[U-Boot] [PATCH v4 0/5] Add USB boot to HS DRA7xx/AM57xx
Hello all,
This series adds USB boot support to HS DRA7xx/AM57xx platforms.
Thanks, Andrew
Changes from v3: - Rebase on upstream - Sync defconfigs
Changes from v2: - Only use ISW_ENTRY_ADDR for system with a set default
Changes from v1: - Drop explicit UART boot support from DRA7xx as this cannot be tested
Andrew F. Davis (5): defconfigs: dra7xx_hs_evm: Sync HS and non-HS defconfigs defconfigs: am57xx_hs_evm: Sync HS and non-HS defconfigs defconfigs: Add config for DRA7xx High Security EVM with USB Boot support defconfigs: Add config for AM57xx High Security EVM with USB/UART Boot support doc: ti-secure: Add ULO info for AM57xx/DRA7xx secure devices from TI
MAINTAINERS | 2 ++ configs/am57xx_hs_evm_defconfig | 1 + ...hs_evm_defconfig => am57xx_hs_evm_usb_defconfig} | 6 ++++++ configs/dra7xx_hs_evm_defconfig | 8 +++++++- ...hs_evm_defconfig => dra7xx_hs_evm_usb_defconfig} | 13 ++++++++++++- doc/README.ti-secure | 8 ++++++-- 6 files changed, 34 insertions(+), 4 deletions(-) copy configs/{am57xx_hs_evm_defconfig => am57xx_hs_evm_usb_defconfig} (94%) copy configs/{dra7xx_hs_evm_defconfig => dra7xx_hs_evm_usb_defconfig} (87%)
Additions have been made to the non-HS defconfig without the same being made to the HS defconfig, sync them.
Signed-off-by: Andrew F. Davis afd@ti.com --- configs/dra7xx_hs_evm_defconfig | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 735be5506a..f9983f4805 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_SECURE_DEVICE=y CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SYS_MALLOC_F_LEN=0x18000 CONFIG_OMAP54XX=y CONFIG_TI_SECURE_EMIF_REGION_START=0xbdb00000 CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE=0x02000000 @@ -37,13 +37,18 @@ CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="dra7-evm" CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc dra71-evm dra76-evm" +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT_UNCOMPRESS_SZ=0x9000 +CONFIG_OF_SPL_REMOVE_PROPS="clocks clock-names interrupt-parent" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_SPL_DM=y +CONFIG_SPL_DM_DEVICE_REMOVE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y +CONFIG_SPL_OF_TRANSLATE=y CONFIG_DWC_AHCI=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y @@ -62,6 +67,7 @@ CONFIG_DM_MMC=y CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y +CONFIG_SPL_MMC_HS200_SUPPORT=y CONFIG_MMC_OMAP_HS=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y
Signed-off-by: Andrew F. Davis afd@ti.com --- configs/am57xx_hs_evm_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 6924b0bd06..7bdf8dc64d 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -32,6 +32,7 @@ CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_SPI_LOAD=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_PMIC is not set CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="am57xx-beagle-x15"
Add a new defconfig file for the DRA7xx High Security EVM. This config is specific for the case of USB booting.
