[PATCH v2 00/26] CONFIG_IS_ENABLED vs IS_ENABLED
This patch set gets ready to check the usage of CONFIG_IS_ENABLED/IS_ENABLED.
After the set has been applied, you can delete test/usage_of_is_enabled_todo.txt and run test/usage_of_is_enabled_commit.sh
The script test/usage_of_is_enabled_check.sh checks for new questionable uses of CONFIG_IS_ENABLED/IS_ENABLED and is added to .azure-pipelines.yml, and .gitlab-ci.yml
Changes in v2: - new patch - delay include of linux/kconfig.h to do from Makefile - include linux/kconfig.h from tools/Makefile - as suggested by Simon - keep #error, but change condition to use IS_ENABLED_NOCHECK - keep #error, but change condition to use IS_ENABLED_NOCHECK - changed condition of when to include field bdf - added protection to another instance of bdf in uart.c - Thanks to Simon for getting this corrected - use normal if, not preprocessor - new in series - use an accessor function gd_set_pci_ram_top - Always define function instead of using same protection
Troy Kisky (26): kconfig: add IS_ENABLED_NOCHECK to bypass usage_of_is_enabled_check cmd: nvedit: check for ENV_SUPPORT lib: crc32: prepare for CONFIG_IS_ENABLED changes lib: md5: prepare for CONFIG_IS_ENABLED changes lib: sha1: prepare for CONFIG_IS_ENABLED changes lib: sha256: prepare for CONFIG_IS_ENABLED changes lib: sha512: prepare for CONFIG_IS_ENABLED changes tools: prevent CONFIG_IS_ENABLED errors by including linux/kconfig.h tools: Makefile: prepare for CONFIG_IS_ENABLED changes by adding CONFIG_TOOLS_xxx x86: cpu: qemu: qemu: remove SPL use with CONFIG_IS_ENABLED config_distro_bootcmd: remove booting environment variables from SPL environment ofnode: fdt_support definitions needed if OF_CONTROL is enabled ringneck-px30: use IS_ENABLED_NOCHECK to avoid CI test failure for ENV_IS_NOWHERE puma-rk3399: use IS_ENABLED_NOCHECK to avoid CI test failure for ENV_IS_NOWHERE fdt_support: always define fdt_fixup_mtdparts m53menlo: define ft_board_setup only if CONFIG_IS_ENABLED(OF_LIBFDT) freescale: common: pfuze: define pfuze_mode_init only if defined(CONFIG_DM_PMIC) ns16550: match when to define bdf with uart code solidrun: mx6cuboxi: use CONFIG_IS_ENABLED(SATA) instead of CONFIG_CMD_SATA wandboard: use CONFIG_IS_ENABLED(SATA) instead of ifdef CONFIG_SATA arm: mach-imx: use CONFIG_$(SPL_)SATA instead of CONFIG_SATA x86: cpu: i386: cpu: only set pci_ram_top if CONFIG_IS_ENABLED(PCI) gateworks: venice: Always define setup_fec and setup_eqos power: pmic: add dm style definitions if not CONFIG_IS_ENABLED(POWER_LEGACY) arm: cpu: armv7: ls102xa: fdt: remove eth_device support CI: add test/usage_of_is_enabled_check.sh
.azure-pipelines.yml | 11 + .gitlab-ci.yml | 5 + arch/arm/cpu/armv7/ls102xa/fdt.c | 12 - arch/arm/mach-imx/Makefile | 2 +- arch/x86/cpu/apollolake/uart.c | 4 + arch/x86/cpu/i386/cpu.c | 2 +- arch/x86/cpu/qemu/qemu.c | 2 +- board/freescale/common/pfuze.c | 2 +- board/gateworks/venice/venice.c | 2 +- board/menlo/m53menlo/m53menlo.c | 2 + board/solidrun/mx6cuboxi/mx6cuboxi.c | 5 +- .../puma_rk3399/puma-rk3399.c | 2 +- .../ringneck_px30/ringneck-px30.c | 2 +- board/wandboard/wandboard.c | 5 +- cmd/nvedit.c | 5 +- include/asm-generic/global_data.h | 6 + include/config_distro_bootcmd.h | 23 ++ include/fdt_support.h | 26 ++- include/linux/kconfig.h | 5 + include/ns16550.h | 2 +- include/power/pmic.h | 2 +- lib/crc32.c | 11 +- lib/md5.c | 7 +- lib/sha1.c | 7 +- lib/sha256.c | 7 +- lib/sha512.c | 11 +- test/usage_of_is_enabled_check.sh | 19 ++ test/usage_of_is_enabled_commit.sh | 12 + test/usage_of_is_enabled_correct.sh | 50 +++++ test/usage_of_is_enabled_exempt.txt | 9 + test/usage_of_is_enabled_list.sh | 86 +++++++ test/usage_of_is_enabled_splcfg.txt | 21 ++ test/usage_of_is_enabled_todo.txt | 210 ++++++++++++++++++ tools/Makefile | 3 + 34 files changed, 527 insertions(+), 53 deletions(-) create mode 100755 test/usage_of_is_enabled_check.sh create mode 100755 test/usage_of_is_enabled_commit.sh create mode 100755 test/usage_of_is_enabled_correct.sh create mode 100644 test/usage_of_is_enabled_exempt.txt create mode 100755 test/usage_of_is_enabled_list.sh create mode 100644 test/usage_of_is_enabled_splcfg.txt create mode 100644 test/usage_of_is_enabled_todo.txt
This is for use when a config with an SPL version needs to always check the non-spl verion of the config. It avoids error messages from CI test script usage_of_is_enabled_check.sh
Signed-off-by: Troy Kisky troykiskyboundary@gmail.com ---
include/linux/kconfig.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/linux/kconfig.h b/include/linux/kconfig.h index 2bc704e1104..19b71723ab3 100644 --- a/include/linux/kconfig.h +++ b/include/linux/kconfig.h @@ -27,6 +27,11 @@ * 0 otherwise. */ #define IS_ENABLED(option) config_enabled(option, 0) +/* + * Using IS_ENABLED_NOCHECK instead of IS_ENABLED prevents + * complaints from test/usage_of_is_enabled_check.sh + */ +#define IS_ENABLED_NOCHECK(option) config_enabled(option, 0)
/* * U-Boot add-on: Helper macros to reference to different macros (prefixed by
Changes in v2:
- new patch
Avoid error messages when SPL,TPL,VPL build don't have the environment options of the main build. This is needed when defined(CONFIG_ENV_IS_IN_xxx) is changed to CONFIG_IS_ENABLED(ENV_IS_IN_xxx).
Signed-off-by: Troy Kisky troykiskyboundary@gmail.com Reviewed-by: Simon Glass sjg@chromium.org ---
(no changes since v1)
cmd/nvedit.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/cmd/nvedit.c b/cmd/nvedit.c index 7cbc3fd573a..ef0fe55431c 100644 --- a/cmd/nvedit.c +++ b/cmd/nvedit.c @@ -43,6 +43,7 @@
DECLARE_GLOBAL_DATA_PTR;
+#if CONFIG_IS_ENABLED(ENV_SUPPORT) #if defined(CONFIG_ENV_IS_IN_EEPROM) || \ defined(CONFIG_ENV_IS_IN_FLASH) || \ defined(CONFIG_ENV_IS_IN_MMC) || \ @@ -60,10 +61,12 @@ DECLARE_GLOBAL_DATA_PTR; #endif
#if !defined(ENV_IS_IN_DEVICE) && \ - !defined(CONFIG_ENV_IS_NOWHERE) + !defined(CONFIG_ENV_IS_NOWHERE) && \ + !defined(CONFIG_VPL_BUILD) # error Define one of CONFIG_ENV_IS_IN_{EEPROM|FLASH|MMC|FAT|EXT4|\ NAND|NVRAM|ONENAND|SATA|SPI_FLASH|REMOTE|UBI} or CONFIG_ENV_IS_NOWHERE #endif +#endif
/* * Maximum expected input data size for import command
- !defined(CONFIG_ENV_IS_NOWHERE) && \
- !defined(CONFIG_VPL_BUILD)
This is one of the #error messes that we no longer need with Kconfig, where we can ensure things happen. Maybe we can use def_bool y if .. instead of default y if ..., in the ENV_IS_NOWHERE choice ?
