[U-Boot] [PATCH v5 0/6] Iotrace improvements
These set of patches add few improvements to iotrace. * Region limiting - allows setting an address and size where only io operations that falls into that address are logged. * Timestamping - Timestamp every iotrace record with current timestamp * dumping - iotrace dump command for dumping all records from buffer in a readable fashion.
In terms of backwards compatibility, the timestamp is not backward compatible as it changes the iotrace record. so if one developed an offline parsing tool it will be broken. I though of adding #ifdef specific for that, but eventually I didn't.
Changes in v5: - Removed common.h include that caused werid compliation problems in other boards (trini) - Fixed portability issue in printf (trini)
Changes in v4: - Resend complete patchset with patman
Changes in v3: - fixed wrong usage of WARN_ONCE
Changes in v2: - introduced needed_size to notify the user about the needed buffer size.
Changes in v1: - Change timestamp function to get_ticks()
Ramon Fried (6): cmd: iotrace: add set region command iotrace: add IO region limit common: iotrace: add timestamp to iotrace records iotrace: move record definitons to header file cmd: iotrace: add dump trace command iotrace: fix behaviour when buffer is full
cmd/iotrace.c | 63 ++++++++++++++++++++++++++++++++++++++++++--- common/iotrace.c | 65 +++++++++++++++++++++++++++-------------------- include/iotrace.h | 57 +++++++++++++++++++++++++++++++++++++++-- 3 files changed, 153 insertions(+), 32 deletions(-)
Signed-off-by: Ramon Fried ramon.fried@gmail.com Reviewed-by: Simon Glass sjg@chromium.org
Changes in v5: None Changes in v4: - Resend complete patchset with patman
Changes in v3: None Changes in v2: None Changes in v1: None
cmd/iotrace.c | 22 ++++++++++++++++++++++ 1 file changed, 22 insertions(+)
diff --git a/cmd/iotrace.c b/cmd/iotrace.c index e496787e0d..601b8c8e32 100644 --- a/cmd/iotrace.c +++ b/cmd/iotrace.c @@ -15,6 +15,9 @@ static void do_print_stats(void) iotrace_get_buffer(&start, &size, &offset, &count); printf("Start: %08lx\n", start); printf("Size: %08lx\n", size); + iotrace_get_region(&start, &size); + printf("Region: %08lx\n", start); + printf("Size: %08lx\n", size); printf("Offset: %08lx\n", offset); printf("Output: %08lx\n", start + offset); printf("Count: %08lx\n", count); @@ -37,6 +40,22 @@ static int do_set_buffer(int argc, char * const argv[]) return 0; }
+static int do_set_region(int argc, char * const argv[]) +{ + ulong addr = 0, size = 0; + + if (argc == 2) { + addr = simple_strtoul(*argv++, NULL, 16); + size = simple_strtoul(*argv++, NULL, 16); + } else if (argc != 0) { + return CMD_RET_USAGE; + } + + iotrace_set_region(addr, size); + + return 0; +} + int do_iotrace(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { const char *cmd = argc < 2 ? NULL : argv[1]; @@ -46,6 +65,8 @@ int do_iotrace(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) switch (*cmd) { case 'b': return do_set_buffer(argc - 2, argv + 2); + case 'l': + return do_set_region(argc - 2, argv + 2); case 'p': iotrace_set_enabled(0); break; @@ -67,6 +88,7 @@ U_BOOT_CMD( "iotrace utility commands", "stats - display iotrace stats\n" "iotrace buffer <address> <size> - set iotrace buffer\n" + "iotrace limit <address> <size> - set iotrace region limit\n" "iotrace pause - pause tracing\n" "iotrace resume - resume tracing" );
When dealing with a lot of IO regions, sometimes it makes sense only to trace a specific one. This patch adds support for region limits. If region is not set, the iotrace works the same as it was. If region is set, the iotrace only logs io operation that falls in the defined region.
