[U-Boot] [PATCH] Fix compiler warning in fdt_support.c
fdt_support.c: In function 'of_bus_default_count_cells': fdt_support.c:957: warning: passing argument 1 of '__swab32p' discards qualifiers from pointer target type fdt_support.c:965: warning: passing argument 1 of '__swab32p' discards qualifiers from pointer target type
be32_to_cpup() expects an 'u32 *' while prop is 'const u32 *'.
Signed-off-by: Dirk Behme dirk.behme@googlemail.com
Found while building 'omap3_beagle'.
common/fdt_support.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
Index: u-boot.git/common/fdt_support.c =================================================================== --- u-boot.git.orig/common/fdt_support.c +++ u-boot.git/common/fdt_support.c @@ -954,7 +954,7 @@ static void of_bus_default_count_cells(v if (addrc) { prop = fdt_getprop(blob, parentoffset, "#address-cells", NULL); if (prop) - *addrc = be32_to_cpup(prop); + *addrc = be32_to_cpup((u32 *)prop); else *addrc = 2; } @@ -962,7 +962,7 @@ static void of_bus_default_count_cells(v if (sizec) { prop = fdt_getprop(blob, parentoffset, "#size-cells", NULL); if (prop) - *sizec = be32_to_cpup(prop); + *sizec = be32_to_cpup((u32 *)prop); else *sizec = 1; }
Signed-off-by: Dirk Behmedirk.behme@googlemail.com
else *addrc = 2; }*addrc = be32_to_cpup((u32 *)prop);
else *sizec = 1; }*sizec = be32_to_cpup((u32 *)prop);
Maybe we could pull this patch in? That will raise the count of ARM boards building clean.
Amicalement,
Dear dirk.behme@googlemail.com,
Applied, thank.
Gerry, hope this is OK with you.
Applied, thank.
Yes, thanks.
Best regards, Wolfgang Denk
Best regards, gvb
Albert ARIBAUD
Gerald Van Baren