-- Tom
Hi Tom
There is some weirdness here git grep -A1 CONFIG_ENV_IS_NOWHERE *
am62ax_evm_r5_defconfig:CONFIG_ENV_IS_NOWHERE=y am62ax_evm_r5_defconfig-CONFIG_ENV_IS_IN_MMC=y -- aristainetos2c_defconfig:CONFIG_ENV_IS_NOWHERE=y aristainetos2c_defconfig-CONFIG_ENV_IS_IN_SPI_FLASH=y -- aristainetos2ccslb_defconfig:CONFIG_ENV_IS_NOWHERE=y aristainetos2ccslb_defconfig-CONFIG_ENV_IS_IN_SPI_FLASH=y -- imx6q_bosch_acc_defconfig:CONFIG_ENV_IS_NOWHERE=y imx6q_bosch_acc_defconfig-CONFIG_ENV_IS_IN_MMC=y -- imx8mn_beacon_2g_defconfig:CONFIG_ENV_IS_NOWHERE=y imx8mn_beacon_2g_defconfig-CONFIG_ENV_IS_IN_MMC=y -- imx8mn_beacon_defconfig:CONFIG_ENV_IS_NOWHERE=y imx8mn_beacon_defconfig-CONFIG_ENV_IS_IN_MMC=y -- imx8mn_beacon_fspi_defconfig:CONFIG_ENV_IS_NOWHERE=y imx8mn_beacon_fspi_defconfig-CONFIG_ENV_IS_IN_MMC=y -- imx8mp_dhcom_pdk2_defconfig:CONFIG_ENV_IS_NOWHERE=y imx8mp_dhcom_pdk2_defconfig-CONFIG_ENV_IS_IN_SPI_FLASH=y -- imx93_11x11_evk_defconfig:CONFIG_ENV_IS_NOWHERE=y imx93_11x11_evk_defconfig-CONFIG_ENV_IS_IN_MMC=y -- imxrt1020-evk_defconfig:CONFIG_ENV_IS_NOWHERE=y imxrt1020-evk_defconfig-CONFIG_ENV_IS_IN_MMC=y -- imxrt1050-evk_defconfig:CONFIG_ENV_IS_NOWHERE=y imxrt1050-evk_defconfig-CONFIG_ENV_IS_IN_MMC=y -- imxrt1170-evk_defconfig:CONFIG_ENV_IS_NOWHERE=y imxrt1170-evk_defconfig-CONFIG_ENV_IS_IN_MMC=y -- j721e_evm_a72_defconfig:CONFIG_ENV_IS_NOWHERE=y j721e_evm_a72_defconfig-CONFIG_ENV_IS_IN_FAT=y -- j721e_hs_evm_a72_defconfig:CONFIG_ENV_IS_NOWHERE=y j721e_hs_evm_a72_defconfig-CONFIG_ENV_IS_IN_FAT=y -- puma-rk3399_defconfig:CONFIG_ENV_IS_NOWHERE=y puma-rk3399_defconfig-CONFIG_ENV_IS_IN_MMC=y -- ringneck-px30_defconfig:CONFIG_ENV_IS_NOWHERE=y ringneck-px30_defconfig-CONFIG_ENV_IS_IN_MMC=y -- sandbox64_defconfig:CONFIG_ENV_IS_NOWHERE=y sandbox64_defconfig-CONFIG_ENV_IS_IN_EXT4=y -- sandbox_defconfig:CONFIG_ENV_IS_NOWHERE=y sandbox_defconfig-CONFIG_ENV_IS_IN_EXT4=y -- sandbox_flattree_defconfig:CONFIG_ENV_IS_NOWHERE=y sandbox_flattree_defconfig-CONFIG_ENV_IS_IN_EXT4=y -- sandbox_noinst_defconfig:CONFIG_ENV_IS_NOWHERE=y sandbox_noinst_defconfig-CONFIG_ENV_IS_IN_EXT4=y -- sandbox_spl_defconfig:CONFIG_ENV_IS_NOWHERE=y sandbox_spl_defconfig-CONFIG_ENV_IS_IN_EXT4=y -- sandbox_vpl_defconfig:CONFIG_ENV_IS_NOWHERE=y sandbox_vpl_defconfig-CONFIG_ENV_IS_IN_EXT4=y -- socrates_defconfig:CONFIG_ENV_IS_NOWHERE=y socrates_defconfig-CONFIG_ENV_IS_IN_FLASH=y -- stm32mp13_defconfig:CONFIG_ENV_IS_NOWHERE=y stm32mp13_defconfig-CONFIG_ENV_IS_IN_MMC=y -- stm32mp15-icore-stm32mp1-ctouch2_defconfig:CONFIG_ENV_IS_NOWHERE=y stm32mp15-icore-stm32mp1-ctouch2_defconfig-CONFIG_ENV_IS_IN_MMC=y -- stm32mp15-icore-stm32mp1-edimm2.2_defconfig:CONFIG_ENV_IS_NOWHERE=y stm32mp15-icore-stm32mp1-edimm2.2_defconfig-CONFIG_ENV_IS_IN_MMC=y -- stm32mp15-microgea-stm32mp1-microdev2-of7_defconfig:CONFIG_ENV_IS_NOWHERE=y stm32mp15-microgea-stm32mp1-microdev2-of7_defconfig-CONFIG_ENV_IS_IN_MMC=y -- stm32mp15-microgea-stm32mp1-microdev2_defconfig:CONFIG_ENV_IS_NOWHERE=y stm32mp15-microgea-stm32mp1-microdev2_defconfig-CONFIG_ENV_IS_IN_MMC=y -- stm32mp15_basic_defconfig:CONFIG_ENV_IS_NOWHERE=y stm32mp15_basic_defconfig-CONFIG_ENV_IS_IN_MMC=y -- stm32mp15_defconfig:CONFIG_ENV_IS_NOWHERE=y stm32mp15_defconfig-CONFIG_ENV_IS_IN_MMC=y -- stm32mp15_trusted_defconfig:CONFIG_ENV_IS_NOWHERE=y stm32mp15_trusted_defconfig-CONFIG_ENV_IS_IN_MMC=y -- xilinx_versal_virt_defconfig:CONFIG_ENV_IS_NOWHERE=y xilinx_versal_virt_defconfig-CONFIG_ENV_IS_IN_FAT=y -- xilinx_zynq_virt_defconfig:CONFIG_ENV_IS_NOWHERE=y xilinx_zynq_virt_defconfig-CONFIG_ENV_IS_IN_FAT=y -- xilinx_zynqmp_virt_defconfig:CONFIG_ENV_IS_NOWHERE=y xilinx_zynqmp_virt_defconfig-CONFIG_ENV_IS_IN_FAT=y
_________
Should I force CONFIG_ENV_IS_NOWHERE=n in these cases?
BR Troy
-- Tom
Hi Tom
[snip]
No, we support more than one env location being enabled at a time, with nowhere being the location of last resort (at run time).
#endif +#endif
-- Tom
Hi Tom
[snip]
Okay, this help text is misleading then.
config ENV_IS_NOWHERE bool "Environment is not stored" default y if !ENV_IS_IN_EEPROM && !ENV_IS_IN_EXT4 && \ !ENV_IS_IN_FAT && !ENV_IS_IN_FLASH && \ !ENV_IS_IN_MMC && !ENV_IS_IN_NAND && \ !ENV_IS_IN_NVRAM && !ENV_IS_IN_ONENAND && \ !ENV_IS_IN_REMOTE && !ENV_IS_IN_SPI_FLASH && \ !ENV_IS_IN_UBI help Define this if you don't want to or can't have an environment stored on a storage medium. In this case the environment will still exist while U-Boot is running, but once U-Boot exits it will not be stored. U-Boot will therefore always start up with a default environment. ______________
Perhaps this is better ?
config ENV_IS_NOT_IN_DEVICE def_bool y if !ENV_IS_IN_EEPROM && !ENV_IS_IN_EXT4 && \ !ENV_IS_IN_FAT && !ENV_IS_IN_FLASH && \ !ENV_IS_IN_MMC && !ENV_IS_IN_NAND && \ !ENV_IS_IN_NVRAM && !ENV_IS_IN_ONENAND && \ !ENV_IS_IN_REMOTE && !ENV_IS_IN_SPI_FLASH && \ !ENV_IS_IN_UBI select ENV_IS_NOWHERE
config ENV_IS_NOWHERE bool "Environment is not stored" help Define this if you don't care whether or not an environment is stored on a storage medium. In this case the environment will still exist while U-Boot is running, but once U-Boot exits it may not be stored. If no other ENV_IS_IN_ is defined, U-Boot will always start up with a default environment.
