_I2C), could not write " "to EEPROM\n"); - return (1); + return 1; #endif }
@@ -1213,7 +1176,7 @@ static unsigned short updcrc(unsigned short icrc, unsigned char *icp, while (cnt--) crc = (crc<<B) ^ crctab[(crc>>(W-B)) ^ *cp++];
- return (crc); + return crc; }
int do_gain(char **argv) @@ -1228,26 +1191,23 @@ int do_gain(char **argv) }
tsc2000_set_range(range); - return (0); + return 0; }
int do_eeprom(char **argv) { #if defined(CONFIG_CMD_I2C) - if (strcmp(argv[2], "read") == 0) { - return (trab_eeprom_read(argv)); - } - - else if (strcmp(argv[2], "write") == 0) { - return (trab_eeprom_write(argv)); - } + if (strcmp(argv[2], "read") == 0) + return trab_eeprom_read(argv); + else if (strcmp(argv[2], "write") == 0) + return trab_eeprom_write(argv);
printf("%s: invalid parameter %s\n", __FUNCTION__, argv[2]); - return (1); + return 1; #else printf("No I2C support enabled (CONFIG_CMD_I2C), could not write " "to EEPROM\n"); - return (1); + return 1; #endif }
@@ -1266,14 +1226,14 @@ static int trab_eeprom_read(char **argv) len = simple_strtoul(argv[4], NULL, 10); if ((len < 1) || (len > 4)) { printf("%s: invalid parameter %s\n", __FUNCTION__, argv[4]); - return (1); + return 1; } for (i = 0; i < len; i++) { if (i2c_read(I2C_EEPROM_DEV_ADDR, addr+i, 1, buffer+i, 1)) { printf("%s: could not read from i2c device %#x" ", addr %d\n", __FUNCTION__, I2C_EEPROM_DEV_ADDR, addr); - return (1); + return 1; } } print_identifier(); @@ -1293,7 +1253,7 @@ static int trab_eeprom_read(char **argv) else printf("%ld\n", (unsigned long int)value); } - return (0); + return 0; }
static int trab_eeprom_write(char **argv) @@ -1310,7 +1270,7 @@ static int trab_eeprom_write(char **argv) len = simple_strtoul(argv[4], NULL, 10); if ((len < 1) || (len > 4)) { printf("%s: invalid parameter %s\n", __FUNCTION__, argv[4]); - return (1); + return 1; } value = simple_strtol(argv[5], NULL, 10); debug("value=%ld\n", value); @@ -1319,16 +1279,11 @@ static int trab_eeprom_write(char **argv) printf("%s: could not write to i2c device %d" ", addr %d\n", __FUNCTION__, I2C_EEPROM_DEV_ADDR, addr); - return (1); + return 1; } -#if 0 - printf("chip=%#x, addr+i=%#x+%d=%p, alen=%d, *buffer+i=" - "%#x+%d=%p=%#x \n", I2C_EEPROM_DEV_ADDR_DEV_ADDR , addr, - i, addr+i, 1, buffer, i, buffer+i, *(buffer+i)); -#endif udelay(30000); /* wait for EEPROM ready */ } - return (0); + return 0; }
int i2c_write_multiple(uchar chip, uint addr, int alen, uchar *buffer, int len) @@ -1338,24 +1293,18 @@ int i2c_write_multiple(uchar chip, uint addr, int alen, uchar *buffer, int len) if (alen != 1) { printf("%s: addr len other than 1 not supported\n", __FUNCTION__); - return (1); + return 1; }
int i2c_read_multiple(uchar chip, uint addr, int alen, uchar *buffer, int len) @@ -1365,16 +1314,16 @@ int i2c_read_multiple(uchar chip, uint addr, int alen, uchar *buffer, int len) if (alen != 1) { printf("%s: addr len other than 1 not supported\n", __FUNCTION__); - return (1); + return 1; }
for (i = 0; i < len; i++) { if (i2c_read(chip, addr+i, alen, buffer+i, 1)) { printf("%s: could not read from i2c device %#x" ", addr %d\n", __FUNCTION__, chip, addr); - return (1); + return 1; } } - return (0); + return 0; } #endif diff --git a/board/trab/tsc2000.c b/board/trab/tsc2000.c index 27d90b2..2855825 100644 --- a/board/trab/tsc2000.c +++ b/board/trab/tsc2000.c @@ -65,9 +65,8 @@ void tsc2000_spi_init(void) spi->ch[0].SPCON = 0x1A;