Signed-off-by: Andrew F. Davis afd@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- MAINTAINERS | 1 + configs/dra7xx_hs_evm_usb_defconfig | 113 ++++++++++++++++++++++++++++ 2 files changed, 114 insertions(+) create mode 100644 configs/dra7xx_hs_evm_usb_defconfig
diff --git a/MAINTAINERS b/MAINTAINERS index 33f1127e50..cdf5a67321 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -690,6 +690,7 @@ F: configs/am335x_hs_evm_uart_defconfig F: configs/am43xx_hs_evm_defconfig F: configs/am57xx_hs_evm_defconfig F: configs/dra7xx_hs_evm_defconfig +F: configs/dra7xx_hs_evm_usb_defconfig F: configs/k2hk_hs_evm_defconfig F: configs/k2e_hs_evm_defconfig F: configs/k2g_hs_evm_defconfig diff --git a/configs/dra7xx_hs_evm_usb_defconfig b/configs/dra7xx_hs_evm_usb_defconfig new file mode 100644 index 0000000000..378b3d791c --- /dev/null +++ b/configs/dra7xx_hs_evm_usb_defconfig @@ -0,0 +1,113 @@ +CONFIG_ARM=y +CONFIG_ARCH_OMAP2PLUS=y +CONFIG_TI_SECURE_DEVICE=y +CONFIG_TI_COMMON_CMD_OPTIONS=y +CONFIG_SYS_MALLOC_F_LEN=0x18000 +CONFIG_OMAP54XX=y +CONFIG_TI_SECURE_EMIF_REGION_START=0xbdb00000 +CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE=0x02000000 +CONFIG_TI_SECURE_EMIF_PROTECTED_REGION_SIZE=0x01c00000 +CONFIG_ISW_ENTRY_ADDR=0x40306d50 +CONFIG_TARGET_DRA7XX_EVM=y +CONFIG_SPL=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_ARMV7_LPAE=y +CONFIG_AHCI=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_FIT_IMAGE_POST_PROCESS=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="androidboot.serialno=${serial#} console=ttyS0,115200 androidboot.console=ttyS0 androidboot.hardware=jacinto6evmboard" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_MISC_INIT_R is not set +CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_DMA_SUPPORT=y +# CONFIG_SPL_NAND_SUPPORT is not set +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SPL_USB_GADGET=y +CONFIG_SPL_DFU=y +CONFIG_SPL_YMODEM_SUPPORT=y +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_SETEXPR is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="dra7-evm" +CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc dra71-evm dra76-evm" +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT_UNCOMPRESS_SZ=0x9000 +CONFIG_OF_SPL_REMOVE_PROPS="clocks clock-names interrupt-parent" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_DEVICE_REMOVE=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_DWC_AHCI=y +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x82000000 +CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=1 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_DM_GPIO=y +CONFIG_PCF8575_GPIO=y +CONFIG_DM_I2C=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_IO_VOLTAGE=y +CONFIG_MMC_UHS_SUPPORT=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_SPL_MMC_HS200_SUPPORT=y +CONFIG_MMC_OMAP_HS=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_DM_ETH=y +CONFIG_PHY_GIGE=y +CONFIG_MII=y +CONFIG_DRIVER_TI_CPSW=y +CONFIG_SPL_PHY=y +CONFIG_PIPE3_PHY=y +CONFIG_OMAP_USB2_PHY=y +CONFIG_PMIC_PALMAS=y +CONFIG_PMIC_LP873X=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_REGULATOR_PALMAS=y +CONFIG_DM_REGULATOR_LP873X=y +CONFIG_DM_SCSI=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_TI_QSPI=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_SPL_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GADGET=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022
Add a new defconfig file for the AM57xx High Security EVM. This config is specific for the case of USB/UART booting.