BR Troy
#endif +#endif
-- Tom
Hi Tom
[snip]
Yes, rewording this was missed when updating the support.
Seems reasonable, thanks.
We need to include <linux/kconfig.h> in order to include files that use CONFIG_IS_ENABLED. TO prepare for that be more direct with using defined(USE_HOSTCC).
Changes in v2: - delay include of linux/kconfig.h to do from Makefile - as suggested by Simon
lib/crc32.c | 11 +++++++---- 1 file changed, 7 insertions(+), 4 deletions(-)
diff --git a/lib/crc32.c b/lib/crc32.c index aa94d70ef3e..12c104c62a4 100644 --- a/lib/crc32.c +++ b/lib/crc32.c @@ -14,11 +14,14 @@ #else #include <common.h> #include <efi_loader.h> +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#define PET_WDG +#endif #endif #include <compiler.h> #include <u-boot/crc.h>
-#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#ifdef PET_WDG #include <watchdog.h> #endif #include "u-boot/zlib.h" @@ -84,7 +87,7 @@ static void __efi_runtime make_crc_table(void) } crc_table_empty = 0; } -#elif !defined(CONFIG_ARM64_CRC32) +#elif !defined(CONFIG_ARM64_CRC32) || defined(USE_HOSTCC) /* ======================================================================== * Table of CRC-32's of all single-byte values (made by make_crc_table) */ @@ -184,7 +187,7 @@ const uint32_t * ZEXPORT get_crc_table() */ uint32_t __efi_runtime crc32_no_comp(uint32_t crc, const Bytef *buf, uInt len) { -#ifdef CONFIG_ARM64_CRC32 +#if defined(CONFIG_ARM64_CRC32) && !defined(USE_HOSTCC) crc = cpu_to_le32(crc); while (len--) crc = __builtin_aarch64_crc32b(crc, *buf++); @@ -243,7 +246,7 @@ uint32_t __efi_runtime crc32(uint32_t crc, const Bytef *p, uInt len) uint32_t crc32_wd(uint32_t crc, const unsigned char *buf, uInt len, uInt chunk_sz) { -#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#ifdef PET_WDG const unsigned char *end, *curr; int chunk;
Changes in v2:
Lets introduce a Kconfig symbol like HAS_WATCHDOG_RUNNING and then update all of the places we have this convention (there's a few this series doesn't touch).
We need to include <linux/kconfig.h> in order to include files that use CONFIG_IS_ENABLED. TO prepare for that don't pet the watchdog when USE_HOSTCC is defined.
lib/md5.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/lib/md5.c b/lib/md5.c index 1636ab93661..20d5e87814b 100644 --- a/lib/md5.c +++ b/lib/md5.c @@ -29,7 +29,10 @@
#ifndef USE_HOSTCC #include <common.h> +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) #include <watchdog.h> +#define PET_WDG +#endif #endif /* USE_HOSTCC */ #include <u-boot/md5.h>
@@ -288,14 +291,14 @@ md5_wd(const unsigned char *input, unsigned int len, unsigned char output[16], unsigned int chunk_sz) { struct MD5Context context; -#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#ifdef PET_WDG const unsigned char *end, *curr; int chunk; #endif
MD5Init(&context);
-#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#ifdef PET_WDG curr = input; end = input + len; while (curr < end) {
lib/sha1.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/lib/sha1.c b/lib/sha1.c index 8d074078934..cd5d7aead8d 100644 --- a/lib/sha1.c +++ b/lib/sha1.c @@ -19,6 +19,9 @@ #ifndef USE_HOSTCC #include <common.h> #include <linux/string.h> +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#define PET_WDG +#endif #else #include <string.h> #endif /* USE_HOSTCC */ @@ -328,14 +331,14 @@ void sha1_csum_wd(const unsigned char *input, unsigned int ilen, unsigned char *output, unsigned int chunk_sz) { sha1_context ctx; -#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#ifdef PET_WDG const unsigned char *end, *curr; int chunk; #endif
sha1_starts (&ctx);
-#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#ifdef PET_WDG curr = input; end = input + ilen; while (curr < end) {
lib/sha256.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/lib/sha256.c b/lib/sha256.c index 4d26aea1c8c..8e1c3992674 100644 --- a/lib/sha256.c +++ b/lib/sha256.c @@ -8,6 +8,9 @@ #ifndef USE_HOSTCC #include <common.h> #include <linux/string.h> +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#define PET_WDG +#endif #else #include <string.h> #endif /* USE_HOSTCC */ @@ -276,7 +279,7 @@ void sha256_csum_wd(const unsigned char *input, unsigned int ilen, unsigned char *output, unsigned int chunk_sz) { sha256_context ctx; -#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#ifdef PET_WDG const unsigned char *end; unsigned char *curr; int chunk; @@ -284,7 +287,7 @@ void sha256_csum_wd(const unsigned char *input, unsigned int ilen,
sha256_starts(&ctx);
-#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#ifdef PET_WDG curr = (unsigned char *)input; end = input + ilen; while (curr < end) {
lib/sha512.c | 11 +++++++---- 1 file changed, 7 insertions(+), 4 deletions(-)
diff --git a/lib/sha512.c b/lib/sha512.c index fbe8d5f5bfe..a504281bf93 100644 --- a/lib/sha512.c +++ b/lib/sha512.c @@ -13,6 +13,9 @@ #ifndef USE_HOSTCC #include <common.h> #include <linux/string.h> +#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#define PET_WDG +#endif #else #include <string.h> #endif /* USE_HOSTCC */ @@ -292,7 +295,7 @@ void sha384_csum_wd(const unsigned char *input, unsigned int ilen, unsigned char *output, unsigned int chunk_sz) { sha512_context ctx; -#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#ifdef PET_WDG const unsigned char *end; unsigned char *curr; int chunk; @@ -300,7 +303,7 @@ void sha384_csum_wd(const unsigned char *input, unsigned int ilen,
sha384_starts(&ctx);
-#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#ifdef PET_WDG curr = (unsigned char *)input; end = input + ilen; while (curr < end) { @@ -355,7 +358,7 @@ void sha512_csum_wd(const unsigned char *input, unsigned int ilen, unsigned char *output, unsigned int chunk_sz) { sha512_context ctx; -#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) +#ifdef PET_WDG const unsigned char *end; unsigned char *curr; int chunk; @@ -363,7 +366,7 @@ void sha512_csum_wd(const unsigned char *input, unsigned int ilen,
sha512_starts(&ctx);
Changes in v2: - include linux/kconfig.h from tools/Makefile - as suggested by Simon
tools/Makefile | 1 + 1 file changed, 1 insertion(+)
diff --git a/tools/Makefile b/tools/Makefile index e13effbb66a..5d6284e6451 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -298,6 +298,7 @@ endif # !LOGO_BMP # Define _GNU_SOURCE to obtain the getline prototype from stdio.h # HOST_EXTRACFLAGS += -include $(srctree)/include/compiler.h \ + -include $(srctree)/include/linux/kconfig.h \ $(patsubst -I%,-idirafter%, $(filter -I%, $(UBOOTINCLUDE))) \ -I$(srctree)/scripts/dtc/libfdt \ -I$(srctree)/tools \
CONFIG_IS_ENABLED(FIT_SIGNATURE) will check for CONFIG_TOOLS_FIT_SIGNATURE. So define it now in preparation.
tools/Makefile | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/tools/Makefile b/tools/Makefile index 5d6284e6451..86f1b6b5049 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -162,8 +162,10 @@ ifdef CONFIG_TOOLS_LIBCRYPTO # This affects include/image.h, but including the board config file # is tricky, so manually define this options here. HOST_EXTRACFLAGS += -DCONFIG_FIT_SIGNATURE +HOST_EXTRACFLAGS += -DCONFIG_TOOLS_FIT_SIGNATURE=1 HOST_EXTRACFLAGS += -DCONFIG_FIT_SIGNATURE_MAX_SIZE=0xffffffff HOST_EXTRACFLAGS += -DCONFIG_FIT_CIPHER +HOST_EXTRACFLAGS += -DCONFIG_TOOLS_FIT_CIPHER=1 endif
# MXSImage needs LibSSL
Is the "=1" required here, as in we check the value of the define, not just that it is defined?