/* Dummy byte ensures clock to be low. */ - for (i = 0; i < 10; i++) { + for (i = 0; i < 10; i++) spi->ch[0].SPTDAT = 0xFF; - } spi_wait_transmit_done(); }
@@ -75,8 +74,8 @@ void spi_wait_transmit_done(void) { struct s3c24x0_spi * const spi = s3c24x0_get_base_spi();
void tsc2000_write(unsigned short reg, unsigned short data) @@ -317,7 +316,7 @@ s32 tsc2000_contact_temp(void) if (tsc2000_interpolate(u_pt1000, Pt1000_temp_table, &contact_temp) == -1) { printf("%s: error interpolating PT1000 vlaue\n", __FUNCTION__); - return (-1000); + return -1000; } debug("contact_temp: %ld\n", contact_temp);
@@ -378,5 +377,6 @@ int tsc2000_interpolate(long value, long data[][2], long *result)
void adc_wait_conversion_done(void) { - while (!(tsc2000_read(TSC2000_REG_ADC) & (1 << 14))); + while (!(tsc2000_read(TSC2000_REG_ADC) & (1 << 14))) + /* Wait */; } diff --git a/board/trab/tsc2000.h b/board/trab/tsc2000.h index c7ec0bd..db4b408 100644 --- a/board/trab/tsc2000.h +++ b/board/trab/tsc2000.h @@ -124,6 +124,7 @@ void spi_wait_transmit_done(void); void tsc2000_spi_init(void); int tsc2000_interpolate(long value, long data[][2], long *result); void adc_wait_conversion_done(void); +int memory_post_tests(unsigned long start, unsigned long size);
static inline void SET_CS_TOUCH(void) { diff --git a/board/trab/vfd.c b/board/trab/vfd.c index 550d1e8..cc7f9d3 100644 --- a/board/trab/vfd.c +++ b/board/trab/vfd.c @@ -102,8 +102,8 @@ void init_grid_ctrl(void) for (display = 0; display < 4; display++) { for (grid_cycle = 0; grid_cycle < 56; grid_cycle++) { bit = grid_cycle * 256 * 4 + - (grid_cycle + 200) * 4 + - frame_buf_offs + display; + (grid_cycle + 200) * 4 + + frame_buf_offs + display; /* wrap around if offset (see manual S3C2400) */ if (bit >= FRAME_BUF_SIZE * 8) bit = bit - (FRAME_BUF_SIZE * 8); @@ -122,7 +122,7 @@ void init_grid_ctrl(void) else /* grid nr. 0 */ bit = grid_cycle * 256 * 4 + 200 * 4 + - frame_buf_offs + display - 4; + frame_buf_offs + display - 4; /* wrap around if offset (see manual S3C2400) */ if (bit >= FRAME_BUF_SIZE * 8) bit = bit - (FRAME_BUF_SIZE * 8); @@ -156,8 +156,8 @@ void init_grid_ctrl(void)
if (grid_cycle < 37) bit = grid_cycle * 256 * 4 + - (252 - grid_cycle) * - 4 + frame_buf_offs + display; + (252 - grid_cycle) * 4 + + frame_buf_offs + display;
/* wrap around if offset (see manual S3C2400) */ if (bit >= FRAME_BUF_SIZE * 8) @@ -196,13 +196,12 @@ void create_vfd_table(void) for (display = 0; display <= 3; display++) { /* Display 0 blue pixels */ vfd_table[x][y][0][display][0] = - (x == 0) ? - y * 16 + display : + (x == 0) ? y * 16 + display : (x % 4) * 4 + y * 16 + ((x - 1) / 2) * 1024 + display; /* Display 0 red pixels */ vfd_table[x][y][1][display][0] = - (x == 0) ? + (x == 0) ? y * 16 + 512 + display : (x % 4) * 4 + y * 16 + ((x - 1) / 2) * 1024 + 512 + @@ -243,7 +242,7 @@ void create_vfd_table(void)
/* blue pixels */ vfd_table[x][y][0][display][0] = - (x > 1) ? + (x > 1) ? x_abcdef * 4 + ((x - 1) / 3) * 1024 + y * 48 + display : x_abcdef * 4 + 0 + y * 48 + @@ -251,13 +250,13 @@ void create_vfd_table(void) /* blue pixels */ if (x > 1 && (x - 1) % 3) vfd_table[x][y][0][display][1] = - x_abcdef * 4 + - ((x - 1) / 3 + 1) * 1024 + - y * 48 + display; + x_abcdef * 4 + + ((x - 1) / 3 + 1) * 1024 + + y * 48 + display;
