[U-Boot] [PATCH v3] ls1021aqds: add hwconfig setting to do pin mux
The Freescale LS1021AQDS share some pins, so Add the hwconfig option that allows the user to choose which the function he wants.
The main pin mux IP is: eSDHC, SAI, IIC2, RGMII, CAN, SAI.
Signed-off-by: Yuan Yao yao.yuan@freescale.com --- Changed in v3: - Add the change log in comment section. - Use #define instead of magic numbers and computation. Changed in v2: - Rebase to latest u-boot.
board/freescale/ls1021aqds/ls1021aqds.c | 73 +++++++++++++++++++++++++++++++-- include/configs/ls1021aqds.h | 1 + 2 files changed, 71 insertions(+), 3 deletions(-)
diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index 5fafc85..fe293b6 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -10,6 +10,7 @@ #include <asm/arch/immap_ls102xa.h> #include <asm/arch/clock.h> #include <asm/arch/fsl_serdes.h> +#include <hwconfig.h> #include <mmc.h> #include <fsl_esdhc.h> #include <fsl_ifc.h> @@ -18,9 +19,22 @@ #include "../common/qixis.h" #include "ls1021aqds_qixis.h"
+#define PIN_MUX_SEL_CAN 0x03 +#define PIN_MUX_SEL_IIC2 0xa0 +#define PIN_MUX_SEL_RGMII 0x00 +#define PIN_MUX_SEL_SAI 0x0c +#define PIN_MUX_SEL_SDHC 0x00 + +#define SET_SDHC_MUX_SEL(reg, value) ((reg & 0x0f) | value) +#define SET_EC_MUX_SEL(reg, value) ((reg & 0xf0) | value) DECLARE_GLOBAL_DATA_PTR;
enum { + MUX_TYPE_CAN, + MUX_TYPE_IIC2, + MUX_TYPE_RGMII, + MUX_TYPE_SAI, + MUX_TYPE_SDHC, MUX_TYPE_SD_PCI4, MUX_TYPE_SD_PC_SA_SG_SG, MUX_TYPE_SD_PC_SA_PC_SG, @@ -158,11 +172,27 @@ int board_early_init_f(void)
int config_board_mux(int ctrl_type) { - u8 reg12; + u8 reg12, reg14;
reg12 = QIXIS_READ(brdcfg[12]); + reg14 = QIXIS_READ(brdcfg[14]);
switch (ctrl_type) { + case MUX_TYPE_CAN: + reg14 = SET_EC_MUX_SEL(reg14, PIN_MUX_SEL_CAN); + break; + case MUX_TYPE_IIC2: + reg14 = SET_SDHC_MUX_SEL(reg14, PIN_MUX_SEL_IIC2); + break; + case MUX_TYPE_RGMII: + reg14 = SET_EC_MUX_SEL(reg14, PIN_MUX_SEL_RGMII); + break; + case MUX_TYPE_SAI: + reg14 = SET_EC_MUX_SEL(reg14, PIN_MUX_SEL_SAI); + break; + case MUX_TYPE_SDHC: + reg14 = SET_SDHC_MUX_SEL(reg14, PIN_MUX_SEL_SDHC); + break; case MUX_TYPE_SD_PCI4: reg12 = 0x38; break; @@ -181,6 +211,7 @@ int config_board_mux(int ctrl_type) }
QIXIS_WRITE(brdcfg[12], reg12); + QIXIS_WRITE(brdcfg[14], reg14);
return 0; } @@ -214,14 +245,50 @@ int config_serdes_mux(void) return 0; }
-#if defined(CONFIG_MISC_INIT_R) int misc_init_r(void) { + int conflict_flag; + + /* some signals can not enable simultaneous*/ + conflict_flag = 0; + if (hwconfig("sdhc")) + conflict_flag++; + if (hwconfig("iic2")) + conflict_flag++; + if (conflict_flag > 1) { + printf("WARNING: pin conflict !\n"); + return 0; + } + + conflict_flag = 0; + if (hwconfig("rgmii")) + conflict_flag++; + if (hwconfig("can")) + conflict_flag++; + if (hwconfig("sai")) + conflict_flag++; + if (conflict_flag > 1) { + printf("WARNING: pin conflict !\n"); + return 0; + } + + if (hwconfig("can")) + config_board_mux(MUX_TYPE_CAN); + else if (hwconfig("rgmii")) + config_board_mux(MUX_TYPE_RGMII); + else if (hwconfig("sai")) + config_board_mux(MUX_TYPE_SAI); + + if (hwconfig("iic2")) + config_board_mux(MUX_TYPE_IIC2); + else if (hwconfig("sdhc")) + config_board_mux(MUX_TYPE_SDHC); + #ifdef CONFIG_FSL_CAAM return sec_init(); #endif + return 0; } -#endif
int board_init(void) { diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index b19a60f..0f5f988 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -327,6 +327,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_CMDLINE_EDITING #define CONFIG_CMD_IMLS
+#define CONFIG_MISC_INIT_R #define CONFIG_HWCONFIG #define HWCONFIG_BUFFER_SIZE 128
Changed in v3:
Changed in v2:
Applied to u-boot-fsl-qoriq master, awaiting upstream.
York
York Sun
Yuan Yao