-- Tom
When it is converted to CONFIG_IS_ENABLED it will require the =1 The CONFIG_IS_ENABLED logic counts the number of parameters and "empty string" doesn't count. I think it also compares to 1 somewhere in there.
BR Troy
-- Tom
Ah, OK, thanks.
CONFIG_IS_ENABLED(SPL_X86_32BIT_INIT) would check for CONFIG_SPL_SPL_X86_32BIT_INIT for SPL builds
arch/x86/cpu/qemu/qemu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/x86/cpu/qemu/qemu.c b/arch/x86/cpu/qemu/qemu.c index e54082df7f9..274978c023b 100644 --- a/arch/x86/cpu/qemu/qemu.c +++ b/arch/x86/cpu/qemu/qemu.c @@ -97,7 +97,7 @@ static void qemu_chipset_init(void) } }
-#if !CONFIG_IS_ENABLED(SPL_X86_32BIT_INIT) +#if CONFIG_IS_ENABLED(X86_32BIT_INIT) int arch_cpu_init(void) { post_code(POST_CPU_INIT);
SPL environments don't need commands that they can never use. Avoid errors with CONFIG_IS_ENABLED conversions by skipping them now.
include/config_distro_bootcmd.h | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index 9d2a225e7eb..2a136b96a6d 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -35,11 +35,15 @@ #devtypel "_boot=" \ BOOTENV_SHARED_BLKDEV_BODY(devtypel)
+#define BOOTENV_DEV_BLKDEV_NONE(devtypeu, devtypel, instance) + #define BOOTENV_DEV_BLKDEV(devtypeu, devtypel, instance) \ "bootcmd_" #devtypel #instance "=" \ "devnum=" #instance "; " \ "run " #devtypel "_boot\0"
+#define BOOTENV_DEV_NAME_BLKDEV_NONE(devtypeu, devtypel, instance) + #define BOOTENV_DEV_NAME_BLKDEV(devtypeu, devtypel, instance) \ #devtypel #instance " "
@@ -59,6 +63,10 @@ #define BOOTENV_SHARED_MMC BOOTENV_SHARED_BLKDEV(mmc) #define BOOTENV_DEV_MMC BOOTENV_DEV_BLKDEV #define BOOTENV_DEV_NAME_MMC BOOTENV_DEV_NAME_BLKDEV +#elif defined(CONFIG_SPL_BUILD) +#define BOOTENV_SHARED_MMC +#define BOOTENV_DEV_MMC BOOTENV_DEV_BLKDEV_NONE +#define BOOTENV_DEV_NAME_MMC BOOTENV_DEV_NAME_BLKDEV_NONE #else #define BOOTENV_SHARED_MMC #define BOOTENV_DEV_MMC \ @@ -190,6 +198,10 @@ #define BOOTENV_SHARED_SATA BOOTENV_SHARED_BLKDEV(sata) #define BOOTENV_DEV_SATA BOOTENV_DEV_BLKDEV #define BOOTENV_DEV_NAME_SATA BOOTENV_DEV_NAME_BLKDEV +#elif defined(CONFIG_SPL_BUILD) +#define BOOTENV_SHARED_SATA +#define BOOTENV_DEV_SATA BOOTENV_DEV_BLKDEV_NONE +#define BOOTENV_DEV_NAME_SATA BOOTENV_DEV_NAME_BLKDEV_NONE #else #define BOOTENV_SHARED_SATA #define BOOTENV_DEV_SATA \ @@ -293,6 +305,11 @@ BOOTENV_SHARED_BLKDEV_BODY(usb) #define BOOTENV_DEV_USB BOOTENV_DEV_BLKDEV #define BOOTENV_DEV_NAME_USB BOOTENV_DEV_NAME_BLKDEV +#elif defined(CONFIG_SPL_BUILD) +#define BOOTENV_RUN_NET_USB_START +#define BOOTENV_SHARED_USB +#define BOOTENV_DEV_USB BOOTENV_DEV_BLKDEV_NONE +#define BOOTENV_DEV_NAME_USB BOOTENV_DEV_NAME_BLKDEV_NONE #else #define BOOTENV_RUN_NET_USB_START #define BOOTENV_SHARED_USB @@ -395,6 +412,9 @@ "\0" #define BOOTENV_DEV_NAME_DHCP(devtypeu, devtypel, instance) \ "dhcp " +#elif defined(CONFIG_SPL_BUILD) +#define BOOTENV_DEV_DHCP BOOTENV_DEV_BLKDEV_NONE +#define BOOTENV_DEV_NAME_DHCP BOOTENV_DEV_NAME_BLKDEV_NONE #else #define BOOTENV_DEV_DHCP \ BOOT_TARGET_DEVICES_references_DHCP_without_CONFIG_CMD_DHCP @@ -413,6 +433,9 @@ "fi\0" #define BOOTENV_DEV_NAME_PXE(devtypeu, devtypel, instance) \ "pxe " +#elif defined(CONFIG_SPL_BUILD) +#define BOOTENV_DEV_PXE BOOTENV_DEV_BLKDEV_NONE +#define BOOTENV_DEV_NAME_PXE BOOTENV_DEV_NAME_BLKDEV_NONE #else #define BOOTENV_DEV_PXE \ BOOT_TARGET_DEVICES_references_PXE_without_CONFIG_CMD_DHCP_or_PXE
With the use of CONFIG_IS_ENABLED in code, instead of at the preprocessor level, these defines are still needed if OF_CONTROL is enabled.
include/fdt_support.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/fdt_support.h b/include/fdt_support.h index 5638bd4f165..eeb83e6251d 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -7,7 +7,8 @@ #ifndef __FDT_SUPPORT_H #define __FDT_SUPPORT_H
-#if defined(CONFIG_OF_LIBFDT) && !defined(USE_HOSTCC) +#if (defined(CONFIG_OF_LIBFDT) || defined(CONFIG_OF_CONTROL)) && \ + !defined(USE_HOSTCC)
#include <asm/u-boot.h> #include <linux/libfdt.h>
When usage_of_is_enabled_check.sh is added, this will show a false positive for IS_ENABLED(CONFIG_ENV_IS_NOWHERE). Use IS_ENABLED_NOCHECK to avoid check and error on SPL builds.
Changes in v2: - keep #error, but change condition to use IS_ENABLED_NOCHECK
board/theobroma-systems/ringneck_px30/ringneck-px30.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/theobroma-systems/ringneck_px30/ringneck-px30.c b/board/theobroma-systems/ringneck_px30/ringneck-px30.c index 47d1a40ef7c..5b2e0c7d40f 100644 --- a/board/theobroma-systems/ringneck_px30/ringneck-px30.c +++ b/board/theobroma-systems/ringneck_px30/ringneck-px30.c @@ -118,7 +118,7 @@ int mmc_get_env_dev(void) return CONFIG_SYS_MMC_ENV_DEV; }
-#if !IS_ENABLED(CONFIG_ENV_IS_NOWHERE) +#if !IS_ENABLED_NOCHECK(CONFIG_ENV_IS_NOWHERE) #error Please enable CONFIG_ENV_IS_NOWHERE #endif
Changes in v2:
board/theobroma-systems/puma_rk3399/puma-rk3399.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/theobroma-systems/puma_rk3399/puma-rk3399.c b/board/theobroma-systems/puma_rk3399/puma-rk3399.c index 97f398bd754..d1e3a544974 100644 --- a/board/theobroma-systems/puma_rk3399/puma-rk3399.c +++ b/board/theobroma-systems/puma_rk3399/puma-rk3399.c @@ -136,7 +136,7 @@ int mmc_get_env_dev(void) return CONFIG_SYS_MMC_ENV_DEV; }
Changes in v2:
Changes in v2:
As I said against v1, the platform needs to select ENV_IS_NOWHERE.
