[U-Boot] [PATCH 0/8] spl: Move image loader names into the linker list
At present we have a linker list for all the image-loader methods but announce_boot_device() uses its own switch() statement with the names of each method. We may as well combine the name into the linker list.
The names are only needed if libcommon support is enabled, since printf() is used to display then.
This series performs this adjustment, by adding the names and then converting the generic SPL code over to use them. This allows the board-specific spl_board_announce_boot_device() functions to be dropped as well.
Simon Glass (8): spl: Use a single underscore in the SPL_LOAD_IMAGE_METHOD() macro spl: Add a name to the SPL load-image methods spl: Move the loading code into its own function spl: Pass the loader into spl_load_image() spl: Drop announce_boot_device() spl: sunxi: Drop spl_board_announce_boot_device() spl: uniphier: Drop spl_board_announce_boot_device() spl: sandbox: Drop spl_board_announce_boot_device()
arch/arm/mach-sunxi/board.c | 11 +-- arch/arm/mach-uniphier/boot-mode/spl_board.c | 7 +- arch/sandbox/cpu/spl.c | 19 +--- common/spl/spl.c | 125 ++++++--------------------- common/spl/spl_mmc.c | 6 +- common/spl/spl_nand.c | 2 +- common/spl/spl_net.c | 5 +- common/spl/spl_nor.c | 2 +- common/spl/spl_onenand.c | 3 +- common/spl/spl_sata.c | 2 +- common/spl/spl_spi.c | 2 +- common/spl/spl_ubi.c | 4 +- common/spl/spl_usb.c | 2 +- common/spl/spl_ymodem.c | 2 +- drivers/mtd/spi/sunxi_spi_spl.c | 2 +- include/spl.h | 27 ++++-- 16 files changed, 70 insertions(+), 151 deletions(-)
A double underscore is normally reserved for compiler predefines. Use a single underscore instead.
include/spl.h | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/include/spl.h b/include/spl.h index e080a82..11bdc2d 100644 --- a/include/spl.h +++ b/include/spl.h @@ -172,15 +172,15 @@ struct spl_image_loader { ll_entry_declare(struct spl_image_loader, __name, spl_image_loader)
/* - * __priority is the priority of this method, 0 meaning it will be the top + * _priority is the priority of this method, 0 meaning it will be the top * choice for this device, 9 meaning it is the bottom choice. - * __boot_device is the BOOT_DEVICE_... value - * __method is the load_image function to call + * _boot_device is the BOOT_DEVICE_... value + * _method is the load_image function to call */ -#define SPL_LOAD_IMAGE_METHOD(__priority, __boot_device, __method) \ - SPL_LOAD_IMAGE(__method ## __priority ## __boot_device) = { \ - .boot_device = __boot_device, \ - .load_image = __method, \ +#define SPL_LOAD_IMAGE_METHOD(_priority, _boot_device, _method) \ + SPL_LOAD_IMAGE(_method ## _priority ## _boot_device) = { \ + .boot_device = _boot_device, \ + .load_image = _method, \ }
/* SPL FAT image functions */
It is useful to name each method so that we can print out this name when using the method. Currently this happens using a separate function. In preparation for unifying this, add a name to each method.
The name is only available if we have libcommon support (i.e can use printf()).