Signed-off-by: Ramon Fried ramon.fried@gmail.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None Changes in v1: None
common/iotrace.c | 27 +++++++++++++++++++++++++++ include/iotrace.h | 24 ++++++++++++++++++++++++ 2 files changed, 51 insertions(+)
diff --git a/common/iotrace.c b/common/iotrace.c index b16b0d612d..f39885663a 100644 --- a/common/iotrace.c +++ b/common/iotrace.c @@ -42,6 +42,8 @@ struct iotrace_record { * @start: Start address of iotrace buffer * @size: Size of iotrace buffer in bytes * @offset: Current write offset into iotrace buffer + * @region_start: Address of IO region to trace + * @region_size: Size of region to trace. if 0 will trace all address space * @crc32: Current value of CRC chceksum of trace records * @enabled: true if enabled, false if disabled */ @@ -49,6 +51,8 @@ static struct iotrace { ulong start; ulong size; ulong offset; + ulong region_start; + ulong region_size; u32 crc32; bool enabled; } iotrace; @@ -66,6 +70,11 @@ static void add_record(int flags, const void *ptr, ulong value) if (!(gd->flags & GD_FLG_RELOC) || !iotrace.enabled) return;
+ if (iotrace.region_size) + if ((ulong)ptr < iotrace.region_start || + (ulong)ptr > iotrace.region_start + iotrace.region_size) + return; + /* Store it if there is room */ if (iotrace.offset + sizeof(*rec) < iotrace.size) { rec = (struct iotrace_record *)map_sysmem( @@ -142,6 +151,24 @@ u32 iotrace_get_checksum(void) return iotrace.crc32; }
+void iotrace_set_region(ulong start, ulong size) +{ + iotrace.region_start = start; + iotrace.region_size = size; +} + +void iotrace_reset_region(void) +{ + iotrace.region_start = 0; + iotrace.region_size = 0; +} + +void iotrace_get_region(ulong *start, ulong *size) +{ + *start = iotrace.region_start; + *size = iotrace.region_size; +} + void iotrace_set_enabled(int enable) { iotrace.enabled = enable; diff --git a/include/iotrace.h b/include/iotrace.h index 9fe5733f87..1efb117343 100644 --- a/include/iotrace.h +++ b/include/iotrace.h @@ -58,6 +58,30 @@ void iotrace_reset_checksum(void); */ u32 iotrace_get_checksum(void);
+/** + * iotrace_set_region() - Set whether iotrace is limited to a specific + * io region. + * + * Defines the address and size of the limited region. + * + * @start: address of the beginning of the region + * @size: size of the region in bytes. + */ +void iotrace_set_region(ulong start, ulong size); + +/** + * iotrace_reset_region() - Reset the region limit + */ +void iotrace_reset_region(void); + +/** + * iotrace_get_region() - Get region information + * + * @start: Returns start address of region + * @size: Returns size of region in bytes + */ +void iotrace_get_region(ulong *start, ulong *size); + /** * iotrace_set_enabled() - Set whether iotracing is enabled or not *
Add timestamp to each iotrace record to aid in debugging of IO timing access bugs.
Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None Changes in v1: - Change timestamp function to get_ticks()
common/iotrace.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/common/iotrace.c b/common/iotrace.c index f39885663a..2f03a6082e 100644 --- a/common/iotrace.c +++ b/common/iotrace.c @@ -27,11 +27,13 @@ enum iotrace_flags { * struct iotrace_record - Holds a single I/O trace record * * @flags: I/O access type + * @timestamp: Timestamp of access * @addr: Address of access * @value: Value written or read */ struct iotrace_record { enum iotrace_flags flags; + u64 timestamp; phys_addr_t addr; iovalue_t value; }; @@ -81,7 +83,7 @@ static void add_record(int flags, const void *ptr, ulong value) iotrace.start + iotrace.offset, sizeof(value)); } - + rec->timestamp = timer_get_us(); rec->flags = flags; rec->addr = map_to_sysmem(ptr); rec->value = value;
The header definitions are needed for reading record information in cmd/iotrace.c
common/iotrace.c | 27 --------------------------- include/iotrace.h | 28 ++++++++++++++++++++++++++++ 2 files changed, 28 insertions(+), 27 deletions(-)
diff --git a/common/iotrace.c b/common/iotrace.c index 2f03a6082e..83691b1dba 100644 --- a/common/iotrace.c +++ b/common/iotrace.c @@ -11,33 +11,6 @@
DECLARE_GLOBAL_DATA_PTR;