SPL code wants fdt_fixup_mtdparts defined as a NOP when the function isn't linked in.
Prepare for ifdef CONFIG_OF_LIBFDT being converted to if CONFIG_IS_ENABLED(OF_LIBFDT)
include/fdt_support.h | 23 +++++++++++++---------- 1 file changed, 13 insertions(+), 10 deletions(-)
diff --git a/include/fdt_support.h b/include/fdt_support.h index eeb83e6251d..94497d755a3 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -245,16 +245,6 @@ int fdt_increase_size(void *fdt, int add_len); int fdt_delete_disabled_nodes(void *blob);
struct node_info; -#if defined(CONFIG_FDT_FIXUP_PARTITIONS) -void fdt_fixup_mtdparts(void *fdt, const struct node_info *node_info, - int node_info_size); -#else -static inline void fdt_fixup_mtdparts(void *fdt, - const struct node_info *node_info, - int node_info_size) -{ -} -#endif
void fdt_del_node_and_alias(void *blob, const char *alias);
@@ -412,6 +402,19 @@ int fdt_get_cells_len(const void *blob, char *nr_cells_name);
#endif /* ifdef CONFIG_OF_LIBFDT */
+#if CONFIG_IS_ENABLED(OF_LIBFDT) && defined(CONFIG_FDT_FIXUP_PARTITIONS) +struct node_info; +void fdt_fixup_mtdparts(void *fdt, const struct node_info *node_info, + int node_info_size); +#else +struct node_info; +static inline void fdt_fixup_mtdparts(void *fdt, + const struct node_info *node_info, + int node_info_size) +{ +} +#endif + #ifdef USE_HOSTCC int fdtdec_get_int(const void *blob, int node, const char *prop_name, int default_val);
The function ft_board_setup calls do_fixup_by_path_string which is only available on CONFIG_IS_ENABLED(OF_LIBFDT). This prepares for the conversion.
ft_board_setup is only called from image-fdt which is linked by obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += image-fdt.o
board/menlo/m53menlo/m53menlo.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/menlo/m53menlo/m53menlo.c b/board/menlo/m53menlo/m53menlo.c index 14324c7087d..ca3b81c57ff 100644 --- a/board/menlo/m53menlo/m53menlo.c +++ b/board/menlo/m53menlo/m53menlo.c @@ -264,6 +264,7 @@ void board_preboot_os(void) gpio_direction_output(IMX_GPIO_NR(6, 0), 0); }
+#if CONFIG_IS_ENABLED(OF_LIBFDT) int ft_board_setup(void *blob, struct bd_info *bd) { if (lvds_compat_string) @@ -272,6 +273,7 @@ int ft_board_setup(void *blob, struct bd_info *bd)
return 0; } +#endif
struct display_info_t const displays[] = { {
pfuze_mode_init calls pmic_reg_read which is only available from
obj-$(CONFIG_$(SPL_TPL_)DM_PMIC) += pmic-uclass.o
Prepare for conversion of defined(CONFIG_DM_PMIC) to CONFIG_IS_ENABLED(DM_PMIC).
board/freescale/common/pfuze.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/freescale/common/pfuze.c b/board/freescale/common/pfuze.c index 6dca22960bf..a9288820b2e 100644 --- a/board/freescale/common/pfuze.c +++ b/board/freescale/common/pfuze.c @@ -91,7 +91,7 @@ struct pmic *pfuze_common_init(unsigned char i2cbus)
return p; } -#else +#elif defined(CONFIG_DM_PMIC) int pfuze_mode_init(struct udevice *dev, u32 mode) { unsigned char offset, i, switch_num;
When switching defined(CONFIG_PCI) to CONFIG_IS_ENABLED(PCI) bdf is no longer accessible. So add preprocessor protection to avoid access.
Changes in v2: - changed condition of when to include field bdf - added protection to another instance of bdf in uart.c - Thanks to Simon for getting this corrected
arch/x86/cpu/apollolake/uart.c | 4 ++++ include/ns16550.h | 2 +- 2 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/x86/cpu/apollolake/uart.c b/arch/x86/cpu/apollolake/uart.c index a9362436000..878aa48ed76 100644 --- a/arch/x86/cpu/apollolake/uart.c +++ b/arch/x86/cpu/apollolake/uart.c @@ -79,10 +79,12 @@ void apl_uart_init(pci_dev_t bdf, ulong base)
static int apl_ns16550_probe(struct udevice *dev) { +#if IS_ENABLED_NOCHECK(CONFIG_PCI) && defined(CONFIG_SPL_BUILD) struct apl_ns16550_plat *plat = dev_get_plat(dev);
if (!CONFIG_IS_ENABLED(PCI)) apl_uart_init(plat->ns16550.bdf, plat->ns16550.base); +#endif
return ns16550_serial_probe(dev); } @@ -110,7 +112,9 @@ static int apl_ns16550_of_to_plat(struct udevice *dev) ns.reg_offset = 0; ns.clock = dtplat->clock_frequency; ns.fcr = UART_FCR_DEFVAL; +#if IS_ENABLED_NOCHECK(CONFIG_PCI) && defined(CONFIG_SPL_BUILD) ns.bdf = pci_ofplat_get_devfn(dtplat->reg[0]); +#endif memcpy(plat, &ns, sizeof(ns)); #else int ret; diff --git a/include/ns16550.h b/include/ns16550.h index e7e68663d03..41b977b5b26 100644 --- a/include/ns16550.h +++ b/include/ns16550.h @@ -74,7 +74,7 @@ struct ns16550_plat { int clock; u32 fcr; int flags; -#if defined(CONFIG_PCI) && defined(CONFIG_SPL) +#if IS_ENABLED_NOCHECK(CONFIG_PCI) && defined(CONFIG_SPL_BUILD) int bdf; #endif };
setup_sata is linked with obj-$(CONFIG_SATA) += sata.o
So use SATA instead of CMD_SATA.
Changes in v2: - use normal if, not preprocessor
board/solidrun/mx6cuboxi/mx6cuboxi.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index 7c44379ec4a..6fa5cf4d27d 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -275,9 +275,8 @@ int board_early_init_f(void) { setup_iomux_uart();
-#ifdef CONFIG_CMD_SATA - setup_sata(); -#endif + if (CONFIG_IS_ENABLED(SATA)) + setup_sata(); setup_fec();
Changes in v2:
Prepare for linking setup_sata only when CONFIG_SATA/CONFIG_SPL_SATA is defined.
Changes in v2: - new in series
board/wandboard/wandboard.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index da995dd0f58..48914450a29 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -352,9 +352,8 @@ static void setup_display(void) int board_early_init_f(void) { setup_iomux_uart(); -#ifdef CONFIG_SATA - setup_sata(); -#endif + if (CONFIG_IS_ENABLED(SATA)) + setup_sata();
return 0; }
Changes in v2:
- new in series
This avoid an error with enable_sata_clock when defined(CONFIG_SATA) is changed to CONFIG_IS_ENABLED(SATA).
arch/arm/mach-imx/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index 4dfc60eedc4..50f26975eac 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -54,7 +54,7 @@ obj-$(CONFIG_IMX_RDC) += rdc-sema.o ifneq ($(CONFIG_SPL_BUILD),y) obj-$(CONFIG_IMX_BOOTAUX) += imx_bootaux.o endif -obj-$(CONFIG_SATA) += sata.o +obj-$(CONFIG_$(SPL_)SATA) += sata.o obj-$(CONFIG_IMX_HAB) += hab.o obj-$(CONFIG_SYSCOUNTER_TIMER) += syscounter.o endif
This avoids an error when ifdef CONFIG_PCI is changed to if CONFIG_IS_ENABLED(PCI)
Changes in v2: - use an accessor function gd_set_pci_ram_top
arch/x86/cpu/i386/cpu.c | 2 +- include/asm-generic/global_data.h | 6 ++++++ 2 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/x86/cpu/i386/cpu.c b/arch/x86/cpu/i386/cpu.c index c7f6c5a013e..068670dfc41 100644 --- a/arch/x86/cpu/i386/cpu.c +++ b/arch/x86/cpu/i386/cpu.c @@ -415,7 +415,7 @@ int cpu_phys_address_size(void) /* Don't allow PCI region 3 to use memory in the 2-4GB memory hole */ static void setup_pci_ram_top(void) { - gd->pci_ram_top = 0x80000000U; + gd_set_pci_ram_top(0x80000000U); }
static void setup_mtrr(void) diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index 987fb66c17a..952e17b2c13 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -560,6 +560,12 @@ static_assert(sizeof(struct global_data) == GD_SIZE); #define gd_event_state() NULL #endif
+#if CONFIG_IS_ENABLED(PCI) +#define gd_set_pci_ram_top(val) gd->pci_ram_top = val +#else +#define gd_set_pci_ram_top(val) +#endif + /** * enum gd_flags - global data flags *
Changes in v2:
The compiler will optimize away base on IS_ENABLED(CONFIG_FEC_MXC). It avoids an error in converting to CONFIG_IS_ENABLED(NET).