/* red pixels */ vfd_table[x][y][1][display][0] = - (x > 1) ? + (x > 1) ? x_abcdef * 4 + 24 + ((x - 1) / 3) * 1024 + y * 48 + display : @@ -266,9 +265,9 @@ void create_vfd_table(void) /* red pixels */ if (x > 1 && (x - 1) % 3) vfd_table[x][y][1][display][1] = - x_abcdef * 4 + 24 + - ((x - 1) / 3 + 1) * 1024 + - y * 48 + display; + x_abcdef * 4 + 24 + + ((x - 1) / 3 + 1) * 1024 + + y * 48 + display; } } } @@ -300,7 +299,8 @@ void create_vfd_table(void) */ if (pixel >= FRAME_BUF_SIZE * 8) pixel = pixel - - (FRAME_BUF_SIZE * 8); + (FRAME_BUF_SIZE + * 8); adr = gd->fb_base + (pixel / 32) * 4 + (3 - (pixel % 32) / 8); @@ -310,9 +310,10 @@ void create_vfd_table(void) bit_nr + 4;
adr_vfd_table[x][y][color] - [display][entry] = adr; + [display][entry] = adr; bit_vfd_table[x][y][color] - [display][entry] = bit_nr; + [display][entry] = + bit_nr; } } } @@ -330,10 +331,9 @@ void set_vfd_pixel(unsigned char x, unsigned char y, ulong adr; unsigned char bit_nr, temp;
- if (!gd->vfd_type) { + if (!gd->vfd_type) /* Unknown type. */ return; - }
/* Pixel-Eintrag Nr. 1 */ adr = adr_vfd_table[x][y][color][display][0]; @@ -490,24 +490,23 @@ int drv_vfd_init(void) int vfd_inv_data = 0;
if (vfd_init_done != 0) - return (0); + return 0; vfd_init_done = 1;
debug("Detecting Revison of WA4-VFD: ID=0x%X\n", vfd_board_id);
switch (vfd_board_id) { case 0: /* board revision < Rev.200 */ - if ((tmp = getenv("vfd_type")) == NULL) { + tmp = getenv("vfd_type"); + if (tmp == NULL) break; - } - if (strcmp(tmp, "T119C") == 0) { + if (strcmp(tmp, "T119C") == 0) gd->vfd_type = VFD_TYPE_T119C; - } else if (strcmp(tmp, "MN11236") == 0) { + else if (strcmp(tmp, "MN11236") == 0) gd->vfd_type = VFD_TYPE_MN11236; - } else { + else /* cannot use printf for a warning here */ gd->vfd_type = 0; /* unknown */ - }
break; default: /* default to MN11236, data inverted */ @@ -562,12 +561,15 @@ int drv_vfd_init(void) /* Synchronize VFD enable with LCD controller to avoid flicker */ /* Start LCD-Controller */ lcd->LCDCON1 = 0x00000B75; - /* Wait for end of VSYNC */ - while ((lcd->LCDCON5 & 0x180000) != 0x100000); + while ((lcd->LCDCON5 & 0x180000) != 0x100000) + /* Wait for end of VSYNC */; /* Wait for next HSYNC */ - while ((lcd->LCDCON5 & 0x060000) != 0x040000); - while ((lcd->LCDCON5 & 0x060000) == 0x040000); - while ((lcd->LCDCON5 & 0x060000) != 0x000000); + while ((lcd->LCDCON5 & 0x060000) != 0x040000) + ; + while ((lcd->LCDCON5 & 0x060000) == 0x040000) + ; + while ((lcd->LCDCON5 & 0x060000) != 0x000000) + ; if (gd->vfd_type) VFD_ENABLE;
@@ -611,7 +613,7 @@ ulong vfd_setmem(ulong addr) debug("Reserving %ldk for VFD Framebuffer at: %08lx\n", size >> 10, addr);
- return (size); + return size; }
/* diff --git a/common/cmd_version.c b/common/cmd_version.c index 7f165c7..3fd1d0c 100644 --- a/common/cmd_version.c +++ b/common/cmd_version.c @@ -24,8 +24,6 @@ #include <common.h> #include <command.h>
-extern char version_string[]; - int do_version(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { printf("\n%s\n", version_string); diff --git a/common/cmd_vfd.c b/common/cmd_vfd.c index 9c5b038..e65e212 100644 --- a/common/cmd_vfd.c +++ b/common/cmd_vfd.c @@ -41,8 +41,6 @@ #define VFD_TEST_LOGO_BMPNR 0 #define VFD_REMOTE_LOGO_BMPNR 1
-extern int transfer_pic(unsigned char, unsigned char *, int, int); - int trab_vfd (ulong bitmap);