-/* Support up to the machine word length for now */ -typedef ulong iovalue_t; - -enum iotrace_flags { - IOT_8 = 0, - IOT_16, - IOT_32, - - IOT_READ = 0 << 3, - IOT_WRITE = 1 << 3, -}; - -/** - * struct iotrace_record - Holds a single I/O trace record - * - * @flags: I/O access type - * @timestamp: Timestamp of access - * @addr: Address of access - * @value: Value written or read - */ -struct iotrace_record { - enum iotrace_flags flags; - u64 timestamp; - phys_addr_t addr; - iovalue_t value; -}; - /** * struct iotrace - current trace status and checksum * diff --git a/include/iotrace.h b/include/iotrace.h index 1efb117343..063371f23f 100644 --- a/include/iotrace.h +++ b/include/iotrace.h @@ -6,8 +6,36 @@ #ifndef __IOTRACE_H #define __IOTRACE_H
+//#include <common.h> #include <linux/types.h>
+/* Support up to the machine word length for now */ +typedef ulong iovalue_t; + +enum iotrace_flags { + IOT_8 = 0, + IOT_16, + IOT_32, + + IOT_READ = 0 << 3, + IOT_WRITE = 1 << 3, +}; + +/** + * struct iotrace_record - Holds a single I/O trace record + * + * @flags: I/O access type + * @timestamp: Timestamp of access + * @addr: Address of access + * @value: Value written or read + */ +struct iotrace_record { + enum iotrace_flags flags; + u64 timestamp; + phys_addr_t addr; + iovalue_t value; +}; + /* * This file is designed to be included in arch/<arch>/include/asm/io.h. * It redirects all IO access through a tracing/checksumming feature for
Add dump trace command which dump all trace buffer content in a much more readable fashion than md.
Changes in v5: - Fixed portability issue in printf (trini)
cmd/iotrace.c | 36 +++++++++++++++++++++++++++++++++++- 1 file changed, 35 insertions(+), 1 deletion(-)
diff --git a/cmd/iotrace.c b/cmd/iotrace.c index 601b8c8e32..f8ce3398af 100644 --- a/cmd/iotrace.c +++ b/cmd/iotrace.c @@ -24,6 +24,36 @@ static void do_print_stats(void) printf("CRC32: %08lx\n", (ulong)iotrace_get_checksum()); }
+static void do_print_trace(void) +{ + ulong start, size, offset, count; + + struct iotrace_record *cur_record; + + iotrace_get_buffer(&start, &size, &offset, &count); + + if (!start || !size || !count) + return; + + printf("Timestamp Value Address\n"); + + cur_record = (struct iotrace_record *)start; + for (int i = 0; i < count; i++) { + if (cur_record->flags & IOT_WRITE) + printf("%08llu: 0x%08lx --> 0x%08llx\n", + cur_record->timestamp, + cur_record->value, + (unsigned long long)cur_record->addr); + else + printf("%08llu: 0x%08lx <-- 0x%08llx\n", + cur_record->timestamp, + cur_record->value, + (unsigned long long)cur_record->addr); + + cur_record++; + } +} + static int do_set_buffer(int argc, char * const argv[]) { ulong addr = 0, size = 0; @@ -76,6 +106,9 @@ int do_iotrace(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) case 's': do_print_stats(); break; + case 'd': + do_print_trace(); + break; default: return CMD_RET_USAGE; } @@ -90,5 +123,6 @@ U_BOOT_CMD( "iotrace buffer <address> <size> - set iotrace buffer\n" "iotrace limit <address> <size> - set iotrace region limit\n" "iotrace pause - pause tracing\n" - "iotrace resume - resume tracing" + "iotrace resume - resume tracing\n" + "iotrace dump - dump iotrace buffer" );
This fails to compile for me:
cmd/iotrace.c: In function ‘do_print_trace’: cmd/iotrace.c:42:2: error: ‘for’ loop initial declarations are only allowed in C99 mode for (int i = 0; i < count; i++) { ^ cmd/iotrace.c:42:2: note: use option -std=c99 or -std=gnu99 to compile your code scripts/Makefile.build:278: recipe for target 'cmd/iotrace.o' failed
Alex
Yes. I didn't notice this part in time, and I've posted a patch to start using -std=gnu11 globally as that makes more sense to me than reworking this (and a few other ARM-specific areas) that make use of this construct.
Wouldn't it make more sense to fix this place up for now and postpone the -std=gnu11 patch for post-release?
Alex
Don't continue updating the offset when buffer is full. When the buffer size exhausts and there's no space left to write warn the user and update only the needed size and not both the offset and needed size.
Add needed buffer size information in the iotrace command.