arch/arm/mach-sunxi/board.c | 2 +- arch/arm/mach-uniphier/boot-mode/spl_board.c | 2 +- arch/sandbox/cpu/spl.c | 2 +- common/spl/spl.c | 4 ++-- common/spl/spl_mmc.c | 6 +++--- common/spl/spl_nand.c | 2 +- common/spl/spl_net.c | 5 +++-- common/spl/spl_nor.c | 2 +- common/spl/spl_onenand.c | 3 ++- common/spl/spl_sata.c | 2 +- common/spl/spl_spi.c | 2 +- common/spl/spl_ubi.c | 4 ++-- common/spl/spl_usb.c | 2 +- common/spl/spl_ymodem.c | 2 +- drivers/mtd/spi/sunxi_spi_spl.c | 2 +- include/spl.h | 15 ++++++++++++++- 16 files changed, 36 insertions(+), 21 deletions(-)
diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 0f8ead9..205236d 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -142,7 +142,7 @@ static int spl_board_load_image(struct spl_image_info *spl_image,
return 0; } -SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_BOARD, spl_board_load_image); +SPL_LOAD_IMAGE_METHOD("FEL", 0, BOOT_DEVICE_BOARD, spl_board_load_image); #endif
void s_init(void) diff --git a/arch/arm/mach-uniphier/boot-mode/spl_board.c b/arch/arm/mach-uniphier/boot-mode/spl_board.c index 854ab05..ba84087 100644 --- a/arch/arm/mach-uniphier/boot-mode/spl_board.c +++ b/arch/arm/mach-uniphier/boot-mode/spl_board.c @@ -127,4 +127,4 @@ static int spl_board_load_image(struct spl_image_info *spl_image,
return 0; } -SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_BOARD, spl_board_load_image); +SPL_LOAD_IMAGE_METHOD("eMMC", 0, BOOT_DEVICE_BOARD, spl_board_load_image); diff --git a/arch/sandbox/cpu/spl.c b/arch/sandbox/cpu/spl.c index 1ad7fb6..632446b 100644 --- a/arch/sandbox/cpu/spl.c +++ b/arch/sandbox/cpu/spl.c @@ -51,7 +51,7 @@ static int spl_board_load_image(struct spl_image_info *spl_image, /* Hopefully this will not return */ return os_spl_to_uboot(fname); } -SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_BOARD, spl_board_load_image); +SPL_LOAD_IMAGE_METHOD("sandbox", 0, BOOT_DEVICE_BOARD, spl_board_load_image);
void spl_board_init(void) { diff --git a/common/spl/spl.c b/common/spl/spl.c index bdb165a..4f23c0e 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -220,9 +220,9 @@ static int spl_ram_load_image(struct spl_image_info *spl_image,
return 0; } -SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_RAM, spl_ram_load_image); +SPL_LOAD_IMAGE_METHOD("RAM", 0, BOOT_DEVICE_RAM, spl_ram_load_image); #if defined(CONFIG_SPL_DFU_SUPPORT) -SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_DFU, spl_ram_load_image); +SPL_LOAD_IMAGE_METHOD("USB DFU", 0, BOOT_DEVICE_DFU, spl_ram_load_image); #endif #endif
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index c674e61..97edf78 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -352,6 +352,6 @@ static int spl_mmc_load_image(struct spl_image_info *spl_image, return err; }
-SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_MMC1, spl_mmc_load_image); -SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_MMC2, spl_mmc_load_image); -SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_MMC2_2, spl_mmc_load_image); +SPL_LOAD_IMAGE_METHOD("MMC1", 0, BOOT_DEVICE_MMC1, spl_mmc_load_image); +SPL_LOAD_IMAGE_METHOD("MMC2", 0, BOOT_DEVICE_MMC2, spl_mmc_load_image); +SPL_LOAD_IMAGE_METHOD("MMC2_2", 0, BOOT_DEVICE_MMC2_2, spl_mmc_load_image); diff --git a/common/spl/spl_nand.c b/common/spl/spl_nand.c index d1abda6..cd39f9b 100644 --- a/common/spl/spl_nand.c +++ b/common/spl/spl_nand.c @@ -151,4 +151,4 @@ static int spl_nand_load_image(struct spl_image_info *spl_image, } #endif /* Use priorty 1 so that Ubi can override this */ -SPL_LOAD_IMAGE_METHOD(1, BOOT_DEVICE_NAND, spl_nand_load_image); +SPL_LOAD_IMAGE_METHOD("NAND", 1, BOOT_DEVICE_NAND, spl_nand_load_image); diff --git a/common/spl/spl_net.c b/common/spl/spl_net.c index f4b4bc4..0fba017 100644 --- a/common/spl/spl_net.c +++ b/common/spl/spl_net.c @@ -51,7 +51,8 @@ int spl_net_load_image_cpgmac(struct spl_image_info *spl_image,