Changes in v2: - Always define function instead of using same protection
board/gateworks/venice/venice.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/gateworks/venice/venice.c b/board/gateworks/venice/venice.c index c4d86c26a9b..7a819e76a1c 100644 --- a/board/gateworks/venice/venice.c +++ b/board/gateworks/venice/venice.c @@ -41,7 +41,6 @@ int board_fit_config_name_match(const char *name) return -1; }
-#if (IS_ENABLED(CONFIG_NET)) static int setup_fec(void) { struct iomuxc_gpr_base_regs *gpr = @@ -71,6 +70,7 @@ static int setup_eqos(void) return set_clk_eqos(ENET_125MHZ); }
+#if IS_ENABLED(CONFIG_NET) int board_phy_config(struct phy_device *phydev) { unsigned short val;
Changes in v2:
This avoids an error in converting to CONFIG_IS_ENABLED(DM_PMIC). Many boards SPL code needs these definitions to compile, even if the functions are not linked.
include/power/pmic.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/power/pmic.h b/include/power/pmic.h index 70f2709bd0b..636221692d0 100644 --- a/include/power/pmic.h +++ b/include/power/pmic.h @@ -86,7 +86,7 @@ struct pmic { #endif /* CONFIG_IS_ENABLED(POWER_LEGACY) */
/* TODO: Change to CONFIG_IS_ENABLED(DM_PMIC) when SPL_DM_PMIC exists */ -#ifdef CONFIG_DM_PMIC +#if defined(CONFIG_DM_PMIC) || !CONFIG_IS_ENABLED(POWER_LEGACY) /** * U-Boot PMIC Framework * =====================
commit e524f3a449f5 ("net: Remove eth_legacy.c")
removed struct eth_device This prevents errors in the conversion to CONFIG_IS_ENABLED(DM_ETH).
arch/arm/cpu/armv7/ls102xa/fdt.c | 12 ------------ 1 file changed, 12 deletions(-)
diff --git a/arch/arm/cpu/armv7/ls102xa/fdt.c b/arch/arm/cpu/armv7/ls102xa/fdt.c index 599b7e18ef3..a5c5c780ae8 100644 --- a/arch/arm/cpu/armv7/ls102xa/fdt.c +++ b/arch/arm/cpu/armv7/ls102xa/fdt.c @@ -25,11 +25,7 @@ DECLARE_GLOBAL_DATA_PTR;
void ft_fixup_enet_phy_connect_type(void *fdt) { -#ifdef CONFIG_DM_ETH struct udevice *dev; -#else - struct eth_device *dev; -#endif struct tsec_private *priv; const char *enet_path, *phy_path; char enet[16]; @@ -37,12 +33,8 @@ void ft_fixup_enet_phy_connect_type(void *fdt) int phy_node; int i = 0; uint32_t ph; -#ifdef CONFIG_DM_ETH char *name[3] = { "ethernet@2d10000", "ethernet@2d50000", "ethernet@2d90000" }; -#else - char *name[3] = { "eTSEC1", "eTSEC2", "eTSEC3" }; -#endif
for (; i < ARRAY_SIZE(name); i++) { dev = eth_get_dev_by_name(name[i]); @@ -53,11 +45,7 @@ void ft_fixup_enet_phy_connect_type(void *fdt) continue; }
-#ifdef CONFIG_DM_ETH priv = dev_get_priv(dev); -#else - priv = dev->priv; -#endif if (priv->flags & TSEC_SGMII) continue;
Add script usage_of_is_enabled_check to print any configs that use CONFIG_IS_ENABLED instead of IS_ENABLED and vice versa.
Add usage_of_is_enabled_commit.sh to generate commits to fix the above issues.
You can remove entries from test/usage_of_is_enabled_todo.txt or the entire file and then run test/usage_of_is_enabled_commit.sh to convert to suggested usage of CONFIG_IS_ENABLED/IS_ENABLED
or run test/usage_of_is_enabled_check.sh to see which configs are still todo.
.azure-pipelines.yml | 11 ++ .gitlab-ci.yml | 5 + test/usage_of_is_enabled_check.sh | 19 +++ test/usage_of_is_enabled_commit.sh | 12 ++ test/usage_of_is_enabled_correct.sh | 50 +++++++ test/usage_of_is_enabled_exempt.txt | 9 ++ test/usage_of_is_enabled_list.sh | 86 ++++++++++++ test/usage_of_is_enabled_splcfg.txt | 21 +++ test/usage_of_is_enabled_todo.txt | 210 ++++++++++++++++++++++++++++ 9 files changed, 423 insertions(+) create mode 100755 test/usage_of_is_enabled_check.sh create mode 100755 test/usage_of_is_enabled_commit.sh create mode 100755 test/usage_of_is_enabled_correct.sh create mode 100644 test/usage_of_is_enabled_exempt.txt create mode 100755 test/usage_of_is_enabled_list.sh create mode 100644 test/usage_of_is_enabled_splcfg.txt create mode 100644 test/usage_of_is_enabled_todo.txt
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 8327edf87aa..3f216d82a7e 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -67,6 +67,17 @@ stages: :^doc/ :^arch/arm/dts/ :^scripts/kconfig/lkc.h :^include/linux/kconfig.h :^tools/ && exit 1 || exit 0
+ - job: check_usage_of_is_enabled + displayName: 'Check usage of CONFIG_IS_ENABLED vs IS_ENABLED' + pool: + vmImage: $(ubuntu_vm) + container: + image: $(ci_runner_image) + options: $(container_option) + steps: + # generate list of SPL configs + - script: test/usage_of_is_enabled_check.sh + - job: cppcheck displayName: 'Static code analysis with cppcheck' pool: diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index c3ceca2974d..57330060b82 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -137,6 +137,11 @@ check for new CONFIG symbols outside Kconfig: :^doc/ :^arch/arm/dts/ :^scripts/kconfig/lkc.h :^include/linux/kconfig.h :^tools/ && exit 1 || exit 0