Signed-off-by: Andrew F. Davis afd@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- MAINTAINERS | 1 + configs/am57xx_hs_evm_usb_defconfig | 98 +++++++++++++++++++++++++++++ 2 files changed, 99 insertions(+) create mode 100644 configs/am57xx_hs_evm_usb_defconfig
diff --git a/MAINTAINERS b/MAINTAINERS index cdf5a67321..6f026024a9 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -689,6 +689,7 @@ F: configs/am335x_hs_evm_defconfig F: configs/am335x_hs_evm_uart_defconfig F: configs/am43xx_hs_evm_defconfig F: configs/am57xx_hs_evm_defconfig +F: configs/am57xx_hs_evm_usb_defconfig F: configs/dra7xx_hs_evm_defconfig F: configs/dra7xx_hs_evm_usb_defconfig F: configs/k2hk_hs_evm_defconfig diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig new file mode 100644 index 0000000000..6e4580ae39 --- /dev/null +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -0,0 +1,98 @@ +CONFIG_ARM=y +CONFIG_ARCH_OMAP2PLUS=y +CONFIG_TI_SECURE_DEVICE=y +CONFIG_TI_COMMON_CMD_OPTIONS=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_OMAP54XX=y +CONFIG_TI_SECURE_EMIF_REGION_START=0xbdb00000 +CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE=0x02000000 +CONFIG_TI_SECURE_EMIF_PROTECTED_REGION_SIZE=0x01c00000 +CONFIG_ISW_ENTRY_ADDR=0x40306d50 +CONFIG_TARGET_AM57XX_EVM=y +CONFIG_SPL=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_ARMV7_LPAE=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_FIT_IMAGE_POST_PROCESS=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_IMAGE_POST_PROCESS=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="androidboot.serialno=${serial#} console=ttyS2,115200 androidboot.console=ttyS2 androidboot.hardware=beagle_x15board" +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_MISC_INIT_R is not set +CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_DMA_SUPPORT=y +# CONFIG_SPL_NAND_SUPPORT is not set +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SPL_USB_GADGET=y +CONFIG_SPL_DFU=y +CONFIG_SPL_YMODEM_SUPPORT=y +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_PMIC is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="am57xx-beagle-x15" +CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am57xx-beagle-x15-revc am572x-idk am571x-idk am574x-idk" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SCSI_AHCI=y +# CONFIG_BLK is not set +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x82000000 +CONFIG_FASTBOOT_BUF_SIZE=0x2F000000 +CONFIG_FASTBOOT_USB_DEV=1 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=1 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_OMAP_HS=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ90X1=y +CONFIG_DM_ETH=y +CONFIG_MII=y +CONFIG_DRIVER_TI_CPSW=y +CONFIG_PHY=y +CONFIG_PIPE3_PHY=y +CONFIG_OMAP_USB2_PHY=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_PALMAS=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PALMAS=y +CONFIG_DM_SERIAL=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_TI_QSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_DM_USB_GADGET=y +CONFIG_SPL_DM_USB_GADGET=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GADGET=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" +CONFIG_USB_GADGET_VENDOR_NUM=0x0451 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd022
Booting from UART and USB on HS devices is now supported for this platform. Update documentation for the same.
Signed-off-by: Andrew F. Davis afd@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- doc/README.ti-secure | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/doc/README.ti-secure b/doc/README.ti-secure index 4b5380c0f3..76950253ac 100644 --- a/doc/README.ti-secure +++ b/doc/README.ti-secure @@ -108,7 +108,8 @@ Booting of U-Boot SPL Invoking the script for DRA7xx/AM57xx Secure Devices ====================================================
- create-boot-image.sh <IMAGE_TYPE> <INPUT_FILE> <OUTPUT_FILE> + create-boot-image.sh \ + <IMAGE_TYPE> <INPUT_FILE> <OUTPUT_FILE> <SPL_LOAD_ADDR>
<IMAGE_TYPE> is a value that specifies the type of the image to generate OR the action the image generation tool will take. Valid @@ -116,7 +117,6 @@ Booting of U-Boot SPL X-LOADER - Generates an image for NOR or QSPI boot modes MLO - Generates an image for SD/MMC/eMMC boot modes ULO - Generates an image for USB/UART peripheral boot modes - Note: ULO is not yet used by the u-boot build process
<INPUT_FILE> is the full path and filename of the public world boot loader binary file (for this platform, this is always u-boot-spl.bin). @@ -130,9 +130,13 @@ Booting of U-Boot SPL the device ROM bootloader requires for loading from the FAT partition of an SD card (same as on non-secure devices) + u-boot-spl_HS_ULO - boot image for USB/UART peripheral boot modes u-boot-spl_HS_X-LOADER - boot image for all other flash memories including QSPI and NOR flash
+ <SPL_LOAD_ADDR> is the address at which SOC ROM should load the + <INPUT_FILE> + Invoking the script for Keystone2 Secure Devices =============================================
Andrew F. Davis