return spl_net_load_image(spl_image, bootdev); } -SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_CPGMAC, spl_net_load_image_cpgmac); +SPL_LOAD_IMAGE_METHOD("eth device", 0, BOOT_DEVICE_CPGMAC, + spl_net_load_image_cpgmac); #endif
#ifdef CONFIG_SPL_USBETH_SUPPORT @@ -62,5 +63,5 @@ int spl_net_load_image_usb(struct spl_image_info *spl_image,
return spl_net_load_image(spl_image, bootdev); } -SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_USBETH, spl_net_load_image_usb); +SPL_LOAD_IMAGE_METHOD("USB eth", 0, BOOT_DEVICE_USBETH, spl_net_load_image_usb); #endif diff --git a/common/spl/spl_nor.c b/common/spl/spl_nor.c index 6bfa399..d07ca84 100644 --- a/common/spl/spl_nor.c +++ b/common/spl/spl_nor.c @@ -71,4 +71,4 @@ static int spl_nor_load_image(struct spl_image_info *spl_image,
return 0; } -SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_NOR, spl_nor_load_image); +SPL_LOAD_IMAGE_METHOD("NOR", 0, BOOT_DEVICE_NOR, spl_nor_load_image); diff --git a/common/spl/spl_onenand.c b/common/spl/spl_onenand.c index f076e2c..fc98e9c 100644 --- a/common/spl/spl_onenand.c +++ b/common/spl/spl_onenand.c @@ -36,4 +36,5 @@ static int spl_onenand_load_image(struct spl_image_info *spl_image, return 0; } /* Use priorty 1 so that Ubi can override this */ -SPL_LOAD_IMAGE_METHOD(1, BOOT_DEVICE_ONENAND, spl_onenand_load_image); +SPL_LOAD_IMAGE_METHOD("OneNAND", 1, BOOT_DEVICE_ONENAND, + spl_onenand_load_image); diff --git a/common/spl/spl_sata.c b/common/spl/spl_sata.c index a3c07cd..5476206 100644 --- a/common/spl/spl_sata.c +++ b/common/spl/spl_sata.c @@ -57,4 +57,4 @@ static int spl_sata_load_image(struct spl_image_info *spl_image,
return 0; } -SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_SATA, spl_sata_load_image); +SPL_LOAD_IMAGE_METHOD("SATA", 0, BOOT_DEVICE_SATA, spl_sata_load_image); diff --git a/common/spl/spl_spi.c b/common/spl/spl_spi.c index a3caafb..7388dda 100644 --- a/common/spl/spl_spi.c +++ b/common/spl/spl_spi.c @@ -124,4 +124,4 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, return err; } /* Use priorty 1 so that boards can override this */ -SPL_LOAD_IMAGE_METHOD(1, BOOT_DEVICE_SPI, spl_spi_load_image); +SPL_LOAD_IMAGE_METHOD("SPI", 1, BOOT_DEVICE_SPI, spl_spi_load_image); diff --git a/common/spl/spl_ubi.c b/common/spl/spl_ubi.c index c03910b..24633f4 100644 --- a/common/spl/spl_ubi.c +++ b/common/spl/spl_ubi.c @@ -78,5 +78,5 @@ out: return ret; } /* Use priorty 0 so that Ubi will override NAND and ONENAND methods */ -SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_NAND, spl_ubi_load_image); -SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_ONENAND, spl_ubi_load_image); +SPL_LOAD_IMAGE_METHOD("NAND", 0, BOOT_DEVICE_NAND, spl_ubi_load_image); +SPL_LOAD_IMAGE_METHOD("OneNAND", 0, BOOT_DEVICE_ONENAND, spl_ubi_load_image); diff --git a/common/spl/spl_usb.c b/common/spl/spl_usb.c index e37966e..567a450 100644 --- a/common/spl/spl_usb.c +++ b/common/spl/spl_usb.c @@ -65,4 +65,4 @@ static int spl_usb_load_image(struct spl_image_info *spl_image,
return 0; } -SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_USB, spl_usb_load_image); +SPL_LOAD_IMAGE_METHOD("USB", 0, BOOT_DEVICE_USB, spl_usb_load_image); diff --git a/common/spl/spl_ymodem.c b/common/spl/spl_ymodem.c index 13e8e51..5d1db7d 100644 --- a/common/spl/spl_ymodem.c +++ b/common/spl/spl_ymodem.c @@ -133,4 +133,4 @@ end_stream: printf("Loaded %d bytes\n", size); return 0; } -SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_UART, spl_ymodem_load_image); +SPL_LOAD_IMAGE_METHOD("UART", 0, BOOT_DEVICE_UART, spl_ymodem_load_image); diff --git a/drivers/mtd/spi/sunxi_spi_spl.c b/drivers/mtd/spi/sunxi_spi_spl.c index 67c7edd..2159f38 100644 --- a/drivers/mtd/spi/sunxi_spi_spl.c +++ b/drivers/mtd/spi/sunxi_spi_spl.c @@ -283,4 +283,4 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, return 0; } /* Use priorty 0 to override the default if it happens to be linked in */ -SPL_LOAD_IMAGE_METHOD(0, BOOT_DEVICE_SPI, spl_spi_load_image); +SPL_LOAD_IMAGE_METHOD("sunxi SPI" 0, BOOT_DEVICE_SPI, spl_spi_load_image); diff --git a/include/spl.h b/include/spl.h index 11bdc2d..3470733 100644 --- a/include/spl.h +++ b/include/spl.h @@ -152,10 +152,14 @@ struct spl_boot_device { /** * Holds information about a way of loading an SPL image * + * @name: User-friendly name for this method (e.g. "MMC") * @boot_device: Boot device that this loader supports * @load_image: Function to call to load image */ struct spl_image_loader { +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT + const char *name; +#endif uint boot_device; /** * load_image() - Load an SPL image @@ -177,11 +181,20 @@ struct spl_image_loader { * _boot_device is the BOOT_DEVICE_... value * _method is the load_image function to call */ -#define SPL_LOAD_IMAGE_METHOD(_priority, _boot_device, _method) \ +#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT +#define SPL_LOAD_IMAGE_METHOD(_name, _priority, _boot_device, _method) \ SPL_LOAD_IMAGE(_method ## _priority ## _boot_device) = { \ + .name = _name, \ .boot_device = _boot_device, \ .load_image = _method, \ } +#else +#define SPL_LOAD_IMAGE_METHOD(_name, _priority, _boot_device, _method) \ + SPL_LOAD_IMAGE(_method ## _priority ## _boot_device) = { \ + .boot_device = _boot_device, \ + .load_image = _method, \ + } +#endif
/* SPL FAT image functions */ int spl_load_image_fat(struct spl_image_info *spl_image,
Create a boot_from_devices() function to handle trying each device. This helps to reduce the size of the already-large board_init_r() function.
common/spl/spl.c | 33 +++++++++++++++++++++------------ 1 file changed, 21 insertions(+), 12 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 4f23c0e..8c3a47d 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -372,12 +372,29 @@ static int spl_load_image(struct spl_image_info *spl_image, u32 boot_device)
bootdev.boot_device = boot_device; bootdev.boot_device_name = NULL; - if (loader) - return loader->load_image(spl_image, &bootdev);
+ return loader->load_image(spl_image, &bootdev); +} + +static int boot_from_devices(struct spl_image_info *spl_image, + u32 spl_boot_list[]) +{ + int i; + + for (i = 0; i < ARRAY_SIZE(spl_boot_list) && + spl_boot_list[i] != BOOT_DEVICE_NONE; i++) { + struct spl_image_loader *loader; + + announce_boot_device(spl_boot_list[i]); + loader = spl_ll_find_loader(spl_boot_list[i]); #if defined(CONFIG_SPL_SERIAL_SUPPORT) && defined(CONFIG_SPL_LIBCOMMON_SUPPORT) - puts("SPL: Unsupported Boot Device!\n"); + if (!loader) + puts("SPL: Unsupported Boot Device!\n"); #endif + if (loader && !spl_load_image(spl_image, spl_boot_list[i])) + return 0; + } + return -ENODEV; }
@@ -391,7 +408,6 @@ void board_init_r(gd_t *dummy1, ulong dummy2) BOOT_DEVICE_NONE, }; struct spl_image_info spl_image; - int i;
debug(">>spl:board_init_r()\n");
@@ -418,15 +434,8 @@ void board_init_r(gd_t *dummy1, ulong dummy2)
memset(&spl_image, '\0', sizeof(spl_image)); board_boot_order(spl_boot_list); - for (i = 0; i < ARRAY_SIZE(spl_boot_list) && - spl_boot_list[i] != BOOT_DEVICE_NONE; i++) { - announce_boot_device(spl_boot_list[i]); - if (!spl_load_image(&spl_image, spl_boot_list[i])) - break; - }
- if (i == ARRAY_SIZE(spl_boot_list) || - spl_boot_list[i] == BOOT_DEVICE_NONE) { + if (boot_from_devices(&spl_image, spl_boot_list)) { puts("SPL: failed to boot from all boot devices\n"); hang(); }
Hi Simon,
2016-11-18 2:29 GMT+09:00 Simon Glass sjg@chromium.org:
if (loader)
int i;
I do not believe ARRAY_SIZE(spl_boot_list) would work in this context.