int do_vfd (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) diff --git a/common/main.c b/common/main.c index 10d8904..22bc020 100644 --- a/common/main.c +++ b/common/main.c @@ -332,9 +332,8 @@ void main_loop (void)
#ifdef CONFIG_VERSION_VARIABLE { - extern char version_string[]; - - setenv ("ver", version_string); /* set version variable */ + /* set version variable */ + setenv("ver", (char *)version_string); } #endif /* CONFIG_VERSION_VARIABLE */
diff --git a/drivers/i2c/s3c24x0_i2c.c b/drivers/i2c/s3c24x0_i2c.c index c8371cf..e6c0083 100644 --- a/drivers/i2c/s3c24x0_i2c.c +++ b/drivers/i2c/s3c24x0_i2c.c @@ -53,7 +53,7 @@
#define I2C_TIMEOUT 1 /* 1 second */
-static int GetI2CSDA(void) +static int get_i2c_sda(void) { struct s3c24x0_gpio *gpio = s3c24x0_get_base_gpio();
@@ -65,14 +65,7 @@ static int GetI2CSDA(void) #endif }
-#if 0 -static void SetI2CSDA(int x) -{ - rGPEDAT = (rGPEDAT & ~0x8000) | (x & 1) << 15; -} -#endif - -static void SetI2CSCL(int x) +static void set_i2c_scl(int x) { struct s3c24x0_gpio *gpio = s3c24x0_get_base_gpio();
@@ -84,7 +77,7 @@ static void SetI2CSCL(int x) #endif }
-static int WaitForXfer(void) +static int wait_for_xfer(void) { struct s3c24x0_i2c *i2c = s3c24x0_get_base_i2c(); int i; @@ -98,14 +91,14 @@ static int WaitForXfer(void) return (readl(&i2c->IICCON) & I2CCON_IRPND) ? I2C_OK : I2C_NOK_TOUT; }
-static int IsACK(void) +static int is_ack(void) { struct s3c24x0_i2c *i2c = s3c24x0_get_base_i2c();
return !(readl(&i2c->IICSTAT) & I2CSTAT_NACK); }
-static void ReadWriteByte(void) +static void read_write_byte(void) { struct s3c24x0_i2c *i2c = s3c24x0_get_base_i2c();
@@ -127,7 +120,7 @@ void i2c_init(int speed, int slaveadd) i--; }
- if ((readl(&i2c->IICSTAT) & I2CSTAT_BSY) || GetI2CSDA() == 0) { + if ((readl(&i2c->IICSTAT) & I2CSTAT_BSY) || get_i2c_sda() == 0) { #ifdef CONFIG_S3C2410 ulong old_gpecon = readl(&gpio->GPECON); #endif @@ -149,17 +142,17 @@ void i2c_init(int speed, int slaveadd) #endif
/* toggle I2CSCL until bus idle */ - SetI2CSCL(0); + set_i2c_scl(0); udelay(1000); i = 10; - while ((i > 0) && (GetI2CSDA() != 1)) { - SetI2CSCL(1); + while ((i > 0) && (get_i2c_sda() != 1)) { + set_i2c_scl(1); udelay(1000); - SetI2CSCL(0); + set_i2c_scl(0); udelay(1000); i--; } - SetI2CSCL(1); + set_i2c_scl(1); udelay(1000);
/* restore pin functions */ @@ -238,16 +231,16 @@ int i2c_transfer(unsigned char cmd_type, &i2c->IICSTAT); i = 0; while ((i < addr_len) && (result == I2C_OK)) { - result = WaitForXfer(); + result = wait_for_xfer(); writel(addr[i], &i2c->IICDS); - ReadWriteByte(); + read_write_byte(); i++; } i = 0; while ((i < data_len) && (result == I2C_OK)) { - result = WaitForXfer(); + result = wait_for_xfer(); writel(data[i], &i2c->IICDS); - ReadWriteByte(); + read_write_byte(); i++; } } else { @@ -257,19 +250,19 @@ int i2c_transfer(unsigned char cmd_type, &i2c->IICSTAT); i = 0; while ((i < data_len) && (result = I2C_OK)) { - result = WaitForXfer(); + result = wait_for_xfer(); writel(data[i], &i2c->IICDS); - ReadWriteByte(); + read_write_byte(); i++; } }
if (result == I2C_OK) - result = WaitForXfer(); + result = wait_for_xfer();
/* send STOP */ writel(I2C_MODE_MR | I2C_TXRX_ENA, &i2c->IICSTAT); - ReadWriteByte(); + read_write_byte(); break;
case I2C_READ: @@ -279,13 +272,13 @@ int i2c_transfer(unsigned char cmd_type, /* send START */ writel(readl(&i2c->IICSTAT) | I2C_START_STOP, &i2c->IICSTAT); - result = WaitForXfer(); - if (IsACK()) { + result = wait_for_xfer(); + if (is_ack()) { i = 0; while ((i < addr_len) && (result == I2C_OK)) { writel(addr[i], &i2c->IICDS); - ReadWriteByte(); - result = WaitForXfer(); + read_write_byte(); + result = wait_for_xfer(); i++; }
