[U-Boot] [PATCH 0/3] Support for TI's DA850/OMAP-L138 platform
This patch series adds support for TI's DA850/OMAP-L138 platform. This series is dependant on the following patch which I have submitted earlier:
[U-Boot] [PATCH] da830: Move common code out of da830evm.c file
Sudhakar Rajashekhara (3): TI: DaVinci: Prepare for da850 support TI: DaVinci: Add board specific code for da850 EVM TI: DaVinci: Create configuration file for da850 EVM
MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 5 +- arch/arm/include/asm/arch-davinci/hardware.h | 1 + board/davinci/{da830evm => da8xxevm}/Makefile | 5 +- board/davinci/{da830evm => da8xxevm}/config.mk | 0 board/davinci/{da830evm => da8xxevm}/da830evm.c | 0 board/davinci/da8xxevm/da850evm.c | 111 +++++++++++++++++++ include/configs/da850evm.h | 135 +++++++++++++++++++++++ 9 files changed, 260 insertions(+), 2 deletions(-) rename board/davinci/{da830evm => da8xxevm}/Makefile (91%) rename board/davinci/{da830evm => da8xxevm}/config.mk (100%) rename board/davinci/{da830evm => da8xxevm}/da830evm.c (100%) create mode 100644 board/davinci/da8xxevm/da850evm.c create mode 100644 include/configs/da850evm.h
I ran into
da850evm.c:64: error: array type has incomplete element type da850evm.c: In function 'board_init': da850evm.c:75: warning: implicit declaration of function 'irq_init' da850evm.c:90: warning: implicit declaration of function 'davinci_configure_lpsc_items'
Please check that this patchset still builds and rebase if necessary.
Tom
Hi Tom,
-----Original Message----- From: Tom Rix [mailto:tom@bumblecow.com] Sent: Thursday, May 06, 2010 3:14 AM To: Sudhakar Rajashekhara Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH 0/3] Support for TI's DA850/OMAP-L138 platform
I ran into
This patch set depends on one patch which I had submitted earlier (http://lists.denx.de/pipermail/u-boot/2010-April/070383.html). This patch was Acked by Nick Thompson but not yet pulled in. I have mentioned about this dependency in patch 0/0. Can you try after applying this patch?
Thanks, Sudhakar
Tom
Tom Rix