So with gcc-5.x and later: +In file included from include/common.h:27:0, + from common/spl/spl.c:9: + #define ARRAY_SIZE(x) (sizeof(x) / sizeof((x)[0])) + ^ +common/spl/spl.c:384:18: note: in expansion of macro 'ARRAY_SIZE' + for (i = 0; i < ARRAY_SIZE(spl_boot_list) && + ^ +common/spl/spl.c:380:13: note: declared here + u32 spl_boot_list[]) + ^ w+common/spl/spl.c: In function 'boot_from_devices': w+include/linux/kernel.h:45:30: warning: 'sizeof' on array function parameter 'spl_boot_list' will return size of 'u32 * {aka unsigned int *}' [-Wsizeof-array-argument]
Which I think is what Masahiro was pointing out :) So the rest of the series needs some re-work following that too, thanks!
Hi Tom,
Yes indeed, will get to it this week...need to test it properly with a board with multiple loaders.
- Simon
Rather than have this function figure out the correct loader again, pass it in as a parameter.
common/spl/spl.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 8c3a47d..4555216 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -365,12 +365,12 @@ static struct spl_image_loader *spl_ll_find_loader(uint boot_device) return NULL; }
-static int spl_load_image(struct spl_image_info *spl_image, u32 boot_device) +static int spl_load_image(struct spl_image_info *spl_image, + struct spl_image_loader *loader) { struct spl_boot_device bootdev; - struct spl_image_loader *loader = spl_ll_find_loader(boot_device);
- bootdev.boot_device = boot_device; + bootdev.boot_device = loader->boot_device; bootdev.boot_device_name = NULL;
return loader->load_image(spl_image, &bootdev); @@ -391,7 +391,7 @@ static int boot_from_devices(struct spl_image_info *spl_image, if (!loader) puts("SPL: Unsupported Boot Device!\n"); #endif - if (loader && !spl_load_image(spl_image, spl_boot_list[i])) + if (loader && !spl_load_image(spl_image, loader)) return 0; }
This task can be handled by inline code now. Drop this function.
common/spl/spl.c | 86 ++------------------------------------------------------ 1 file changed, 3 insertions(+), 83 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 4555216..86474bb 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -267,87 +267,6 @@ __weak void board_boot_order(u32 *spl_boot_list) spl_boot_list[0] = spl_boot_device(); }
-#ifdef CONFIG_SPL_BOARD_LOAD_IMAGE -__weak void spl_board_announce_boot_device(void) { } -#endif - -#ifdef CONFIG_SPL_LIBCOMMON_SUPPORT -struct boot_device_name { - u32 boot_dev; - const char *name; -}; - -struct boot_device_name boot_name_table[] = { -#ifdef CONFIG_SPL_RAM_DEVICE - { BOOT_DEVICE_RAM, "RAM" }, -#endif -#ifdef CONFIG_SPL_MMC_SUPPORT - { BOOT_DEVICE_MMC1, "MMC1" }, - { BOOT_DEVICE_MMC2, "MMC2" }, - { BOOT_DEVICE_MMC2_2, "MMC2_2" }, -#endif -#ifdef CONFIG_SPL_NAND_SUPPORT - { BOOT_DEVICE_NAND, "NAND" }, -#endif -#ifdef CONFIG_SPL_ONENAND_SUPPORT - { BOOT_DEVICE_ONENAND, "OneNAND" }, -#endif -#ifdef CONFIG_SPL_NOR_SUPPORT - { BOOT_DEVICE_NOR, "NOR" }, -#endif -#ifdef CONFIG_SPL_YMODEM_SUPPORT - { BOOT_DEVICE_UART, "UART" }, -#endif -#if defined(CONFIG_SPL_SPI_SUPPORT) || defined(CONFIG_SPL_SPI_FLASH_SUPPORT) - { BOOT_DEVICE_SPI, "SPI" }, -#endif -#ifdef CONFIG_SPL_ETH_SUPPORT -#ifdef CONFIG_SPL_ETH_DEVICE - { BOOT_DEVICE_CPGMAC, "eth device" }, -#else - { BOOT_DEVICE_CPGMAC, "net" }, -#endif -#endif -#ifdef CONFIG_SPL_USBETH_SUPPORT - { BOOT_DEVICE_USBETH, "USB eth" }, -#endif -#ifdef