Changes in v5: None Changes in v4: None Changes in v3: - fixed wrong usage of WARN_ONCE
Changes in v1: None
cmd/iotrace.c | 11 ++++++----- common/iotrace.c | 13 +++++++++++-- include/iotrace.h | 5 +++-- 3 files changed, 20 insertions(+), 9 deletions(-)
diff --git a/cmd/iotrace.c b/cmd/iotrace.c index f8ce3398af..fa6c68b198 100644 --- a/cmd/iotrace.c +++ b/cmd/iotrace.c @@ -9,12 +9,13 @@
static void do_print_stats(void) { - ulong start, size, offset, count; + ulong start, size, needed_size, offset, count;
printf("iotrace is %sabled\n", iotrace_get_enabled() ? "en" : "dis"); - iotrace_get_buffer(&start, &size, &offset, &count); + iotrace_get_buffer(&start, &size, &needed_size, &offset, &count); printf("Start: %08lx\n", start); - printf("Size: %08lx\n", size); + printf("Actual Size: %08lx\n", size); + printf("Needed Size: %08lx\n", needed_size); iotrace_get_region(&start, &size); printf("Region: %08lx\n", start); printf("Size: %08lx\n", size); @@ -26,11 +27,11 @@ static void do_print_stats(void)
static void do_print_trace(void) { - ulong start, size, offset, count; + ulong start, size, needed_size, offset, count;
if (!start || !size || !count) return; diff --git a/common/iotrace.c b/common/iotrace.c index 83691b1dba..49bee3c92a 100644 --- a/common/iotrace.c +++ b/common/iotrace.c @@ -15,7 +15,8 @@ DECLARE_GLOBAL_DATA_PTR; * struct iotrace - current trace status and checksum * * @start: Start address of iotrace buffer - * @size: Size of iotrace buffer in bytes + * @size: Actual size of iotrace buffer in bytes + * @needed_size: Needed of iotrace buffer in bytes * @offset: Current write offset into iotrace buffer * @region_start: Address of IO region to trace * @region_size: Size of region to trace. if 0 will trace all address space @@ -25,6 +26,7 @@ DECLARE_GLOBAL_DATA_PTR; static struct iotrace { ulong start; ulong size; + ulong needed_size; ulong offset; ulong region_start; ulong region_size; @@ -55,7 +57,12 @@ static void add_record(int flags, const void *ptr, ulong value) rec = (struct iotrace_record *)map_sysmem( iotrace.start + iotrace.offset, sizeof(value)); + } else { + WARN_ONCE(1, "WARNING: iotrace buffer exhausted, please check needed length using "iotrace stats"\n"); + iotrace.needed_size += sizeof(struct iotrace_record); + return; } + rec->timestamp = timer_get_us(); rec->flags = flags; rec->addr = map_to_sysmem(ptr); @@ -65,6 +72,7 @@ static void add_record(int flags, const void *ptr, ulong value) iotrace.crc32 = crc32(iotrace.crc32, (unsigned char *)rec, sizeof(*rec));
+ iotrace.needed_size += sizeof(struct iotrace_record); iotrace.offset += sizeof(struct iotrace_record); }
@@ -162,10 +170,11 @@ void iotrace_set_buffer(ulong start, ulong size) iotrace.crc32 = 0; }
-void iotrace_get_buffer(ulong *start, ulong *size, ulong *offset, ulong *count) +void iotrace_get_buffer(ulong *start, ulong *size, ulong *needed_size, ulong *offset, ulong *count) { *start = iotrace.start; *size = iotrace.size; + *needed_size = iotrace.needed_size; *offset = iotrace.offset; *count = iotrace.offset / sizeof(struct iotrace_record); } diff --git a/include/iotrace.h b/include/iotrace.h index 063371f23f..be1d2753e1 100644 --- a/include/iotrace.h +++ b/include/iotrace.h @@ -146,11 +146,12 @@ void iotrace_set_buffer(ulong start, ulong size); * iotrace_get_buffer() - Get buffer information * * @start: Returns start address of buffer - * @size: Returns size of buffer in bytes + * @size: Returns actual size of buffer in bytes + * @needed_size: Returns needed size of buffer in bytes * @offset: Returns the byte offset where the next output trace record will * @count: Returns the number of trace records recorded * be written (or would be if the buffer was large enough) */ -void iotrace_get_buffer(ulong *start, ulong *size, ulong *offset, ulong *count); +void iotrace_get_buffer(ulong *start, ulong *size, ulong *needed_size, ulong *offset, ulong *count);
#endif /* __IOTRACE_H */
Alexander Graf
Ramon Fried
