[U-Boot-Users] Debugging U-boot with BDI-2000 on MPC8349
Hello,
Has anybody been able to successfully single step through U-boot code on an MPC8349 CPU using a BDI-2000? I've been working with an FAE at the company that represents Abatron in the US, and he seems to think it's a GDB problem. Of course, I'd prefer it to be something else... I'm using the ppc_6xx-gdb version 6.3 that's part of ELDK 4.0. I've also built the latest gdb 6.5, but no dice there either.
Here's a snippet:
(gdb) target remote 10.69.69.200:2001 Remote debugging using 10.69.69.200:2001 0x00000100 in ?? () (gdb) b board_init_f Breakpoint 1 at 0xfe0044a4: file board.c, line 374. (gdb) c Continuing.
Breakpoint 1, board_init_f (bootflag=1) at board.c:374 374 { (gdb) list 369 * 370 ************************************************************************ 371 */ 372 373 void board_init_f (ulong bootflag) 374 { 375 bd_t *bd; 376 ulong len, addr, addr_sp; 377 ulong *s; 378 gd_t *id; (gdb) next Cannot access memory at address 0xfd000efc /****** This isn't an address in Flash! The BDI-2000 shows the PC incrementing, so 'next' did advance things ******/
(gdb) del 1 (gdb) b relocate_code Breakpoint 2 at 0xfe0035a0: file /bld_home/bwarren/fpga/u-boot/cpu/mpc83xx/start.S, line 888. (gdb) c Continuing.
Breakpoint 2, relocate_code () at /bld_home/bwarren/fpga/u-boot/cpu/mpc83xx/start.S:889 889 mr r9, r4 /* Save copy of Global Data pointer */ (gdb) next 890 mr r10, r5 /* Save copy of Destination Address */
/****** We can single step through this code for some reason ******/
If anybody's seen this behavior and has any clues, please let me know. I apologize if this is a bit off-topic.
regards, Ben
Ben Warren wrote:
Hello,
I've attached two config files. One can be used to flash the 9349E-mITX, and the other can be used to debug it.
The flash-enabled one programs a bunch of registers that wake up the flash chip. Unfortunately, when using this config, U-boot hangs somewhere in start.S. I'm probably programming the board just differently enough to confuse U-Boot.
The other config programs nothing, which gives U-Boot a clean slate to program.
I presume it should be possible to create a "unified" config that works in both situations, but I haven't had the time to try it.
I've never used GDB with the BDI.
Thanks Timur,
On Thu, 2006-09-14 at 13:57 -0500, Timur Tabi wrote:
Ben Warren wrote:
Hello,
The config I use to debug is much like your second one. In general, less is more.
I've used it with Linux drivers and it's really very slick. I imagine it would be excellent with U-boot too, if I could get it to work in code other than start.S.
regards, Ben
Ben Warren wrote:
Thanks Timur,
Ben Warren wrote:
Hello,
regards, Ben
Have you tried the FAQ "10.1.2. Debugging of U-Boot After Relocation"? http://www.denx.de/wiki/view/DULG/DebuggingUBoot
gvb
Hi Jerry,
My problem arises when I try to do exactly what's shown in the FAQ (before relocation, in this case).
Instead of:
Breakpoint 1, cpu_init_f () at cpu_init.c:136 136 asm volatile(" bl 0f" ::: "lr"); (gdb) s 137 asm volatile("0: mflr 3" ::: "r3"); (gdb)
I get:
Breakpoint 1, cpu_init_f (im=0xe0000000) at cpu_init.c:42 42 { (gdb) s Cannot access memory at address 0xfd000ed8 (gdb) print im $1 = (volatile immap_t *) 0xe0000000 (gdb) print *im Cannot access memory at address 0xe0000000 (gdb)
Uncool.
regards, Ben
Ben Warren
Jerry Van Baren
Timur Tabi