CONFIG_SPL_USB_SUPPORT - { BOOT_DEVICE_USB, "USB" }, -#endif -#ifdef CONFIG_SPL_DFU_SUPPORT - { BOOT_DEVICE_DFU, "USB DFU" }, -#endif -#ifdef CONFIG_SPL_SATA_SUPPORT - { BOOT_DEVICE_SATA, "SATA" }, -#endif - /* Keep this entry last */ - { BOOT_DEVICE_NONE, "unknown boot device" }, -}; - -static void announce_boot_device(u32 boot_device) -{ - int i; - - puts("Trying to boot from "); - -#ifdef CONFIG_SPL_BOARD_LOAD_IMAGE - if (boot_device == BOOT_DEVICE_BOARD) { - spl_board_announce_boot_device(); - puts("\n"); - return; - } -#endif - for (i = 0; i < ARRAY_SIZE(boot_name_table) - 1; i++) { - if (boot_name_table[i].boot_dev == boot_device) - break; - } - - printf("%s\n", boot_name_table[i].name); -} -#else -static inline void announce_boot_device(u32 boot_device) { } -#endif - static struct spl_image_loader *spl_ll_find_loader(uint boot_device) { struct spl_image_loader *drv = @@ -385,10 +304,11 @@ static int boot_from_devices(struct spl_image_info *spl_image, spl_boot_list[i] != BOOT_DEVICE_NONE; i++) { struct spl_image_loader *loader;
- announce_boot_device(spl_boot_list[i]); loader = spl_ll_find_loader(spl_boot_list[i]); #if defined(CONFIG_SPL_SERIAL_SUPPORT) && defined(CONFIG_SPL_LIBCOMMON_SUPPORT) - if (!loader) + if (loader) + printf("Trying to boot from %s", loader->name); + else puts("SPL: Unsupported Boot Device!\n"); #endif if (loader && !spl_load_image(spl_image, loader))
This function is not used anymore. Drop it.
arch/arm/mach-sunxi/board.c | 9 --------- 1 file changed, 9 deletions(-)
diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 205236d..aa11493 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -247,15 +247,6 @@ u32 spl_boot_device(void) return -1; /* Never reached */ }
-/* - * Properly announce BOOT_DEVICE_BOARD as "FEL". - * Overrides weak function from common/spl/spl.c - */ -void spl_board_announce_boot_device(void) -{ - printf("FEL"); -} - /* No confirmation data available in SPL yet. Hardcode bootmode */ u32 spl_boot_mode(const u32 boot_device) {
arch/arm/mach-uniphier/boot-mode/spl_board.c | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/arch/arm/mach-uniphier/boot-mode/spl_board.c b/arch/arm/mach-uniphier/boot-mode/spl_board.c index ba84087..a6b6686 100644 --- a/arch/arm/mach-uniphier/boot-mode/spl_board.c +++ b/arch/arm/mach-uniphier/boot-mode/spl_board.c @@ -12,11 +12,6 @@
#include "../soc-info.h"
-void spl_board_announce_boot_device(void) -{ - printf("eMMC"); -} - struct uniphier_romfunc_table { void *mmc_send_cmd; void *mmc_card_blockaddr;
arch/sandbox/cpu/spl.c | 17 +++-------------- 1 file changed, 3 insertions(+), 14 deletions(-)
diff --git a/arch/sandbox/cpu/spl.c b/arch/sandbox/cpu/spl.c index 632446b..7cc76d4 100644 --- a/arch/sandbox/cpu/spl.c +++ b/arch/sandbox/cpu/spl.c @@ -25,19 +25,6 @@ u32 spl_boot_device(void) return BOOT_DEVICE_BOARD; }
-void spl_board_announce_boot_device(void) -{ - char fname[256]; - int ret; - - ret = os_find_u_boot(fname, sizeof(fname)); - if (ret) { - printf("(%s not found, error %d)\n", fname, ret); - return; - } - printf("%s\n", fname); -} - static int spl_board_load_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev) { @@ -45,8 +32,10 @@ static int spl_board_load_image(struct spl_image_info *spl_image, int ret;
ret = os_find_u_boot(fname, sizeof(fname)); - if (ret) + if (ret) { + printf("(%s not found, error %d)\n", fname, ret); return ret; + }
Masahiro Yamada