+check usage of CONFIG_IS_ENABLED vs IS_ENABLED: + stage: testsuites + script: + - ./test/usage_of_is_enabled_check.sh + # QA jobs for code analytics # static code analysis with cppcheck (we can add --enable=all later) cppcheck: diff --git a/test/usage_of_is_enabled_check.sh b/test/usage_of_is_enabled_check.sh new file mode 100755 index 00000000000..6bd5d9c1ac7 --- /dev/null +++ b/test/usage_of_is_enabled_check.sh @@ -0,0 +1,19 @@ +#!/bin/bash +# SPDX-License-Identifier: GPL-2.0+ +# +# Written by Troy Kisky troykiskyboundary@gmail.com + +scriptdir=`dirname "$0"`; +${scriptdir}/usage_of_is_enabled_list.sh | grep -vw FOO; +if [ $? -eq 0 ] ; then + echo "The above may have incorrect usage of IS_ENABLED/"\ +"CONFIG_IS_ENABLED" + echo "Run test/usage_of_is_enabled_commit.sh and "\ +"squash with appropriate commit" + ret=1; +else + ret=0; +fi + +rm ${scriptdir}/splcfg.tmp ${scriptdir}/exclude.tmp +exit ${ret} diff --git a/test/usage_of_is_enabled_commit.sh b/test/usage_of_is_enabled_commit.sh new file mode 100755 index 00000000000..593dbd1428c --- /dev/null +++ b/test/usage_of_is_enabled_commit.sh @@ -0,0 +1,12 @@ +#!/bin/bash +# SPDX-License-Identifier: GPL-2.0+ +# +# Written by Troy Kisky troykiskyboundary@gmail.com + +scriptdir=`dirname "$0"`; +${scriptdir}/usage_of_is_enabled_list.sh | \ +xargs -I {} sh -c "${scriptdir}/usage_of_is_enabled_correct.sh {}; \ +git commit -a -m"CONFIG_{}: correct usage of CONFIG_IS_ENABLED/IS_ENABLED";" + + +rm ${scriptdir}/splcfg.tmp ${scriptdir}/exclude.tmp diff --git a/test/usage_of_is_enabled_correct.sh b/test/usage_of_is_enabled_correct.sh new file mode 100755 index 00000000000..8724747beed --- /dev/null +++ b/test/usage_of_is_enabled_correct.sh @@ -0,0 +1,50 @@ +#!/bin/bash +# SPDX-License-Identifier: GPL-2.0+ +# +# Written by Troy Kisky troykiskyboundary@gmail.com + +scriptdir=`dirname "$0"`; + +if [ -z "$1" ] ; then + echo missing config + exit 1; +fi +if [ ! -f "${scriptdir}/splcfg.tmp" ] ; then + echo missing splcfg.tmp + exit 1; +fi + + +grep -qw $1 ${scriptdir}/splcfg.tmp +if [ $? -ne 0 ] ; then + # not splcfg + # change CONFIG_IS_ENABLED to IS_ENABLED + git grep -l \ + -e "CONFIG_IS_ENABLED($1)" \ + | \ + xargs -IFile sh -c \ + " \ + sed -i -E "\ +s/CONFIG_IS_ENABLED($1)/IS_ENABLED(CONFIG_$1)/g; \ +" File"; +else + # splcfg + # change IS_ENABLED to CONFIG_IS_ENABLED + # change ifdef to CONFIG_IS_ENABLED + # change ifndef to !CONFIG_IS_ENABLED + # change defined to CONFIG_IS_ENABLED + git grep -l \ + -e "IS_ENABLED(CONFIG_$1)" \ + -e "^#ifdef[ \t]+CONFIG_$1>" \ + -e "^#ifndef[ \t]+CONFIG_$1>" \ + -e "defined(CONFIG_$1)" \ + | \ + xargs -IFile sh -c \ + " \ + sed -i -E "\ +s/([^_])IS_ENABLED(CONFIG_$1)/\1CONFIG_IS_ENABLED($1)/g; \ +s/^#ifdef[ \t]+CONFIG_$1>/#if CONFIG_IS_ENABLED($1)/; \ +s/^#ifndef[ \t]+CONFIG_$1>/#if !CONFIG_IS_ENABLED($1)/; \ +s/defined(CONFIG_$1)/CONFIG_IS_ENABLED($1)/; \ +" File"; +fi diff --git a/test/usage_of_is_enabled_exempt.txt b/test/usage_of_is_enabled_exempt.txt new file mode 100644 index 00000000000..d9fefd6cb6c --- /dev/null +++ b/test/usage_of_is_enabled_exempt.txt @@ -0,0 +1,9 @@ +BLOBLIST +BLOBLIST_FIXED +DM_PMIC_PFUZE100 +FOO +NAND_BOOT +OF_CONTROL +SYS_L2_PL310 +WATCHDOG +X86_64 diff --git a/test/usage_of_is_enabled_list.sh b/test/usage_of_is_enabled_list.sh new file mode 100755 index 00000000000..0f51d3602ca --- /dev/null +++ b/test/usage_of_is_enabled_list.sh @@ -0,0 +1,86 @@ +#!/bin/bash +# SPDX-License-Identifier: GPL-2.0+ +# +# Written by Troy Kisky troykiskyboundary@gmail.com + +scriptdir=`dirname "$0"`; +# generate list of excluded configs +{ +# 1. ignore configs that have a number or string for a value +git grep -h -A2 -E "^config " '*Kconfig*' | \ +sed -En '/depends on/!p' | \ +sed -En '/^config/{h;$!d} ;H;x; s/config[ \t]+(.*)\n[ \t]*/config \1 #/p' | \ +sed -E "/#bool/d; /#def_bool/d; /#tristate/d; \ +/#default y/d; /#select/d; /#prompt/d; /#imply/d" | +sed -n -r "s/^config[[:space:]]+([0-9a-zA-Z_]+)/\n{\1}\n/p" | \ +sed -n -r 's/^{([0-9a-zA-Z_]+)}/\1/p' | sort -u; +# 2. configs that are exempt for other reasons +cat ${scriptdir}/usage_of_is_enabled_exempt.txt; +# 3. configs that need converted later +[ -f ${scriptdir}/usage_of_is_enabled_todo.txt ] && \ +cat ${scriptdir}/usage_of_is_enabled_todo.txt +} | sort -u > ${scriptdir}/exclude.tmp + +# generate list of CONFIGs that should use CONFIG_IS_ENABLED +{ +# 1. all obj-$(CONFIG_$(SPL_)xxx in Makefiles +git grep -h 'obj-$(CONFIG_$(SPL_' '*Makefile' | sed -e "s/SPL_TPL_/SPL_/"| \ +sed -n -r 's/obj-$(CONFIG_$(SPL_)([0-9a-zA-Z_]+))/\n{\1}\n/gp'| \ +sed -n -r 's/{([0-9a-zA-Z_]+)}/\1/p'; + +# 2. all SPL_xxx in Kconfig files +git grep -h -E 'config [ST]PL_' '*Kconfig*' | \ +sed -n -r "s/config [ST]PL_([0-9a-zA-Z_]+)/\n{\1}\n/p" | \ +sed -n -r 's/{([0-9a-zA-Z_]+)}/\1/p'; + +# 3. all CONFIG_CMD_xxx which already use CONFIG_IS_ENABLED +# The Makefile for most if these use ifndef CONFIG_SPL_BUILD +# instead of obj-$(CONFIG_$(SPL_)xxx +git grep -h -E 'CONFIG_IS_ENABLED(CMD_' | \ +sed -n -e "s/(CONFIG_IS_ENABLED(CMD_[0-9a-zA-Z_]*))/\n\1\n/gp"| \ +sed -n -r "s/CONFIG_IS_ENABLED((CMD_[0-9a-zA-Z_]+))/\1/p"; + +# 4. A list of other configs that should use CONFIG_IS_ENABLED +# This list could be reduced if obj-$(CONFIG_$(SPL_)xxx was used instead of +# ifndef CONFIG_SPL_BUILD in Makefiles +# usage_of_is_enabled_splcfg.txt mostly contains configs that should always +# be undefined in SPL/TPL +# Note: CONFIG_CLK was included to prevent a change in test_checkpatch.py +# which is checking for an error. +cat ${scriptdir}/usage_of_is_enabled_splcfg.txt; +} | sort -u | \ +comm -23 - ${scriptdir}/exclude.tmp >${scriptdir}/splcfg.tmp + +{ +# generate list of CONFIGs that incorrectly use CONFIG_IS_ENABLED +git grep -h CONFIG_IS_ENABLED | \ +sed -n -e "s/(CONFIG_IS_ENABLED([0-9a-zA-Z_]*))/\n\1\n/gp"| \ +sed -n -r "s/CONFIG_IS_ENABLED(([0-9a-zA-Z_]+))/\1/p" |sort -u| \ +comm -23 - ${scriptdir}/exclude.tmp | \ +comm -23 - ${scriptdir}/splcfg.tmp ; + +# generate list of CONFIGs that incorrectly use IS_ENABLED +git grep -h -w IS_ENABLED | \ +sed -n -e "s/(IS_ENABLED(CONFIG_[0-9a-zA-Z_]*))/\n\1\n/gp"| \ +sed -n -r "s/IS_ENABLED(CONFIG_([0-9a-zA-Z_]+))/\1/p" |sort -u| \ +join - ${scriptdir}/splcfg.tmp; + +# generate list of CONFIGs that incorrectly use ifdef +git grep -h -E "^#ifdef[ \t]+CONFIG_" | \ +sed -n -E "s/(ifdef[ \t]+CONFIG_[0-9a-zA-Z_]+)/\n\1\n/p"| \ +sed -n -E "s/ifdef[ \t]+CONFIG_([0-9a-zA-Z_]+)/\1/p" |sort -u| \ +join - ${scriptdir}/splcfg.tmp ; + +# generate list of CONFIGs that incorrectly use ifndef +git grep -h -E "^#ifndef[ \t]+CONFIG_" | \ +sed -n -E "s/(ifndef[ \t]+CONFIG_[0-9a-zA-Z_]+)/\n\1\n/p"| \ +sed -n -E "s/ifndef[ \t]+CONFIG_([0-9a-zA-Z_]+)/\1/p" |sort -u| \ +join - ${scriptdir}/splcfg.tmp ; + +# generate list of CONFIGs that incorrectly use defined +git grep -h -E "defined(CONFIG_" | \ +sed -n -E "s/(defined(CONFIG_[0-9a-zA-Z_]+))/\n\1\n/gp"| \ +sed -n -E "s/defined(CONFIG_([0-9a-zA-Z_]+))/\1/p" |sort -u| \ +join - ${scriptdir}/splcfg.tmp ; + +} | sort -u; diff --git a/test/usage_of_is_enabled_splcfg.txt b/test/usage_of_is_enabled_splcfg.txt new file mode 100644 index 00000000000..29d6257c5c7 --- /dev/null +++ b/test/usage_of_is_enabled_splcfg.txt @@ -0,0 +1,21 @@ +BZIP2 +CONFIG_CLK +CONSOLE_MUX +DM_EVENT +DM_HWSPINLOCK +DM_RNG +DM_STDIO +EFI_DEVICE_PATH_TO_TEXT +EFI_LOADER +ERRNO_STR +EVENT_DYNAMIC +GENERATE_SMBIOS_TABLE +IOMMU +MMC_HW_PARTITIONING +NAND_CS_INIT +OFNODE_MULTI_TREE +PINCTRL_ARMADA_38X +PRE_CONSOLE_BUFFER +RESET_MEDIATEK +RESET_ROCKCHIP +UT_DM diff --git a/test/usage_of_is_enabled_todo.txt b/test/usage_of_is_enabled_todo.txt new file mode 100644 index 00000000000..005531cff46 --- /dev/null +++ b/test/usage_of_is_enabled_todo.txt @@ -0,0 +1,210 @@ +ACPIGEN +ARCH_MVEBU +ARCH_VERSAL_NET +ARM_PSCI_FW +ARMV8_SEC_FIRMWARE_SUPPORT +ATMEL_PIT_TIMER +BLK +BLOCK_CACHE +BOOTCOUNT_LIMIT +BOOTDEV_ETH +BOOTDEV_SPI_FLASH +BOOTSTAGE +BOOTSTD +BZIP2 +CLK +CLK_CCF +CLK_IMX6Q +CMD_DHCP +CMDLINE +CMD_PXE +CONSOLE_MUX +COREBOOT_SYSINFO +CPU +CRC32_VERIFY +CROS_EC_KEYB +DFU_SF_PART +DFU_VIRT +DISPLAY_AER_FULL +DM +DMA +DM_DMA +DM_ETH +DM_GPIO +DM_I2C +DM_KEYBOARD +DM_MMC +DM_PMIC +DM_PMIC_DA9063 +DM_REGULATOR +DM_RNG +DM_RTC +DM_SERIAL +DM_SPI +DM_SPI_FLASH +DM_USB +DM_USB_GADGET +DOS_PARTITION +DWC_AHSATA_AHCI +EFI_DT_FIXUP +EFI_EBBR_2_1_CONFORMANCE +EFI_LOADER +EFI_PARTITION +EFI_SCROLL_ON_CLEAR_SCREEN +EFI_TCG2_PROTOCOL_MEASURE_DTB +EFI_UNICODE_CAPITALIZATION +ENV_APPEND +ENV_IS_IN_EXT4 +ENV_IS_IN_FAT +ENV_IS_IN_FLASH +ENV_IS_IN_MMC +ENV_IS_IN_NAND +ENV_IS_IN_SPI_FLASH +ENV_IS_NOWHERE +ENV_WRITEABLE_LIST +ERRNO_STR +EVENT_DEBUG +EXPO +EXYNOS7870 +EXYNOS7880 +FASTBOOT_UUU_SUPPORT +FAT_WRITE +FIT +FIT_CIPHER +FIT_IMAGE_POST_PROCESS +FIT_SIGNATURE +FIT_VERBOSE +FPGA +FRU_SC +FSL_ISBC_KEY_EXT +FSL_LS_PPA +FS_LOADER +FSP_VERSION2 +GENERATE_ACPI_TABLE +GENERATE_SMBIOS_TABLE +GMAC_ROCKCHIP +GZIP +I2C_EEPROM +I8259_PIC +IMX_RDC +LED +LEGACY_IMAGE_FORMAT +LIB_UUID +LOG +LZ4 +LZMA +LZO +MALTA +MARY +MEMSIZE_IN_BYTES +MIPS_BOOT_CMDLINE_LEGACY +MIPS_BOOT_ENV_LEGACY +MIPS_BOOT_FDT +MMC +MMC_IO_VOLTAGE +MMC_VERBOSE +MULTI_DTB_FIT +MULTIPLEXER +MXC_OCOTP +NAND_DENALI +NET +NO_FB_CLEAR +NXP_FSPI +OF_LIBFDT +OF_LIVE +OFNODE_MULTI_TREE +OF_REAL +OF_TRANSLATE +OPTEE +OPTEE_IMAGE +PARTITIONS +PARTITION_UUIDS +PCI +PCI_PNP +PG_WCOM_UBOOT_UPDATE_SUPPORTED +PHY +PHY_CADENCE_SIERRA +PHY_CADENCE_TORRENT +PHY_FIXED +PINCTRL +PKCS7_MESSAGE_PARSER +PLATDATA +POWER_DOMAIN +POWER_I2C +QFW +QFW_PIO +RAM +RANDOM_UUID +RESET_MEDIATEK +RESTORE_EXCEPTION_VECTOR_BASE +RISCV_SMODE +ROCKCHIP_RK8XX_DISABLE_BOOT_ON_POWERON +RSA_PUBLIC_KEY_PARSER +RSA_VERIFY_WITH_PKEY +SANDBOX +SATA +SEC_FIRMWARE_ARMV8_PSCI +SEMIHOSTING +SERIAL +SERIAL_PUTS +SERIAL_RX_BUFFER +SHA1 +SHA384 +SHA512 +SHA512_HW_ACCEL +SHA_HW_ACCEL +SHOW_BOOT_PROGRESS +SILENT_CONSOLE +SILENT_CONSOLE_UPDATE_ON_RELOC +SILENT_CONSOLE_UPDATE_ON_SET +SIMPLE_BUS_CORRECT_RANGE +SKIP_LOWLEVEL_INIT +SMC911X_32_BIT +SMP +SPI +SPI_BOOT +SPI_DIRMAP +SPI_FLASH_BAR +SPI_FLASH_MACRONIX +SPI_FLASH_MTD +SPI_FLASH_SFDP_SUPPORT +SPI_NOR_BOOT_SOFT_RESET_EXT_INVERT +STM32_ETZPC +SYS_CONSOLE_IS_IN_ENV +SYS_DCACHE_OFF +SYS_DEVICE_NULLDEV +SYS_ICACHE_OFF +SYSINFO +SYSRESET +SYS_THUMB_BUILD +SYS_WHITE_ON_BLACK +TARGET_DENEB +TARGET_EVB_RK3399 +TARGET_GIEDI +TARGET_KMCOGE5NE +TARGET_KMETER1 +TARGET_ST_STM32MP15x +TEST_KCONFIG +TIMER +_UNDEFINED +UNIT_TEST +USB_CDNS3_GADGET +USB_CDNS3_HOST +USB_ETHER +USB_GADGET +USB_GADGET_OS_DESCRIPTORS +USB_HOST +USB_STORAGE +USE_ARCH_MEMSET +UT_DM +UT_UNICODE +VID +VIRTIO +WDT +X509_CERTIFICATE_PARSER +X86_16BIT_INIT +XILINX_MICROBLAZE0_DELAY_SLOT_EXCEP +XILINX_MICROBLAZE0_USR_EXCEP +ZLIB +ZSTD +ZYNQMP_PSU_INIT_ENABLED
Troy Kisky