@@ -293,16 +286,16 @@ int i2c_transfer(unsigned char cmd_type, /* resend START */ writel(I2C_MODE_MR | I2C_TXRX_ENA | I2C_START_STOP, &i2c->IICSTAT); - ReadWriteByte(); - result = WaitForXfer(); + read_write_byte(); + result = wait_for_xfer(); i = 0; while ((i < data_len) && (result == I2C_OK)) { /* disable ACK for final READ */ if (i == data_len - 1) writel(readl(&i2c->IICCON) & ~0x80, &i2c->IICCON); - ReadWriteByte(); - result = WaitForXfer(); + read_write_byte(); + result = wait_for_xfer(); data[i] = readl(&i2c->IICDS); i++; } @@ -316,17 +309,17 @@ int i2c_transfer(unsigned char cmd_type, /* send START */ writel(readl(&i2c->IICSTAT) | I2C_START_STOP, &i2c->IICSTAT); - result = WaitForXfer(); + result = wait_for_xfer();
- if (IsACK()) { + if (is_ack()) { i = 0; while ((i < data_len) && (result == I2C_OK)) { /* disable ACK for final READ */ if (i == data_len - 1) writel(readl(&i2c->IICCON) & ~0x80, &i2c->IICCON); - ReadWriteByte(); - result = WaitForXfer(); + read_write_byte(); + result = wait_for_xfer(); data[i] = readl(&i2c->IICDS); i++; } @@ -337,7 +330,7 @@ int i2c_transfer(unsigned char cmd_type,
default: diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index c07a26e..6997a2b 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -1197,7 +1197,6 @@ void logo_plot (void *screen, int width, int x, int y) static void *video_logo (void) { char info[128]; - extern char version_string; int space, len, y_off = 0;
#ifdef CONFIG_SPLASH_SCREEN diff --git a/include/common.h b/include/common.h index 07897f6..103c48c 100644 --- a/include/common.h +++ b/include/common.h @@ -216,6 +216,12 @@ int display_options (void); void print_size (phys_size_t, const char *); int print_buffer (ulong addr, void* data, uint width, uint count, uint linelen);
+/* common/vfd.c */ +#if defined(CONFIG_CMD_VFD) +int trab_vfd(ulong bitmap); +void transfer_pic(int, unsigned char *, int, int); + +#endif /* common/main.c */ void main_loop (void); int run_command (const char *cmd, int flag); @@ -224,6 +230,7 @@ int readline_into_buffer (const char *const prompt, char * buffer); int parse_line (char *, char *[]); void init_cmd_timeout(void); void reset_cmd_timeout(void); +extern int do_mdm_init;
/* lib_$(ARCH)/board.c */ void board_init_f (ulong) __attribute__ ((noreturn)); @@ -234,6 +241,7 @@ int checkdram (void); int last_stage_init(void); extern ulong monitor_flash_len; int mac_read_from_eeprom(void); +extern const char version_string[];
/* common/flash.c */ void flash_perror (int); @@ -478,6 +486,12 @@ void _serial_puts (const char *, const int); int _serial_getc (const int); int _serial_tstc (const int);
+#ifdef CONFIG_MODEM_SUPPORT +void disable_putc(void); +void enable_putc(void); +int hwflow_onoff(int); +#endif + /* $(CPU)/speed.c */ int get_clocks (void); int get_clocks_866 (void); diff --git a/lib_generic/display_options.c b/lib_generic/display_options.c index 2dc2567..a01f00f 100644 --- a/lib_generic/display_options.c +++ b/lib_generic/display_options.c @@ -28,8 +28,6 @@
int display_options (void) { - extern char version_string[]; - #if defined(BUILD_TAG) printf ("\n\n%s, Build: %s\n\n", version_string, BUILD_TAG); #else
